Visitor Agreement.
191k? Yeah baby! OK, you gotta hit the 1/4 million mile mark, keep it up!
Good job, Craig. In the big picture, I didn't even notice the cord!
-juice
Anybody investigated the switch connections?
There are "mod" directions on this at scoobymods.
Craig
Jim
First, the gate shifter has the D, 3, 2, and 1 positions.
The sportshift mode lets you cycle through the gears at the nudge of the handle.
Why can't the non-sportshift be driven through the gears manually?
What is the mechanical difference?
Many thanks,
-mike
Steve
-juice
Steve - I wish that was the case but starting the car and then scraping the windows I can hear the AC kick in even when air temperature is below freezing.
Gordon
Gordon, if you find an easy solution to either or both of these, let me know.
MikeF
Jon
Patti
Cdn MSRP 33,095 incl. Auto & dest.
US MSRP 24,695 incl. Auto & dest.
US MSRP in C$ 32,100 that's a $1000 less, and if U.S. dealers deal it'd even be a better deal. Based on an exchange rate of 1.3 C$/US$
Mark
We have a 7/100, and we're pretty sure we'll get the full 7 years out of ours.
Mark: last year it came on all Outbacks. Now it's missing only from the Outback with the Sound Package, primarily meant for markets like Florida. Most of the ones you'll find in NY will have the AWP.
-juice
I too tried it out last night at 39'f, and it still came on. But this morning at 34'f it would no longer engage the compressor. So the temp is lower than I expected, but at some point it should be a non-event. It is possible that sensor placement could be an issue. Say if it is in an area that engine bay heat influences, then it might run despite true outside conditions. I have to see if I can borrow a shop manual set and look it up.
Steve
A good $400 saving off the retail!
-juice
As nobody else posted, here's my entry. Changing the hardwired 'logic' within the HVAC control unit would be difficult without a lot of disassembly to get to the rotary contactor behind the knob. There is a wiring harness connector out the back, but I don't have a wiring diagram to tell you which wire goes to the compressor.
Suggested method: The A/C compressor is right on top next to the oil dip stick. The wire for the magnetic clutch exits in plain site, goes to a black connector, then right into the harness. If you open that connector, the compressor should stop running. Hit a good autoparts store for a matching connector set (so that it is fully restorable), run the line back thru a grommet in the firewall and add a dash switch. Turn the switch off for the winter, if you please.
I once owned a Mercury Montego in which the A/C ran in all modes except vent. There was no separate A/C switch. Needless waste of gas. This is exactly how I handled it.
Steve
It was going in for an alignment the next day. The guy at that shop seemed amazed I had broken it and wanted to know what was I doing to break it -- thoughts of traversing a boulder-strewn dried creekbed running through his head, no doubt. Alas, I was only turning left into my son's high school parking lot when it happened (or at least the first time after it broke and I heard the chunk-chunk).
I have pulled the removal and installation instructions off of AllData, but they do not seem to match up with what I see under the car. It appears that the bar runs under the exhaust pipes right where they connect to the manifolds, so it appears that these will have to be disconnected to do the repair. However, the AllData info does not say anything about this step. Can anyone shed light on this?
K9Leader
Grease up the bushings first. I think the routing will become obvious to you.
Back then, the 18mm rear bar for a Forester was about $80 from a wholesaler.
Did you jump a curb or something? It's a thick metal bar, pretty wild that it broke.
-juice
No, nothing out of the ordinary. It isn't bent or crushed or torn -- the break is clean and just sheared right through. Probably just a weak spot that finally gave out.
Can I do the job on ramps (Rhino Ramps) or do I need jackstands (i.e., does it have to be off the suspension)?
K9Leader
Even without them, you could jack it up at the rear diffy and put jack stands at the jacking points.
It's an easy job. I'd remove the broken one now, rather than wait for the new part.
-juice
Sway bars are generally supposed to be lifetime parts. They should not fail under normal use.
Craig
-juice
Since the sway bar is really a "sprung" part I would expect it to fail all at once, and not be something that develops over time. Hard to say. But it would be interesting to look at the fracture and see if there are any clues. How about a picture?!?
Craig
Just a thought on de-linking the A/C compressor from the defrost function (although I agree with the sentiment). I recall reading some years back that when A/C became a standard feature on all but the cheapest cars that the manufacturers were concerned about the A/C seals, gaskets - whatever - "drying out" by not being used during the winter months - especially by owners living in the more northern latitudes (not meaning to ignore you, Graham). Hence, they caused the compressor to run when the defrost cycle was selected - at least down to a certain temperature. That, plus the fact that running the compressor does improve defrosting efficiency in some temperature/humidity conditions.
This may be dated - or irrelevant - information at this point, but perhaps it's worth considering before you alter the system.
Cheers from [cloudy, rainy, windy] Seattle!
Ken M.
-mike
Jim
FWIW, this morning in the drizzle and 50F temps, I turned on full defrost without much thought or worry.
-Brian
The A/C compressor is so efficient nowadays, honestly I don't think it's worth it. The compressor may run even with the temp setting towards the hot end, but that dehumidifies the air and successfully removes condensation from the windshield.
In other words, it defrosts.
I track my mileage and all summer long with A/C my efficiency was excellent, better than in the winter with oxygenated fuels. So compressor efficiency is so good that I really would not worry about it. Plus you keep those seals lubed.
Just my 2 cents' worth.
-juice
You are right -- I didn't mention that it was the front sway/stabilizer bar that snapped -- that is why the broken piece would hit the wheel during left turns.
Well, I guess I will find out how difficult it is to replace, as the part is ordered and is to be my Saturday project. As I noted in another post, the removal/installation instructions on AllData seemed straightforward, but do not say anything about disconnecting the exhaust pipes from the manifolds, which appears to be necessary (they are bolted together right at that spot). Has anyone done this or can confirm this is what I have to do?
--K9Leader
-juice
"When the dial is placed in the "defrost" or "defrost/foot" position, the air conditioner compressor operates automatically regardless of the position of the air conditioner button to defog the windshield quickly. At the same time, the air inlet selection is automatically set to "Outside air" mode.
In this mode you cannot select "recirculation" mode by manually pressing the air inlet selection button."
Unfortunately the manual is accurate for my car. My salesman thought the 2000 OBW were the same, but my memory says otherwise.
However, further in the manual, for cars with auto air system (which I don't have and hence never read before) it restates the above quotes and continues with "Even with this mode selected, you can turn the air conditioner ON/OFF and select interior air recirculation or outside air introduction as desired."
So, it appears the upper level cars can turn off the A/C and can recirc air when in defrost mode, but the lower level can't.
I'll disagree with you on the A/C question Juice. When it is cold outside, the Relative Humidity of warmed air is very low and the air is very dry. Extra dehumidification is not needed (in fact, many houses have humidifiers for the winter as teh air is too dry). If we could recirc the air, then it may be needed, but I can't do that. Note that the manual indicates that the A/C is to help defog, not defrost.
The manual gives no indication that the compressor turns off at low temperatures but does state: "Operate the conditioner compressor as a low engine speed (at idle or low driving speeds) a few minutes each month during the off-season to circulate its oil.". To me that implies that the compressor will work even in sub-freezing temperatures.
MikeF
-mike
MikeF
In a nutshell: focus on dewpoint (yes, you'll find this on the Weather Channel). The dewpoint is the temperature at which relative humidity is 100% (as an aside, it also indicates the lowest ambient temperature possible unless the dewpoint drops). Most relatively normal people won't describe conditions as "humid" much below the 40s (Fahrenheit) - simply because the dewpoint is too low (see previous sentence). Hence, when it is 39 with 100% humidity, few of us complain. On the other hand, when it is 85 with relative humidity of 80% (indicating a dewpoint of roughly 79), we're all miserable. Dewpoints below 40 are dry, 50s are comfy, 60s are sticky, and 70s and above are tropical. This is why Seattle, despite our wet fall and winter climates (especially today), is never "humid."
'nuf said. Time to clean the leaves out of the gutters (again).
Cheers from Seattle!
Ken M.
As I posted above, it is easy enough to do by adding a switch to the compressor clutch.
You must run the compressor periodically year round for two reasons.
1) Compressor oil (2-4 oz mixed in with the R-134) lubes and helps to swell compressor seals & "O" rings . If it all drains to the bottom, seal leakage will eventually occur.
2) Automotive refrigerants contain a certain amout of free fluorine and chlorine. When they remain stagnant for long periods of time in the presence of trace amounts of water vapor present in the system, weak acids are formed (HCl, HF, etc.). Eventually, they eat the system from the inside out.
Steve
Install the ski racks! Launch the Outbacks!
Cheers!
Ken in snowy(!!) Seattle
I would like to add, that some people (my spouse, for one) mistakenly think that the defogger blows warm air even with a cold engine. Until that engine runs for a few minutes, the defogger blows cold air in your face.
I say, give me the OPTION of turning on the AC compressor with the defogger. I drove many vehicles that had no AC and yet did a satisfactory job of clearing the fog from the windshield.
- jim
I just wish that it didn't hurt some horsepower on my H4.
Oddly enough, I think that some of the lines in my rear-defrost have stopped working. I have 2 fog lines in my view. Anyone else had that happen?
Steve - thanks, found the wire but will have to wait until the weekend to locate a switch position and route through the firewall.
Having the ability to use the AC to dehumidify is great and I have used it frequently in the past in previous vehicles - but I want to choose! My habit in winter is to have air directed to windshield and footwell for most of the time once the car has warmed up and I just don't need the AC cycling on all the time. I have driven on 4 continents (lived on 3) from the arctic to tropics, even had the outside of the car fog up due to high AC inside and high humidity outside!
Thanks for all the comments - I will report back when I have done the mod.
Gordon
In another Edmunds discussion a link was provided to another site which had details on how to modify the micro switch behind the controller. If the link is not there, send me an E-mail and I'll send it to you.
If you disble the A/C feature, follow the advice given here and run the compresor at least once a month to keep seals lubricated.
Let us know how it turns out.
MikeF
I personally perfer the compressor being on, clears my windows much quicker (I can control it on my Trooper) and have tested it AC v. No AC and every time, it's the AC version that works faster.
-mike
-juice
Ralph
Press days are 4-6, public days are 10 and later. That means we will have back stage access 4 days before the public! Cameras allowed, too. Plus a round table discussion with Subaru, so we can provide our feedback.
Very exciting score for the whole Crew. We'll try to get all your questions answered. The Subaru Legacy GT will debut and we will have full access to it.
-juice
