I have heard about BP gas being bad. Have always owned GM cars and have used BP 90% of the time with no issues. By no means am I saying it is not possible.
Seems that many people like myself have replaced the hatch handle.
This van is a lot better than the previous Lumina mini van. I decided to go with a Dodge during that era. Has anyone experienced a vibration a high speeds. Sometimes it happens and then again not. When it was time for new tires on the Venture the vibration is still there. Is it the roof rack cross bars?
To be blunt though I wish that I had seen this discussion sooner. My van has apparently been leaking for some time (van eventually died with 65000 miles on the odo). I believe that GM is doing a dis-service to everyone who owns this engine by not informing them of the potential problem. The only signs that I saw of a potential internal engine problem, were those that could easily be related to an external leak. Light dusting of a 'sticky substance' on the outside of the engine and the occasional refill of coolant in the coolant container that couldn't really be otherwise accounted for. Never once did any signs of antifreeze show up in the oil or any other signs of internal issues. My engine just suddenly and quite simply died an unnatural death. Started it up a few months ago to a nasty 'clacking' noise from the bottom end. A sign of 'spun' crank bearings most likely amongst other things.
The problem I believe, at least for me, was that the leak never became large enough to cause an major short term signs. Partilay I believe this is due to the way that the 'newer' radiator fluids evaportate and what they leave behind. Pulling apart the engine partially, it became obvious that the damage was more long term then could be fixed by simple replacement of the gaskets could not fix (I do most/all of my own car work, including things like building up of the top end of an LT-1 engine with new cam, rockers, etc.). Basically the radiator fluid had evaportated inside the rocker covers, leaving behind a vasolline like sludge at the top of the covers. Many ports were also clogged by this material. I would guess that similiar sludge was at the bottom of the engine although by that point I figured it was a lost cause and said forgetaboutit. Again though, I would repeat that at no time did any residual gunk, sludge, or the typical signs of radiator fluid in the oil that I would have expected to see show up under normal oil changes.
My experience with this particular vehicle, as well as a 1995 Buick Regal whose paint is almost completely off (which I had brought to the attention of both dealer and Buick prior to expiration of warranty but for which now post warranty they want nothing to do with), has led me to resist the purchase of any more GM vehicles. And I am in the market to replace the Regal at this point. I simply no longer trust GM with my hard earned, no raise for the last few years, cash. Fool me once shame on you, fool me twice - see ya later.
THNX
BRAD
I'd like atleast 7 passenger seating and I noticed the base Montana only has 6 seats.
Does the Venture LS have 7 passenger seating standard? I also liked the switch gear (radio/air system knobs) better in the Venture.
What are the other differences in the base models of the triplets?
Replaced tranny for 2500 with a jasper transmission.
Now the window regulator took a hike and Ill have to replace that.
My question is the low coolant light. Every 8k miles I have to add coolant. Is this the dreaded manifold gasket?
My one complaint is the fuel mileage. So far we have 2800 kms on the dial and the fuel consumption is not getting better. I realize sometimes that the first few tanks are bad but I was kind of hoping for some improvement. Can anyone shed some light on this situation for me? Will I ever get close to the 19/26 I'm suppose to?
What mileage are you actually getting?
Much of the variability in mileage comes from driving style. How hard do you accelerate from a stop? How fast do you drive? Do you have a rooftop carrier on the van?
I don't recall much of a break-in period on ours, so I don't think you should expect something to change in the near future. You could always have it checked by the dealer to see if something is wrong with the computer that controls the engine.
I don't have a leadfoot and I'm not aggressive at all in my driving. The weather is warm now so mileage should be at it's peek and that's what scares me. I will bring it in to the dealer if things don't get better soon. I just thought there mite be a break in where other's saw their mileage get better after a couple of months. We love the van otherwise and we got a great deal on it which makes it even better!
BTW - I know leather is available as an aftermarket, but I'd rather not go that route.
Talk about it in the 2005 Chevrolet Uplander/Pontiac Montana SV6/Saturn Relay/Buick Terraza discussion.
I know someone who got after maket leather in their Odyssey. It looks really good and its lasted very well for 3 years! In fact , if GM original leather seats are like anything like the cloth ones in our present Venture which are falling apart, these aftermarket ones are probably better!
Most recent problem was my wife's parking ticket, that's about it.
The Warner Bros version had it as standard but with cloth inserts and 7 passenger seating only.
Not sure if they continued this after 2000
Our Venture turned 86k miles this month. I took it to replace original plugs & wires, fuel filter & AC compressor (ouch). Anyway, the new plugs & wires made an immediate difference in the engine, it feels like it did when we bought it.
Still happy with this car.
Maybe we were lucky to not have the problems listed on here, but if so, we weren't alone, as we know two other happy Venture owners in our crowd. Routine maintenance, a brake job, a temporarily balky drivers side window, and an alignment is all I ever had done (there were two recalls, one for the rear hatch and one for the power side door).
I am 50 years old and have owned quite a few vehicles, and can say without hesitation or doubt that the Venture was overall the best of all of them, and I miss her sorely. The comfort, functionality (tv's, lumber, pvc pipe, whatever; just about anything fits in this van) and reliabilty of this vehicle was top notch, and better than anything I had before.
From my observations, you can do a lot worse than a Venture.
Rgds
7,380 miles: Belt squeal, serpentine belt replaced.
12,130 Miles: Pass. Rear door motor assembly replaced, door opens while driving (recall), Driver side rear door latch replaced, Serpentine belt and tensioner replaced (belt squeal), Rear brakes replaced, Rough idle, can’t duplicate. Front suspension bushing replaced(noise) alignment checked.
14,473 miles, Serpentine belt replaced(squeal,chirping).
14,990 miles, Water leaking at rear hatch, Rear intake leaking oil( oil pan bolts, oil filter, drain plug tightened) Questioned fix and was told that’s how they fix Honda’s., Front alignment( Paid by me)
17,578 miles, Serpentine belt squealing and chirping( belt replaced) Water in LR taillight(replaced)
19,696 miles, AC pressure valve blew out.(replaced) AC air is warm and spitting water out vents. This is Aug. 2003
19,826 miles, Told AC is working Fine, use recirculate to cool Vehicle. Water coming out of vents normal. Was told no problem with serpentine belt, tensioners, pulleys etc. Belt squealing and chirping normal. Some belts do this(This is 4th belt since new) At this time I made the mistake to contact GM Customer Service, then the BBB. Both said they would help me neither did. All I have ever got is to be told to take it in for repairs. Dah! That’s what I have been doing.
20,752 miles, AC recharged, Vents stopped spitting water, Air cool at times but not close to what it was, mostly warm and humid. Belt squeal was used on belt many times and did not fix. Belt noise to be fixed for last time Per area Service Manager. Dealer saturated the belt with belt lube, then told me they could not duplicate problem. Belt still squealing and chirping. E-brake not holding, brakes not stopping van. Rear brake parts fell apart.
21,380 miles, Belt problem addressed again, pulleys not lined up properly, seems to fix. AC still not working right, told cannot fix unless hot outside. Begged them to fix so I could travel to Arizona and Florida, they refused. Pleaded with them to compare to other like vans( I did) they refused. 60 degrees outside, drive all day long will AC full blast and not be cold.
Arbitration Hearing, IMPARTIAL Tech. Determines AC is working properly( 35 Degrees outside) Failed to mention noise in vent for which there is a TSB on. Offered extended warranty, Told GM I couldn’t get it fixed with the one I had.
23,296 miles, Loss of power, bad gas mileage, Oil leak, anti-freeze in oil, rough Idle( intake gasket replaced) engine oil overfilled 3/4 Qt. AC checked(warm outside) No Problem found. Although dealer claims they did not work on AC, works a little better.
24,000 miles to current 25,600 miles, Oil leak continues, Oil dripping from engine since May 2003. Engine stumbles or bucking while driving, Transmission slams into gear and slips. Driver window slow or almost stops midway. AC Blows warm humid air with moldy smell. Before AC was repaired you could have made ice-cream and van smelled new. I had to turn rear unit off cause kids were too cold. Dealers have never driven Van more than 2-3 miles. Vehicle never wrecked or abused and serviced above normal. Luxury Van to Sweat Box to Expensive Yard Ornament. That’s my story and I’m sticking to it.
One or two people have had the issue with their Venture and traced the cause to the seat belt buckle:
schumaker Mar 30, 2001 6:10pm
Meanwhile your airbag may not work right in an accident.
A newspaper reporter would like to talk with recent minivan buyers who live in Michigan. Please respond to jfallon@edmunds.com or swebster@freepress.com with your daytime phone number by Thursday, June 17, 2004.
Thanks, Jeannine Fallon
PR Director, Edmunds.com
I also found moving the drivers seat (power assist) to the very front and down to floor, then bring up vertically then full back horizontally.
My airbag warning light blinks 7 times and then goes out. I also found if I stop the van with engine running in Park open power passenger sliding door. Once door closed the airbag light comes on and generally goes out. If not I restart the engine and it goes out.
I'm having trouble starting my motor. The starter motor always works. After attemping to start the motor for 5 or 6 tries I don't smell gas under the hood. After waiting for about 1 or 2 minutes I'll try again and the car will start. Can anyone resolve my problem, could this be the "electronic fuel pump"?
Thanks....
Hope this helps,
Tomek (2000 venture, 46K miles)
How do I get the power sliding door opened? What is the problem? I can't even unlock the door manually.
25,848 miles, Engine problem caused by spark plug wires not attached properly when intake was done. Bracket not connected and wires shorted out on egr tube. Had AC checked by a private tech. To confirm AC was not working properly. Then had GM dealer check again. Both agreed it was not right and has low charge. After 3 last chance to repair and 5 attempts to get fixed in almost a year I had an attorney file for repurchase under lemon law. GM refused my claim on that primary concerns have been fixed and AC problem cannot be duplicated. GM has flat out refused to fix the AC and properly diagnose problem since Aug. 03. At times AC vents look like a steam iron and now Recirculate/outside air switch will not work. I have gone to different dealers. Yes this is a true story, I wish it wasn’t.
1st Dealer's Answer: Call Chevrolet.
Chevrolet's Ans: Call the dealer.
2nd Dealer's Ans: Swaybar/stableizer and engine oil cooler.
3rd Dealer's Ans: Just a hitch and wire harness! (I'm not joking ..an actual dealer told me this even after I proposed oil coolers, transmission oil cooler, air shocks, etc).
4th Dealer: Heavy duty Alternator and large capacity radiator.
Now, the www.Chevrolet.com site allows you to choose options to purchase a new van and for the 2005, it lists the towing package as: Heavy duty Alternator and large capacity Radiator.
BUT! WHen you go to the GMCanada.com site and pull up the towing package, it lists: touring suspension, heavy duty radiator, alternator, and signal flasher, transmission oil cooler.
Is there some who knows the REAL answer to this and can back it up?
There was a post somewhere in here that suggested it is the larger radiator which includes a larger transmission cooler (that must imply that the transmission cooler is within the radiator), and a water-cooled engine oil cooler.
THank you for any help ...even if you suggest where I can find the answer would be appreciated.
THanks!
