Visitor Agreement.
-juice
I'm intrigued by that 1lb difference F/R.
I guess they are trying to get the rolling diameter of the tires identical. Since a little more weight is on the front tires (unloaded), that would make sense.
Personally, I find those pressures too low, and prefer about 32psi all around.
-juice
The only reason I ask is the issue that Craig raised regarding the psi difference between front and back.
Ron
Honestly I don't think 1 psi makes enough of a difference to even matter.
-juice
I think this is a good question for Patti to answer. So how about it, Patti: why the 1 psi difference?
OK now onto my OCD's anonymous confession. I did something terrible to my Bean this morning, and it's all the fault of OCD. I won't mention the details in order to avoid aggravating any potential ulcers, but let's just say it involved a crooked piece of trim. I fixed it real good -- now the trim is crooked with scratches and dents!!
I think I need to have a beer at lunch today. It's a good thing I am not designing commercial aircraft anymore . . . .
Craig
Incidentally, my dealership fills my tires up to their MAX pressures everytime I bring it in for service -- retards. I bring it to their attention every time, but they clearly don't get it. So much for the "professionals." 43psi -- good god.
-mike
Greg
Can tires be sufficiently different in pressure to approach the magic quarter-inch tolerance mark?
Found a cut on the sidewall on one of my summer skins - dealer replaced it no charge, and since the other three just went on in August, I doubt there's enough tread gone to bump up against the dreaded circumference difference limit.
Cheers!
Paul
mike k
-juice
-juice
Also installed the rear gate bar (exterior grab handle). Fairly simple also, 2 holes to drill through the rear hatch and the hatch liner needs to be removed. The template supplied was off by about 1/2 inch. Double check before taking drill to new car!
Eric
Question: was the rivet you removed limiting rearward travel? If so, does it have another one to stop it, or could the seat roll all the way back and off the track?
I modified my Miata's seat track by putting spacers under the front to raise the front of the seat for more thigh support. The Subie seats are different, though, because the front anchor appears to be at an angle, so it would be hard to raise the seats at all.
-juice
This isn't even for me, but I'm sure there will be countless others that will thank us both.
-juice
Do the rails bolt onto the seat? Did you just move the rails forward on the seat and re-mount them?
Craig
Also, anyone ever installed one of those plastic hood deflectors? I'm planning on getting one, and just want some feedback on whether it's worth it, and whether it's easy to install if I order from Subaruparts.com.
Thanks all and have a good day!
Mike
Patti
Patti: thanks for the opinion on tire pressure. I have some lecture notes somewhere on tire design, and will dig them out to see if 1psi would even matter from a technical side. That will satisfy my rocket scientist tendencies. If the 1 psi difference really doesn't matter, Subaru should take it out of the specs!
Pete: I put a hood deflector on my first Outback, and have been pretty happy with it. Beware -- the first deflector I got (from a Subaru dealer) was not the official Subaru deflector, it was an aftermarket unit. Apparently Subaru deflectors were scarce for a while, and some of the dealers started selling the aftermarket units. Long story short, the aftermarket deflector was junk, and came loose while I was driving. The dealer exchanged it for the "real" thing, and that one is much nicer and more secure. Installs easier too. Make sure you get the real one, which has a small silver "Subaru" logo near the upper driver's side corner of the grille.
Craig
-juice
Checked?.... NOT
-Dave
Eric
great car - I'd be sold on one if i didn't already own one (only one set of payments allowed at any time).
-steve-V
-mike
My 1998 hasn't had any bulbs blow at all.
-juice
It looks like you have to replace the switch if the indicator light quits working.
Cheers Pat.
If you are having multiple bulbs go in a short period of time, there may be an issue with voltage regulation rather than the bulbs. Get it looked at by your dealers auto electrical specialist.
Cheers
Graham
I have a 2K OB wagon purchased in March 2000 and had metallic tint film installed on the "back five" windows a week later. Absolutely no effect on radio reception, and a signficant improvement in both privacy and heat resistance during summer weather. Film has held up fine so far. I could see if you had a rambunctious pet that you carried around in back the film might take a beating - but other that that, no problem. Go for it!
Ken in Seattle
mike k
5/8" thick barstock. Drilled one hole and tapped the other. Needed slightly longer bolts for the
bottom hole. The thickness is needed to compensate for the gap created when lifting the seat. I can give more specifics if anyone is interested.
GAM2
I live in tidewater VA where it gets pretty damn hot in the summer (95+ on a regular basis). My Outback doesn't get any hotter than any other car I have owned, and in fact it seems cooler than I expected. Certainly much cooler than my wife's black Mazda 626 (my Outback is dark green).
One thing that helps is the light interior. No matter how much radiation gets through the windows, the lighter the interior, the less of that radiation will be absorbed by the car as heat. If you have a real light interior, the exterior color of the car probably is a bigger issue than window tinting (though tinting will still be beneficial).
I do think aftermarket tinting would be good to have (and I may get it done one of these days), but the factory tinting seems reasonably effective to me. Then again, I have never owned a car that stayed cool in the summer, so maybe I am missing something!
Craig
Both sets of steel wheels which I bought from Tirerack (for two 92 legacies and a Venture) as well as original Ford steel wheels I had for a minivan are all in a pretty sorry state after anywhere from 2-10 seasons. On the other hand alloys I have for my 98 GTs snowtires (actually they are Outback alloys) are great after 4 seasons while alloys from an older legacy LS which I haven't usually changed tires on in winter are still doing quite well despite some 5-6 winters and 10 years.
Did I just get real cheap steel wheels?? I can understand the Tirerack ones for the Legacies/Venture may have been less than OEM standard but for my Windstar when I got the snowtires there were no alternative wheel suppliers and I had to buy a Ford wheel (which actually is the standard steel wheel from a Taurus but sold as the optional full spare steel wheel if you buy a Windstar but you pay a cheaper price if you order it from the Taurus parts numbers and not the Windstar!! - go figure that one!). I don't wax them like some of you folks but it seems my alloys are doing a whole lot better in the snow and salt!
Re Window Tint: Florida is probably one of the states where aftermarket tint film is on most cars. I had a 2001 OB Limited (with the antenna in the rear window) and had Titanium tint installed. No effect on radio reception. Re cost for Titanium tint (supposedly the best quality) for 7 windows and both sunroofs, I believe we paid $160 (dealer cost). On my regular OB, with 7 windows only, I think he charged me $100. Again, this was our cost, and this guy did about 3 cars a week for me. I think though you should expect to pay about that. The one thing you want to look into is the quality and warranty. I have had customers return to me when they did not tint through me and chose a "cheaper alternative" and wanted my guy to "redo" their tint. DEFINITELY tint though, it keeps the car a lot cooler when parked in the summer, and doesn't make the AC work as hard.
Lots of info- hope it helps.
Pete.
I agree that the factory tinting on the OB wagons is pretty decent - but I was used to the "privacy glass" tinting commonly found on minivans and SUVs - which undoubtedly helps with heat, but also has nice cosmetic and "security" features. I didn't bother with the sunroofs (since you can close them off), but have really enjoyed the "back five" tint job. There's so much glass area on the wagon that I felt like I was driving in a fishbowl until I had the windows tinted. I've never regretted the decision.
Here in Seattle (which, admittedly, is not a place where concern about hot sunshine is prevalent), I paid $199 plus tax for the "top of the line" metallic film, 38% transmittance, with a lifetime (for my ownership of the vehicle) guarantee - a guarantee more expansive than for the lesser films. I'm sure that you could beat that price in regions less pricey than Seattle. Took them a couple of hours, and, as I've mentioned, it's been perfect for about 20 months now.
I say go for it!
Merry Christmas from Ken in Seattle
This is a metallic film with a lifetime warranty, cost here in Ottawa was $250 Canadian.
I would also highly recommend tint both from a heat and privacy issue.
Cheers Pat.
For some people who break into cars - tinting often goes with better stereos, more value of contents inside, etc.
Limited visibility looking inwards does affect visibility looking outwards to some degree. If you live in the mountains, where it is dark at night (very few street lights), and/or park in parking garages, it is very hard to see what is behind you in a car that is already hard to see backing up.
I don't know any statistics but I would imagine that any vehicles that you cannot see through have more close calls with rear-ending, given the way society likes to follow too closely at any given speed.
-steve-V
Happy (post) solstice and days of the yule.
Steve you may be right about visibility & appeal to thieves, but I feel that risk is so minor it's hardly worth thinking about (my opinion, of course).
Starting my tint fund savings now.
Jillian
--'rocco
I want to put a new deck in the dashboard, too, but until the dollars are available, the best advice I've gotten so far is that the speaker upgrade is the most economical way to make the current stereo sound better.
Cheers!
Paul
