Visitor Agreement.
How's things with your van? So far I am impressed by the lack of any mechanical defects in my Savana. Usually within the first 2 weeks of delivery I can hear or feel that something is not right and in need of repair. I doubt Toyota can match it (my other vehicles always had a few mechanical defects on delivery). Of course now that I mentioned it the whole vehicle will likely become unglued by tomorrow....LOL.
Love the seats, good support and they don't wobble in their tracks (when stopping and going) like I noticed with the 2001 Rams....hate that!
Good luck!
I just finished installing a cargo area floor tray. The company I buy from (Husky), did not make one "Econoline specific", so I purchased the new '00 Suburban version and trimmed it a little on the back side (it was 4" longer than I needed, but the width was perfect). Then I "tucked" the cut edge under the regular carpet trim piece and it looks like it was sold that way! Now my carpet in the cargo area is protected from the dogs, dirt, oil, kids, etc.
Have you figured out an easy way to wax the top of your van yet? I am leaning towards the "Nu-Finish" product just for use on the top. It is supposed to last almost a year (with 2 coats).
I have already waxed my van 3 times and only have 1600 miles on it. Boy does the water bead....lol
I know we discussed using synthetic oil, but what are your feelings on the synthetic transmission fluid from Mobile ?
Hope your enjoying your new toy...
I think the idea of synthetic oils for the tranny is a good one. The worse enemy for a tranny is heat, and regular oils break down quicker under heat. So if your towing I think it is especially good. More important though is not the type of oil used, but rather frequency of oil changes. Lot of people still believe you do not need to change tranny oil, and will drive it for the life of the vehicle without a tranny oil change. Guess that is why we have as many tranny shops as donut shops in my area. Change your oil at least somewhere in the 15-25,000 mile range, whatever you prefer (including filter). Likely with synthetic oil having reduced friction properties and having it in both the tranny and engine should improve mileage a bit I would think. I myself doubt I will use either since I have been able to get enough engine/tranny life on regular oil for the vehicles I have owned. I don't think oil alone will make a big difference in life of a vehicle (some but not a lot). More important issues in extending the life of a vehicle I have found are doing things like adjusting valves, timing to avoid pre-ignition (older engines), and correcting any pinging noises, bad hesitation problems,etc which produces a lot of stress and wear on an engine. My point is making sure the mechanical stuff is working right is more important then just the type of oil (although it is essential to have good oil and keep it full).
If you think you need to worry about oil think again, worry more about your gas. I was regularly going to Sunoca for my gas in my neighbourhood and coulnd't figure why I was always having a hesitation problem (didn't believe water could be the only cause). Finally I started seeing blue smoke coming out of my rear, and thought I needed another engine. Well, my friend brought his motorcycle in to the same place and on leaving noticed the same problem. SO I switched stations and the hesitation went away, and so did the blue smoke. In other words there was water, and that water I think likely caused enough rusting in the combustion chamber to cause a ring to stick and so it never was sealing right. Well, changing to another gas company with dry fuel helped that ring unseize and things returned to normal. The change was fast and obvious.
My point is worry less about the oil you use and more about the mechanical aspect. If the suspension has a unusual noise then fix it before it gets worse (eg- a bad ball joint will eventually put more stress and wear on other suspension components). If the engine hesitates badly, then fix it promptly before this added stress reduces rapidly the life of other engine components (rings, etc). Flush your cooling system yourself more frequently before you have a failing radiator or heater core from calcification(up to $1000 to replace if you want heat...lucky I did myself). So I feel any oil will do, but it will not replace taking care of the vehicle if you want to really extend it's life (mechanically and body if you oil it). By the way, I always add ONLY DISTILLED WATER to my coolant, the less calcification occuring inside the engine block, the better the transfer of heat away from the the engine block to the coolant to the radiator fan and to the air. The calcification on the block walls acts like insulation and the transfer of heat is reduced. It sure extends the life of the accessory components around the engine (like rad and heater core).
Well, thats my 2 cents worth on how to extend the life of Vguards full size passeneger van and mine which were not cheap to buy (LOL). Since they do not go through frequent model changes, it would be nice to extend the life of our vehicles....and worrying about type of oil used won't make a big difference how it will look or run 10 years from now.
Yup, sure am enjoying that new toy Vguard. Love the added space with the extended model. I liked what one friend of mine called it.....The U.S.S Savana , like a ship!
Considering the tight space under the hood of a full size van, adding all the a/c lines will be labour intensive and costly. It's one thing to add it at the factory, quite another to do it later on. I tried adding air to my tercel many years ago, and got nailed by a lack of a wiring harness and a vacuum bracket (hard to find). This is one option you want from the factory, not later as a add on. I doubt there are after market units for the rear either (front yes), and I hear they are never as good. Ask the dealer, bet he says forget it. If it's a cargo van, adding the rear unit may be a bit easier (no vent problems), but all the other problems still exist.
The option of adding a roof a/c unit would be a LOT easier because it is entirely self contained. I have talked to RV dealers before and they all said back then that all Coleman and other brands run off electricity only. HOwever in my research I had found a company that allowed their unit to run off electricity OR propane. Can't remember the brand name, but it sure would make life a lot easier.
Good luck!
First I went to Pep Boys and bought seven small 13-3/4 by 16-1/4 inch generic black rubber floor mats that have carpet rippers on the bottom. I think they were 3.99 each. I placed two on the driver's floor, two on the front passenger's floor, one each between the front and 2nd row bucket seats, and the seventh adjacent to the 3rd row bench seat at the entry way. There was no cutting involved. They are pliable enough to arrange them in front on the floor and up where your feet rest.
For the 2nd and 3rd row seats floors, I went to Home Depot and bought four charcoal Apache Mills brand "Gatekeeper" 18 by 27 inch carpeted rubber door mats, #76-080-7003. They also have carpet rippers on the bottom. They are an exact fit and no cutting is involved. They cost 9.95 each.
For the rear cargo area, also at Home Depot, I bought 4 lineal feet of charcoal Apache Mills "Scrape & Fri" commercial carpeted vinyl backed runner, SKI #357-140, from a 4-foot-wide roll. It costs 5.69 per LF. It does not have carpet rippers.
I have about 95% coverage, it looks very professional, and suits my needs exactly. It may not work for muddy off-road users. However, everything can be taken out, washed and dried.
Anyone had experince with these? Safe? Robust? I know that some telescop and swing out of the way of the rear doors. Does it really work? Your help is much appreciated for our trip across the USA!!
THanks and happy trails.
vivhoward "Full-size conversion vans" Jun 7, 2001 12:30pm
Drew
A photo of it should be sent in to the manufacturer, and another placed in here. Maybe then they will start manufacturing quality vehicles.
In my younger days when I was a paramedic, I saw two vans that had rolled: another ambulance and a hightop conversion van. Both hightops survived the rolling, but, admittedly, and ambulance top is much more reinforced than a cheapo conversion. I guess those were mounted better than this guys "Quality" conversion top.
Still don't like hightops, much though. Higher cost, less safe, real ugly.
Interesting information though on break-in from the GMC manuals I bought from the dealer (about 8 inches high....yikes) for the Savana. From the Shop Manual>>
OIL CONSUMPTION DIAGNOSIS:
"Excessive oil consumption (not due to leaks)
is the use of 1 liter (1 quart) of engine oil
within 2000 miles. However, during initial
engine break-in periods (3000-4000 miles), oil
consupmtion may exceed 1 liter or more."
Souce: GMC 2001 Savana/Express Shop Manual, Book
1 of 3, Chapter 6, pg 365.
So comments like "what break-in"?, and 700 miles per quart is "normal" is incorrect, at least with the GMC full size vans. If you got a problem, I think purchasing a manual to confirm things is in order. This can be useful in court if your unfortunate enough to get a bad vehicle.
I have one problem developing (rotational type grind) when I make left and right turns. So far too infrequent to be able to diagnose it, even the dealer was not lucky to reproduce it. So I will wait till it fails a little more or falls off...LOL! I don't expect a perfect vehicle, just a good tranny/engine....the rest are no big deal to fix.
I packed it with two Trojan 105 true deep cell Golf Cart batteries, TV/VCR, Coleman fridge, and some other toys. I got enough juice to last me about 7-9 nights camping in my steel leakproof tent(3-4 hours per night of TV viewing). So it will be great on short/med photo trips. Later I will be doing more extensive work adding more goodies to the rear space. That 12 feet of rear space is going fast (2500 extended), might just want a trailer soon or a "add a trunk" supported by the trailer hitch. LOL! A travel trailer would be nice, but then how do you tow a boat?
Hey, how is your oil consumption? Wheels not falling off, eh? Just kiddin! Also how is your gas mileage?
So far I took the average over several tanks of gas and computed an average of 17 miles per gallon (Cdn) averaging city and hiway on the 5.7L engine, 3.73 axle. That computes to about 15mpg US, which is about what I expected. From all my readings most averaged 17 mpg (US gal) on hiway.
After break in I expect 20 mpg CDN(hiway),and the window sticker had said 22 mpg CDN.....so I am satisfied there are no major problems. One person in here was getting 13 mpg US for hiway driving! I feel fortunate.
Well, See yu soon, I'm off on a 2 week trip, and will see how it holds up. The rear air sure is NICE!~
http://www.edmunds.com/reviews/roadtests/spin/46527/article.html
Enjoy!
Drew
I am in love in driving along American side roads since 98 when I did Seattle - San Diego - Seattle trip. Over 6000 miles and no more than 10% of it on highways. Big country with big cars and looooong roads... For an European with an explorers soul it is like playing Columbus. My wife loves to travel around with me so having our own bedroom on wheels will cut down our hotel bills.
After checking and seeing many (~20)used converted vans in our price range I am ready to buy 1991 Ford E150 conversion van with 91000 miles on it. Price: $4900. I checked Carfax record - clean, two previous owners, I had 30 miles test drive, I had it checked by independent mechanic and it is the best looking and driving vehicle from all I have seen.
It is white (what I wanted, does not overheat in the sun).
It is a high top conversion (wanted it too we are both quite tall).
It has a big V8 351 engine - I believe it is longer lasting than small V6.
It has a rear A/C, TV/VCR, Captain chairs, power bed, locks, windows and very clean interior.
It has almost no exterior rust.
It has wide alloy wheels with wide "sporty" tires - I don't like that.
It has almost brand new looking brake system - including drums, and front discs.
Exhaust system looks very good.
The water pump looks almost new - nice and shiny.
Shocks are still good and not leaking but they may be still original ones.
The only points I found suspicious - a small leak from the rear end shaft seal at the differential and corroded oil pan (a future danger) are just being corrected by the dealer at his cost.
THE BIG QUESTION to Experienced FSV users : is it a sound deal? What I had overlooked? This is my first car purchase in US... I read most of the posts in this message board and I don't think that there is any BIG difference between main 3 van producers... It is like a discussion between Volvo, Mercedes and BMW users in Europe... they are all OK but appeal to different tastes.
I can sign a deal for Service contract with PWI www.warrantys.com 24month/30000 miles is extra $800 at the moment of purchase. It sounds to good to be true, almost like a new car warranty in "Plus" plan. Anybody here with experience hoe to interpret a clause " ...service contract does not cover repairs or replacements resulting from defects, damage or deterioration due to normal use, wear and tear..."
I am (like anybody else in the world) always afraid os small print clauses - on the other hand even a small repair in a van can be costly. Please advice me about purchasing the extra service contract.
I will be very obliged for any opinions. This is the only messageboard for full size vans I can find on the Web. There are many for trucks but vans seem to be less popular.
Voytec
$4,900 does not seem like a lot for a full-size van with 91k miles, if everything is presentable and in working order (like the rear a/c). I am guessing that the dealer was asking more; if not, he may come down. I don't think there is a lot of demand for a conversion van that is over 50k miles and, say, $3,000. I sold mine last year, and it was difficult.
If you and your mechanic like the vehicle, and the $800 service contract seems reasonable to you, go for it. It is always a bit of a risk buying a used vehicle, no way around that.
Good luck. Happy highway yachting.
ejp
I ended up with a Ford full-size van, and even then, I suspect it is only because I found a Ford dealer with one on the lot.
I am glad I ended up with the Ford however. I really enjoy the room it gives my family of 5.
Perhaps you should consider trading...
vguard
Also what is the proper octane rating for this vehicle. It has a v 8 engine, my friend drove it to I 95 to my home and filled the tank with 87 regular unleaded. On the highway the van showed hesitation and lack of power. His other friend said that this van needed a 93 premium gas. Is this true? Also when he bought it, there is no owner manual to refer to. So, does anyone know where to purchase an owner manual for this vehicle?? Please respond...
Change the air filter (dirty ones cause bucking and hesitation), then use Regular 87 octane. Could be all you need. A full tune-up never hurts (including new plug wires), either. Try it before you spend the extra .20/gal for Premium.
And I don't think any of the American 8-cylinder engines used timing belts - all chains (I think).
ejp
However, having said that, I still think extra weight is the answer for snow conditions (just as it is with a pickup).
The great thing about rear wheel drive is it's advantages when towing, but for ice and snow, nothing will ever beat a front wheel drive vehicle (in my opinion, anyway).
Of course, also keep in mind that for many years, people survived the snow with nothing but rear wheel drive vehicles, so it can be done.
vguard
I can't remember exactly where, but I do remember reading one post where the writer suggested using a "high performance" brake pad (vs Ford OEM).
The impression I got was the "high performance" brake pad is not as soft as the OEM version, which means less brake dust and longer life.
I will search for more specific information (since I will be in the same boat soon), and post what I find.
vguard
Despite all the attention paid a few months back to the roll over propensity of these big vans when fully loaded, I still believe it is safer to be in this vehicle than many others. The vehicle's stability and mass helped me stay in control of the vehicle, and avoid sliding over into opposing traffic, which would have been an unwanted test of my offset-impact survivability at about 70 - 80 mph (35 - 40 mph both directions). Had I been in a smaller vehicle, the impact would have probably easily pushed me into opposing traffic.
When I started my search for a new vehicle, my first stop was State Farms (my insurance provider) "25 safest vehicles" list, which included the Ford E-150.
vguard
Can anyone here recommend a big van (reliability is important, the band tours frequently). She needs something that can hold 5 or more people (so probably two benches) and lots of equipment. Is the Ford, Chevy and Dodge best? Anyone know which engines from these manufacturers are best? Thanks.
The conversion vans vary in size (length), and some have "Hi-Tops" that mean less stooping over (but don't fit in some parking garages). You could always take out the 3rd bench seat/bed if you want to make more room. Usually the first 2 rows of seats are captain's chairs, though, so that would only leave seating for 4. If you are handy, you might move the bench/bed to the middle position and have plenty of room behind for equipment.
I've had 4 full-sized vans (all Dodges, and I can recommend them), 3 of them work-type; the one conversion van I bought (with 131k miles on it!) worked out real well.
Good luck. Rock (?) on.
ejp
She doesn't want a conversion van because she has to install a 'loft' in the back, under which the band will lock and store their equipment (the band tours big cities like NY and Chicago, where break-ins are a fact of life). We looked at a 15 passenger extended van, which tend to be expensive and two of the four seats would get pitched. Now she's considering buying a cargo van and putting in one seat, which I think is goofy. The only advantage I can see to a cargo van is that they're cheap. I personally wouldn't want to ride in a vehicle with no insulation (sound or weather) for 1000 miles, and most of them don't have rear heat and lots of them don't have air at all. I've seen everything in the papers and on-line from higher mileage newer models to older ones with low miles. She's considering everything from 88s to as new as she can afford. Personally I'd rather have something newer (like after the body change in 92), well kept with a few more miles. So far here in Chicago, Fords tend to be far more numerous than Dodges or Chevys, and she's had good luck with Fords, but she's considering all brands. I just found a 94 Ford Club Wagon 7 passenger with 78k for $6500 negotiable, we may have a winner.......
ejp
As for my results here goes. I have the 2001 Savana 2500 extended van, 5.7L engine with 3.73 axle, andthe test is during the break in period (it returned with 4100 miles on it after 1800 miles of driving). Of the 1800 miles the first 1000 miles was flat driving and the remainder was a mix of city and mountain driving on hiways through New Hampshire. The results are (the entire time the A/C was on) based on a combined hiway and city average of 14.6 mpg (U.S) which is approximately 17 mpg Cdn.With A/C off I expect perhaps about 19-20mpg Cdn (and for the U.S. people the 17mpg average I read about for hiway driving is about right in my opinion). I drove with a light foot, averaging 55-65mph which perhaps explains the better then average mileage from what I expected. However, on the window sticker it did give the EPA rating of 22mpg Cdn.
This puppy has plenty of power, and you won't find it downshifting in the hills. The vehicle is extremely quite, rattle free and solid, and towing most things should be a breeze. My guess is the AWD drive effects gas mileage a bit in your case. For the huge space available, I am not complaining on my longer trips. I don't care about city mileage, since usually you don't travel very far anyways. On the open road it is nice to have all that room, easy access to the back for a beer (oops....did I say that...orange juice...just kiddin about the beer).
Good luck
I have 4200 miles on mine so far, and so far it looks like were both pleased with our vehicles (thumbsup). The reliability issue will be interesting in the future I bet. How is your gas mileage? Have you bumped any smaller vehicles to confirm our opinions regarding safety yet? (LOL). I hope not! LOL!
I have searched and searched for a "base" GMC or Chevy van, new, on dealer lots, but all I can find are commercial vans.
So I ordered one....
a Pewter Metallic base level w/1SB convenience package, 8 speaker sound system and Locking rear differential.
I still have yet to see one on the road -- I will be stand out with the base level headlights, grill, and *no white paint*!!
All kidding aside, I too disliked the conversion options on the dealer lots (not to mention the outrageous markup), so I got a 2001 GMC 3500 15 passenger (ext. wheelbase) SLE, locking diff, 8.1L, all the options I could chose (I had to order it through the dealer; I have some earlier posts regarding this van & my experiences). Then I went to El Kapitan and had them install a fiberglass "bubble top"(?) roof with a normal headliner (= no disco lights), giving about 5' 8" of room inside + I added a TV & VCR.
I am extremely happy with my van (and so are my kids) and even more so after post #584 above.
