Visitor Agreement.
What is the cheapest way to fix this please? Is there a relay or fuse somewhere that will restore function to the instruments cluster (speedometer etc) or does it need replacement?
Thanks for all replies
HIH,
littleh
the 87 aerostar has a digital tacho and some other electronics. why a thermometer for those inside and outside temperature is missing can I not understand! there probably someone has from Fords not too ends thought... :-(
Peter
Any tips out there as to how to go about this plug change? I can gain access to the plugs on the driver's side of the engine from the hood, but the other side I don't know about. I have a shop appointment later this week. They tell me the book hours for a sparkplug change list at 2.5. At $58 Canadian an hour, plus tax, that figures out to $167 or so.
Your timely tips I shall surely most appreciate!!!
I test drove a used 93 , with 165,000 miles on it.
The airbag light keep blinking, and when I made a sharp left turn it shuttered a little but only when making a sharp left, not straight or right turn,
The seller does not speak English hardly, and I got conflicting answers from him, and I don't speak spanish.
Any thoughts on this ?
A tune up was done 3-4 years ago accordinly to him.
It seemed to drive ok , When I lifted the hood , it was running with the AC on and the AC seemed to make alot of noise . ??
Anyone use Duralube with thier oil and notice a difference ??
GR1
The 4.0 L is known for its very picky with spark plugs and wires.
You should use either Motorcraft OEM (expensive) or Autolite (better price, similar quality) parts ONLY.
Use Double Platinum plugs with anti-seize. Be careful & patien when remove the old plugs. I would change the air filter, all fluids also, O2sensor.
HIH
I've used it for years and count it amoung the very few products that actually meet/exceed their advertising/expectations. Rain-X ROCKS!
'83 Pontiac Grand Prix, 5L w/200+KMi running in mid-summer in Miami rush hour with A/C on full. Noticed temp guage pegged. Took 10 minutes to wrangle out of traffic into a parking lot. Blown lower radiator hose. NO water! No steam, even! I could hear the motor oil boiling!
Gave it 5 - 10 minutes too cool down, then added water. Started up smoothe as silk. Note: Hot as it was when I pulled into the parking lot, there was no pinging/laboring/dogging - kinda scary!
jg
I bought it cheap because I needed wheels! Shortly after I bought it I noticed that it'd slip in and out of overdrive at highway speeds. I asked around and the consensus was that it sounded like it was time to replace the filter and fluid. Three "events" happened at the same time and resulted in my current problem: Even in PARK, the transmission is "engaged" in a forward gear. The engine won't rev. <--Imaging having the selector in DRIVE while standing on the brake and giving it gas. The engine runs, but bogs down and won't rev. Ditto in NEUTRAL. Ditto in REVERSE! That is, regardless of where the selector is set, a forward gear is engaged! The only way I can back up is to get out and push.
The 3 coinciding "events":
1. I tried to run the van up onto plastic ramps that had been sitting out in the sun. They didn't hold up and the van collapsed down with a "thump". I then reverted to jackstands to lift & hold the front end up.
2. I replaced the filter and fluid - with the THREE quarts my parts store guy told me I'd need. I cleaned the "fuzz" (metal) off the magnet inside the pan.
3. Bourbon & Coke was my copilot in this endeavor, so it's entirely possible I nudged something (a switch or its wires?) in the bottom of the transmission while replacing the filter & pan.
The result was that I had no REVERSE; PARK, NEUTRAL and REVERSE all had forward gear engaged and the slipping in and out of overdrive at highway speeds persisted. I later found out that 4-1/2 quarts of fluid is needed and by adding fluid the overdrive slipping in & out problem was resolved.
I've been in the troubleshooting/repair business for 40+ years and my gut instinct tells me I have a minor solution to a major problem. My handicap is that I'm not a "Ford Guy" and I don't know the quirks of this vehicle.
I'm hoping for some (inexpensive) help.
Maybe related; only get heat in the back half of the van, even in MAX AIR' setting on the front panel.
Another sore spot is the rubber seal around the hatch. After aging it sort of collapses and it too will leak.
Hope this helps, good luck!!!
I AM FROM GREECE AND I HAVE A GOLD AEROSTAR 11/1989
EVERYBODY TELL ME IT IS A BAD CHOICE THIS CAR A IT IS NOT FOR A EUROPE AND GREECE BUT I LOVE THIS CAR AND I FEEL GOOD WHEN DRIVE IT.
THE ONLY PROBLEM ITS I CAN'T FIND PARTS TO REPAIR IT AT EUROPE
IF SOMEBODY KNOW TO HELP ME PLEASE...
NOW THE AUTOMATIC TRASMISSION LOST OIL FROM THE TORQUE CONVERTER AND I CANT FIND THE PART..
HELP ME FOLKS ....
(2) the accelerator pedel is hard to push down. Is there a way to make it easier to push down, perhaps by changing a return spring somewhere?
Thanks in advance for your help and advice.
thanks!
also, i managed to change all plugs and wires/cap this weekend without dropping the motor. it was a combo of hitting them from the side, under the van, and from the top of the motor.
Soory that I don't know about the 3.0L engine heater hose system.
I've been on the Taurus forum for over 5 years (own a 2000 Taurus SEL) but am in need of some help from you Aerostar owners.
Our agency just recently got rid of our 1997 Aerostar and gave us a 2005 Caravan. Now one would think that we'd be happy, BUT, we all hate it!! We want our old one back cause it was so perfect for hauling all of the tall items that we haul constantly. It had the perfect back-end loading area - high in the center and almost square at the corners. Also, the space behind the 3rd seat was enough to put some items without taking the seat out (which was a pain - new Caravan - just as painful). :mad:
My boss told me to get the dimensions of the back-end (height and width) so that I can research to see if a new van exists that is close to the old van.
I might add that we had absolutely no trouble with this van and most of the miles were in the city (Washington, DC).
I'm currently trying to do some minor repairs on a 1992 Ford Aerostar 4 WD Eddit Bauer edition full sized van.
Problem is, the fuse box cover states: Consult manual; but I didn't get a manual with my used van. So I don't know what fuse goes where.
Can anyone help me out by listing what each fuse # does, and what size fuse should be in the slots?
My car just stopped yesterday and now it won't start again.
I check the fuelpump shut-off switch (inertia switch) and that's not the problem.
Please help me. :sick:
