Visitor Agreement.
a 98 Trans Sport (Montana) with a lot of brake
problems. I am using the BBB Autoline service
in the back of the owners manual.
Any feedback would greatly help.
Here is one where you might get some helpful information:
Buying a Lemon
guitarzan
Community Leader/Vans Conference
http://www.hwysafety.org/vehicle_ratings/ce/vans/trans_sport.htm
I haven't given the dealer their money yet and glad it's that way. I discovered an oil leak, so it's at the shop today. It seems like I've heard of this complaint with similar GM vans but I can't remember if it's a problem that keeps recurring or not. Anyone have any oil leak horror stories? (hope not)
Does that sound familiar?
Let me know what your dealer says!
The master cylinder was replaced at 2,900 miles.
I had lots of brake problems with the van. I finally gave up after 11 tries to fix it and
with 18,000 miles on it I went to arbitration
and won GM bought my van back. I bought a 1999
Nissan Pathfinder used, and am very happy with it.
I had a terrible experience with GM, they don't
care if you can stop the van or not. The service
manager said everything was fine. However, an independent expert hired by the BBB found otherwise. I hope GM gets there act together one day but today is not the day.
I hope all of you have better luck than I did.
Stay away from the GM trio if possible.
MAD AS HELL.
the engine idles rough when you first start it. if you let it run for 30-60 seconds, it smooths-out and runs beautifully. It does not seem to matter if it is 15 or 95 degrees outside and it happens every time you start the engine. cold or at running temp. would the oxygen sensor be causing this??? any other ideas.
the compression is good on all 6 cyls and there are no apparent vacuum leaks.
any input would be greatly appreciated
it may not be extending and retracting properly, with that much mileage, check for carbon buildup in the isc passage. Also have the coolant sensor checked, and if equiped, check MAT SENSOR, (manifold air temperature sensor), if you feel confident enough to do it yourself, just replace those 3 items, the oxygen sensor most likely is not the problem with the initial 2 minutes of running , but keep in mind its a good rule to replace oxygen sensor no less than every 60k miles, for the best gas mileage and efficiency, I hope this helps, E-mail me if you need more input
I have had a problem with the wipers quitting during 2 different rain storms. They just stop in the middle of their cycle.
Has any body else had this problem also?
"a couple" of good ones for the Trans Sport.
I found an absolutely gorgeous '94 Trans (V6 3.8 eng) that is dark green with gold 2-tone. Rides like new from what I can tell and very clean inside and out.
Would seat the whole family nice for $9388.00
or should I buy that '94 Trooper (partial to Isuzu's) for 8K already?
Ernie
I really love our 1998 Montana van. We bought it over two years ago in January 1998. It presently has 60,000 kms on it (about 40,000 miles). It takes me to and from work every day (mostly moderately busy highway driving)and has done a number of 4-5 hour out of town trips. Even at two years old it is still a really nice looking van - some people even mistake it for a new van (surprising considering the mileage!)
It is fully loaded with just about every option that was available at the time (with the exception of the child seats - we have the 4 captain chairs configuration).
I find it to be very comfortable and easy to drive . It is my very first van, and I found the adjustment to it to be quite easy. It drives well in any weather condition (rain, snow).
We've experienced no serious problems with it - so far everything that has been done has been normal maintenance. The only real problem with it is the power door - it is overly sensative. It will sometimes (maybe 15% of the time) refuse to shut even though nothing is blocking the door; 95% of the time it will then shut on the second attempt. Very rarely it has to be "manually convinced" to shut (by me holding onto the door and refusing to let it reopen!). Of course, it never exhibits this "bad behavior" when we take it in for maintenance :-)
We've also had an excellent experience with the dealer who is looking after the regular maintenance (City Pontiac in Toronto, Ontario). They treat us so well, and have always gone out of their way to make sure that we were satisfied with our vehicle. This is such a huge contrast with the Dodge dealership that serviced our previous vehicle.
In short, I would highly recommend this van!
We just ordered a new Montana last month, and
we're in Toronto as well... didn't get it at City
though, bought it at Marvin Starr... it was great to hear that you find City to be good for service,
just in case we run into problems later, with
Starr...
I was happy to hear that driving it as a new van owner was easy, too; this is our first time as well, and I'm used to a small cavalier wagon, I have been a little concerned about the transition!
Keep us posted, now that you're almost POST warranty, about how the van does, K?
I'm really not sure whether or not we'll purchase the extended warranty, but since we'll probably keep this van, for about 10 years, (Hopefully!) I think it would be wise...
so many expensive repairs to these things now! IE:
ABS brakes.
Great info, glad I caught your letter!
Make sure that's NOT the cause for the (leak)!
With what I have invested and what this vehicle is worth, I will be keeping it until 160,000 miles now...
Another owner here. I had the oily leak and $800 later its fixed. Lower intake manifold. Lots of gaskets got changed.
On going problem. The van loses power when driving along. (not when flying over 100 km/hr). It kind of hesitates, bogs etc, never dies. One earlier posting mentioned the oxygen sensor.
Any suggestions
There was a post in the 2000 Montana forum about a month ago that dealt with the crash issue. In the Gvn't. frontal tests it didn't perform well, much better with side impacts. It pretty much depends on which report you choose to believe, for me, I value owner testimonials and from what I researched, it appears to hold up well in the real world.
By the way, friends of ours have a '98 and love it too!
I have the 3spd. tranny and only got 18-20 mpg when new. With synthetic oils I not only have improved my engine and tranny life but have increased my mpg to 24-27. I wonder what it would be like with overdrive?
The hood release cable has snapped where the cable attaches to the plastic handle under the steering wheel. I'm left with cable sticking out but even with pliers I can't pull the cable enough to release the hood lock. I can't believe I'm the only Trans Sport owner who has had this problem but I have no idea how else to open the hood. Any ideas anyone?
Just to lwt anyone who's interested know, the Trans Sport isn't ideal for England - the nose and turning circle need American-style space - but I still enjoy it and want to keep it a while yet.
Don't know how to open the hood with a broken cable, but sugget you go to a Vauxhall dealer. They sell the Chey Venture short wheel base van under the Vauxhall name in the U.K. Perhaps they can help and you can get a replacement cable.
We are very happy with the van. We need a minivan and I gave Chrysler 3 tries but they screwed me twice with transmission problems so they're rid of me for good.
So far we have had only a few items that we
have had to bring it back to the dealer for. One
was a problem with the CD player, a hanging emergency brake cable, and a check engine lite that went on caused by a bent wire. We have been
very happy so far with the vehicle.
However, I have been hearing a rapping sound,
sort of a lifter tap, coming from the engine for
some time now. I have mentioned it to the dealer
and he said it was normal. Is there something more
to this sound than the dealer let on ? One post
mentioned a piston-slap that he had corrected before the 36k warranty expired. Does anyone
know anything about this ? Is this a "secret recall" item ? Thanks.
adding the Acura MDX to our garage next month though.
I’m in the UK and considering a TransSport and would like to talk to someone who has one. Please e-mail me at pontiac@norton.org.uk
All the best. Paul.
Ed Wright
Winnipeg, CANADA
Trans Sport SE with 47,547 miles and fully loaded, however we are new to the whole minivan
world. If anyone out there can give us some feedback or experiences that they've had good, bad, indifferent, we would really appreciate it!
Thanks Amanda. Our Email address is Mvsafsmjs@aol.com.
