-mike
So, anyone else had THIS sound?
Kim
-mike
Bob
Cheers!
Paul
I am hoping to take my first long road trip in my 2001 Outback for Thanksgiving this year. I think I might need to get a cargo carrier for the trip. Does anyone have any suggestions about which one to purchase? I do not want to exceed the weight limit.
Julie
-mike
My rack actually is quieter with the box!
They have lots of room, lock, are waterproof, aerodynamic, open from either side, and look very good.
Messages #313 and #327 on the Legacy/Outback Problems and Solution thread as well #5501 and #5514 of this thread seem to be talking about the same symptom.
My dealer says its normal but I didn't hear it in a "loaner" that I drove.
Has anyone with the "sound" been able to get rid of it? TO me , it sounds like friction that shouldn't be there that could eventually lead to a problem.
I'd appreciate your comments and help.
Mike k
Do I know better than the engineers? Nope. But I was one, and know of their constraints. When setting a spec, customer satisfaction and costs are often weighed against each other.
For example, a spec tolerance of +/- 10 units might result in a customer complaint rate of 5%, while a tolerance of +/- 5 units would have a comlaint rate of less than 1%, but cost the manufacturer $100,000 a year. Some decisions will go one way, some the other.
Heather
You're right about the WRX, its a little too small and ride is harsher. I almost couldn't get one as my better half said it had to fit our daughters cello and it was tight but it just made it! If you thought the stock 16 in wheels on the WRX were a little bumpy, don't ride in one with 17 in wheels! I think I could jar my tooth fillings loose over rail tracks now! WRX is definitely more sporty feel than a GT. When the engine loosens up and you get over 4K, boy does it go though! My GT is my daily commute car. My WRX my mid life crisis fun car! Congragulations, you will love your GT!
-mike
I put the Bean up on my 4-post lift and raised it up. Removing the access panel was easy enough, and changing the filter was a breeze. The drain plug is easily accessible but man, it was just about welded in there. The car is 7 months old and has 3700 miles on it. I took the time to wipe down any oil drips underneath and witnessed first-hand the sticky undercoating that is responsible for the "burning" smells we all got just after delivery. There was still some left on the transmission pan.
Anyway, just venting, since I'm sure I'd be fightin' a robot anyway.....
Bruce: I see the Legacy L as the bargain in the Subaru line up. You get the same engine from many pricier GT Ltd and OB Ltd models, all the space, the rigid chassis, the safety cage that aced IIHS tests, 4 disc brakes, AWD, and ABS. All the ice cream is there, and even some hot fudge, but not the sprinkles.
I paid $17.8k. That's actually less than a Camry, Altima, or Accord, similarly equipped and those are sedans with about 1/4 the cargo space and no AWD!
From a pure value stand point, in my humble opinion, the Legacy L makes the strongest argument in the entire Subaru lineup. Nothing can touch that price, not even close, with the same equipment. Nothing, there simply is no compeition. Well, maybe the Outback Sport. ;-)
Why aren't reviews glowing? Well, I love the Forester, but I'll admit it has easier competition. The Passat wagon is much nicer than a RAV4 or CR-V.
My Forester is lighter, more nimble and fun, spunky, trendy even. Our Legacy L is refined, quiet, and smooth. For personal use I'd still pick my Forester, but my wife prefers her Legacy by far.
Other comparisons? I'd pick the Forester for the city streets, the Legacy for the highway. The Forester if you have an empty nest, the Legacy if yours is full.
-juice
Mike,
Sad but true.
-mike
I've been lurking for a bit, but figured it was time to actually speak up now
that I've "joined the Subaru club". I know it sounds rather trite on this
board, but my path towards Subaru ownership was very similar to several
others': I spent 7+ months researching *every* available vehicle that fit
my requirements, including trying everything from the Hyundai through the
Mercedes M-class (I decided that for my new vehicle I would throw all my
bias out the window and start with a completely "clean slate"). The "finalists"
were the Subaru Outback, the VW Passat
4motion wagon, and the Volvo XC (the Audi Allroad would've been on the list
also, but since the price was so much higher than all the others I couldn't
justify it). Needless to say the Outback ended up winning, although the
decision was difficult.
I've always been a huge fan of German cars, especially VWs. In fact, I currently own
two VW Golf GTIs (a 2000 GLX that is my "toy" and a 1991 8V that is being
replaced by the Outback as my "daily vehicle"). Most of my friends were
astounded that I picked a Subaru over a VW. To be honest, the Passat was
a very nice vehicle, but I felt that the Outback was a better overall value (and
I knew I still had my GTI GLX to "play"
As for the which model of the Outback to get, that was actually the hardest
choice. I definitely wanted the H6 (wow, was a sweet power plant), so
that meant either the LL Bean or the VDC. At first I was leaning towards the
Bean, mainly due to the lower price. After several test drives between the Bean
and the VDC (especially in the snow, which we get a bunch of here in Western NY)
I fell in love with the VDC. Being one who enjoys the art of driving, the VDC also
had a better "feel" (likely due to the 45/55 rearward-bias torque split). Knowing that
the VDC had a "beefier" powertrain (e.g. the "torsen" differential) helped, and
of course the McIntosh audio system just blew me away. The only real downside-
as several others have mentioned- is the lack of a manual transmission (I haven't owned
an automatic since the mid-80s). However, I'm finding that I don't miss it as much as
I thought I might.
So, I ordered a 2002 Outback VDC wagon (Timberline Green- that truly is a sweet color)
with all the options I wanted, and the rest is history...
I would also like to mention the dealership I worked with- Van Bortel Subaru (in Victor, NY).
During my 7+ month research quest, I interacted with pretty much every different type of
dealership imaginable: everything from the "pushy-don't-bother-me" types all the way
through "I want to make this the best vehicle-buying experience you've ever had" type.
Van Bortel was *definitely* the latter- in fact they were absolutely the best dealer
I've ever visited! My first interaction with them went something like this:
[I'm climbing all over one of the Subarus on the lot]
"Hi, can I help you?"
"I'm just looking at the different models here."
"That's cool. I'll be inside- let me know if you have any questions. Here's a
license plate you can use for a test drive. All the vehicles have keys in them
already, so just slap this on the back of whatever you want to try, and bring the
plate back inside when you're done..."
Wow! They've really got a great overall philosophy. In a recent thread here, some
folks were talking about having routine oil changes done at a dealership- Van Bortel
offers $10 oil changes for the life of your vehicle! Although I traditionally have done
maintenance myself, it's hard to justify my time with such an offer (especially since
time seems to be more and more a precious commodity!). They told me that they want to
do business with customers again in the future, and so they expect to get the vehicles
back as trade-ins. If the cars are well-maintained, they hold a higher re-sale value,
so everyone wins long-term if they provide incentives to have you maintain your vehicle.
Combine their incredible attitude with the best price around and you've got a situation
where it's next to impossible to say "no". In short, I *highly* recommend them...
As a long-time VW owner, I've enjoyed the VW "community"; most VW owners are passionate
about their vehicles, and you don't often hear folks say "I stumbled onto a VW lot and
bought this car on a whim". Imagine my surprise when I found that Subaru owners
have quite the community of their own, with a similar passion! Not only did I get
a really cool machine, but I now have the opportunity to network with a new-found
group of fellow enthusiasts!
Anyway, I just wanted to say "Hi" and thank everyone for participating in this forum.
It's good to meet you all!
-- Geordie
The problem was there from DAY 1, I just didn't notice it until a couple of days after picking up the car. I'm wondering if SOA should be notified as this seems to be a problem with more than 1 or 2 cars. My advisor said that they have fixed another one with the same problem, Hmmmm?
Revka
Hatchbacks & Station Wagons Boards
As a former VW owner I can see how the decision process takes you to an Outback. I aslo had a lovely 91 GTi 8v which gave me immense pleasure. the blast you get from chucking a GTi over fast winding roads is somedthing you just can't replicate. However, the Outback is even more stable and dramatically more fun when things get slippery. Alos the brakes are better!
I had a VW Passat immediately before the Outback. Similar idea but different outcome. If I was back to continuous high speed freeway travel I would have the Passat. For the travellling I now do which can include sheep paddocks and other strange bits, the Outback is much better.
Look forward to hearing your views over time, particularly driven back to back with the Golfs
Cheers
Graham
As another satisfied Van Bortel customer, I second your comments about that dealership. Not only have I had a great buying experience there, but by service experience over the past 2 1/2 years has been superb (I have a 2K OBW with 42K, purchased 11/2/99).
-Howard
On the strong advice of my Subie dealer, I did switch to synthetic for the tranny and engine. you might talk to your dealer.
BTW, it looked lonely in the garage, so I added a WRX wagon to go with it. Now I have the best of both worlds.
Mike
Steve
Congrats and welcome, Geordie.
The VDC is really nice. VW will add stability control to the 4Motion next year, I hear, but it would have cost far more. You get strong value at Subaru.
-juice
My CD player stopped playing one day (they are not designed for highly repititios ejecting in the hands of two year olds), so I switched back to the factory unit - and it definitely did not sound as good. When I got my eclipse back (covered by warantee - weeee) I put it back in and wow, the high end of music came back.
If you listen to radio the factory deck and the tweeter kit sound great. If you listen to a lot of CDs (loud) an after market deck sounds better than great.
I chose eclipse because they use a security code over a removable face. It also does not transform the dash into the lights of vegas. Now I'll buy them again because of the warrantee.
-steve-v
One note - does everyone get pretty good service from their Subaru dealer? Renick Subaru/Cadillac in Fullerton provides me with such good service that I am starting to feel guilty! I think they are just a solid dealership and the Subaru owners benefit from the Cadillac level of customer service.
So far so good.....
Matt
I have a 2000 Outback wagon with less than 30k miles. It's my fourth scoober. I saw in some earlier messages that others were having the mystery burning rubber smell eminating from under the hood and somewhat through the vents. I don't live where the roads get salted, I haven't run over anything, and the car started this smell about two months ago. There are no puddles of oil or anything else under the car.
I've had the techs tell me it was CV boot leaks, but now that they've replaced both of them, the smell remains. I'm about ready to take my car in for the third time on this problem. There are no TSBs or recalls regarding the smell.
Has anyone successfully resolved the issue?
thx for any info!
/PB
Al
I don't know if anyone has posted anything like this, but I've recently noticed on my '02 base OB 5 speed, that the clutch shudders (and the Subie along with it) on gentle startups when it's wet outside. Of course I thought it was my driving technique, but I've been driving sticks for years, and I honestly don't think so. If I really feather the clutch, or do an abrupt engagement, it doesn't do it, but when I'm not thinking about it, it surprises me with the shuddering.
Anyone else?
David
The clutch shudder seems to be a fairly common thing among 5 speeds for some reason. I had the same issue in my 2000 OB, and I was able to have the clutch replaced at 34,600 miles because I had service records from before 15K showing the problem.
Be sure to let your dealer know so there is evidence of it before 15K so that when it gets worse, they can replace it under warranty (before 36K). I have 42Kmiles now, and do not have the shudder [yet?].
-Howard
-mike
The local dealer, which is absolutely awful, seems less than interested in a sale and I've heard from several people that their service department leaves something to be desired. Does anybody know of a good dealership in the Madison, Wisconsin area (+/- 120 miles)?
I've also heard that repairs on a Subaru are very expensive, in particular the exhaust system. I'm not worried about the reliability, just what I can expect to pay for general maintenance items. I don't have the time or the tools to do repairs myself and don't want to have to take out a second mortgage to pay for a typical repair item. Have the costs that people have been experiencing within reason? Are they anymore than a Nissan or a Honda?
Thanks in advance.
Grand High Poobah
The Fraternal Order of Procrastinators
Anyone else have problems keeping those rubber feet on the deflector? Solutions?
--Jay
Mike k
Good luck. I would definetely recommend an Outback. Especially up here in the frozen tundra.
David
Subaru offers several extended warranties (Classic or Gold), and you can choose your deductible, or have no deductible. It's your choice.
Bob
YetAnotherDave
We rebuilt the automatic trans on the Legacy at 176K, probably due to neglect in changing the trans fluid. Its electronic clutch pack at the center differential got tight after around 190K; an expensive repair we're putting off. There have been the usual brake jobs every 50K or so + replacement of timing belts 80-100K, radiators at around 150K with the Legacy. This is all normal high mileage car stuff. There have been a few minor, annoying electrical fixes with each car (Toyota beats this). BUT.. Neither Subaru has needed anything done to the exhaust! The older Toyotas tended to need exhaust work every 50k or so after a while.
To me, Subaru is almost as good as Toyota as far as general toughness and reliablity go - and a better value because their overall design, character and AWD capabilities in every model. This puts Subaru at the top of the heap.
John
