Subaru Legacy/Outback
15253555758230
  • mtnshoppermtnshopper Member Posts: 58
    I don't have any wisdom on this, but I share your complaint. It's irritating.
    Becky
    Morgan: if you like the 5 speed, go with that. Though the AWD systems are different, both are effective. The manual trans AWD system is full-time, sealed and maintenance-free. They've been extremely durable and if you read the the nearly 3000 posts in this topic I don't think you'll find one failed AWD system.
    Michael: I would try an ECU reset. With a cool engine, pull the negative terminal from the battery. Wait 30 minutes, then reconnect. Let it idle until warm then drive off. Now, the ECU will be "learning" your driving habits, so drive aggressively if what you want is good passing power.
    Chuck: bleeding the brakes is the same as in any other vehicle. 30k is a bit earlier than necessary, IMO. I've never heard of anyone changing power steering fluid.
    Regarding the trans solenoid, I think there were no responses simply because noone has done this and we're not familiar with it. If that's the case, it's likely not necessary.
    -juice
  • hypovhypov Member Posts: 3,068
    no, nothing melodious.
    Took an impromptu trip to Maine yesterday (boy did I regretted it this morning) just to have lunch(clam chowder, fried clam basket and oyster 1/2s @ Boone's).
    Anyway, when I arrived at Portland, a familiar burnt rubber odor was coming from the engine compartment, more so from the front wheel well.
    Is my CV Joint, DOJ, whatever you call it, giving out? Had those recalls done long time ago, as well as a wheelseal replaced. Or, could it be something else?
    Anyone with insights to take with me, no not to Maine, to the Dealer Service?
    TIA
    Dave
  • evilizardevilizard Member Posts: 195
    I bleed mine out every 15K. Its actually a little easier on the OB because of the ground clearence. I'd highly recommend speed bleeders if you plan on doing it more than once. 4 of em cost around $20 but it turns a 2 person job into a one person. They are little one way valves that open only under positive pressure. Best part is that you can see the level of your resevior while you pump the brakes.
    Short of a suction siphon I don't see any way to change the PS fluid (don't worry your car will get old and it will leak out on its own accord in time).
  • jvannormanjvannorman Member Posts: 3
    Although this question isn't Subaru related (except for the fact that my questions arose from the fact I washed my Outback yesterday), I figured I would present them since everybody has been so nice to answer my questions in the past. I live in an apartment complex that has a free car wash. It is one of your basic "do-it-yourself" types with a spray gun and a suds brush. I noticed that one of the available functions is a wax-spray (it comes out mixed in with the water). Now I know there is no way this wax would be as effective as a good old coat of wax out of a can (or to be modern, a bottle). However, since it is free, I figure I might as well use it. So here is my question. How effective is this stuff and how do you properly use it? Do I need to spray it on and leave it? Should I wash it off after letting it sit awhile? I doubt I need to polish it with a cloth since the stuff doesn't really seem to stick to the car.
    You spray it on and rinse it off. It's supposed to leave a wax residue to protect the paint.
    Of course, it's not rubbed on like a good paste wax, so you can imagine how long it will last. I'd say for the in-between car washes, it's fine, but I'd still wax by hand twice a year.
    -juice
  • goosegoggoosegog Member Posts: 206
    My missus and I just got back from a 3 week, 5,500 km trip from Vancouver BC, through the Washington Cascades, Idaho, Montana, Wyoming (Yellowstone), back into Montana, Saskatchewan, Alberta (Calgary, Banff, Jasper) and back to Vancouver. Average mileage about 29 miles per Canuck gallon, pulling a pop-up tent trailer. "Erfie", our 2000 OB H4 5spd did great.
    Min elevation: 6 metres
    Max elevation: 3,600 metres
    Max speed: 145 kmh
    Min speed: 0 kmh
    Distance on gravel roads: 135 km
    Max speed on gravel with trailer: 80 kmh
    Max speed on gravel without trailer: 100 kmh
    Max ambient temperature: 31C
    Min ambient temperature: -6C
    More later. Stay tuned if you are interested in towing with an H4.
    Very interested. Any data on fuel efficiency?
    -juice
  • roaminchargerroamincharger Member Posts: 11
    RE 2708, is a "canuck gallon" the same as a Imperial gallon ? How many ounces in one ? I'm very interested in towing,I bought my legacy to tow two snomobiles.On my first tankful I averaged 24.6 MPG in short trips mostly.
  • roflickroflick Member Posts: 14
    We purchased a '01 5 spd Outback LTD after careful consideration and extensive research. All reviews I've read note that the automatic transmission is not well matched to the H4 engine and recommend the 5 speed for the extra boost in acceleration. We are very happy with the manual. I can't wait to drive in the snow.
  • FrankMcFrankMc Member Posts: 228
    are horsepower-happy. I'm happy with the power in my '97 Legacy Wagon with the 2.2 L (137hp) engine.
    Frank
    I took my 2001 Outback in to the dealer to have some "repairs" done and I figured this would be a good forum to address my complaints. Has anyone noticed that repair shops will do ABSOLUTELY nothing without making you bring the car in first? One of the plastic tabs on the cargo screen that you pull out to cover the trunk area broke (actually, it wasn't even on there when I bought the car from the dealer. I didn't notice it was missing until after I got home). So I called the dealership and they said the repair shop would have to take care of it. So I call them up and proceed to tell them what part I need (My hope was that, if needed, they could order the part beforehand and I could avoid having to waste time dropping it off and picking it up twice) but they won't even listen, they just said to bring it in. So I took the darn thing in yesterday evening only to have them call me today to say they have to order the part! Of course they can't get it until next week, so I have to go back, pick my car back up and go through this whole mess next week! All this for a little piece of plastic! Why am I telling you this, I don't know, but boy do I feel better!
    ...is an imperial gallon (8 imperial pints or 4 imperial quarts, and if my schooling was correct, that would be 160 ounces, as "a pint of water weighs a pound and a quarter"). But gasoline is different to water and were those troy ounces or avoir dupois? And what about rods, poles and perches?
    Of course we use metric in Canuckland, and mileage is expressed as litres per 100 km. As I was brought up in the imperial age I find mpg a more useful measure, but it gets confusing when buying gas in US gallons and recording the distance in km.
    Anyway, I did record my fuel consumption and will post the figures when I have time to write a brief commentary.
  • rangerron7rangerron7 Member Posts: 317
    After living with this vehicle for the past year or so, here are my impressions after 10K:
    Pros:
    AWD: The advantage of AWD was brought home to me once again this weekend while driving in a fairly heavy rain. Maneuvering at close to highway speeds was a snap. The responsiveness of the suspension in adverse weather is very predictable. This vehicle handles much better than any SUV I have driven.
    Comfort: The OB is smooth and quiet, almost as quiet as a Camry. This vehicle really has a refined ride but with much better road feel than a Camry.
    Interior: This is my first vehicle with leather interior and I had second thoughts about buying the Ltd because of the leather interior. After over a year, I have changed my opinion about leather. The leather in the OB Ltd is done very well. A couple of treatments per year with Lexol and it should stay in good shape. The heated seats have really spoiled my wife and I, we love them.
    Cargo capacity: I feel that the OB has as much usable cargo capacity as most SUV's. I know that most SUV's quote greater cubic inch cargo capacities, but the OB just seems to be more usable.
    MPG: Much better than the Chevy Blazer I got rid of. (But, see cons below)
    Cons:
    Dealer Service - I have not had a particularly good dealer service experience. Three trips to the dealer to properly diagnose and fix a blown door speaker, three trips to properly diagnose and replace a front strut. (And it sounds as if the problem my be returning.) This underscores my lack of confidence with dealer service departments.
    Parts Availability: Here is the basic drill that I have gotten: Oh, you need a new speaker/front strut/cabin air cleaner element. It is not in stock. Should be here in a week.
    So, this means at LEAST two trips to get a problem fixed/part replaced (three if they misdiagnose). When I went to the parts department to get two bottles of touch-up paint, they had to order it. Come on, that’s ridiculous!
    Paint: Not a real big deal here but I have gotten quite a few paint chips on the front end. This seems like a relatively easy fix for SOA.
    MPG: For a 4-banger, my mileage has not been up to par. I have gotten mileage ranging from a high of 24.4 mpg (mostly highway) to a low of 17.8 mpg (mostly city on winter blend gas). The average tankfull mpg over the past year has been 20.4 mpg. Not terrible mileage, but not quite what I was hoping to achieve.
    Conclusions: Both my wife and I really like this car. I know that I have mentioned a few Cons but none of these would prevent me from doing it all over again. As a matter-of-fact, my wife is so impressed with the OB and AWD, in particular, that we just bought a Forester for her. This has really been the first time that she has expressed a strong interest in a particular car. I know that the H-4 gets knocked sometimes for being underpowered, but truthfully I really do not have a problem with it. Even with the 4EAT, I feel it has plenty of punch for merging onto highways and other maneuvers.
  • cptpltcptplt Member Posts: 1,075
    I've heard of body shops not ordering parts till you bring the car in, after all they don't want to be stuck with a complete fender and bumper if you write it off before your scheduled appointment but little bits of the trim???? You need to find a new dealer!
  • mrk610mrk610 Member Posts: 378
    Wht was the problem with your front strut. I have a 2002 OB and i get a clunking sound from the front when I accelerate . Could this be the problem . thankyou in advance .
  • fibber2fibber2 Member Posts: 3,786
    Hi folks,
    I have been lurking on and off for a few months to see what people thought of their vehicles, and it is now time to join in and post....
    MOTIVATION:
    I began looking at Legacys and Outbacks last Spring ('01 models), but decided to
    soldier on with my aging '93 Toyota Corolla wagon due to concerns about the sagging economy.
    Then came Sept 11, and the subsequent call by our President to spend money to save the American way. While no great fan of Mr. Bush, he is right that fear and reservation feeds our
    enemies. That next weekend we resumed the hunt for new wheels. Tried out a Highlander, Legacy L and Outback.
    OPINION:
    Highlander - Another great Toyota, but way too expensive for the package
    Legacy L - A bit too basic. Nice riding, but uncomfortable drivers (not power) position
    Outback wagon - Power seat, better headlights, limited slip diff, Just Right for not much additional money!
    THE DEAL:
    We came away with a '02 Outback wagon (base model) with automatic, cargo net and bumper cover for $22,350 (sticker $24,339, invoice $22,100). At the last minute we added the overpriced CD player for $400. We could have saved about $125 if we took a blue wagon with factory installed CD, but wanted a dark green car. The service dept wanted pretty much full retail to order and install the player. They offered $3500 for the Corolla (equivalent to about $3750 with the sales tax credit on trades in NY). We could have made a few hundred more by selling it privately, but as I found out a few years ago, sometimes it is not worth the time and hassle. The low cost Subaru/Chase 5.5% / 60 month financing cinched the sale. Overall, a decent deal. I got a slightly better selling price for a nearly identical OB from a dealer in nearby CT, but decided to keep the money in my community. With everything that is going on now, this maybe isn't the time to fight for the last dime....
    Never owned a Subaru before, but have a sometimes rough wintertime commute over (occasionally) unplowed farm roads in Dutchess County, NY. The Corolla was a good winter car, but with insufficient ground clearance. I have high hopes for the OB!!!!
    A FEW QUESTIONS:
    Has anyone ordered and installed the trailer hitch kit (L1010LS001) or the security system (H7110LS100) themselves? How good are the instructions? Everything included? Any drilling, welding or cutting into wiring harnesses required? I am a good backyard mechanic, but don't want to butcher anything. Any help or pointers are appreciated!
    Steve H.
  • scubadvrscubadvr Member Posts: 13
    Once again, thanks to all that have answered my questions in previous posts. I wanted to take the time to relay my own shopping experience for my new Subaru, but due to circumstances, have not been able to do so until now.
    I had a wonderful shopping experience. This was my first time shopping for a new car, and I followed a procedure that is recommended on the site motleyfool.com. Basically, it involves shopping dealers located within 100 miles by fax. I was curious as to how this method of shopping would 'work', and from my experience, it was great. I shopped ten dealers (fleet/sales managers), received quotes from six, and then allowed the dealers to bid against each other. After two dealers came back a second time to beat the original lowest bid, the original lowest bidder was offered a chance to then sell the car if they could beat the new lowest bid. No deal. I then went back to the second place bidder, who out of the ten dealers was the only salesman I was dealing with, and he again beat the lowest bid. The bid I received was this... $26,615 for a 2001 LL Bean with Subwoofer/Amp, Rough Road group and trailer hitch. Also included was the cargo net. I chose, and it was no problem to do so, to opt for the Subaru financing in lieu of the $750 dealer cash. The price I paid was $27,365, not including tax and fees.
    BTW, the reason I was faxing the salesman at this particular dealership was because my experience with him during a previous visit was extremely positive. He was very pleasant, informative, and not at all pushy. He actually had a prior engagement the night that I took delivery of the Bean, but I had just as good experience with the salesman who took care of the delivery of the vehicle. For those of you in So Cal, check out Dennis, or Mike, at Timmons Subaru.
    I have pictures posted of the new Bean. As an afterthought, and in reply to a previous posting, I also have pictures of the interior and the Weathertech floor mats that I purchased. Thoughts on the mats... the Subaru rubber mats are fitted exactly for the odd dimensions of the floor and because of that, in my opinion, have a cleaner look then the Weathertechs. But because the Weathertechs are not a perfect fit, they are larger and cover more of the area. Though not as form fitting as the Subaru mats, I would make the decision again to purchase the Weathertechs because of their size, depth and ability to protect the carpet.
    Check the pics out here, http://home.earthlink.net/~colinis/outback/.
    And my thoughts regarding the Bean itself, I absolutely love it. I am stopping by the dealer tomorrow morning, though, as I've had a 'check engine' light on for the last two days.
    Thanks to all,
    Colin
    The problem with my right front strut manifested itself as more of a tinny rattle when going over medium to hard bumps. At first I thought it was the heat shield had come loose based upon the sound. It definitely did not clunk.
    Well, it appears that the tinny rattle is starting to come back gradually, so it may be back to the dealer soon.
    If you are experiencing a front end clunk when moving at slow speed over small bumps, I believe that it is considered "normal". I recall someone posting info on this quite a while ago.
    Perhaps someone can chime in if they remember?
    Ron
  • megawatt1megawatt1 Member Posts: 16
    see posts 1704 and 1725 in Subaru Crew - General Maintenance & Repair II
    -Ralph
    Congrats to Steve and Colin (nice Bean!).
    -juice
    That's the steering rack noise I was referring to.
  • 99gs99gs Member Posts: 109
    I had a bad time with the oe trailer hitch. Ended up returning it for a refund. The instructions ask you to cut the bumper facia and make 1.5" holes at other points. The part number lines up with the one on your post. Not quite sure what the problem is. I had a Draw-tite hitch installed complete for $190. It is well designed as it is well concealed. Jack
    Wow, nothing like the OE hitch for my Forester. That was a bolt-on operation, really a piece of cake compared to yours.
    That's why it's great to have this Town Hall. Now we know.
    -juice
  • akgakg Member Posts: 85
    I know this is random, but I need a little feedback, please. I currently drive a '90 Legacy wagon with 151K.....the car that will not die! I am really due for another and want to go to an automatic after many years with a 5spd. My husband is really wanting to get an Outback. My questions are: Do they really get 22-27mpg? My Subaru averages about 22 period. They also seem so much smaller to me than my '90 wagon....Do any of you find them too squishy?
    I was interested in the Highlander, but the price on them is way out of my range. My real fantasy is a Doublecab Toyota Tacoma 4x4, but they seem to get around 19mpg average. How about a good pep talk? Thanks!!!
  • erics6erics6 Member Posts: 684
    The OE hitch on the 00 and newer Outback's do not require cutting the bumper facia. The 99 and older Subaru's require a cut in the bumper. I seem to remember the dealer installation price was higher for the older version with the additional work involved.
    Ascha: you answered your own question, in my opinion. 151k miles and still going strong? I'd buy another in a heart beat.
    My 5 speed Forester averages 25mpg, but it's a manual. A slightly heavier auto Outback with the same engine would probably get about 23-24mpg on average.
    In terms of size, they've actually grown a bit. The 2000 got wider, which you can tell if you have 3 across in the rear seat.
    Look at the Legacy L, Outback, and Legacy GT. I'm sure you'll find something you'll like.
    -juice
  • jay_24jay_24 Member Posts: 536
    Ascha,
    I normally get 26 to 28 mpg with my 2001 OB. However I do almost entirely interstate driving. When adding in a bit more stop-and-go, it drops down to the 25 or 26 range. If I ever did all in-town 20 to 22 would probably be the low end.
    Size wise, its great. I'm 6' 4" and it has the leg room for me and enough in the back seat for the kids in car seats. Also has enough room for a weekend trip for 4 to the in-laws.
    We are even thinking of trading the mini-van for another subaru.
    --jay
    Thanks for the input! Further on the random path.......I wish they made a gold Outback(works great with dust), but the wintergreen and pearlized white-cream are my only dust-camo choices. Which one is the most prefered by drivers and which would have the higher resale value?
  • ffsteveffsteve Member Posts: 243
    Akg,
    I choose the white for my Bean. Although it is actually an off-white pearly kind of color, it is the first white car I owned. I used to have a "gold" car that hid dirt very well, but find the Outback white to do just as good a job in that regard. In fact, it surprises me to see the amount of dirt that washes off when I do get around to washing it!
    Steve
  • nygregnygreg Member Posts: 1,936
    on your new OBs. Hey Steve, I'm a neighbor - Putnam County. Wanted to buy from Smith Cairns but they didn't have what I wanted, at least they didn't return my call. Anyway, wound up buying at Colonial. Lots of luck both of you.
    Greg
  • miksmimiksmi Member Posts: 1,246
    Hi Ascha,
    My wife and I had a 91 Legacy L wagon, 5sp manual, Front Wheel Drive that we sold to our next door neighbor at 61,000mi. We replaced it with a 00 Legacy GT wagon, 5sp manual, AWD. My wife commutes (urban), gets 20mpg. I drive on vacations (highway), get 27-30mpg. We prefer manual over auto transmissions but it's really a personal preference. A manual transmission isn't practical in heavy urban traffic or for those with painful joint disease (knee arthritis). I didn't care for the downshifting of the 00 auto; others don't mind. Try driving in a hilly area to see if it bothers you.
    Also on the test drive, compare the suspension of the L, GT, and Outback; the GT is a little stiffer and I'm glad my wife convinced me to go with the GT (though for other reasons like fabric).
    The 02 cockpit might seem smaller than the 90 because the dash curves toward the driver for easier access to AC and radio controls. Measure the distance between the rear wheel wells; you'll find the 02 wider due to a multi-link suspension instead of the 90's struts. Another thing you'll notice is the steering wheel only tilts; the 90 tilts and telescopes (oh, well). Our 00 is quieter than the 91.
    Feel free to ask other questions.
    ..Mike in MD
    ..Mike
    is actually here: rangerron7 Sep 25, 2001 1:42pm
    (due to a bug in the Emunds software).
    ..Mike
    ..Mike
  • anibalbanibalb Member Posts: 193
    Congrats to the new owners. You guys are getting great prices. Almost feel like buying another one myself. Enjoy them.
  • sb69coupesb69coupe Member Posts: 21
    Hi Folks, I've posted here before as I was looking at Outbacks for purchase. I rented one for 2 weeks on business/vacation with the family and that sealed the deal. I determined that I wanted a 2002 LL Bean in Regatta Red, with the L06 premium sound pkg (6 disc CD and subwoofer). Fitzgerald agreed to order it at $27,792 ($100 over invoice). I took that deal to my local dealer and they matched the price. Of course, they added on a $179 doc fee, but I balked so we split the difference. So, for $27,882 I placed my order for the car with the color and options that I wanted. I get it locally instead of traveling 300 miles, and everyone is happy.
    Then last night my wife got t-boned in our 2000 Honda Odyssey van. It's not drivable. That, coupled with a bit of buyers remorse, has left me thinking of just buying a Winestone 2001 LL Bean off the lot. That color is my second choice, but I really like the new Regatta Red much better. On the other hand, I could have the car today and probably save about $1200 in price. Hmmmm, what to do. Any opinions?
    Regardless, I'm firmly planted in the ranks of the Subaru fans.
    Shannon
  • mikenkmikenk Member Posts: 281
    I faced the same dilemma when we got our wintergreen VDC; we really wanted the winestone but couldn't find it. Now, after several months, I have really grown to like the wintergreen better. I think color grows on you moreso than an absence of features.
    Just my opinion.
    Mike
  • drcdrcdrcdrc Member Posts: 5
    Hey all,
    I've been shopping around lately for an all wheel drive 4 door sedan and the Outback Limited H6. I know most of the Outbacks are wagons but I really like the uniqueness of the 4 door, I definitely don't see as many on the road. I'm just looking for feedback on the car to see how everyone likes them, and also to find a good dealer in my area. I live in Southwestern CT not far from the Westchester County NY line. I'm willing to travel within the area for the right dealership experience. I test drove the '01 Outback Limited 4 cylinder and while I liked it, I think I'd like the smoothness of a 6 cylinder better. Anyway, any feedback in general would be appreciated. Thanks...
  • oclvframeoclvframe Member Posts: 121
    Shannon,
    I know that once you are without a car, you feel the pressure to hold out or just buy...I am very happy with my 01 bean, but at the time I bought it, neither the WRX or the redesinged Odyssey were available. I could not have waited that long anyway, but, your preferred color vehicle should not take that long to get. Given those choices today, I am not sure I would have bought what I did, but, as it is, I am very happy. Besides liking the color better, another good reason to wait on the 02 is the redesigned console.
    Is there a chance you have a rental car coverage during the repairs or replacement of the Odyssey?
    BTW, my other car is a 99 MB Odyssey. Have you been over to www.odyclub.com? If not, you ought to check it out!
    -r
    Daniel,
    I drove an H6 VDC recently and liked it alot. I have a Bean wagon, so I had a good comparison. I felt the sedan was a little stiffer and with the shorter wheel base, it felt more nimble around twisty roads. I also think it got up and went better due to the slightly lower weight.
    I think if you went with the sedan you would definately have a unique vehicle and would enjoy it very much. I would not trade my wagon since that was specifically what I was looking for, but the sedan sure was nice.
    -r
    Is it true that you can get the H6 in Non-LL Bean and Non-VDC trim? Trying to settle a bet here.
    -mike
    I've pretty well decided to wait for the order, rather than taking the 2001 off the lot. I don't think that I'd be as happy long-term with the Winestone. I keep cars a LONG time. I'm currently driving a 1989 Nissan 240SX that I bought new. Even though it's just getting broken in :) I need something larger.
    The insurance company is paying for a rental while the van is repaired. Then comes the hassle of dealing with the repair, diminished value, etc......
    Shannon
    Daniel,
    -r
    I believe you can get an 02 limited sedan with the H6. You need to spring for the 02 Bean or VDC if you want the H6 in wagon form.
    Shannon - I hope your wife and any passengers (kids?) where not injured. Having said that, don't settle. If you really want the 02, it's best to wait if you can.
    Side question - is there a new blue for 02? I see the advertisements on the tube and it appears the blue is lighter....or am I getting too old.
    Greg
  • rthompson20rthompson20 Member Posts: 2
    Can anyone give me their experience with towing with the new V6 Outback Wagons? I am considering buying one but have a 2000lb boat.
    2000lb boat should be cake. the boat is aerodynamic, and the H6 is more than capable.
    -mike
    Sorry to hear about your wife's accident; hope everyone's ok.
    Winestone was discontinued in 01; perhaps it will be more unique. OTOH, when you sell it, the color might look dated. Manufacturers follow the finicky trends of the consumer; there's a reason Subaru dropped maroon. Winestone might be less desirable when you sell it.
    Regarding 01 vs. 02, consider the value of the car if you had to sell it today. To a buyer, an 01 will be worth less than a 02, even if never driven. In my mind, the 01 has already depreciated. More than $1,200? I don't know.
    ..Mike in MD
    ..Mike
  • otis123otis123 Member Posts: 439
    Try Curry Subaru in Yorktown Heights, NY. I bought my 2001 LLBean from Pete Acton in Feb. He was an excellent salesman and is a NYC fireman...
    Shannon: 2002s have other differences besides the color. Cup holders, built-in antennae, intermittend wipers now variable, more wood, no more Firestone tires, and a lit ignition switch are others. All that plus better resale vs. $1200 up front - I could see going either way.
    BTW, not V6, H6. The cylinders are laid out in a horizontally opposed fasion. Then again, you could look at it as a 180 degree vee. :-)
    Daniel: my wife really likes the sedans. If they were available in H6/5 speed we'd strongly consider one.
    paisan: the H6 sedan comes in a non-LL Bean "base" model and then a VDC.
    -juice
  • wrobelcwrobelc Member Posts: 45
    Has anyone used speed bleeders? I'd like to install these on my 2000 Legacy L wagon and wanted to know if anyone knows the size needed. You can get more info on these at http://www.speedbleeder.com/
    chuck
