They are here.
-juice
-various checks and fluid top-offs
-oil change/rotation (already done)
-change air filter
-check cruise control (??? what's there to check? it either works or it does not, and i dont even use mine)
-inspect/clean brakes (might have been done alredy w/rotation, have to see the invoice)
I specifically asked whether anything else aside from oil+filter, rotation and air filter has to be DONE or REPLACED. He said no. Asked about price without oil/rotation - was quoted $195.
I still fail to unerdstand how (possibly) adding a little fluid here or there and air filter can cost $195... I probably can manage to change air filter myself, with the help of your pictures.
I did my 15k service as recommended in manual plus AT fluid and front/rear diff oil change (synthetic), and replaced AT filter, fuel filter, and PCV valve.... whopping $500+ The hefty $$$ was the man hours spent on removing the AT fluid pan and putting it back.
-Dave
Steering and suspension - do what with it? Look at it? Check steering fluid?
I am asking because I feel that sometimes mechanics take us all for the ride. How do I know what they really did for that amount of money? How do I know whether they did not just pop the hood open and check fluids with respective dipsticks? If levels/colors are ok (and likely are), they don't do anything and charge big bucks?
check hoses - how? try to pull it by the hand and see if it's attached tightly?
I think my husband is inclined to take it to the dealer fo service... I am still trying to find out what exactly am I going to be paying for...
The synthetic fluid, Fuel & AT filters and PCV valve were changed at my request (not part of schedule)
Steering and suspension, yes basically inspect them.
Mechanic(s) taking you for a ride... Yes and No. It's not so much as to what is performed, but how long it takes statistically. The bulk of the charges comes from the man hours.
Charges for service are levied based on minimum* man hours required to perform a specific task. i.e. 0.3hrs to perform an oil change, 0.5hrs for tire rotation/balance, etc. So, when you put those static time together and multiple by their going rate = the hefty service charge (parts, sundry, tax, misc. not included).
How do you know they did what they were to do?... without going to extreme like marking the tires or the likes, if you can, watch them at work.
* I might be wrong, it could be average.
-Dave
Nice thing about dealer service is that receipt will help you come time to re-sell. Plus there is never a question if a warranty issue comes up. If that gives you piece of mind, use a dealer. Alternatives are a mechanic you can trust, or doing it yourself.
15k is too early for changing tranny fluids. Flush the radiator, change the oil, rotate the tires, swap the wiper blades. Spray lithium grease on the sway bar bushings. Check all fluid levels. Clean the brakes? Sure, why not, once the wheels are off. You don't need to bleed them yet so no big deal.
30k is the first "big" service.
-juice
Juneau has hills but there are no roads to anywhere else. Sitka and Ketchikan did not have anything like the same proportion of Subes.
-juice
Dave - I am toying with changing the AT fluid and differential fluids with Mobil 1 at 30K. Did you see any difference with the synthetics and what did you use? Thanks.
Viktoria - I don't get the expense either. I understand your point, Dave, but $195 is not "justifyable" for just checking the car.
Greg
-juice
I concur on your observation of Subarus in Alaska. It was the high number of Subarus I saw in Anchorage a few years ago (plus my brother had bought a used Legacy wagon that he let me drive) that attracted my attention to the make. They do indeed rule in the northern state. More surprising to me at the time, was the greater proportion of OLD Subarus to old models of other makes that I noticed. Indicates they last, and their owners hold them in such high regard they continue to maintain and use them.
Now my brother has traded his Legacy for an Audi A6 (oh, the pain!) and now I am enjoying my still-new Bean.
Steve
Ya, I know. I watch the guy change the oil on my OB, and every time I'll say to myself, "Man, I'm paying him $22.50 just to do that (0.3hrs @ $75.00/hr).
On synthetic AT fluid and front & rear diffs oil I used Amsoil, Mobil 1 for engine oil. Well, the AT does shift smoother (don't feel the AT abrupt shifts I get during the winter). Can't comment on the diff since I don't really know what improvement(s) to look/feel for.
I'd switch to synthetic engine oil first and notice some improvement with mpg - upped my mpg by ~1.
After the AT fluid and the diff oil, my mpg upped another ~2. My average mpg prior was 19 mpg mostly city and now its ~22mpg.
-Dave
Hmmm...$195 for an oil and filter change, new air cleaner, rotate tires, look at and check off a list of items.
juice - Flushing the radiator is not part of the 15k service.
My two-cents' worth: Oil and filter change (I change mine every 3.5K in any event), rotate wheels (up on a rack - which presents the opportunity to check all that "under the car" stuff that's hard to do otherwise - exhaust, brakes (clean?), steering & suspension components, CV boots, diffs, any damage, etc.), check all fluids and top off if needed, spend a couple of minutes carefully looking through the engine compartment for anything amiss, and that's it if the car is asymptomatic. It can't hurt to change any/all other fluids, but why bother (and the environment doesn't really need the excess waste).
Changed the air filter myself (2K OB w/H4) - couple of tools and no more than 30 minutes - could do it in 10 minutes now.
I'd expect a professional shop/mechanic to do all that in under an hour for $100 - unless they're trying to take you for a ride, so to speak. And them's city prices.
Cheers from Seattle,
Ken M.
Gary -
The AT fluid change is not in the manual for 15k service. I specifically asked for it, cause I was changing them to synthetic.
Viktoria -
I went through the maintenance required minus oil change and tire rotation/balance,
and:
-Disc Brake Pads and Disc 0.3hrs
-Front/Rear Axle Boots and
Axle Shaft Joint Portions 0.3hrs
-Inspect Brake Line and check operation of parking and service brake system 0.5hrs
-Steering and Suspension 0.3hrs
Total = 1.4hrs
@ $75/hr = $105
I can't say the number is realistic for IL, it is as close as I can get using $/manhour from my dealer service. Hope it could help you in any way getting your service worth.
-Dave
I at least expected a pic at the end of you standing next to the car with the hood open, grinning from ear to ear like a proud papa.
Seriously, of all the threads that I follow, this is one of the most helpful and informative to people who have questions without insulting them.
Grand High Poobah
The Fraternal Order of Procrastinators
The 30k was over $400 and that was w/o oil change, tire rotation, and spark plugs!
I will most likely do the 60k service myself.
Thanks Viktoria for raising awareness on this!
If it were all just inspections, the obviouse answer would be no, but the list of items they actually do is fairly extensive.
Juice,
I noticed in your fotos you show that you replaced the fuel filter...how hard was it to pull the hoses off the filter once you un-did the screw down straps? I was lead to believe they can be a bear to remove. Any special tools needed (hose puller? etc)?
Thanks for all the help!
-r
maint since I was 15 when I worked at a neighbor
hood garage, I was doing tuneups before I was
old enough to drive. Later in the Navy, I did
all my own maint, including rebuilding two engines. I've never done tranny's or clutches.
My experience with these periodic maint checks,
is that they are a rip-off, but not to someone
who knows nothing about cars.
Most of the things they check, should be checked
by you everytime you get a chance, especially at
oil change time. I check all levels at oil change time which I do myself. I check brakes when I rotate the tires, again, I do myself.
I don't trust anyone else working on my cars,
I have some experience with dealer repair shops
I can't do it all myself, when I have had repairs done at dealers, they usually break something when they are working on the problem,
sometimes they give the car back with the problem not fixed, I will take my car to a dealer
only as a last resort. Consumer Reports did an article on Auto maint, and they found better satisfaction at independent garages than at dealers.
My advice to you is to learn where the things are that you need to check, and check them yourself.
If you are a person who knows little about cars,
and has no desire to learn, then the services provided by the dealers are well worth the cost.
It is the free enterprise system at work, you get what you pay for.
As far as warranty's are concerned, I have never had a problem with warranty repairs. I believe that federal laws protect us from that, in other words, the dealer cannot refuse warranty repairs because you did not get the periodic service, I am no lawyer, but I think that would be illegal.
Many of us complain about our governments, but they do protect us more than the business community does. (except on 9/11).
Now let me clarify, I have had my OB for 2 years and have only had 3 "non-maintenance" repair problems. Two of the problems required multiple trips to the dealer and the other one was resolved in one trip. For me this doesn't represent enough datapoints to conclude that this particular Subie dealer is either "good or bad".
On the other hand, my wife's 02 Forester has been flawless since day one (we've had it nine months now).
Ron
Guess where I'll go for the "real" service needed at 30K - and where I'll buy my next tires?
Business loyalty does count. Been using these guys since 1982.
Ken in Seattle
Also- are there any good aftermarket accessory dealers out there? I'd like to get an extended higher armrest for between the 2 front seats.
Could this be a first?
I don't think anyone had thought of this question until now...
Oh, Len, you got me creally really really curious :-)
Let us, at least me, know what it is.
-Dave
-mike
This label is on the door and faces the tire pressure label when the door is closed. However, I didn't see the Vehicle Weight which, as Mike said, you subtract to get the passenger+cargo capacity.
The explaination is in the owner's manual but I didn't see the numbers in the manual.
After some reading and a few test drives, I've shortened my list to a Legacy L or a Volkswagen Jetta wagon (I know, I know. A few on the Jetta board think I'm nuts, too.)
Anyway, I know the Legacy has a great reputation for being reliable and durable. But what about maintenance schedules? Does the Legacy require frequent preventative maintenance work that makes it expensive to own? What about parts (I'm thinking after-warranty work)? I've kept the Chevy running to 196,500 miles, and would expect the same from the Legacy. Is that realistic?
But wait, there's more.
As an International Mountain Bike Association member, I'm eligible for the Subaru VIP program, which entitles me to purchase a Subaru at dealer invoice cost. IMBA defines that as "the amount the Subaru dealer is invoiced by Subaru of America for the car."
Does this mean "invoice" as used with Edmunds True Market Value system, or "invoice" as in dealer wholsale?
If it's the former, it is possible to purchase a Legacy at below invoice? I plan on buying sometime between this weekend and the end of August (it all depends on how long the S10 lasts). Given the time of year and model availability (Legacy L, stick with keyless entry), is it possible to buy below invoice?
One last thing. Our second child is due in September. A couple people on the Jetta board thought the rear seat of the Jetta wagon would be too small for two car seats. I'm sure two car seats will fit in the Legacy -- my question is how comfortably?
Thanks for the help, and sorry for the long post.
It is possible if you've got the MBNA Subaru points to use.
mike + James -
Thanks for the enlightenment.
-Dave
-mike
I traded my s-15 jimmy (182,000 miles) for an Outback Wagon a year ago. Invoice probably would match the 'Kelly Blue book' invoice price. Edmunds list invoice as well as their TMV price.
Will they last 200,000? I hope so too.
For the car seats. I have two kids (3 and 5) the seats have plenty of room. A third car seat might be a little tight but I think somebody here has done it as well! We commonly take the the Subaru on trip(250 miles) an leave the mini-van home because the Subaru is more fun to drive and gets way better gas milage. (28 vs. 22)
--Jay
I have one car seat in my '00 OB Wagon, and it is installed in the middle of the rear seat. When our second child comes, it will be tight I can see for a few reasons:
(2) I always have the driver's seat all the way back, and for long trips, by wife does too, even though she is 'normal' sized (compared to my 6'6" height).
(1) There is more fore-to-aft room in the middle where there is no seat to obstruct little legs. You will definitely have little room to move the front seat back with a rear facing seat installed in the side positions.
With a toddler, or booster seat, take goodlook at how much leg room the child will have while in the child seat. Toddlers love to kick and push seats with their feet also, so if the front seat back is right on top of them, get ready for a loooooooonnnnnggggg trip!
I see a minivan in my future, once the second child is on the horizon.
Just my observations.
-Howard
Cheers!
Paul
1) Load, is the car fully loaded? How many people? Adults?
2) Terrain, is it large hills? Mountains? Plains?
3) Altitude, high altitude v. low altitude will result in different milage
4) Interstate v. 2-lane blacktops, interstates you will generally get better milage on than twisty winding state roads
5) driving style, are you a gun-it type? how fast? there will be a significant difference between 65 and 80mph runs. Do you use cruise?
6) How was it calculated?
Also I think the other person said it was a legacy, maybe even a legacy L which has different gearing and weight than an OB.
-mike
Brian
Thanks again for your input.
John: I've skinned plenty of knuckles and have scars and even stitches to prove it. My wife? LOL, she wouldn't dare harm her beautifully manicured nails! I can't even get her to help in the garden, "it's dirt".
The Fuel Filter is easy. The hoses come off in a snap. Remove pressure in the fuel system by removing the gas cap first, and I used clamps to keep leaking to a minimum.
Payload for the Outback is 850 pounds or so. So you can carry 850 minus the weight of the driver.
VIP program - I just bought with this. You get Edmunds' invoice price minus any incentives, which right now is $750 I believe. That means you pay $750 under invoice.
I bought at Fitzmall.com and according to my math they gave me $850 under invoice plus 6 free oil changes and a free service loaner for life. Sweet deal.
There is plenty of room for 2 kids in the back, leg room is better than the Forester. Head room is excellent sans moonroof. Both are far better than in the Jetta.
Other pluses? Rear disc brakes with ABS in this price range is unheard of. So is AWD. And the Best Pick safety rating from IIHS doesn't hurt.
We bought a 2002 Legacy L wagon with keyless and carpets for $17,827. Keep in mind that includes ABS, 4 disc brakes, 4 channel ABS, power windows, power locks, power mirrors, cruise, keyless, carpets, cargo cover, roof rack rails.
Cons? No cross bars and no CD player, but those are options. Donut spare, though I replaced mine and got alloys too.
Can't beat the value for the money. The Jetta is Impreza sized.
-juice
I've watched my mileage for the past 14 months and 20,000 miles. Lowest was 24 with cold temps and some idle/warm-up and highest was 30 with nothing but warm interstate driving.
Needless to say I'm very happy.
Like Juice posted a couple days ago, did the winter mix gas go away? My milage has jumped up about 1.5 mpg in the past 3 weeks.
--jay
Jon
