Laters
Marnie>> get used to the paint, it only gets more chipped!
gravel from the road. But, every time I take a slight corner, I hear it. Weird. Anyone
have any input. Also, the question was asked already, but no one answered. At 30,000
miles, what HAS to be done and what doesn't have to be. The manual recommends a lot
and it will cost close to $400-$500. Any input into these two concerns will be
appreciated.
Rob SEV6
The one thing I'm not sure about is having the transmission fluid replaced or flushed. I think if you have an automatic transmission, it would probably be a good idea to do this, but I have a manual transmission, and I didn't think I had to have transmission fluid replaced. I asked the question a few weeks ago if any manual transmission owners had their transmission fluid replaced or planned on having their transmission fluid replaced, but didn't get much input from anyone. Hope that helps a little.
This exhaust is the only difference between the Camry and Solara and is why it gets 6 more HP.
The exhaust is so important! I understand the reason that the ES300 has an additional 10-15 horses or so is only because the exhaust headers are better.
About the transmission fluid, auto/manual, I would change the filter, fluid and gasket ever 30,000 no matter what type of car, fluid, or transmission I had. That's one thing I don't want to mess with. Cost me a whole lot more money later if I neglect it now.
Rob SE V6
Why worry. I thought you were going to dump the Solara and buy a Chrysler? Did you change your mind?
fastdriver
PS Their stock is down to $44.39 from a high of $80+ in January.
P.S. My companys stock price is "under water" like DC! Doesn't mean we are a bad company, or have a bad product, just top heavy! That will change when the shareholders grumble a bit, just watch.
The new model, similarly equipped, will actually sticker for less than the previous version. This is supposed to be a small, affordable 4WD drive for young folks -- not a LandCruiser wannabe.
Michael J.
1. Our '00 SLE V6 definitely "pulls" to the left. Two different dealership have tried to fix it, (alignments, tire pressure, etc.), but nothing can keep this car in a straight line for any length of time. I really believe it is a defect.
2. Have had a few rattles in the rear A pillars that neither dealership can seem to find/fix. Both said they might do more harm than good if they took everything apart and tried to put it back together. It's really annoying to have such a quiet car overall and have these few rattles continue.
3. Toyota Customer Service. Well, you just have to keep at it. My initial calls to Toyota only found very rude employees as I explained my ****** problem(I promised Cliffy1 that I wouldn't mention the exact problem!), but I finally found someone at Toyota Customer Assistance in Torrance that took care of my problem. No small claims court or lawyers. So while I think things could be better, I have to admit that they did come through in the end.
4. Paint chips. Flame Red has a few minor ones after one year, but no more than our '97 Camry.
Chrysler? I'd rather walk.............
The tires are warranteed by the TIRE manufacturer, not Toyota. Call the tire company and tell them that you have a problem and that you would like a factory approved tire dealer in your area to look at them.
I had this problem for 10 1/2 months and 11,000 miles on my 300M. The car not only wanted to go left, it felt like someone was under the hood pulling the wheel left! Of course my "award winning 5-STAR" dealerS had NO clue what the problem was! I solved my own problem with Goodyear at 11,000 miles. The tires were defective! I got 4 new tires for FREE! If I listened to my dealerS telling me that this was a characteristic of the car or that they all did it or that it was the crown in the road, my 300 would STILL be going left! Sometimes you just have to take the bull by the horns and get a little crazy! You spent hard earned money on this car. It SHOULD go straight!
fastdriver
(about $45.00 "ouch") and replaced the "homelink" panel with the eyeglass panel. An easy swap if you work carefully to remove the original remote control panel with a thin tool (a butterknife). The panel releases by inserting the tool into the slot under the rear edge. After removing the remote panel the "Homelink" wiring is tied and tucked away. Now there is an drop-down overhead panel that is useful, and here in the southwest sunglasses are standard equipment for most people.
when i got my 00 SE.It was in a little box and i just swapped it for the remote panel.
I had a '99 SLE-V6 (and now have a 2K SLE-V6) and neither came with the sunglass holder in the glovebox. The overhead homelink unit is standard with the SLE. There is a very slim tray that opens below the auto-climate control. This is/can be used for a very petite pair of sunglasses or clipons (which I use). Since I use the homelink to activate exterior lights upon departing/arriving when it is dark, I chose not to replace to homelink component with an overhead sunglass storage compartment.
To boil it down, the SLE does not come with the overhead sunglass storage as a swap for the homelink.
Hope this helps.
2K SLE-V6 - 7 K miles and still smooth & creamy!
Michael J.
How do I determine if I can go with a wider tire on my '99 Solara (on stock 16x6 alloy wheels)? It has Bridgestone 205/60 HR16's on it now and I would like to go with the 225/55 HR16 Michelin Pilot XGT H4's given that they are just slightly smaller in diameter and less than an inch wider. I live in eastern NY so snow/wet traction is a must, but I want performance as well. The Bridgestones worked well for the last two years, but now it is time for a real tire. My main concern is clearance with the wider tire. Thanks in advance for any input.
Well, after much discussion with Michelin, Toyota, a local tire company, and tirerack, I decided to put Pilot XGT H4 215/60HR16 tires on it. The Michelin book says 205/60 to 215/65 will fit the car fine and the 215/60 is the closer to original size of the 2 choices.
The 215/60 is .4" wider and .5" taller than OEM.
The 215/65 is .4" wider and 1.3" taller than OEM.
The 225/55 is .8" wider and .06" shorter than OEM.
Also, it was determined that it may be necessary to do some body mods to fit the 225/55's and I don't want to take that chance. The 16x6 wheel size also concerned the local dealer, because that tire would push its limits just a little to far...
I will keep you posted on the ride/noise change after I get them installed this weekend.
'99 SE V6 5-Speed w/ 22,500 flawless miles (and crappy, worn Bridgestone tires)
