-juice
Depending on the application, one would want torque to be either at low or high RPMs. For a daily driver with lots of stop and starts, low RPM torque results in a vehicle that is snappy off the line. However, the same car would be quite unsatisfying to drive, say on a track, where the engine would be seeing high RPMs. Of course, RPMs also depend on the transmission gearing the manufacturer choses as well.
As for octane requirements, why doubt what the manufacturer recommends? They engineered and tested the vehicle so why try and skimp out on $0.10/gallon by going to a lower grade? If you do the math, you really don't save THAT much by dropping grades. Furthermore, engines often run less efficiently at octane levels outside their spec so the cost savings may even be a wash.
Ken
If I had to guess, I'd say increased availability of HID headlights, VDC (stability control), and navigation as options throughout the lineup, and the replacement of the remaining 4-speed automatic transmissions with their nice 5-speed auto. I could also see Subaru adding snazzy blue puddle lights like the new B9 Tribeca's.
If sales are slow, maybe we'll even see the incorporation of the new corporate grill along the lines what Impreza just received for '06, but I wouldn't bank on it.
I have a 2003 Legacy GT Station Wagon which came with 205/55/16 tires on 16" wheels. I want to install a "winter package" consisting of 195/60/15 tires on 15" wheels.
A 15" package is a lot less expensive that a 16". I went to 2 Subaru dealers and they knew less about it than I did. At least they would not commit to the 15" and that I should go to the tire sellers. I did this and they said they couldn't tell without the 15" inch wheels. Something about the "calipers" might be different.
They all said to go to "Tire Rack" on the internet and of course they would be happy to sell me anything I wanted, but no guarantee as to fit.
Isn't a Legacy L wagon and a Legacy GT basicaly the same suspension wise except the L comes with 15" wheels and the GT comes with 16" wheels?
Is there anyone who has made this change successfully?
Any help is greatly appreciated.
Len
I just checked for you and they state you cannot downsize to a 15" on an 03 Legacy GT wagon and they are already sold out of 16" steel rims for the season.
I doubt most 15" rim will fit, though there may be rare exceptions (the Gold rims on the Impreza RS left an unusual amount of space for instance).
-juice
I have a call into Goodyear consumer service to complain. I have a 30 day trial on the tires. Anyone out there with similar experiences, having gas mileage drop dramatically due to new set of tires?
The GT has bigger brakes. The 05 and 06 models can't go down to 16" for the same reason. You can go to the joe spitz site and all the wheel - and brake - sizes are listed.
If you decided not to get dedicated winter tires in Fairbanks how are us folks in the lower forty eight supposed to rationalize Blizzaks? I was counting on the Alaska people to spur me on with tales of snow and ice. But no, you have opted for all seasons. You have let me down lad.
Bob from Long Island
So more than tires may have changed in the last 30 days depending on where you live.
--j
Like I said, at this point, when I get a new vehicle I will probably get a set of dedicated winters w/ rims, but it is not worth the investment on my current Subaru since I feel comfortable enough without them.
I am a bad, bad lad! :P
I ran my van from Oregon to Alaska once on a bad master cylinder (unknown at time of departure!). I was about 1000 miles from my start and 1500 miles from my destination when the cylinder when poof and my brakes along with it. Being a broke college student with a 30-year-old van in the middle of wilderness, Canada, I nursed it the rest of the trip but it made for a few hair-raising moments. Ah, my young, foolish days.
This could be a deal-breaker for me.
I gather that consumer reports rates the 98 engine reliability as "poor" because of a gasket failure problem. My question is has this been fixed or is it fixable (like replacing the gaskets once with new & improved) so that it is not recurring?
The ask on this vehicle is $6,900 and it only has 84K on it. If it's in as good shape as the seller claims, it might be a good deal but I'm worried about what I've heard.
Should I run away?
John
Sorry for making my original post longer but I thought the above info might help. I'm no mechanic but I was wondering if since the car has had no seal/gasket trouble so far if that meant it was not likely to. Just guessing here...any opinions would be valued and appreciated.
Thanks again,
John
The new gasket material is indeed better, so as long as the engine doesn't overheat badly and warp, you'd be fine with a new set of gaskets.
They probably mean rear wheel bearings, which isn't exactly common on Outbacks but does happen on occasion.
-juice
So yes the new gasket material is better but this car still has the original gaskets. I'm not even sure which gaskets/seals we're talking about but are they expensive to replace?
And "as long as the engine doens't overheat badly..." was that a problem with the 98 models? Is that why the gaskets were failing or maybe the other way around?
Sorry, but I did try looking thru the archives and can't get a clear understanding of what I might be getting into.
John
The dealer wanted 100 bucks to change out the cabin filter so I'm deciding on it doing myself. I searched the forums to change out the in-cabin filter, and came across the information but too bad the links don't work since they are old. I was wondering if anyone is willing to share the photos or has a more recent instructions for an 04?
John: FWIW, for the past couple of model years the engine is rated "much better than average", data which agrees with what we've observed here on Edmunds. I think since mid-year 2002 or so we haven't observed any pattern of gasket issues.
-juice
Any other comments would be appreciated?
-juice
The overheating is typically a result of gasket problems, but can be caused by other things such as thermostat failures, water pump failures, etc as with any other car. The point is that if an overheating occurs, you could likely have more problems than existed before.
The question is not if, but when, the gaskets will fail. I would say that if the car is in good condition now and you are prepared to invest another $1,800 in it for gasket replacement, go for the buy and research the gasket issue extensively (there is plenty of documentation on it!) so you can nip it in the bud early on when problems begin to arise. Or, you could preemptively replace them as part of scheduled maintenance (probably the best option). $6,900? Are the '98s still worth that much?
Maybe with the mileage on it, I suppose.
Here is a recount of my contribution to head gasket replacement if you're interested.
Alland
Thanks for all help from all quarters. I'll keep my newfound knowledge handy for when I find the next one.
John
http://www.cars101.com/subaru/airfiltration.html
I own the same year Outback, and after having paid to have this done once, plan on doing it myself in the future. Unfortunately, of all the models now with filtration, ours seems the most complicated to replace... but still easily worth saving $100.
Maybe some Nokian users will chime in to offer more info.
Alland
Oh well, see what happens. Thanks again
Thanks for the tip bout the filter Hmm, $65 for the cabin filters? I might try your way. I will let you know what happens. Thanks again.
I think the Nokian WR tires might be alittle extreme since we do not have really cold winters in the philly are. I can see in the northern states or Canada to get this tires.
http://www.consumersearch.com/www/automotive/tires/reviews.html
I will let you know what I decide on.
Thanks again
Now I have a set of Yokohama Avid TRZ which are again unidirectional and have very good wet and snow ratings but don't have the All Weather Plus rating of the Nokians.
My tire size is 205/70/R15 and due to the sidewall height and flexibility, I felt that the WRs didn't corner as well as I prefer. The Avid TRZ is much better in the performance category and are rated for 80k miles.
The cost differential made the decision easier too.
Nokian WR $112
Yoko Avid TRZ $79
Alan
98 OBW Ltd (~110,000 miles)
Yeh, can't beat the price. I saw that Falken ZE512 cost $55 -$63?
Has anyone heard anything about the Nokian I3? Just curious.
Mike k
If you have any other accessories to install, this is also the perfect time. I did the alarm system upgrade, as well as the sound system subwoofer install. Much of what you need to get to with these items can be reached when you have the glove box assembly and console side strip out.
Oh, and great idea about 'rebuilding' the filters! Base model cars do not have them installed (at least they didn't do so on '02 models), so I did have to buy them the first time. But maybe I will refurbish them the next time around rather than throwing them out. Thanks for that tip.
Steve
edit - Mike - yes. The spot is empty and they pop right in. I did notice, however, that the total airflow is reduced slightly due to the filter media restriction.
Steve
http://forums.nasioc.com/forums/showthread.php?t=929236
Any help very much appreciated. Would like to get a reliable mechanic in the Detroit area to get my tranny fixed. Thanks.
