Visitor Agreement.
thanks again!!
There are 2 of them in there behind that door in the back.
That was the issue they were plugged solid!!! You guys are amazing, all total you have saved me $1000 in repairs and unnecessary trips to the shop. If your ever in Halifax, give me a buzz and lunch is on me!!
thanks again guys!!
All the best,
John :shades:
PS - I don't know about Tony but I like to eat a LOT so it might be cheaper to consult with a mechanic next time than offer to buy lunch...
what could the problem be Electric problem, needs a tune up. wires. alternator
Anyway, last year I had two of my pullies bearings go out. When they did they took out the belt and some wiring. Pull the belt off and manually feel all the pullies, and when I say all I do mean all. Give them a turn and wiggle them up and down to see if they have any play. The pullies are all generally easy to change.
Also.....check your bottom crank pully and your alternator. The crank pully is made up of two metal parts bound together with a rubber piece between them. The rubber gets hard over time and the two metal parts start to separate. If they look misalligned at all you will do yourself a favor by changing it. Mine luckly just ate up a belt first. I have heard of the pully coming apart and really doing some damage to the van. You will need to go through the right side wheel well to change it.
I have not changed the alternator yet. So I don't know what that entails yet.
Man I sure hope you can help me out with this one. My 2001 Venture has started making a funny squealing sound when I am driving and I need to give it some gas to get up a hill or anytime it has to downshift and rev up a bit. Any suggestions on what this could be? I have just changed the belt and tensioner and still a loud squealing noise when it revs up. Any ideas? Could it be another pulley or water pump?
regards,
Stephen
regards,
Stephen
Take the belt off and try to turn all of the pulleys by hand. Except for the crankshaft (obviously), they should all be pretty easy to turn by hand. You might find the problem that way.
Another way to check the water pump while the belt is off is to grab the pulley and try to move it in and out or up and down. If there's any play in it, the bearing is shot and the pump is due for replacement.
I don't own our Venture any more so I can't go outside and look but there's likely an idler pulley in addition to the tensioner pulley so be sure to check that too.
You didn't mention having the AC or defroster on so we won't talk about the compressor for now.
Good Luck - write back and let us know how you made out....
John
Don't forget to check the alternator while your at it.
I have also replace the power stearing pump.
My suggestion to you would be to remove the belt, pull off the pullies one by one and feel with you fingers how easy/hard it is to turn. It should turn fairly easy with no (NO) bumpy feeling at all.
a drastic suggestion: check your parts place for returns! you can always take the approach of changing things out till you find the problem!
As for the TCC - if the switch is stuck on, the torque converter is staying locked and is likely causing the stutter & stall under 40 MPH. Unfortunately, it has to be replaced. You can try changing the trans fluid & filter as I've seen that cure a stuck TCC but likely you'll need to have it repaired. They don't have to remove the trans but they have to remove a bunch of stuff to get to it. If you're not above average with tools its best left to a mechanic.
I spoke to a Chevy dealer who had the hardest time finding out who the manufacturer of the dvd player is. Since he wasn't able to find it even by calling GM (very helpful) I was wondering if anyone out there had this information? Also, does anyone know of a reputable company that will sell me a refurbished dvd player and remote for my 2003 Venutre Van?
motherhen68
Mine stopped working on a regular basis and there is a proceedure to go thru that will make it work again. Do a search on resetting the door opener and you'll find it. If I have time, I'll post it here unless you find it before me. I also think it's in the owner's manual; check there.
-Tony
Also, the wheel berrings and brakes always cost me a fortune for this thing. :mad:
The recall was NOT for a simple non-working door.
I live in Wisconsin. Need something decent in snow and rain. Are one of these a lot better than the other?
Thanks in advance!
there
if you live in the Mississauga ontario area there is an autowreckers
called COOKSVILLE AUTO
i've seen that part that you are looking for they have 10 minivans for Scrap there
and i seen that part today cause mine is missing also
it needs to be replaced
i here ya
i just bought a 2000 chevy Venture back in December 2009 for $2,500 and it is in mint condition no rust it has 156000km when i bought it and now it is 160660km and it runs really well i've had minivans in the past but this one tops them all
i get 1150kns on a full tank on the high way but i only get 750kms in the city driving
this van is my first here in ontario. i'm orignally from NEWFOUNDLAND me and the wife were hoping to drive to newfoundland this summer 2010 2,464 miles.but i'm afraid where i don't want to wreck the vehicle it's to good i was going to by a 2010 Dodge Grand caravan that sucks cause there all the same as in the features like the seats fold down into the floor ? what if you spill pop or juice on the floor there goes your seats, side windows rolls down if a kid is not locked in there seat they could fall out of the window , and the front end where the grill and the rad surport is well it's all plastic. :surprise:
but you can reset them yourself just go to your owners manual and it will tell you how to reset them what you have to do is press the lock and unlock at the same time for 7 seconds and it should reset.
it is for the air that circlates inside the vehicle from the outside for fresh clean air,
they are $ 20.00 to $25.00 comes with two in a box it is called a Cabin Filter.
