Good luck with your Ventures !!
I've got a 2001 Venture LS with 200 000 KM (+/- 125 000 miles). I'm in Canada. I've had the same Intake gasket and Head gasket failures. My dealer up here in Canada told me GM fixes these for free - even out of warranty. I had the Intake fail at 80 000 Km (+/- 50 000 miles), well out of warranty. They changed the gaskets, oil, filter etc. Within a few days the intake failed again, and blew the rear head gasket also. GM replace the rear head gasket, intake gasket, oil, filter etc for free again. I did request that the front head gasket be replaced at the same time as a precaution. It cost me less then $100 (canadian), since most of the motor was ripped down. The dealer also told me the reason for the intake/rear head gasket failures is the poor design of the engine compartment. The Intake and Rear of the motor are covered, so the heat builds up, because cold air can't circulate back there. This also causes premature alternator failure. Notice the '05 Uplander - new front end (ie longer), but same rear portion as the Venture. I would [non-permissible content removed] and complain if the dealer charges you for the Intake and Head gaskets. My Chevy Dealer willing told me. They even fixed the roof paint no charge - another GM problem - because of rust spots. GM also fixes paint delamination for free if you scream loud enough - it works trust me.
As for the No Start/Security issue. That also happened to me under warranty. I would turn the key, and nothing. Try turning the off then to start again. Should work for a bit. With me it turned out the Security Chip in the Head (under the black rubber) of the Ignition/Door Lock key was flakey. It screwed up the ignition cylinder. After the Key and Ignition module were changed all was fine.
Any questions please let me know.
I had problem with wipers not going into a park. Shops offered replacement of motor and electronic card. They did not sound convincing so I did my research. I noticed that wipers went to park when it's raining. I disconnected wipers' transmission and tried to move it with hand and they were hardly moving. One of bearings appeared to be clogged with road salt so motor could not move it to park and normal moving speed was slow also. I found shop that agreed the reason of problem (there were some that did not listen) and got transmission replaced.
Try that.
P.S. I still do not know how damn motor works; too complicated.
Good luck!
I also have have wierd electrical problems such as the tail lights burning out and the driver's side window not working.
Climate Control Problems: All Cars
Electronic Gremlins: Electrical Problems That Are Driving You Crazy
I'm guessing it is the alternator, but on a previous post someone mentioned a "10316685 Kit screw for Bosch generators" that fixed an electrical system problem? Is it the alternator? The battery? Also if i have to replace the alternator what is a good place to get an alternator with lots of Amps so i can eliminate all light dimming from my subs.?????
My problems have been minimal over 200,000 miles, but include the following and resolutions:
If you have ever changed the air filter, it is a PAIN. Get a K&N filter, it does not need changing very often, increases gas mileage, and it is reuseable.
Change your plugs more often than 100,000 miles. Ask the mechanics for the used plugs - there was nothing left of mine, and it really puts a strain on the ignition system to bridge an enlarged gap. You would be amazed at how little is left of them. My mechanic can put the car up on the lift and change them without lowering the engine.
Change your fluids - transmission every 50,000 - mine was not and a local dealership messed up a warranty repair on a valve assembly - the combination equalled a new transmission.
LOSE THE RED ANTIFREEZE!!! - That stuff will eat your gaskets, especially the intake gasket. After only 40,000 miles I changes mine out - it looked fine, but it washed out mud. I put in green and it stayed clean. The red turns very acidic quickly. I recently put in the yellow/orange universal fluid.
I still have the original brake rotors, all original brakes and pads on the back. Ceramic pads are on the front, a little more expensive, but great improvement in braking, and the rims stay clean. A pad change on the front of these is a snap!
I just got new struts and shocks - I was riding on nothing but springs. Well worth the cost, the back shocks are cheap and simple to change.
Get an induction treatment from your mechanic to clean all of the goop out of your intake. Mine gets so bad that my throttle plate sticks shut.
I enjoy driving my car, and I love the 25-28 mpg on the Interstate. I have a rattle that is a lifter or injector, not sure which. I am tempted to take off my intake and clean it out good. I got the idea to get a shotgun cleaning kit and try to use it to reach in and clean it out, but have not tried it yet.
Hope this helps someone someplace!
Ted
Good luck!
Do you think it is better to switch from Dexcool orange to Prestone orange (are they the same?) or just do a thorough flush and switch to green antifreeze. I have used Prestone orange for 182K miles without any problems whatsoever on my '95 Mazda Protege. Of course, that is quite a different engine than our 2001 Olds Silo. with 45K miles.
Another problem that came up recently was a small coolant leak. I still have original hoses and thermostat, but I did replace the water pump about a year ago - did it myself, very easy and inexpensive. My leak was where the lower tranmission coolant line goes into the radiator. A repair would have been extreme, possibly requiring a new radiator! I used a Prestone leak stop, and it fixed it right up. Stay away from Bar's Leaks and other similar products.
It doesn't seem to weaken the metal that much, but it is unsightly. If you're seeing this type of thing in the middle of the hood, seems hard to explain. (Unless, of course you mounted a big hood ornament!!
Is there any other material in contact or nearby the parts of the hood that corroded?
Copy and paste it into your address line.
If you can see the crack, you MIGHT be able to use some engine silicone to plug it for a bit.
((I actually ripped a hole in the rubber grease boot on each and spay oil in once every couple days to keep it freed up - good enough for now, and my 7-year-old gladly had this task added to his list of weekly chores!))
Bottom line is this - the parts are not real expensive - its the labor - get it all done at once! It all has to be taken apart and aligned anyway. It is easier for a mechanic to pull out a new part than mess with an old one. Make sure the replacement parts have grease fittings on them for longer life.
just wanted to let you know that it sounds like your alternator is bad. but without properly testing you really cant be sure.. and when you say your ABS light comes on even when your not using it? You are always using your abs unless its disabled.. its probably a wheel speed sensor going bad or not getting enough voltage... that will turn on your light. your brake light will only come on if there is a problem with the fluid. perhaps you have an electrical problem as well. I would get it checked by someone who has a scanner... NOT A DEALER... go somewhere that makes there money on other things, like tires and ask there mechanics if they have a scanner.. pay the 60 to 70 bucks to find out whats wrong. then call other places to find out they're price to fix it... as for all the other people that complain about prices of auto repair.... WHERE ARE YOU GOING??? Think about this... I take my venture van to about 6 different places... I talk to the mechanics not the service guys... I listen to what they say and i judge them.. If i think they're just trying to get my money i go elsewhere... if i feel confident in that mechanic, ill let him work on it... take it from me, I AM an honest ASE certified mechanic. I know how they work... I still go to other places when i dont have time to work on my own vehicle.. or its something thats out of my league... like why wont my dash lights come on.... or the radio lights... i know its not the fuse. but not sure how this venture van works. I am not an electrical mechanic... sorry to ramble on but nobody else has this problem and i was reading yours and had an idea of what your problem was...
I've checked all the fuses, and just testing different things, i've come to the conclusion that I am lost.... everything works except the dash lights and the radio lights, now the radio lights come on but go off when the headlights come on... there is a dimmer switch that dims the dash lights and i'm thinking that this may be the problem... but before i spend over 100 bucks for this i want to know if anyone has had this problem and if they found a solution... thanks
Sometimes a bulb filitment can melt instead of break fusing itself together and completing the circuit creating bridging circuits that should not be. Look for bulbs that are not as bright as the others or burnt out, even if they have nothing to do with the interior lights. You could also try pulling the fuse on non-essential components (like the radio) and see what happens.
If not, I think your problem is your headlight/dimmer switch. I would imagine you can use an ohm/amp meter to check it out befor sure. You might even try cleaning it and its connections with electronics cleaner.
is on after I drive about 3 to 4 miles. Any suggestions on where to take the van to have this checked out? I am under the impression that a whole slew of diagnostics can be preformed by 'plugging' my car into some sort of terminal or 'reader'. Does this mean that I need to take the van to a specialist? Or can I go to a trusted Brake, Tire and Wheel dealer? I like the idea of going to the Chevy dealer where the car was purchased, but am worried about having to pay a premium. Thanks
Ask around - find someone that is ASE certified and has been in business a long time, long enough to have regular customers, accountability, and never hesitate to answer all of your questions. Word of mouth is best, look for the happy customers, ask for mechanic horror stories, if you know someone with a fleet of vehicles, they usually deal with one shop - you might even figure out where to go by learning where NOT to go.
A good shop will have a diverse range of specialists to cover all of your needs, and Make a list of problems and take it with you, since putting the car up on a lift and doing an inspection will take time and cost you a little.
I do not believe that the computer stores much in the way of compter codes for the brakes. Most car parts stores can read and clear your codes for you free of charge, and will even help you at least check your brake fluid and add some if you need it (mine is a 2000 too - adding brake fluid is impossible!).
Any ideas??
Gary
For example, the code read they did for me on my car showed the neutral switch being bad. But this could also be caused by the PCM connection being bad or the PCM not getting voltage or the wiring between the PCM and the neutral switch being bad. So check engine codes do not necessarily give one simple answer to a problem but rather a more focused number of possible causes. This is where the knowledge and experience of a good mechanic comes in.
If you desire to do it yourself, the Haynes manual for GM minivans has several pages of check engine code identifications related to Emission problems. You can find these manuals at your local library reference desk or at Auto Part Stores. And ALLDATA for $24/yr. has a lot of good TSB and diagnostic code charts for troubleshooting.
The procedure to reset the oil change message involves turning the key to on (but not starting the car), pumping the gas pedal three times, then turning the key off, all in 5 seconds.
The owner's manual will give you all the details.
Took it to the closest dealership and they told me to replace the radio/cd player with a refurbished unit would be $550! I about choked. We decided to do it. Then mid-May I'm sitting at a stop light and the temp gauge is sitting all the way in the red hot - then check engine light goes on, then check oil light goes on. I about croaked! Take it to the dealer, they say not sure...maybe cylinder head warped because it kind-of over heated, but didn't really overheat so coolant didn't kick in to cool it..and possibly warped the cylinder head. (They never did come up with a theory on why it overheated!) Would cost $500 to tear the engine down and diagnose the problem - not to mention the cost to try and fix it! They then continued to hee and haw about what was wrong for 2 days, so we had it towed back to the dealership where we bought it...they discredited the warped head diagnosis and said it was probably the gaskets (but would never know because the 1st dealership threw them out when tearing the engine down.)
After 2nd dealership replaces the gaskets, $1,000 later and 9 days later, I have my car back (this dealer picked up half the tab - this is where we bought it and they felt really bad about the problems). One week later the A/C stops working!! Then the next day the temperature gauge starts fluctuating all over the place (never all they way over to hot, mind you - so coolant probably not kicking in). It's now back at the dealership where we bought it - I'm still waiting to see what all is wrong this time. :lemon: We've already sunk $1,500 into this flippin' car since April. :mad:
I'm looking at Odysseys tonight - I think we're going to lease a $29K car - trading this stupid thing in - and be done with it! I really did like the Venture when it was running, but I'm a Mom and I need a dependable car! One lesson for sure, don't buy a Used Venture without buying the extended warranty - dummy me!
Maintenance cost for latest visit to dealer broke the camel's back. AC compressor they wanted $900, both brakes $650. Factor in a leaking washer tank, leaking windshield, and everything rattles after only 58K miles. Engine runs fine, but I am also starting to add coolant, very suspicious. A 2001 WB edition, and the VCR doesn't work either. Bottom line: I am not willing to wager any additional $$ on this time bomb.
Traded this 4 year van for 1/4 of the new car price, and got me a Toyota Sienna. Hope this time around the van will last longer than the car payments.
Good luck to you all. Won't see me in a GM dealer ever again.
Anyone know of a place online that I can purchase these from? I've gone to some replacement part websites with no luck. Repair seems simple enough. Any directions would be appreciated as well.
Thanks in advance!
Rich
The transmission cooler has been the best investment. It cost $180 to install and mounts on the front of radiator. I have the transmission fluid and filter changed every 30/35K miles. It does mainly a lot of short drives and stop starts so I go to a transmission only guy and I had it done last Saturday for $65.00. I would suggest you find a transmission only place in the yellow pages. Avoid the High Street regulars or quick change people.
If the fluid has bubbles then you need a cooler. The manufacturers short change by running through the radiator which on a hot day can make it worse. The cooler drops the transmission temperature by 20-30 degrees.
Im would suggest to anyone who wants to avoid a costly transmission replacement to get one the cost is minimal in the scheme of things.
I tried to get one on my other car - Suzuki GV XL7 and just was not the room.
What I do is physically move the throttle fulcrum over to the right three times to ensure it is reset. As you are limited on time you have to have the drivers window down to lean in and turn key then go round to the front.
