Visitor Agreement.
And, last but not least, what type of mileage should we expect. Does mid range or premium gas help mileage and / or performance. Since we are new to this vehicle and not sure what to expect, we feel it's better to ask the one who know.
Ps. No where in the book does it state at what miles to replace cam belt. Anybody know?
Bill
They have color coordinated ones in the avalon colors. They are more expensive than off the shelf generic ones but worth it IMHO.
Absolutely not! Don't believe everything you hear--The Toyota V6 is no less tolerant of neglect than any other, and in fact, more tolerant than most. The only folks who promote the hearsay theory you reference are those who won't accept the truth---they figured the car would run forever with nil maintenance!
That it's impossible to tell how often the previous owner changed oil? Again, not true. A comprehensive pre buy inspection by a reputable technician should be able to give you a pretty fair picture of how a used car was maintained.
I have had new 1996 avalon, and it has about 90K miles on it. I also own 2000 Tundra V8 with 40K miles, both with absolutely ZERO problems. Both of these vehicles are absolute fun to drive either on a short trip to the grocery store or on multiple long trips I made (1200 miles each way). With Toyotas/Hondas, you don't end up breaking your backs on real long trips !
Rest of my family owns 3 more Toyotas and 1 Honda. ZERO problems on 700K+ combined miles, over 13 years of continued ownership.
Chirravu ..
What is incredulous is that my oil changes for the first 24 months are free and the regular price for rotating the tires is $22.95. What gives?
Shouldn't this scheduled maintenance include things like:
--Check and clean the brakes
--Replace wiper blades
--Check and change transmission fluids
--Change AC filter
--What about spark plugs and coolant?
I know these new engines require less frequent scheduled maintenance, but what is the minimum I should have gotten? They did charge me for 2.5 hours of labor time.
TYRANNY -- I've had all of the injectors replaced at 20M. Ever since the first one fouled, the cranny seems to shift hard, especially when downshifting at about 25 mph. Also, at about 60 mph, when I decelerate, the car seems to "lunge". The dealer says, "That's how an Avalon is." This really bugs me. Has anyone else experienced anything similar?
Has anyone communicated with Toyota directly and had any success?
LOOKING FOR HELP IN MN.
But now I saw some power steering fluid on the floor, and power steering fluid went below the minimum level. I went to auto parts store and try to find a can of power steering stop leak fluid.
There are only two kinds of power steering fluid: 1 for GM, Chrysler, Ford and others. 1 for Honda's only. I checked the Avalon Owner's manual, it says to use ATF Dexron II or III fluid.
Can I use the power steering stop leak for Non-Honda's car? Does anyone have any information?
HiC
Considering Toyota's history for reliability and dependability buying such a warranty is superfluous. I have seen (but can't recall) companies offering warranty protection on the Interned for about $800. And if you filed no claims after five years you would get 75% of your money back.
the first 11,000 Miles were fine but soon after that my Transmission
Started to develop a clunk when accelerating after a slowdown.
It also has a heavier clunk when shifting from neutral to reverse.
There is a vibration in the steering wheel on acceleration in the front
wheels with the front jacked up.
the is a vibration in the steering wheel while on the highway
at 40 MPH on up - worse on curves or turning the wheel slightly.
Had repeated fronted alignments and tire balancing, tried 4 sets of new tires
Toyota dealer is acknowledges that there is a problem and balance the tires
with no improvement.
Toyota Rep says the vibration is characteristic, because all 98's and 1999's vibrate
and clunk is bad driving habits
Abitraitor says it is a grey area and claim has been denied .
Toyota Re said at the Green field, Massachusetts Dealership there was 1998 that
was worse than mine sitting on the lot.
If what the Factory Sep says is true about this charctaristic then it seems a class action
lawsuit is in order, Would any one with a similar problem please contact me.
thank you
my husband being the smart consumer that he is, called the dealer where the car was leased
from. We wondered why it was from another
county. Now we know! Seems it had a new transmission put in at 22,000 miles. It now
has only 27,000. The dealer that has it now didn't say a thing about the new transmission to us. Only by us investigating on our own did we find out. After reading what joefinkle wrote I
just may be glad we didn't rush out and buy it.
Thought joe may be interested in hearing other
99's having transmission problems. Good luck to you!
i have a 1998 avalon that is a great car with only 25,000 miles on it. my only complaint is that the suspension seems to be a little "loose" and tends to rattle over bumps and rough roads. superb on smooth highways, though! i guess i was expecting a better ride over the "bumps". any comments or suggestions would be appreciated. thanks.
it to my liking except for the transmission shifting comments you noted. My previous
car was a 96 Camary V6LE and shifting was silkly smooth. I assumed the new Avalon
would be likewise.
If anyone has found, or if Toyota has available, an alternate transmission or a microchip
which would improve smoother shifting, I would be interested
Albert, just to know how Toyota is responding to questions about Avalon crash test results, look at postings #854 and #865 in "Toyota Avalon" in "Sedans". In your case it is not just a hypothetical crash test that turned out poorly, it is real injured people.
Dave
The car developed two more noises, a rattle in the passenger side front door and a popping noise in the roof, both of which were fixed by the Toyota dealer, but the console creaking never went away, even after the third visit to the dealer. I don't think they know what's causing it. It's very annoying, especially because the car's quietness was one of the main reasons for me to buy it... - Any suggestions? Thanks!
We took it to an independent transmission repair shop and they definitely noticed the problem. They changed the transmission fluid, but it made no difference.
Since then my wife took it in to one Toyota dealer and I took it to another. Both claimed that the car had no problems.
I would love to be part of a class action suit or use Michigan "Lemon Law". Any advice would be appreciated.
Steve Dobson dobsonsm@cbpu.com
All installable by self.
I just recently purchased a 98 avalon. Once the car is turned on the car drives beautifully. I've had problems though, the alarm shuts off the car once I apply brakes to move the gear off park. Has anyone else had this problem?? I'm thinking this problem might be my battery or something. I do realize that the battery needs changing, but that should not have anything to do with the alarm system. When the brake is applied the entire car shuts off, lights and all. Any possible remedies would be greatly appreciated
I'm not looking to spark a big discussion on the pros & cons of the DTRL, I would just like to have the lights off.
