Ford Focus Hatchback ZX3 - Part X
diesel sound - based on ownership of zx2 prev.
this seems to be normal.most unpleasant sounds can
be alleviated by heavy cd usage.the only shake,rattle or roll i hear comes out of those fine
stock speakers.
Saw your response (#455) on the $85 armrest.
Where can I find the Focus accessory catalog you mentioned? I'd like to see how it differs from the 4 door armrest.
I'm not sure if I like the armrest yet. Maybe I'm just not used to it, but it seems like it's about an inch too high, and as someone mentioned earlier, it seems to get in the way when I'm shifting.
The armrest is the same one as in the sedans. So you already will know what it looks like
Joe
Has anyone put one in on a Focus? If so, is it difficult? Are there any potential problems I may run into now or in the future? Any help is appreciated to quell this excessive urge.
Thanks again,
Joe
I drive a Sony Edition Focus and the face plate in mine is more of a silver but they do make aftermarket white and silver face plates. Go to http://www.fastfoci.com and go into their forums and scroll down to appearance and click on interior, someone has left a posting with exact directions on how to change face plates, it looks pretty difficult to do, but I guess that depends on your mechanical abilities, and as mine are very limited it looks pretty hard.
Good Luck,
Brent
Since it has been a topic, I have opened the windows (both sides), but I have not heard it at all. I do have that hesitation. My 5 speed transmission is perfect. No balking or any problems.
I have driven 5 spd for 22 years (I am 40!)and this is my experience with all the cars I have owned and tips on how I shift:
When trying to engage in reverse, it requires from time to time to engage the clutch more than once. When engaging in reverse, the car must be fully stopped and I always have the clutch fully engaged and gently shift to reverse and it should be performed slowly.
Engaging into first should also be performed at a somewhat slower operation. One does not not slam on the clutch and rifle the shifter into first. Shifting all other gears can be performed as fast as you like. Full engagement of the clutch is extremely important.
Needless to say, I have always had more than 80,000 miles on my clutches and have never had a transmission problem.
Downshifting a bit of an art. Revs and speed are important factors when shifting and become more important as you shift from 5-4 (any speed); 4-3 (from about 40 mph or less) and 3-2 (from about 35 or less). It should always be smooth and not herky jerky!! I never shift from 2-1.
ND
this is my first brand new car.
I had several old cars with manual transmissions before. And most of them seemed to have smoother and way lighter shifting trannys than the Focus. Especially the one on my
Chevy Sprint with 252K on it.
The Sprint's tranny could be shifted literally just by finger movements.
My focuses tranny (2000 miles) in comparison has some kind of a heavy feel to it. And it takes longer to upshift and downshift than in the other cars.
Here is a question.
Is your tranny becoming lighter the more miles you put on it or is this the way it was designed to perform?
Or was it light and smoothe from the day one?
Another related source is loose baffels inside mufflers or occasionally catalytic converters.
These problems are most common on older cars, but assembly errors or bad spot welds on a new car can do it as well.
Fortunately these noises are annoying, but they are otherwise harmless.
The Focus gear shifter is pretty good. I have not noticed it to be improving over time, but it was quite good to start off with.
While shifting,I notice a slight resistance prior to going into the gear of choice. It is very silky, but there is a point where you need to use a slight force. I do not shift it with a firm grip, but just a light grasp of the shifter and gently guiding it into the gear. Reverse involves a more deliberate action. Timing is key. The full engagement of the clutch is mandatory. The shift throws are fairly long, but the clutch action is absolutely perfect. Taking your time is important.
I think some people are hearing wierd noises intermitantly because of their lack of good technique. No damage is done to your transmission, but it balks at this 'rushed' operation and noise is created.
I have noticed people shifting like they are working hard and beads of sweat are building up on their brow. Manhandling. It should be a skilfully performed task where your passenger doesn't even notice that you have a 5 speed. Subtle.
ND
Also, make sure to come to a complete stop when backing out and then starting forward. You put a lot of undue strain on your car when you shift into first and start forward while still rolling back.
And try not to sit at lights with the clutch depressed or balance on hills.
As far as shifting: Every shifter has a different feel. I like the very deliberate feel of this shifter. It's more precise than many. Some shifters are so loose that you can't tell what gear you're in unless you already know. Mine is loosening up a bit with just over 5000 miles, and I quite like the feel of it. I also love the clutch in this car.
that is all...
Appreciate everyone's effort.
Gonna spend a part of the weekend examining the heat shields.
And in general will take a good look at that area.
Thanks everybody.
I agree. Do not shift in first while your car is still moving in reverse. Keeping your foot off the clutch while at a stop is important too.
Also keep your left foot on the floor while not shifting. It is very comfortable this way because of our upright seating position. You will wear out the clutch prematurely if you leave your foot resting (even lightly) on the clutch between shifts.
ND
My build date: June 2000
Problems here:
1-Bad Mass Air Flow Sensor (replaced). Hesitation has gotten better since I get a new sensor.
2-Doesn't idle all that smooth. Every few seconds in idle it shakes a bit, not much, just a bit.
3-Noise in the tranny. While I've only been hearing this in gear at low RPM's, a funny thing happened last night. Maybe this will add some insight to our discussion. After I cranked my Focus she was making the normal "in gear" noises at idle and in neutral. I popped the hood, noises still going, and looked around the engine. If I only had a stethoscope from work with me :0. Anyway, I couldn't place the noise, but it definitely wasn't just a loose component somewhere on the top of the engine. Anyway, I still heard it when I gave it some gas in neutral. To me it sounds identical the noise you get if you try to put the car in gear without pushing in the clutch. A light rat-tat-tat is heard. This is similar I think. Anyway, it hasn't become a driveability problem yet, but I'm scheduled to meet with the Ford tech. Gods Monday. After turning off my Focus and restarting her, she no longer made the sound in idle, but did if I gave her some gas, still in neutral. This still happens on and off.
Other than that, she's beautiful...I keep loosing myself in thought on the highway, only to look down and find her at 70...75...80...she's such a cruiser.
I'm praying daily that the Ford elves that live in my engine will be good to me on my vacation!
I am alos excited because I get my baby back from the body shop in 1 hour and a half, and its gonna be perfect!! I didnt have a problem getting parts, because I couldnt get an appointment for repair for less than a month after, and all the parts needed came in, though at different times. I was worried about that but we got all the parts, which was a front fender, door frame, moldings, center caps, rocker panel. The total of the repair is $2200, bout 300 less then we thought. I cant wait till i can be proud to drive my car again!! Do you know how embarassing it is to drive a brand new car with a messed up right side????? (especially when your a teenager!)
I am lost.
What is just a characteristic of the car you're reffering to?
rgarner,
I have the SAME idle shake.
Exactly as you described it.(not sure if it's normal).
And other problems as well.
Nice observation btw.
Wonder if replacement of the MAF sensor will lessen my engine hesitation.
Regarding the tranny noise. It's always there during acceleration.
In neutral it comes and goes without any particular pattern
And if it present I can make it go away by pressing the clutch pedal again. Weird stuff.
y'all are kinda depressing....my zx3 came in to day (ordered may 6th). i pick it it up saturday!!! tell me i should still be excited....
Can we post digital pictures here onto the Forum? If yes i would like to know how. I did a real low budget idea on the headlight wedge shape with static film and paint to test what the headlights would look like with the top edges rounded out a wee bit. Changed the whole front end look!
Just farting around and the cost was ZIP to experiment without harming the car in anyway.
Brake dust is not so much a problem as i think the pads have seated and the rotors are doing the same.
Short Story for today (BORING)
Cheapo lawnmower formed all engine moving parts into one. Time to go get a new lawn mower!
Figured twenty minutes would have the seats figured out on how to fold them down etc...
Button pushed on rear seat left...folded. What? I guess i should push it back up and find out how to pull the rear seat forward! Grabbed the back of the seat/folded forward/pushed the rear seat release button left/then right side! Done! 30 seconds.
Opened Hatch and released the "hide" cover and tossed it forward. Total time/first time? 1 minute.
Went to Sears and bought a good (on sale) mower and tossed it in sideways and not lenghtwise.
No match for a pick up truck but when the loading guy held the carton one way and i said to put it in sideways he said "are you sure"? Well with a carton with staples on the bottom i knew if i was wrong my tail bumper would be scratched.
Gained a little more respect for the ZX-3 because of the ultra low lift required to put packaged goods into the boot.
Figured out why the birds Chit on my car at work! Park away from refuse bins! Almost got the distance right as i only have bird Chit down one side of my car
Clutch seems fine now. Pulling fast in first i get a torque shift feel (not a PULL but an ossilation<sp english is not that good).
Still think the A/C sucks but all in all i really do like this car.
Ohhh spoke with a person that has the wagon 5-sd and asked him about the 'boating' and he said not a problem.
Just for fun i said "Windows'? WOOOWWZA!
We BOTH AGREE that they roll down BACKWARDS and are difficult to reach AND that it takes to many rolls to get the windows down/up.
Going to install power windows myself as i have the motors and know how?
Great Forum, and let's ask for options to 'Carlady'/to allow PICTURES.
With all respect.
WhyFord?
My point? Re-read the posts. most of us are happy. Also, people are more likely to post if they have a complaint than if they're 100% satisfied. So, if 25% of the people on this board have minor problems, and maybe 10% (I'm making these #s up) have bigger ones, then in reality its more like 10% and 3% or so. Am I making sense?
We're mostly happy, and these boards are filled with praise for the car. Stay excited...you'll love your Z.
Is it just me, or is everyone's gas pedal plastic and flimsy? Not really a problem, just an observation.
Yes, I love my Z and I'll tell you why. For one, it's a car that fits my needs almost perfectly. Like I've said before, beyond a few small changes, it's all I want. Secondly, I commend Ford for having the guts to produce a world-class world car! Where's chevrolet's version, there isn't one! And it is new, so we should expect some unforseen problems. Last time I checked (and I went to an engineering school), engineering was not a perfect discipline. So, in some way we're all lab rats, but who wants to buy a car just because it's been out for 20 years and every possible glitch has been fixed? We all take risks! Yet, there still are no perfect cars...the Focus is an experiment without lasting results in my mind. Hopefully it will be successful...
Btw, I'm a former Ford, Honda, Jeep, and MGB owner. The Focus is by far the most well designed car I've owned, except I'll hold that comment for the time being in terms of engineering and reliability. I'm optimistic, but it will take time to see how our sweet cars last. I would highly recommend the Focus, and I've been down the road of car problems, many, many times. But I'm also mature enough to know that stressing over car problems isn't worth it in the scheme of things.
More to come...hope we can all sleep peacefully knowing we've made the right choice.
By the way, I'm completely satisfied with my ZX3 (not even a tiny problem has surfaced in 8K miles). I've never been so happy with a new car.
I really wouldn't obsess too much over these little details. Most cars make odd noises and they run thousands of miles while doing it.
whyford - There are actually two very good Focus discussion boards, this one and the Focus Forum. Focus Forum does allow pictures, and is a very active group. Several folks have already posted interesting headlight mods there. Visit it at;
http://www.discussion-board.com/clubfocus
Yeah, I know there are others, but these are the best!
I want to use synthetic oil in the 5-spd manual transmission of my z. For a quieter, smoother, transmission.
The tranny is quiet and smooth now, but I want to make sure I use the "best" lube in it anyway.
In "Focus Owners Guide" P.249 (under "Lubricant Specifications") there are two "Manual Transaxle"s listed.
I guess that means, all 5-spd Z's come with one of two transmission models. (Is that right?)
I don't know which Model I have.
Here they are......
"MANUAL TRANSAXLE FLUID--IB5"....
"synthetic manual transmission fluid".
"MANUAL TRANSAXLE FLUID--MTX75"....
"Mercon automatic transmission fluid".
(I assume "IB5" and "MTX75" are the Transmission Model #'s. Correct?)
MY QUESTION:
Do you think the z can use synthetic in either tranny?
I know you say BMW uses it in all their trannys -- but do most, or all other car mfrs "use/allow" synthetic in their 5-spd trannys also?
I ask, because if I wait around for Ford to give me the answer, I'll wait forever.
Thanks in advance for any info.
zx3
brake dust has been reduced significantly.i had
also thought a/c was not too cool.however it was pointed out to me by fgaydos sometime back to
engage the the interior re-circ.button.after initial cooling .it does get
icy cold.after 7 mo. the window cranks + door locks
seem normal.
Paranoia alert: It isn't likely, but in the event of a transmission failure, Ford could do a lubricant analysis and deny warranty coverage, claiming you used the wrong lube. Legally, they would be within their rights to pull a stunt like this. Also, make sure you ask for "MTL", not "MTV"... otherwise you are going to get some weirdos with guitars and orange hair
thanks for the encouragement about my zx3. has any heard of colored window tinting? i'm getting autumn orange and thought that getting my windows tinted to match might be cool. any comments, suggestions?
Well, they finally, had an engineer to look at it. Of course he or she did not find anything wrong, just as all the other dealer technicians.
However, in during there test the found a problem with the front strut and replaced that instead of fixing the rear suspension. There explanation to me was that the strut noise in the front was echoing to the rear--yea right!!!
So now my car has a new strut which I never knew was broken and a rear suspension that still needs fixing. I don't know what to do.
I know others have heard this noise and I even mentioned to them a few others on this site express hearing similar things. I was told that I need to be careful about the info you here on such sites. Well that makes 2 repair attempts and 4 dealer visits. Ford stated that lemon law is 4 repairs to be declared a lemon. I like my car but am tired of dealing with this issue. I don't know if I would purchased this car again if given a choice!!
I welcome any feedback.
When I went to the cashier, she wanted to charge me $27 for my service. I bought the service plan (just didn't want to deal with it) so the charge should have been $0. That was quickly corrected. No biggie. Then I looked, and I couldn't find where they listed tire rotation on the invoice. I had reread the maintenance schedule, where it lists "Rotate Tires" as one of the 5000 mile services.
I said to the manager, Tim, "Tim," I said,"I don't think you rotated the tires."
To which he replied, "We don't rotate the tires yet."
To which I replied, "It says here that you do."
An he says, and this is a gem, "Yeah, but WE don't. We do it at 7,000 miles. Your next oil change."
I felt like saying "Unless YOU aren't Ford, 'cause this is a Ford document, you DO." But instead I just pointed out that my next oil change was at 10,000.
Anyway, they did it, but they wouldn't have, even though they had about 10,000 brochures that said they were supposed to. All happy now. Oil changed, filter changed, TIRES ROTATED, etc.
Edgar is happy =]
It's just one chunk of plastic with a cable attached through a hole. Never seen anything like this before.
Clearly a cost cutting measure.
Also, wonder about the outcome of your trip to the dealership on Monday. Please keep us posted.
Over the years I've made a habit of not rotating my tires. Why you may ask? Because I would rather pay for my new tires two at a time then four at a time. When the front tires finally wear out I move the still like new rear tires to the front, and put the new tires on the rear. I'm guessing that over the long haul the average wear and cost is pretty much the same.
So what's the hole in my logic? Is this a good idea or am I just an eccentric nut case?
That comment about being weary of what you hear on these sites is a bunch of crap. I don't think anyone on here has any vested interest in making Ford look bad. Ford just doesn't want you to think that there could actually be a problem with your Z and a problem that is more widespread than your situation. Ford just wants to censor you from the truth, and that's just plain wrong.
As far as Ford Motor Co., you can bet that they don't give a rat's a** about you or your situation. Ford is a huge multinational corporation, and their interest is purely financial. YOU are a monthly check to them. Don't kid yourself into thinking that they actually care about you. For example, they spend millions of dollars buying up ad space in Time magazine's Earth Day issue (to remind us how environmentally friendy they are), and make those great "world" commercials, but then they introduce the Bolivian Troop Carrier (aka Excursion), not exaclty a step towards environmental stewardship. So, it's doubtful that Ford is going to go out on a limb to help you.
I recommend that you one, document all of this. The letters you've sent, service you've had, discussions with your dealer, Ford, mechanics, everything. Depending on where you live the lemon law will go into effect after a couple of services, so why not get your Z checked out 2 more times. If they can't fix it, boom, it's a lemon. Remember, YOU are the customer, and you have the right to have a car that works according to your desires and what is reasonable. If your dealer refuses to service your car take it to another dealer. If Ford Motor Co. refuses to service your car, seek litigation.
And that brings me to the last step you could or should take. In most states the Attorney General's office handles the lemon law and other consumer complaints. Don't hesitate to contact the AG should Ford stonewall you.
Just my thoughts, but I strongly believe that you should do what you can to have your problem fixed. Like I said, you are the consumer.
Hope that helps...
My case is hard to prove, now that a Ford engineer, not the dealership service people has looked at my vehicle. I have had my ZX3 for 7 months. I have over 12,000 miles on my car and have been dealing with this since 4,000 miles. I wonder what will happen the day after my warranty runs out?
Someone here posted a week or so ago that, on the Contour board, there were many MT problems noted. As the happy owner for 6 months of a 2000 Mystique with V6 and 5 speed, I haven't noticed that and I'm quite satisfied with the shifting and the clutch.
I'm mostly just "listening" here because I'm a car/ZX3 fan. To me, the Z is more car for the money that a Civic Hatch and a comparable car to the VW Golf Hatch for less money.
By the way, are the Z and the Golf built near each other in Mexico?
The fuel pump went out. Dealer says the part will be in Monday as he had to get the part from Ford. We shall see!
case and logical at the same time. actually,i find
it makes life more interesting.so i ask,does this
sound logical ? or does this sound like an eccentric nut case? by the way ,i agree with you .
What works ok for me might not be a good thing for everyone. On the otherhand folks who drive moderatly, avoid the weekend motorcross events, and don't have piles of cash sitting around waiting to be spent, might want to consider my practice.
Those few z owners who mention having occasional faint tranny-noise, should give it a try also -- since Redline synthetic is supposed to make transmissions quieter and smoother. (2 quarts won't bankrupt anyone).
Is it available in Walmart, or auto stores, or do you have to contact vendor?
Does anyone have a link to Redline? Thanks.
Rand
