Visitor Agreement.
Do the 16" from previous years fit the 06's? I can probably get some OEM 16" rims on eBay.
If you do get it it will most likely be something that you will be happy with everytime you are in a slippery situation justifying to yourself if it wasn't for the VDC you would have had problems.
If you don't get it, I really don't see a time while driving that you wished you had it RIGHT NOW.
-juice
Found the answer courtesy Joe Spitz. Both 17x7jj offset 48 (1.89) and 16x6" offset 48 (1.89)fit both 2005 and 2006.
Still don't know about the 16" on the 2000-2004.
Len
Just had the same problem. 2001, just short of 60k. Burned through new battery and alternator (both requiring out of state tows w/ the family on board). Now the brake/battery light are on.
Who'd have thunk that our VW Jetta is more relable than our Subaru?!
Might be worth checking into.
Len
Warren
Warren
Just find it odd that fleet salesperson would advise customers to take action that Subaru specifically warns against. For the time being, until I hear differently, I will start using premium. Have gone about 1,000 miles so far on mid-grade (87 octane) and don't notice any performance or pinging issues, but don't want to take any chances. Besides, it's usually only an extra 2 - 3 bucks per fill up. Any other insight on this would be greatly appreciated.
It is true that one can run lower octane at higher altitudes since the thinner air does resist detonantion.
However, I'm not sure about a turbo engine. Since a turbo can maintain mainfold pressure, it will compensate for the lower ambient pressure by increasing boost. I'd ask Subaru about that one and be careful before using a lower grade.
Ken
You can probably get away with mid-grade, but I'd still opt for the highest octane I could get.
-juice
I note that VDC is intended to prevent a skid, which is more critical the higher the car is. Thus it seems to be standard on more and more SUVs since a skid often results in roll-overs for those cars. We have it in our Toyota mini-van and I'm glad to have it there for the extra help.
Also, I note that VDC is an option on 2.5i models on the models listed on the Subaru Global website http://www.subaru-global.com/lineup/outback/safety/ac_control.html and is standard on all 3.0s on the global site. http://www.subaru-global.com/ It's too bad that it's an upscale option on the US Outback still.
-juice
-juice
I will post results!
I am staring at 116,700mi on my 01 LL Bean. I am curious if anyone with an H-6 has replaced their chain or had any problems related to the chain. I haven't had any problems but was warned that the chain should be replaced at 150kmi. That doesn't sound right to me...I thought the chain would pretty much stretch a little bit but basically last the life of the car. Any comments? Thoughts?
-r
-juice
Last login was 3/14/05! Been a long time. Good to see the same support here! I always promised to report back, in turn for all the good info you guys supply.
My 2001 LLBean H6 is reaching 87,000 miles and still [knock on wood] continuing to provide flawless reliability. No problems...zip.
My front rotors/pads are ready to be replaced [the one design flaw this model run had - along with the stupid side window grommets]. Question.... do I shell out $450. for Subaru rotors/pads (they say there have been NO design changes from the original) OR do I go to Meineke brakes for $275. and maybe get a better designed rotor/pad combo?
Your expert advice??
Ralph
Facing the same dilemma on my '02 OBW, the stock rotors and pads were exactly what I wanted to avoid. I still have problems with the pads sticking to the rotors after leaving the car parked outside for more than a few days (airports, etc.).
After some research, I settled on a set of PowerSlot Frozen Rotors (slotted disks, cryo treated), and Hawk HPS (Street Performance) pads. When I do the snows to all-seasons changeover in a few weeks, they go on. While you can get them cheaper, I went to TireRack (around $400) as I figured that they are more likely to help if I have any problems.
Steve
I really have no idea about the quality of the Meineke rotors. What kind of warranty do they include?
I think I'd shop for those PowerSlots. Slotted rotors have gaps for the gasses to escape and increase the surface area for more efficient cooling, plus they don't crack in extreme circumstances like drilled rotors do.
Why not get an upgrade for just $125 more?
-juice
Short answer - no problems are being reported on dedicated Subaru websites that have 10-100x the messages here at Edmunds.
Email Subaru on the website and they'll snail mail you a response a couple weeks later. Chains can wear out but it's not typical.
What dealer told you this?
Ralph
Thanks. Sounds good. I think I'm going to get the Frozen Rotors cryo-treated rotors and bring them to a lifetime brake place near me - they use Wagner brake pads.
That way I should be covered for the life of the Beaner (at 88K now)...and avoid the warped rotor syndrome...
Thanks for the info!
Ralph
If you didn't follow my brake story over in the Subaru Crew Problems & Solutions, I'll give you the Readers Digest Condensed version.
The week before I planned to do the work, I had the front right inside pad break apart. Friction material had glued itself to the rotor again, and when it snapped free, it was ejected right out of the caliper assembly!
I got everything apart, only to find that my '02 was not really an '02 in the brakes department, and had to go back to TireRack for '01 brake pads (old style). Gotta tell you, that really annoyed me big time! I feel a bit cheated, as the changes in design and effective sweep area were pretty substantial.
It is a little weak when cold, but grips very nicely when warmed up a bit. I am hoping it is not too slow to stabilize on a cold winter day. Overall, I think I am pretty happy with the setup. And those rotors sure are pretty! They say the plating will keep most of the surfaces from ever rusting.
Steve
It's getting hotter now and when I turn on the AC it only blows not very cool air. In addition when I press AC button I can hear it kick in, but for the first 30 seconds it makes strange kind of ticking sound that disappears later.
This sounds like a leaf in the vent.
Is this some easy fix like adding $20 AC refrigerant from Walmart or something more serious?
The car is out of warranty.
Yikes! Sounds like you weren't in harm's way. Good thing!
Did more research, too. I've decided to get the Frozen Rotors ($230.) from TR and have a local shop put ceramic pads ($89.) on w/ a lifetime guarantee - only $45. labor to replace. That way I'm pretty well covered.
Local shop said the Frozen Rotor option is becoming popular with in-the-know Outback owners trying to avoid the warped rotor syndrome. And they mentioned I should go with the ceramic pads with those rotors. Hope it works...
Thanks again for steering me toward them!
Ralph
Perhaps some of the dealers are conditioned to look at this problem, and not beyond it. On dedicated forums there are not routine postings of electrical problems like you describe, which sounds on the face of it like a loose connection.
Brakes were an issue for some, so see if the pedal pulses under hard braking, if so just budget to have the rotors turned (or replaced).
-juice
Unlike the turbos the H6's tend to have been babied.
Call 800-SUBARU3 to open up a case file. They will help track the case. They usually bring in a regional manager for tougher issues like yours. The case just helps you track it better, and makes sure you're getting all the help you need.
-juice
OBDII - on-board diagnostics, level II. I own a scanner myself. It's handy. A chipmunk ate some of my wires and it threw a code, so I had to read it. I've used it once for my wife (loose gas cap) and twice for different friends that complained they had 'em.
-juice
-juice
will that be for MT as well as AT??? just what I have been waiting for!
-juice
BTW...the speedo error is 7.6%....so now I am having to re-train myself as to a safe speed to set the cruise at for my early morning commute to work!
BTW...anyone interested in a set of 01 LLBean wheels?
-r
I would like to start by thanking all the people who have submitted posts. I like doing as much research as possible before I buy, and this page has made finding that info very easy.
Although my VDC is in great shape and seems to run smooth, ran into some problems this morning on the way to work...
Started the car, no problem, started driving, no problem, 4-5 km later the car suddenly cut power to the engine. The engine would still crank, but would not turn over.
Thank God I bought an extended warranty program with the car, but I have only had it for a week! I read so many great things about Subaru, and being a Honda owner I put reliability at the top of my priority list when looking in to buying a car. Has anyone heard of the reason for this? The lights and electrics still work but no go with the engine.
Any suggestions for this new worried Subaru owner would be great... I still have faith that Subarus are reliable, but this event has put a small question of my judgement in to play.
Please give me the scoop if there is one.
New broke down Subie owner.
John
John
Any how, the trick here is that is a used car, we don't know how the previous owner treated it.
Since you're getting a new fuel pump, I'd ask for a new fuel filter as well.
When I buy a used car, I do a 60k service on it even if the mileage isn't at 60k, because I want what I call a "baseline" on the age of all wear and tear items. So I change the fuel filter, air filter, PCV valve, O2 sensor, oil and filter, gear oil, and differential oil. I also bleed the brakes and flush the coolant.
That way you know all the fluids are new, and can get on your own maintenance schedule.
Rack this up to bad luck and/or previous owner neglect (maybe they never changed the fuel filter?), one problem is not a pattern so don't worry about it.
-juice
Due to the fact they helped me so quick, I feel as though they deserve some props for their attention in this matter....So....
Special Thanks to
-Leon's Fine Cars - Etobicoke ON, Canada (Emmil)
-A-Protect - Toronto ON Canada (Shenelle)
-All people that have taken the time to share their problems and solutions on this board.
Thanks again,
Hoping for a better week to come.... still love my car
"Feeling better" Subaru owner,
John
