Visitor Agreement.
Pontiac's cladding had become a joke in the industry. It's about time they got rid of it. Sales of them are way down this year and they needed to modernize the cars.
Cladding is like too many gold chains and "Mullet" hair, over!
When I first bought my 2000 Grand Am SE I didn't really like the body cladding, I thought it was a bit excessive. But after having the car for 1 1/2 years I have grown to like it.
...I'll stick with my 2000 model with the "excessive cladding"
Low and behold it was black(PS fluid should be clear looking with a tint of brown) so i flushed the system by using a giant seringe and sucking all the fluid that i could out and adding clean fluid. i have done this maybe 6 times now and put more than 2 quarts of fluid throught it. the fluid is now clear and does not seem to be getting any darker as i drive it. The squeaking is less severe, but its still there. i have thought about changing the belt that runs the pump. also, if i rev the engine up a little when i turn it wont squeak as much. any help with this????
If it's a V-belt, adjust it.
The fluid was probably just dark from age. It's best to take a drop of the fluid and put it on a piece of white paper (thick paper that it won't soak into fast) and then you can really get an idea of how dirty it is. By the way, it's acceptable (and many times recommended) to use trans fluid in the power steering, which will not be clear.
Also where can you get refurbished rims from? My sister seems to have dented one somehow.
I know it seems like we're are horrible drivers but its just bad luck. Our 96 prix just got totaled and we never got any $$ back from it and it wasnt our fault, it was just parked.
Also on our GA we recently just got our rotors changed too at 26K. Ok I know this will sound stupid but what are rotors for? Thank you for reading sorry for rabling.
The highway is being mean to my GA's front and I think I might want to protect it by using a bra.
Anyone out there use a car bra? Anyone have good/bad info on them?
Any suggestions on where to get them?
I would not recommend getting a car bra. I was in the same position as you last year, my front bumper on my 2000 Grand Am was repainted and I wanted to keep it looking nice and new. I purchased a full front end car bra from my local Pontiac dealer for about $50. I wanted to make sure it fit perfectly and was made for the car so that's why I didn't go with an aftermaket one. A front end cover consists of the front end cover that covers the entire front end bumper and a hood cover that slides over the front edge of the hood.
I used it for a while and then stopped using the front end cover and only used the hood cover. About 6 months ago I stopped using it all together. These were my reasons:
1. It is not really difficult to clean the front end cover, but it does take time to dry. It is NOT recommended that you put the cover back on the car while wet.
2. Dirt, sand, etc. collect along the underside edges of the cover which can cause minor scratching of the clearcoat if left for several weeks without cleaning. Leaves, bugs, dirt, etc. also collect along the underside of the hood cover.
3. Water does not drain as efficiently on the hood cover as it does with the front end cover. This can lead to mold spots on the surface of the car. (see my experience below)
4. The hood cover caused paint to rub off of the side edges of the hood (This is where the cover wraps around the thin edge of the hood)
I had been using the hood cover for about 3 or 4 months when I discovered mold spots on the hood of my car. I like to clean my car every few weeks, so I was washing it and I removed the hood cover to clean it. As I was washing the hood of my car I noticed a few small green spots along the front of the hood, directly under where the cover sits. I had to end up scraping the mold off with my finger nail and then washing the affected areas well with the soap. After this I stopped using the cover all together.
I still have the cover, but it's in a box in my storage closet. I would recommend using the cover if you were going on a long road trip, say on a vacation or something like that. But for everyday, local driving, I would not recommend them because I don't think they are very friendly to the car if used regularly.
This is my experience, I hope it helps you decide!
I have a '00 GA GT, and have had this happen to me about 8 times. As you said, the key will not come out, and the owner could spend a long time trying to get it out. Once, I got it out by braking hard and then shifting into park. It doesn't always work though. The other times it would just come out by force after turning the key back and forth (about 10 times). Ironically, my wife uses the car more than I do, and it has never happened to her. I have started to put and remove the key slowly and delibartely. So far so good, it hasn't gotten stuck again. The dealer said it would cost about $250 to repair and that they had succesfully repaired it for someone else. Also, if you definetly can't get it out, I suggest that you carry a keyless entry remote separate from the key chain so at least you can get in and out of your car with the key left inside and at the same time have the car alarm armed! I know this is only a temporary solution (and only if it doesn't happen every time) but it works when you don't need to be out of the car long. Personally, I would only do this if I were to be away from the car 20 minutes tops. Thankfully for me, it has been about a month since I started being very careful and there hasn't been a problem. I hope my comments helped and let me know what happens!
freddie01r
It's probably better that it has become history.
Since Feb. I have driven from Ohio to WV and back on three different weekends. We have also taken a week to drive through WV, Va, NC and back. The car has 54.000 miles on it. I also drive 60 miles a day roundtrip to work, so it gets a good workout.
During the past 5 months, the car has needed front brakes, back tires, a water pump, timing chain, and now it's at the dealer's for an alternator.
I stumbled upon this website in a desperate need to know that we didn't buy a lemon! I have spent the entire weekend reading all 1479 posts...THANK YOU for sharing what you have---it truly puts my mind at ease to know that it's not just my car. I absolutely love it when it's not in the shop, but it is getting a bit aggravating having it there every two weeks. I look forward to keep being "educated" on what to look out for and what to expect/plan for with GA's here...thanks again!
so now i am at the point where i must rip apart the whole engine (intake manifold, exhaust manifole, timing case, power steering pump) so that i can get the cylinder head off and replace the valves that i screwed up, any other ideas i may be forgetting before i rip the cylinder head off? if not does anyone have a good website where i can purchase valves and anytbhing else i need?
My question is this; how does something like this get unnoticed, how does a brand new car just sittin on a lot get so badly damaged? It just pisses me off because it doesn't really feel like a new car cause its BROKE. Would it be unrealistic to ask for them to throw in window tinting or something like that for the inconvenience?
any comments are so very appreciated.
As for asking for a tint job in the previous post, you can try but they are under no obligation to make you happy. Also it is normal for you find and note broken items during your final walk around, not during transport. Unless they were unscrupulous and trying to get rid of a unit with known door problems. Alas its all under warranty. They are under obligation to fix this and should fix it with a smile.
http://minimopar.net/oilfilterstudy.html
Also what air filter do you prefer?
I've been told it's a relay problem. I'm waiting for an electrical diagram to troubleshoot it.
