Why do you want VW wheels? They are overpriced like crazy. I'm running on 18x8.5" IWC Quicksilvers and it looks awesome. Check out some pictures here: http://albums.photopoint.com/j/AlbumIndex?u=1565856&a=11911242&f=0
- Anthony
- Anthony
The tires are brand new, I just got them mounted. I burned out the stock tires in 9,000 miles
- Anthony
Thanks-I am considering a GTI 1.8, Civic EX (boring, but at least $2K less), and an Outback Sport. This hp issue has been gnawing at me.
- Anthony
I was wandering how much the 17" wheels that come on the GTI GLX's cost. I love them. On the sticker it cost 400 dollars extra, is that what i will have to pay for them if I order them?
-dustin
- Anthony
Here's what I love about it:
1. VR6! Huge amount of torque down low, love the big V6 roar, and (the best part for me) simply an awesome highway cruiser. I can blast by cars in 5th gear easily, cars that cost twice as much. It only turns about 3,600 RPMs at 100 mph, and the engine isn't anywhere near strained. I once had it up to 120 mph or so and it still wasn't straining.
(note: In April, I added a Autothority EPROM chip for about $300. It gives you about 10 hp and 12 lbs. of torque. The VR6 really screams now, but remember to use premium unleaded only)
2. Styling. I really like the conservative German exterior. It looks almost like a Golf, to the Honda next to you. Then you leave his cheesy looking ride in the dust when the light turns green.
3. Interior. Like a BMW. Love the blue/red gauges at night. Wood trim is very nice.
4. Price. You get a hell of a lot of car for $23K.
Here's what I would like to see improved, which I think will be addressed with the 2002 redesigned GTI:
1. Not a complaint really. I love the VR6, but I fantasize about the revamped VR6 w/24 valves and dual overhead cams. It's about time! Put a chip in that baby and you'll have almost 220 hp and same amount of torque!
2. Gear shift. What the hell is up with this transmission? Balky, won't shift into first and second properly, etc. I seriously hope the new shifter is a lot smoother. I don't want Honda buttery smooth necessarily, but it'd be nice if I don't have to fight to shift into first when the light turns green!
3. Suspension. My biggest gripe after the tranny. I read it's the same suspension as the Golf, and I can tell. Too much body lean in the corners. Needs serious tightening.
4. Watch out for the window regulator problem. I already had one go bad. I was told this was fixed in 2001 and subsequent models.
5. A little heavy. I think GTI has gotten overlarded with goodies over the years. I could do without the sunroof and lose 100 lbs or so. Next year, many now-standard features will be options, so you can drop some weight from your new GTI if you wish.
Overall, a fantistic ride. If I were in the market for one, though, I would wait until next year and get the remodeled GTI.
I have an AutoThority chip too, and it helped the most of any mod. I like 15 minutes away from them, so it was convenient too.
As for the window regulator, it hasn't been fixed for 2001 models. I think mine might be going bad on my passenger side window. uh oh.
This morning "STOP!" appeared on the computer and it told me to shut off the engine and check the coolant level. Yup, my coolant was dry. I hope it's not a major problem, I'll get it checked out on thursday when I go in for service.
- Anthony
Do any of you guys have a problem with the stock diverter (after installing a chip)? Because i have heard people saying how it leaks and stuff after u increase the boost, so i'm thinking about getting one.. do any of you guys know how much it is (in Cdn)?
Thanks alot guys
I have the Bilstein Sport/H&R sport setup and I couldn't be happier with it. It's a 1.5" drop
"By the way, in Germany they offer the VR6 with the Passat engine, six speed tranny and the 4 motion all wheel drive system."
Not quite correct. The Passat V6 is a traditional 60 degree V6 with a 5-valve head. It's the same engine that Audi sells. Previously it was a 2.8. This year it's a completely new 3.0 liter engine, designed by Cosworth. But it is still a 60-degree V6 with 5 valves and it is used in the Audi A4, A6, and VW Passat. This engine is mounted longitudinally. The Audis and the Passat use the Torsen AWD system.
In contrast, the VW Golf and Jetta use the narrow angle VR6. The VR6 is mounted transversely. In Europe, VW is indeed selling a 24 valve version of this engine, with 6 speed gearbox and Haldex AWD system. Current rumor is that we will get the 24 valve version with a 6 speed first quarter of 2002, but no AWD.
Jared
quick, responsive, playful!!!
i just bought mine and got the racing suspension in it and the cold weather package since im in chicago!! Damn all there is to say about it is SMOOTH, very SMOOTH!
2002 GTI's base sticker is $18,910
1.8T to get 180hp and 174 lb-ft.
http://www.autoweek.com
1) Which chip should I install and how $$ will it cost me?
2) Is it bad for the car to put a chip to increase HP??
Thanks a lot
Thanks for your comments! ;-)
Pocahontas
Hatchbacks / Station Wagons / Women's Auto Center Boards
just wondering ...
will the extra power hurt gas consumption?
the 2001 is 24/31 on a 5 speed manual,
and that ain't bad.
thanks ...
i am getting set to purchase a 2002 GTI;
yet i'd like the optional 17" wheels rather than
the standard 16".
here is the ignorant part: when they say 17" are they referring to the wheel only, or the tire, or both?
i'd like a bigger tire on my GTI than the standard 16" , sort of makes the carlook more solid ...
by the way, does anyone know how big a tire the GTI can take? is 18" too big?
thanks to all.
Jack E.
The stock 16" Montreal IIs weigh 21 lbs without tires, and the 17" Monte Carlo's weigh 23 lbs without a tire. Not bad at all.
- Anthony
1. Humming noise in rpm range 2700-3000 in all gears each time I accelerate through. Has anyone else experienced this? I guessed turbo related...but the dealership has no ideas.
2. When in cruise control and on a slight to steep interstate incline - the engine surges, then releases, then surges....you get the idea. Related to problem 1? It's a new phenomena for me.
3. Window regulator
Any comments are appreciated!
for the 2002 GTI??
thanks.
I'm thinking of getting adding a supercharger, but I don't want to destroy the tranny.
www.bentleypublishers.com
he took it to the dealer and they said there's nothing wrong with car that "volkswagon engines tend to get more hot and burn more oil".
Has anyone out there heard of such a thing, or had a similiar experience?
I was thinking of buying a GTI myself, but now i don't know.
thanks.
assuming of course, that it is well maintained.
i plan to keep mine for 10 years plus.
is this realistic?
my friend claims the "heat" is inside the car, and it comes from under the hood.
maybe he's overly sensitive, who knows?
but before i buy my GTI, i want to check this out ...
Damn right the GTI is hot! That's why I am getting one next year.
- Anthony
