Visitor Agreement.
I agree on the button on the back for the rear hatch and a better release for the emergency brake.
I am also pleased at how manevrable this vehicle is and how it keeps its feet planted on some very rough road.
AS to the gas mileage, I am getting 17 to 18 mpg in suburban driving, about what I expected.
Ed
Ed
This will be our fifth (!) Chrysler minivan and our second T&C AWD. I guess you could say we're true believers! All the luxury, coupled with the room to take everything, plus decent +20 mpg mileage...why does anyone buy an SUV instead?
Jay
This TSB has nothing to do with the transmission. I will add that a conversation with my service manager confirms my belief that the transmission fluid and filter should be changed at 30,000 to 50,000 mile intervals. The owner's manual states 100,000.
I hedged my bet by buying the Maximum Care contract for 100,000 miles. However, good routine maintenance of the oil, transmission fluid, and the above power steering should make the next 66,000 miles uneventful.
Just a note, the PT Cruiser requires 34 psi so the 36 psi doesn't sound out of line for it's big brother.
I have experimented with higher pressures and have monitored tire wear and handling characteristics. On my rear drive sedan, I have increased the pressures by 5 psi and have crisper handling and less cross wind problems. On my T&C, I have increased the pressures to 40 psi when on the highway with full loads.
Bottom line: the posted pressure is the minimum safe pressure. The maximum pressure on the side wall of the tire is the highest safe inflation. All measurements should be made with cold tires at outside ambient temps. Monitor handling and tread wear patterns with each adjustment.
We've now got a situation where we'd like to tow with the vehicle, and were wondering if its possible (or if anyone has done it) to retro-fit the towing package to the vehicle? My local dealer seemed to think it was doable, but at comsiderable cost.
I know that the brochure indicates the the package includes the load leveling rear suspension, an higher capacity alternator and battery. What else is different about the vehicle with the tow package than without it?
If we don't (or can't) add the tow package I know we can still tow around 2,000 lbs. Assuming a tow weight of about 1500 lbs, can we still carry 3 adults and the stuff associated with a weekend caming trip (I'm thinking about GVWR)?
Thanks for the help and advice.
Watch for engine temperature and fill tires to maximum pressures printed on the tires.
My good friend has a 1999 Grand Caravan ES 3.8 FWD with the Autostick transmission they use for towing their trailer and are very happy with their van.
Also, I believe it is not full time AWD and will only kick in once the wheels slip.
We're about to take delivery of our fifth Chrysler minivan. Our first three (starting in 1988) were fwd Plymouths and Dodges. The last was a 98 T&C awd and the new one we're picking up on Friday is an '02 Limited AWD. We put about 20K miles on 'em every year and we live in NE Ohio so we have some experience. There is a slight increase in mechanical noise compared to the fwd versions but, we go in the snow, even if our long driveway hasn't been plowed! It also feels like there's more stability on hills and curves. Whether we would have gotten stuck in a fwd version, I can't answer. All I know is that we somehow feel more secure in the awd vans. AWD means the system is always on; the ratio of front/rear power varies based on demand. In non-slippery conditions, the ratio is 90% front/10% rear. The Chrysler awd system doesn't allow "lockup" which means that if one front wheel and one rear wheel have no traction, you will get stuck! I've read that the Acura MDX awd system will allow lockup. (We've never gotten stuck...)
BTW, we've generally had good luck with our vans. The 98 has 94K miles on it with no unexpected expenses. There are awd specific parts so be prepared when you have to do a brake job...it's more expensive than the fwd versions!
Good luck!
Jay
Any help would be appreciated...
Jeff
This is my first minivan, I have only owned sedans, but I am now a confirmed minivan owner.
[non-permissible content removed] luck with whatever you choose.
Ed
Now you can get a leather trim package just like on the LXi on the eX for about $28,700, and now there is the Touring Edition of the eX which features non chromed T&C Limited wheels, badging, and an in the dash DVD player for the back seat.
The screen comes down in the back just like the VCP, but now you can free up the center consol and load the DVD's where the CD changer is supposed to be.
I believe you can get this with leather also, and its price with leather is around $29,600. Hope this helps!
I appreciate the help, but the problem I am having is finding dealer who knows about the "Touring Edition" package. Did Chrysler actually send any of these out of the factory?
Jeff
Thanks for the help though.
Jeff
I guess these models will start shipping out to dealers pretty soon...
-Adam
can i install the dvd on my 2001 tc? for my year, i believe it came with a vcp option.
BTW, my local Chrysler dealership has several new 2002 Town & Country Touring Edition models ready for sale.
-Adam
just bought a brand new 2002 T&C Ltd last FEB, and i think i am getting very low gas mileage. my wife typically drives the van around 20 miles a day, about 2 miles per trip. we get no more than 14 mpg for this type of driving. this is w/o using the A/C.
on a long freeway trip (100 miles+), we get around 18 mpg. brought the van to the dealer and we were told this was normal for this type of van.
also, we were told that the mileage would get better as it racked-up more miles. (current mileage is 4400 miles). any explanation for this?
any input from other T&C owners out there would be very much appreciated.
Keep tire pressure between 36 and 41 psi, and change your oil no later than after the first 5000 miles. I agree that highway mileage is a more consistent measurement than the variables associated with in-town driving.
we'll go on a long drive this weekend, and i will closely monitor our gas mileage.
nice memorial day weekend to all of you.
ENjoy your trip
Ed
My millage driving in small town / suburban areas is 19. It is a nice vehicle.
Now if it doesn't go through three transmissions like my last one, I will be thrilled.
Long term reliability will be optimized if the transmission is serviced at 30,000 to 50,000 miles. The correct Mopar +4 fluid replacement is essential.
Another area of concern is the power steering pump, rack, and accessory belt tensioner. There is a TSB which details a change in fluid type and a replacement tube for the power steering. The new ATF fluid in the power steering will dramatically quiet the PS pump, eliminate the chirping, and should increase the longevity of all of the above components.
I think that these steps should address the long term reliability issues that have plagued the T&C in the past.
Some parents are being told by dealer and manufacurer that only one [or two] child/carseat may be installed in the 3rd row of the 2002 models. In addition, Chrysler apparently switched the number of factory installed tether anchors from three to one from MY2001 to MY2002.
Any information on this would be appreciated. A scan of the relevant pages in the owner's manual would be great. Please no flames or attacks, I need the information to assist parents with proper carseat installation information. If you do have information, I'd appreciate a copy to the email address in my profile in addition to a response here. Thanks!
I have a 2002 Town and Country Limited and for the second row, we have two captains chairs with tethers on each one. I will have to check the third row, but I believe it is two tethers there also. The third row we have is a split bench, they also have the new LATCH system in the seats.
I would like to take advantage of the headphones that came with the system and the rear audio, but don't necessarily want to pay the 1400 + for the mopar system.
My job requires lots of highway and frankly I'm very disappointed with this vehicle I traded a 99 Chevy Venture with 110,000 miles and in great condition for this T/C(26,000 purchased used)
Talk about buyer's remorse...It starts and idles rough,lacks power and the drivers seating position is uncomfortable due to the power window "hub" rubbing my knee.If I gained anything at all from this purchase is to rent what I intend to buy first or insist on an overnight/extended test drive.
