Nissan Quest/Mercury Villager problems
1. VCR stop working the first year and I can never pull it out since I bought it. It stuck and the pull knob broke. I didn't bother to fix it.
2. cd player/radio light went out..again didn't bother to fix it since it still working.
3. some part of tranmission loosen at very first week when bought it..got it fix at dealer.
4. air sensor went out the first year..got it fix
5. fan won't stop running when turn off engine.. this happen first time when bought the van at very first two weeks..never took to dealer since can be recharge battery and work..then today happen again, but this time can't do just charging battery..
6. noise in the van..dealer said that the way Nissan was..Hah
Does anyone have same problem? I guess after I fix this one up will trade in for Honda..I hated Nissan..Never recommend it to anyone else. Nissan service was bad too.
I have a 99 Villager (base model), 81K. The A/C blower fan has stopped working on the 1,2,3 settings in the last 2-3 days & now only works on 4 or 'max'. I think it's a bad resistance that controls the fan switch. Can someone help me fix it? A wiring diagram perhaps showing location of the bad part.
I have browsed webpages by Steve Cutchen, Marco Veenis & David Massey but my problem is just the switch since I don't have rear A/C blower.
Any help will be greatly appreciated.
mnrana@hotmail.com
Do you by any cahnce still remember the part # for that resistor. Mine blew last night & I need to replace it ASAP, this being summer n'all.
Rana.
I keep hearing that all the Nissans that were manufactured in Ford plants (you can tell this information under the hood) have electrical problems. If this is so, why isn't there any legal action or recalls going on?
I'm with you..thong24k...trying to save to purchase a Honda and get out of this Nissan. I'm really disappointed in the car.
My drivers side power window switch is flaky (a common problem with older and apparently the new Quest) and it was supplied by Alps.
Otherwise my '99 hasn't had near the problems that yours has had.
It is located on the underside of the dashboard on the passenger side. Look for an oblong thing about 3" long with wires going into it, held in place with a screw. If you unscrew it you can pull it out and disconnect the wires & take it to the parts counter with you.
Hope this helps.
Dave
I've been in old Villager/Quests, and yes they do rattle and some of the internal bits aren't where they should be or are completely non-operational, but the vehicles still run - which is any vehicle's most valuable trait.
My 2001 SE has only bothered me with one unscheduled maintenance item (VERY minor and fixed under warranty) in 55,000 miles of ownership. I couldn't ask for much more.
Try removing the hanging spare for a day or two to rule that out.
The only thing else that occurs to me off-hand is the rear brakes. You might try hosing the wheels down good to get rid of any brake dust or just have someone look at them.
I got under the car and had my son push the rear bumper up & down, the noise is definetly from the leaf springs. I took a 1/4 inch washer and put it in- between the two leaf springs and guess what?, it stopped. Maybe I could buy some spring spaces for a more permanent solution. Yes, the guts of the rear brakes have alot of dust in there and could really use a lube on the contact points of the brake hardware. Wonder what the deal with the leaf springs is? I'll keep investigating. Thanks, again. Darrell / Las Vegas
Good Luck shohjwh
My driver's window electric switch in my 2000 Villager, which I changed at outrageous cost, is holding up fine. Has anyone out there had to change that switch group more than once?
Yet :-)
Jon
I have a 96 Villager LS with 103K miles on it.
1. It developed an oil leak from the crank seal and i thought I will get both, the timing belt and the crank seal done at the same time. Today took it to the mechanic but later he called me that he cannot get one of the tensioner pulley(or crankshaft pulley, i am not sure) out of the casing and that now he needs some special tools (he was talking abt putting some two small special screws in it and pop it out or something like that)
Has anyone had a similar problem like this?
2. Also, both my CV boots were torn so the mechanic suggested that the cost of replacing both the CV boots is almost same as getting new remanufactured axles. what do you guys think?
Thanks guys
I would suggest going with the axle assembly if you have driven for very long with torn boots.
There is no noise when backing and turning as long as the steering is not all the way to the stop.
The good people on this board, through sharing experiences, diagnoses the problem as a loose anti sway bar/bushing problem. A trip to the dealer for the turn of a wrench and a little grease solved the problem. Over 55,000 miles have passed and the problem has not returned.
Vadim
Additional info:
I went to AutoZone and used their OBD-2 code reader to find out that computer identified P0325 code (Knock Sensor Circuit Malfunction). I cleared this code and Check Engne light is still *off* after ~50mi.
I am wondering if a knock sensor malfunction could result in high idle RPM?
A reliable mechanic who works out of his home has quoted me $450 including all belts, water pump, seals, antifreeze etc. He has a lot of local satisfied customers as reference.
Also the local dealers are quoting between $775 to $900 for the same job.
Not sure what to do? One Goodyear shop mechanic asked me to save the money for the trip and have the repair done after the holidays as 69k miles is too early for replacing the belts on a Nissan.
I will appreciate your input to this matter. Thanks.
When you do have the water pump and timing belt changed, I would also recommend replacing all coolant hoses if they are still original as this is easy to do as part of this job.
$700+ is what the L/M dealer in SC quoted for the same job.
Then I dreamed the van was stolen and stripped. I don't know what the heck that means :-)
I have an ongoing conversation on this forum with Steve and others and none of us are dead sure of the answer. I have 80K on my 99 and if I find out it has an interference engine that would cause a catastrophic failure if the belt brakes I would be less likely to go the 105K in the manual. My luck is not that good.
Would be interested to see what type of engine your mechanic says we have in our vehicles.
I specifically mentioned my make and model, and he said the total cost would be $ 450.00 including belt(s), seals, water pump, anti-freeze, etc. Can't beat that. Now I like to meet him and get that quote in writing. BTW I will be travelling from TX to IL and MI in winter. I am likely to put almost 3500 miles in two weeks. Just don't want to take the risk of being starnded in the middle of nowhere in freezing temperature.
I will keep everyone posted about my meeting with the mechanic. Until then,
Goodbye.
Another good place to ask is the Stop here! Let's talk about brakes discussion.
Here's one post about it:
dhoff Jan 5, 2002 5:33pm
All the stuff was assembled by Ford employees in Ohio.
The joint venture ended early in ~2002.
I wouldn't worry about stuff unless you start having symptoms of something.
I had noticed were engine hesitation while cruising between 50-55 mph and 20% less gas
mileage. In order to prepare the vehicle for emission test, I took the car to Firestone and it was determined that (P0172 code) new oxygen/O2 sensors ( both upstream and downstream) were needed. They were replaced at $400.
CHECK ENGINE LIGHT had come back on after driving it for less than 20 miles. Firestone determined that it needed EGR-BPT ( back-pressure transducer ) and EGR valves which cost $500 due to P0400 code.
I took my car to another mechanic for a second opinion. By visual inspection, he had determined that the 3-inch BPT hose was cracked. It was replaced at $10. CHECK ENGINE LIGHT came back on again after driving it for 100 miles. It was the same code P0400 which indicated a problem somewhere in the EGR system which could be any of the EGR components.
I took the car back to the second mechanic who took a closer look at both EGR-BPT and EGR valve. Both seemed to be working fine i.e. no carbon build up at least. He cleared the code from the car's control module. I had driven it for more than 100 miles both local and highway, and the CHECK ENGINE LIGHT had not come back on. I decided
to take a chance and took the car for emission test and it PASSED. I have just saved myself $500 for replacing the EGR-BPT and EGR valves. I have 2 more years before the next emission test.
