Ford Focus Hatchback ZX3 - Part X
Well, it's good news I haven't had anything bad to share. And believe me, I have been lurking. I can only post here at work...my comp won't let me post at home...some sort of cookie issue.
I thought I'd spare you all the story of going into the service dept last sat. to have them listen to the intermitant (sp!) thud of my tire. Of course, the mechanic got in the car it wasn't there so ... I get to keep my reputaion of being the crazy paranoid lady.
Going to hit 2000 miles on my commute home (got the car 6/24) so I am still piling the miles on and the brakes still squeak VERY loudly when I brake. It sucks, but there's not much I can do I guess.
So other than that just loving my Z!
and njzx3, I am sorry to hear about your situation. Good luck finding what you want ...
I still feel like something is not right, but like my father says, it's probably all in my head. I do have the hesitation in my engine as well, as many of us do. Also, I have this slight noise "sounds like a diesel" when I'm accelerating in 1st and 2nd before 2500 RPM's. Not loud and doesn't sound like a grinding, more like a rattle. And I think it's in the trans. It may just be part of the way the engine sounds. Anyone else had this problem?
Also, seems like the engine doesn't run that smoothly, and the tac gauge jumps a little when coming back down to an idle. This isn't very noticable at all, but like I said, now I'm weary of every little noise or oddity that I see. Do engines normally get smoother as they break in?
Still like her a bunch, and I would recommend the Focus. I commend Ford for having the guts to put this kind of car on the American market, though I've always been repulsed that small, compact, functional cars are left only to the Europeans (and others). I would like to see them offer more options and models in America, but I know we're a country where size matters, hence the popularity of Ford's Excursion (what an environmental nightmare).
SO WHAT'S THIS I HEAR ABOUT REAR CRASH TEST FOR THE ZX3?
Also it rattles like a diesel during the engine warm up in the morning.
Sounds like a widespread problem (or "feature"??)
Like I've mentioned before, the service manager did tell me he'd replace the pads at my next oil change if they were still squeaking (which I am positive they will be). So, they will do that, BUT from what I've heard the noise won't go away with all the brake dust that's accumulated behind (?) the drums. So, new padds is what they said they'd do for me, but I am afraid this won't solve the problem. The service manager said it may not, it may even be worse (but I have no idea how THAT could possibly be) and so if it doesnt do the trick...I've pretty much been told that is all they CAN do. And that, well.....sucks.
*sigh*
I tought I was done whining about this, sorry folks
click on Hot Import Nights, Chicago, the fifth one down on the left. Some thumbnails will pop up. Scroll down and you'll see a nice red ZX3 with an SVT 2.5L Duratec V6 neatly tucked into the engine bay:-)~
zgrrl - make sure they replace the pads with updated pads that don't produce as much dust.
I suspect that the oil has run down the side of the engine while they were removing the oil filter. Still, I can't see anything. Of course, I haven't crawled under the car and looked. It is far too cramped to get underneath. I only recently found the oil filter. I just shutter at the thought of always having an oil smell after I get an oil change on my car. The horizontal filter location is not 'ideal.'
Zgrrl: You can complain as much as you like in this forum. I am hopeful that the brake pad change will eliminate the sound. It should not be present. Do you sense any pulsing from your brakes or is it only squealing.
I have heard from time to time a rattly noise from the engine as others have experienced. It seems more like an engineering trade off at the designing stage. As the rpm builds the engine is strong. No one said we bought a Honda. I am not saying it is acceptable, but I do not think it is a manufacturing flaw, but a zetec trait.
My zetec engine is made in the USA. Where is your zetec made?
ND
Your air flow sensor problem made the engine run rich. This likely caused some extra carbon build up in the cylinders. Carbon build up will often cause pre-ignition problems.
You might want to run one grade higher octane gas for a while to see if that stops the noise. Over time the carbon should burn out and you can try returning to the regular gas.
Excessive pre-ignition can be bad for your engine. From your description I wouldn't say it's excessive, but I would try to get it under control. Excessive would be very loud and doing it frequently, rather then just occasionally on acceleration.
< I have this slight noise "sounds like a diesel"
< when I'm accelerating in 1st and 2nd before 2500
< RPM's. Not loud and doesn't sound like a
< ginding, more like a rattle.
It immediatly goes away when I press the clutch pedal.
I've experienced all the kinds of pinging and noking in my old car.
This noise is completely different.
The best description would be diesel rattle.
If I have any problems I will surely bring them up. I think we'd that's the whole purpose of this board...sharing and problem solving. I've learned more about oil etc than I ever thought I would. It's necessary especially with a new model. I do know SOME things about car care but it'll be YEARS before I catch up with ND and silver bullet
Before maybe I would have taken it at face value that the dealer says the noise is normal, it must be normal...etc. Now I know better, and anyone else who wanders here does too.
Funny thing: I work for a fairly large company in the Chicago burbs, they've just hired another person (who I have not met yet) who drives a CD silver ZX3 just like mine...I came back from lunch and he had park right in front of me so the cars were facing each other mirrored like. Sort of a surreal look in the sea of Civics and Corollas out there.
Funny story: I've never owned a new car before and I am TERRIFIED of parking lots. So, yes, I am one of those people who parks miles away. Took a friend to lunch the other day, parked WAY in back of the lot...my friend in mock serious, he looked at me and asked when the shuttle bus was coming to take us to the restaurant. I told him this way we'd walk off the meal on our way back.
Ok, guess you had to be there.
Anyway, thanks guys....as usuall you ROCK>
I got a free parking spot in Downtown Seattle one day, and I was very excited. I left my car there all day, didn't leave for lunch...nothing.
Anyway, after work I was walking to my car and I was reading a brochure I had. I stopped in front of what I thought was my car and looked up from my reading. Lo and behold, two identical Silver ZX3s...side by side. Mine was spotless inside, so was the other. I'd only had my plates for two days, so I couldn't remember my number. In short, I couldn't tell them apart. I didn't want to stand there too long, so it occurred to me that I should just punch the old panic button. Sure enough, my baby started a-squealin'...
Glad to know those things come in handy.
The noise I'm referring to is most definitely in the trans. It could be in the engine, but it sounds like trans. noise. I don't think it's pinging...who knows, I've heard it several times, but I can't pinpoint it. When I heard for the first time I thought there was something loose in the engine(battery cover, etc.). So that's what it sounds like. You guys still think it's the pinging?
Any secrets for getting a good streak free cleaning so I won't see halo's all night driving?
Pat
Anybody have any ideas.
Pat
MTX - 75? The same one as in the Contour?
If this is correct, I am not surprised.
Went to the Contour board: lots of tranny problems.
And yes, if you suspect the transmission it would be good to specify which you have.
Reason: It might make tranny smoother, quieter, give better gas mileage.
(This would certainly be a big "plus" for all of us Z owners).
You asked me how I made out.
The only info I have so far is that our Z has two 5-spd transmissions. One model uses conventional oil, the other uses synthetic.
I don't know which model I have.
Someone told me, "Even if you put car on lift and identify which Model tranny you have --- you will still have to look in Ford's computer database to find out which one is using synthetic oil."
To add to the confusion.... the tranny Model that uses conventional oil --- I suspect it might also be able to use synthetic. (Maybe Ford just didn't put the more expensive synthetic in it, at the factory).
Anyone able to help here?
If we Z owners switch to synthetic oil for our trannys, they might become smoother, quieter, give better gas mileage. Also might end any "noisy tranny" complaints. No? / Yes?
zx3
This time for the clutch master cylinder: loose of pressure and difficulties in operating.
Anybody having problems with engaging/disengaging the clutch?
I wasn't the one who posted about the armrest (I remember the post you're talking about), but I had one installed yesterday. Here's a summary of my experience:
o total cost was $550 installed
o as part of my original purchase, I ordered the parts for the armrest in a 4-door Focus - the parts have to be ordered as several individual parts, and end up replacing the entire center console
o the last part arrived about a month after my ZX3
o my dealer had the parts installed by their trim contractor, as that worked out to be cheaper than having the body shop do it
Hope that's helpful.
What is the general time frame of new year intro and the introduction of heavy past year rebates?
Do you think there will be any incentives for the remaining 2000 ZX3?
Is the yellow color only available for 2000?
Any sites for aftermarket accessories?
Drove one today for the 1st time... great fun car!Thanks for the help!
he said he would start callin around to other dealerships and see what he could find, but I'm not going to settle for less than what I ordered, so I may end up sittin around in Dirty Jersey til about mid september just to get the Z that i ordered, but afterall, she'll be my baby, and will definately be worth the wait
availability. aftermarket asccessories. go to
www.focussport.com i doubt very seriously if any
incentives will be available.i would be surprised
if there were any leftovers of zx3,too much demand
presently.yellow is a color option that will be available for 2001 as well.im sure others here will
post other aftermarket sites as well.good luck
with your search for a new z.
http://www.Focusparts.com/
your closer to that model year it may be a better deal for you.given that by the time you get your 2000 model it will be considered a year old
just shortly after its delivered.
Service department said it was OK to drive as is.
Any thoughts??
Neat car, kick to drive, my son and I fight over the keys. He usually wins, he's bigger (but not meaner) and he's making the payments.
Other than that the car is great! I still need to put in braided brake lines and a set of good front pads.
Joe
stanky73@peoplepc.com
I have the man. trans.
Just passed 500 miles last night. Never thought this would be a milestone. The engine has cleared up a bunch with the new sensor. Still love my girl, I just hope she stays trouble free for my long awaited vacation in two weeks...
I did this once with a pasenger and a trunk full of ten boxes of books, so I think it fared pretty well. Also, we have plenty of hills in downtown Seattle, and the car's fine there, too. Just gotta keep it in the right gear. =]
Honestly, It is not worth it for me to order 2001. assuming that im having enough trouble without a car now waiting for my Z to come in the beginning of september, there is no way I could wait until the 001 Z's come out... I just look at it this way, YES it sucks that i have to wait this long to get my car, and yes it's truly screwing up my plans to get back to school, but on the bright side, i have a little extra time to save my checks to start payin off my baby when it finally arrives.
thats my thought on that, now correct me if im wrong, but i didnt think the 001 Z's were hittin production for another few months or so? now if I could order an 001 Z and get it around the same time as my 00 Z that I ordered I will do it, but I cant wait several more months for it
<njzx3- since you have to wait longer,are you able
<to place an order for a 2001 model? given that
<your closer to that model year it may be a better
<deal for you.given that by the time you get your
<2000 model it will be considered a year old
<just shortly after its delivered.
Problems: rattling and engine hesitation.
Problems: Depends on how much tequila our friendly mexican Ford workers drink the night before
Mountain driving: Can't say anything about western mountains. But as far as the Alleghany's and Blue Ridge go, the ZX3 is a pleasure to drive, even with the automatic. Lots of pep and handles the turns extremely well. I found it a joy to drive in the "hills" of Pennsylvina, western Virgina, West Virgina and Maryland.
Pat
