All the panels you're describing are galvanized steel. Aluminum is on the hood and trunk, but you didn't mention those are being dinged, and they're less sturdy. So that is very strange.
-juice
Does anybody have any experience with this product and would you recommend it or not?
Chris
Does the six cylinder really take a hit when at high altitudes?
Angelo
-juice
I know this is technically the case, but I'm looking for real world driving experiences. Is there really a noticeable difference, and if so, was it a deal breaker?
Angelo
My dad just went to the Canadian Rockies (loved it!), and told me the GMC Envoy he rented felt a bit wheezy at higher elevations.
-juice
Steve
-juice
suze
Sorry, I should have been more clear. This is not an engine oil flush, but a particular type of tranny service.
The automatic transmissions in these cars contains essentially three units in a single housing. The front differential is in the forward, lower section and has it's own dip stick & drain plug, and uses 80w90 gear oil. The main 4 spd tranny & torque converter shares its fluid with the 'center' differential. This differential is electronically controlled, and is located in the tail section of the case. Its job is to distribute power front to rear. If this center diff binds up, it will not let the front wheels roll smoothly thru a tight turn, as the sum of the front arc is different from the rear arc.
Some quick oil change shops & some tranny shops have the power flush systems that might help you. One thing to note - while the center diff & tranny share fluid, there is only a small orifice that routes fluid between them. So it is important that the innards spin during the flush, otherwise the tail section may receive little benefit. Ask the tech if it is possible.
Steve
Thanks again. Ours is a manual but your advice may still apply. The service station changed the fluid with synthetic [?] and added LTD slip transaxle conditioner, but problem is still there. They are predicting doom. Is this common in subarus of this age? should we consider changing the part?
Suze
The manual uses a different system. The front diff is probably much the same. The 5 spd gearbox uses gear oil, and I believe the rear tail shaft center diff uses a fixed (non-electronic) torque split clutch plate arrangement with its own fluid reservoir. I don't know much more about it than this, nor can I comment about service life. I don't suspect it to be problematic, as the number of inquiries like yours is practically zero. But I will let someone else jump in here that might be able to help you more.
Steve
The price, horsepower, and MPG are also very close.
The only difference is the obvious. Forester is a crossover SUV and the Legacy is a sedan (not considering wagon because of increased price). Meaning Forester has more passenger and luggage space. But the Legacy has curtain side airbags, Forester doesn't. I have children. I would want side curtain airbags. Forester seems to me would be a family centered vehicle. Why wouldn't it have the airbags? :confuse:
Adults Are Protected, but Kids May Not Be
-juice
http://forums.nasioc.com/forums/showthread.php?t=689844
Equipment is close, but one important thing is missing from the Legacy SE: the all-weather pack. You do not get heated seats, heated mirrors, or a wiper de-icer.
Actually, now that I look, there's more than that. The Forester X Limited also has a rear limited-slip differential and a 6CD changer as well.
To be honest that stuff is easily worth the $1500 difference if you priced those out individually.
I've been watching those closely because I want cloth but I want heated seats. We had 6CDs in both our cars now, so that would also be hard to give up. And we love moonroofs, both our cars have aftermarket ones.
-juice
We have a 98 Forester and an 02 Legacy. The Legacy fits longer items better, but the Forester just seems more versatile, fitting tall/boxy items better.
The Forester is pre-wired for a tow hitch; the Legacy is not. The Outback is, though.
-juice
I don't want to buy it from my local dealership. Don't ask. But, years back when I bought my '01 4Runner, a very helpful person on the Edmunds Toyota forum helped me to purchase a Platinum Toyota warranty from his dealership just over wholesale.
So, anybody know of a Subaru dealership out there that is well priced for an extended warranty? I am in California, but I believe it doesn't matter where I am, at least it didn't with the Toyota warranty which was in Washington DC. Thanks!!
2021 Toyota Venza Limited Hybrid, 2022 Ram 2500 Laramie 6.4 Hemi, 2007 Mazda MX-5 Miata PRHT
http://www.curry.subarudealer.com/
but they don;t have a seperate warranty website anymore flogging cheap warranties.
Maybe some of the owners with newer OBWs will chime in here with their experiences. I cannot be the only owner who loves driving his Subaru in adverse conditions...
If you have the VTD/VDC setup which uses the brakes to clamp down on the spinning wheel, you will effectively have a front 'limited slip' setup as well.
Steve
For what it's worth, both of the Subarus that I have owned (Outback and WRX) had a limited slip rear end and I never got stuck in the snow or mud with either of them. It doesn't make the car unstoppable, but the addition of a LSD does seem to give you one extra layer of protection against getting stuck in the deep stuff.
Brian
Not to be argumentative, but ice was a bad example. Ice, in and of itself, will not stop you. Combine it with deep snow, etc., and then you'll start having problems.
2wd with an open diffy is 1wd
2wd with a limited slip diffy or traction control is 2wd on one axle
4wd with two open differentials is 2wd, but on two axles
4wd with a limited slip rear is 3wd drive
4wd with VCD/VTD is 4wd
Now torque might not be spit evenly in each of the cases listed above, but by now you hopefully get the general concept!
Steve
I went zero deductible because my local dealer is a crook, and always tries to scam on something. Figured there would be less opportunity for games if I had no built in liability.
Steve
-juice
...and you have a newer belt that will last until 240k miles.
-juice
PN 15208AA09a 65mm
Mike
H4 NA and Turbo motors = 15208AA100, H6 Motor = SOA5165109
-Brian
