-June 2024 Special Lease Deals-
Mark
Any ideas as to what the problem might be? I plan on taking it to the dealership - however, I have no experience with the local dealer and would like to have a sense of the differential diagnosis before dealing with them (so that they cannot give me the run-around). Thanks for any advice/info/help.
I cannot change the problem so you learn to live with it, it in no way deminishs how I feel about the car overall I just think it is awesome, quiet and smooth on the highway, I find I have to constantly check the speedometer as the car is so smooth it is very easy to be well over the speed limit and not realise it.
Cheers Pat.
I've heard that if you get the bearings cleaned off real well and lube 'em up, you might effect a short-term fix. In the long run, however, you just install a new bearing/half-axle assembly. It's the labor in that job that is the major expense, not the part (usually), in my experience.
Good luck - hope I'm wrong!
Ken M.
I'll just echo the above comments. Almost certainly a CV joint at this sort of mileage. Checking the condition of the rubber boots around them is one of the critical functions of a detailed service on any car with front wheel drive or independent suspension.
The failure mechanism is that the boot perishes (not common these days) or is torn in some way. This allows grit into the bearing which then chews itself out. When the car is running straight this is not too severe a problem as the line of drive is fairly constant. The problem comes when you turn a corner and the CV joint is asked o transmit power around a bend. You then hear the clunking as metal rubs against metal.
It is usually a shop job to repair tham and it is worth getting them all looked at together. I have not looked under my 99 OB but presume that there are four pairs of CV joints as the car has an independent rear end.
Cheers
Graham
-Greg
I'm not the brightest (in fact I don't even have a filament in my bulb) amongst the ACEs here, but glad I could contribute.
Cheers
I have used it since without any problem. The way it works is as follows: I turn the rear wiper on and it works normally for about 10 seconds, then it goes automatically into intermittent mode. Turning the wiper off and on resets it for another 10 seconds followed by intermittency. The intermittency interval is set by the commercial rear wiper delay.
I am not an electronician so it may not be the most elegant way of doing this, but it works! I fitted the rear wiper delay and external timer relay right behind the small vertical compartment with a door, on the right handside of the trunk (where all necessary wires are easily accessible). My Subaru service manager drove my car for a week to check a transmission problem and she said she really liked the wiper feature...
Pat (Canada).
I'm surprised your dealer did not have a VDC for you to try. Are they expecting any soon? Who is your dealer.
As for the glass distortion, this is new to me. We can check it out for you if you'd like.
Patti
This is the Australian perspective where our cars are built in Japan, however the following may help.
Overall Subaru build quality is excellent with a significant proportion of purchasers being repeat buyers. Before buying in 1999, I asked every Subaru owner I could about their views on the car and the most common response was " Well, this is our nth Subaru".
Subsequently, I have found that one hazard of Subaru ownership is that people approach you on the street to determine your views on Subarus. This ties up with the profile that emerges from contributors to these pages. Subaru owners tend to be analytical, very rational types (there seem to be a lot of engineers, computer people and accountants) who look for long term value for money. The down side is that research on these pages suggest that your forename should be Dave and an Apple Mac is almost obligatory.
After the problems I experienced with a Mercedes before buying my Outback, I had expectations of dramas. The actual ownership experience has been far different.
I do not expect any appliance, particularly one as complex as a modern car to be absolutely trouble free but hope that any problems will be rectified promptly. That has been my experience. My car has been subject to two recalls, one relating to a tow hitch supplied by a third party and the second for a check on a fuel tank plug. Both were handled perfectly.
In fact the contrast between the superb way in which Subaru managed their recall compared with my very sad experience with Mercedes, formed the basis for an article I wrote in a professional journal on the correct manner to deal with product recalls.
Here in Australia, we have a lot of experience with Subarus and they retain their residual value very well as they are recognized as abnormally robust and very good value for money. You should not misinterpret that as cheap as they must be properly maintained. However if you have a value equation that likes Volvos or had a soft spot for Checker cabs, you will understand the benefits.
I also experienced an initial concern over an apparent aberation in the rear screen. On inspection, I discovered that it was a problem with the rear view mirror where the day-night lever acted on the swinging glass. After moving the switch about a dozen times, the aberation disappeared, never to return.
If you are seriously looking at the Subaru, I would suggest you take it for a longer test drive, possibly over a weekend hire. It is not a car which immediately grabs you, but which appeals more and more the longer you drive it. I have recently checked over available replacements for my Outback and realized that my first preference would be another Subaru.
I would also suggest that you test a Subaru in marginal driving conditions, with wet or slippery roads. The worse the conditions, the better the Subaru behaves. I really enjoy driving on rough bush tracks where it is in its element.
There are deficiencies in the car, particularly the quality of interior plastics which tend to scratch easily. However, they are extraordinarily solid as testified to by the fact that I have been rammed fairly hard twice without damage although leaving serious damage to the ramming party. The safety benefits of AWD and superb brakes can also not be overstated.
I hope you enjoy the search for your car.
Cheers
Graham
G. Mendez
Good luck in your search,
Greg
Jim
4NelsonsHere@compuserve.com
Laura Nelson
This is not unique to subaru, I have seen it on Honda's and BMW's. The time you notice it the most is if your window is clean (a dirty window tends to hide those spots). It does seem to be more pronouced, possibly because of the size and angle of the window.
I don't feel that it compromises safety at all. While you are driving and looking through the rear mirror you don't notice it. When you look around to back up it's not significant enough to distract you. After a while you don't even notice it. One of the things that I really like about the OB wagon is the amazing visibilty you have. Compared to Sedans and even other wagons I have driven the subaru has excellent all around visibility and very small and not critcally placed blind spots.
As far as long term reliability goes the general consensus seems to be above average. All cars will have their problems, some cars will be lemons. But if you lurk the other boards (VW, Jeep, Volvo, Audi, Infinity) on edmunds you will see a big difference in the complaints that people post. The worst complaints on the subaru board are from people who feel very annoyed by things like squeeking brakes and pinging engines. The worst complaints on the other boards are by people who feel bitterly betrayed and are at the end of their rope. Things like eating brakepads, differentials, transmissions, no end of electrical failures and other expensive things that prevent the car from running.
I know its not scientific as only the people with exceptional experiences bother to talk about them and there might be more VW, Audi or whatever owners out there on these boards than Subie lovers but it does give you an idea of the types of problems you are likely to face in a worst case scenario. It does tell me that most of these subaru owners are happier with their cars from a reliability standpoint than most of their competitors (go read the Volvo V70/XC boards and see how many people are ready to chuck the thing out the window if they could).
I've got 67K on a 96 OB and I've had less than $200 worth or "repairs" done to fix things that were not maintence related or that I broke myself being adventurous. Of course I have spent around $1600 on maintence (tires, fluids, belts, flushes, oil changes, brake pads, rotors etc). I regard that the same was as gas and insurance, its just what it costs to operate a car.
There are no gaurantee's, you pay your money and take your chances. But you can bais your chances one way or another by your choice of manufaturer and model.
If you want relibility and pretty good saftey the Subaru OB is a good choice. Which model you get (base or VDC) just depends on how much you have to spend. If you have the means I would reccomend the VDC, I have one and it is a very nice car. Good performance, excellent traction (even better if you ditch those firestones) and a killer sound system. Bring a CD, FM radio will not show what it can do.
One thing I CAN tell you is that I have experienced a BIG difference between winter mileage (18-18.5mpg) and current mileage. I have been keeping track of every tankfull since December and am amazed at how quickly mileage improved (with no appreciable change in driving habits) once we stopped getting "winter blend" gas here in the Chgo area.
"It's all about the gas!"
Ron
Greg
I just went through the same selection process, resulting in purchase of an LL Bean after 4 Toyotas (82 Supra, 84 Tercel, 90 Cressida & 95 Lexus). Until March of this year I still owned the last three, and still own the last 2. Although I too had reservations about leaving the Toyota brand, I chose the Subaru for the quality, functionality and value. Time will tell if I made the right choice, but the comments on this board all point in the right direction.
Yes, I am an engineer (wife too!), but there is also a "cuteness" to the Subarus and the positive thinking by Subaru owners that also helped.
Steve
...at 6-7pm Pacific/9-10 pm Eastern. Hope to see you there!
http://www.edmunds.com/chat/subaruchat.html
Drew
This also only occurs when the vehicle has been operated at highway speeds for more then a couple of hours. I also experienced it a month ago after a 3 hr. trip up Island (also wet) but never around town.
I don't know if it is related or not but during this same period, I have noticed a high pitched whine has developed at speeds of 65 m.p.h or a little higher. The whine is not tire noise as it stops when I power off.
Any ideas you might have would be greatly appreciated.
Patti - being a Canuck eh, I don't expect you to look into anything for me but if you have any ideas, that would be great. I have a very good relationship with my dealer and just looking for any info. that I might be able to pass on to them.
Thanks, Tom
Ross
I ran a Merc C class for 4.5 years from new. Over that time, it leaked from virtually every orifice you can think of, and some you can't. The most depressing was when the sunroof mysteriously leaked a lap-full of snow melt onto my groin (and I wasn't even thinking abour Elle McPherson). The boot leaked, the rear screen, the front screen... When I mentioned it to colleagues, they pointe out that these leaks were common to all the Mercedes on our fleet.
The fan motor randomly chose whether it would work at particular settings, the car whistled mysteriously at high speed, the rear door rattled. Each and every problem required multiple visits to the dealer with the car disappearing, usually for days at a time only to return unrepaired and a general attitude of "You shouldn't expect us to fix it for you..."
A car is a Tool of Trade for me and if I am off the road, I am not earning. Over the years, I got to test many exciting Mercs when they were available as loaners, but the necessity to come back to get the car from the dealership meant that I had curtailed business trips, costing me money, time after time.
With no certainty, the immobiliser would slip out of phase with the door locks meaning the car was immobile if you could get into it and vice versa. The remedy was to disconnect the ECU and stand around for a few minutes waiting for the memoory to clear. Of course, in doing so, the cause of the problem was lost from the error memory meaning that the dealer could not trace the problem.
After three years, the wiper motor was a bit jerky and I asked that it be checked. That service took 4 days and cost £1,800 (about USD2,800) as they had to tear the dashboard apart to replace the wiper motor.
Eventually, things came to a head when the car broke down six times in seven days.
Dealer service was universally bad, particularly when recalls (there were several) occurred.
Ultimately, I concluded that the cost of maintaining the car was just not worth it. Never again!
Cheers
Graham
I'm comfortable with the price, but do not want to sink $3000 into the vehicle in 2 years. How much corrosion is typical and is this something I should worry about?
Ed
Any opinions from Colorado drivers?
Would also really appreciate overall OB experience, pros and cons. Many thanks. John
Beyond that, I don't know of any other changes. Oh, there is a different red color (no more Winestone), and the lower cladding is a (very) slightly different color.
We own an '96 Impreza Outback and a '01 Forester, which have been great. I just replaced the tires on the Impreza, which lasted almost 80,000 miles. Can't comment on the ownership experience on the Legacy Outback, although I've driven quite a few, autos, manuals, H-4s & H-6s. Mostly all thumbs up from what alI I've seen and read.
Bob
I had an Audi 4000 quattro in the early 80s, it truely sucked. Was almost as bad as my Dads Jag in the 70s, always in the shop. Maybe Audi is a lot better now (or maybe it isn't which is why they need to bribe you with free maintenance) but I don't see paying a premium when the Sube is far more reliable by any parameter. My family and friends experience with Volvo reliability has been pretty awful as well so forget the XC. The only thing I might vaguely consider besides another Legacy when I have to replace the present one is a Passat 4motion (as long as its made in Germany!) though even their reliability isn't so hot.
<< Since you are obviously into cars in a big way, what is your impression
of the 2002 Explorere XLT?>>
I think Ford did an excellent job with the new '02 Explorer. It's much better than our current '98 model. Much as the ML Mercedes set the standard for engineering (not quality, but engineering) for SUVs, I think the new Explorer will do the same. It's the first traditional "mainstream" SUV with IRS, which allows for terrific packaging. It's very roomy and offers a (small) 3rd row seat, yet is no longer than the old Explorer. It's a very clever design.
<<Re the 2002 Outback, were the foglights and fender larger so the vehicle
had a different look?>>
Yes, to set it apart from the Legacy models.
<<Are their any other exterior color changes and are
you sure that winestone is eliminated?>>
I'm 95% certain that Regatta(?) Red replaces the Winestone color.
<<Oh, any preference for manual vs. auto?>>
The automatic is a good transmission. I do, however, wish it were a 5-speed automatic, rather than a 4-speed unit. The extra gear would allow for closer gear splits, thus better performance. Even though both our Subies are automatics, I prefer a manual. It's more fun IMO.
Bob
I have a 2001 OBW with 4000 miles.
On a recent business trip to from central WI to St. Louis I got 32.5 mpg. I am using 87 octane gas, and when traveling use my Cruise control extensively at around 73-75 mph. I even used my A/C for about a quarter of the trip. Believe me, I have been impressed -- especially with gas at $1.80+.
Regarding the brake squeal. I have it consistently when backing up in the morning. So does my friend's Dad (01 OBW w/6000K), and it has been reported by many on this board, and in the General Maintenance & Repair section. Patti of SoA has mentioned that it has been acknowledged by SoA, and a fix will be forthcomming --- (Patti if you read this post have you heard when that will be?)
I have noticed that 'sometimes' my auto tranmission [non-permissible content removed] hard in going from 2nd to 3rd upon the first shift in the morning. Heard others are experinecing the same. However, it happens so infrequently that I am convinced that the Dealer will not be able to reproduce. I can't leave my car overnight either, as the nearest Subie Dealer is 35+ miles away (I need a car to get to work, and 35 miles is a bit of a trek to have someone pick me up).
Otherwise I love the car. Its been great.
We live in upstate NY (Capital Region) and have a 2001 OB, manual transmission, 2.5 H4. This past winter we got a lot of snow, some of the storms that hit you hit here first. The OB was wonderful, there were days that I was out and about that not many people dared. We also own a 96 Explorer, I really feel the OB has more traction and I feel more in control since it's a bit lower, you don't get the tilt feeling on curves, the Explorer is a manual trans also BTW. The OB is pretty close in cargo capacity to the Explorer, but the 02 Explorer is bigger than mine. All in all I'm really pleased with the way the OB handled this winter, and gas milage is much, much better! I still feel safer in the Explorer, probably just because I sit higher and it feels bigger, but when it goes we'll seriously consider another Subaru, either another OB or the larger Forester that's due out in a couple of years. Oh, and the OB is definitely a LOT more fun to drive!
We have a 2k OB Ltd. with 30k miles.
However, I have to say that after driving several other OBs (2ks and 01s) ours is the most smooth shifting one of them all. Most times you cant tell its shifting.....Its like my friends ES300.
Generally speaking I've always preferred manual transmissions to automatics in the snow, I think they give the driver more control.
Of course, nothing stops in the snow, not even a Subaru. Dedicated winter tires on all 4 wheels really help, so I'm told; I'll be finding out for myself next winter, when I plan to buy a second set of wheels and winter tires. Last winter I went everywhere I wanted with the all-season tires on my GT (which pretty much suck in the snow), so I can imagine that a Subaru with winter tires is all but unstoppable.
Cheers,
-wdb
Live Happy,
Chris
<<Would you be so kind as to try to specifically describe the new "regatta
red" v. the winestone? Is it darker or lighter, brighter, red/red, candy
apple red, red with some orange in it, or maroon?
This request comes from my wife.
I wish I could find a photo of the 2002 Outback>>
I haven't seen the color yet. I believe someone on this forum has seen a swatch of it, however.
Bob
Any suggestions?
