I'm not sure how your warranty is structured but the basis for deductables is to avoid people from abusing the warranty. If there were no deductable, someone could take it in for every little squeek, rattle or anything basic.This would double or even triple the initial cost of the warranty. The warranty is supposed to cover the car if it needs major work like a tranny or motor or anything over $300 dollars or so. If you have a small repair under a $100, just pay for it and don't even use the warranty.
I purchased my 97 GrandAm GT in 98 with 8,000 miles on it. The car currently has 41,000 miles on it. During the factory warranty period, I had to have the weather striping replaced, the front passenger door re aligned, the air conditioning fixed, and an alternator replaced. I have an extended warranty but have not used it for all needed repairs. A knocking and acceleration problem emerged two years ago, but the warranty company refused to approve the diagnosed problem (the lifters) because it wasn't happening all the time. I've replaced on my own the brakes twice, the battery, the driver's side power window motor, and some type of belt bracket. A month ago the alternator failed again and I had it towed to the dealer. The warranty company approved the repair along with fixing several leaky gaskets and connections. I also had other maintenance things done at the time at my expense (engine desludging, fluid flushings, etc) The lifter problem returned last week and I again took it to the dealer who again diagnosed it as a lifter problem. The warranty company after a week of having me provide documentation of regular maintenence and then requiring me to authorize a futher tear down of the engine to determine the cause of the problem was engine sludge buildup (and denied the claim because based on the assumption that this was due to lack of proper maintenance.) I didn't get to speak to the claims adjuster directly but was told by the dealer that there wasn't any sludge there at the time, but it was based on evidence that there had been some sludge buildup in the past. I have documentation that I had the oil changed and other services every 3,000 miles and I'm confused as to what could have caused the sludge buildup if it was not due to my maintenance. I read recently that Toyota customers have had similar engine failures at low mileage and the company first used the same argument to say that the evidence of sludge build up was due to the lack of timely oil changes. After consumers affected by this decision began providing evidence of regular maintenace the company later decided that those who could show at least one oil change a year would be eligible for Toyota to compensate them for the engine work. Toyota won't concede that it was a design flaw that contributed to the problem, but others think that may be the case. My engine is a 3.1L V6. Has anyone else with this engine experienced sludge buildup problems despite regular (every 3,000 miles) oil changes?
Re Message 1470 I have a Grand Prix and the key is now stuck. Dealer showed me that I can put my finger in through the bottom of the steering column cover and push a button up on the bottom of my ignition switch. This allows me to turn the key to the lock position and the key comes out. I found it is easier to get my finger on the button on the bottom of the ignition switch if my steering wheel is all the way up. This is temporary fix until I figure out the real problem.
It looks like I may be going thru my 2nd PS pump! Had 1st one done under warranty. Now I'm off warranty. This car is irritating! I have replaced only ONE power steering pump in my history of car ownership (so no "driving habits" excuse!). Has anyone had a consistent power steering pump problems on this car?
I am starting to have some more problems with my turn signal lever on my 2000 Grand Am SE. Sometimes when I use it, there is no signal. I have to move it up and down a few times and then it will release and start functioning properly. I think what is happening is sometimes when I use it the internal mechanism is not fully releasing after the signal stops, and then when I go to use it again, the lever feels a little loose and no signal comes one.
So I was wondering if anyone else has had this problem? It sounds like something I could fix myself if I get the correct part...is this possible? What part would I be looking for, the turn signal switch lever?
I have a 2001 GT that had a problem with the turn signal making noise, even when the signal wasn't on (it was loud and very rapid sounding). I got it fixed under warranty and heard that it is a common problem with the Grand Ams (a lady was there earlier that week with the same problem). I think they ended up replacing the emergency lights switch in the dashboard, but I'm not sure.
That sounds like you had the same problem (my turn signal also makes the mysterious clicking noise every once in a while). Unfortunately my car is no longer under warranty, but if I knew what part to look for I could order it and install it myself.
Do you know exactly which parts(s) were replaced on your GA...do you have the invoice to refer to?
Sorry, I looked everywhere, but could not find the invoice, as it was almost a year ago (it happened only a few months after I had the car). If I find it, I'll let you know. You could also ask around at http://www.gaownersclub.com, the people there are really helpful as well and know a lot about Grand Ams.
I have a 99 GA SE1 V-6 with a constant noise in the front suspension like a creeky old bed.Could it be struts? Vehicle has 41,000 mi. and has had a motor mount and transmission replaced under warranty, but is out of warranty now. Any ideas?
....yeah....mine has a bit of a noisy suspension too. GMs seem to get this problem in "mid life". Sometimes they blame it on the "sway bar bushings" which might need to be lubricated or replaced (usually not that expensive). The last 3 GMs I've owned have had this problem! (they seem to be bad with motor mounts too). That's why I'm trying hard NOT to buy any more American vehicles!
I forgot about those bushings! I think there's a couple of TSB's on the front suspension. I just bought an additional vehicle - a new Vibe AWD, mainly because of the Toyota engine/transmission. Hope it's less trouble than the '99 GA has been! ++
Im having trouble with my brakes. I had to replace them 2 times this year. What type of brakes would yall recommend for this model? 98 Pontiac Grandam V-6 Sedan. Also i need advice on some good tires for this car!! Deb.
I have a '95 Grand Am and throughout the last year I had replaced my brakes 3 times. I finally figured out that the calipers were sticking on both sides and needed to be replaced. My calipers were only $14 through Autozone so it wasnt a big deal to me b/c I do all the work myself. ** I have major problems with my lights, at first my headlights wouldnt come on right at first and I would have to flash the brights and then all of a sudden the lights would come on. After a while that stopped working and now to have any sort of lights I have to hold the switch back - for the brights - while I am driving. The parking lights always work but the cruise never does. Has anyone ever had a similar problem. I was wondering if it was just the switch itself.
I have a '98 GA and I can't figure out how to adjust the damn headlights. They are pointing too high and I would like to adjust them to point a little lower. But, I just can't find the set screws to point them down - now I have owned a few cars, and never had a problem finding the adjustment screws, but these I just can't seem to find.
I would really appreciate if someone could point me in the right direction with a description of where the adjustment is or a web site, etc.
HI EVERYONE I JUST BOUGHT A 1998 GRAND AM WITH 70000 MILES IT,S A V6 4 DOOR SE SEDAN WOULD LIKE TO HEAR ANY OPINIONS ON THIS CAR U MAY HAVE IM REALLY HOPING IT WILL LAST AT LEAST 150000 MILES
was driving my 93 grand am for about 30 min everything seemed fine then for no reason the car started shaking and stalled . after trying three time I got it running ran for a few more min and did the same thing . got it home waited 5 min drove around for about 30 min it was fine anybody have any ideas what's wrong ?
Fuel delivery is probably the most likely suspect. You didn't say how many miles, but if it's over 75K the pump would be one of the first places I'd look.
Does anyone know what kind of relay I need for the turn signal/hazard lights. Mine is acting up and I've decided to replace it to see it that fixes the problem. I just wanted to see if anyone could give me any info before I take off the front panel trim to access the relay.
Also, my coolant resevoir was really empty (my dash light came on) so I refilled but I'm wondering if I put too much in because I filled it to about 1" from the cap. It's been about a week and I haven't had any problems, no steam or anything. What kind of signs should I watch for if I have overfilled the resevior?
The bottle should be marked where to fill it at when the engine is cold and when the engine is hot. You might do well to get some of the overflow out of there, lest you damage the bottle.
What is the specific problem with the signals? If it is the continual and/or intermittent "clicking" after the stalk is turned off, it's not the relay (flasher) behind the trim panel but the "multi-function switch" in the steering column (yes, the flasher is making the noise, but the switch is causing the problem). The flasher unit is a bee-otch to get out, and the fool thing was $42 Canadian with my 20% discount. The "multi-function" switch was $150 Can + labour. I long for "back in the day" and the $4 universal flasher....
stumack1... It hasn't happened in the last few weeks, but sometimes while my signal is on, it will suddenly stop working (no light or click). I have to reset the turn signal stalk and push the hazard button once or twice to make the turn signal able to work again. Someone said that there might be a short in the relay, and that the turn signal lights are routed through the hazard light switch. But sometimes it feels like the turn signal doesn't release. And yes I have been driving along and all of a sudden I will hear clicking noises, but no turn signal lights come one. What's the deal?
How do I get the flasher unit and multi-function switch out, would I have to replace both?
...the flasher unit you must remove the trim panel around the radio and heater controls. Its tough to get your fingertips in to get a grip, but it will pop off (there are 4 metal clips holding it). To remove the flasher unit, there are three screws holding another small panel to the back of the first which also must be removed. The flasher is then accessible, but I had to break the clips holding it into the small panel (there is no way to squeeze them in to relase the flasher) to get it out. The new flasher will also come with a hazard button already attached.
To get at the multi function switch, there are three bolts on the bottom of the steering column holding the 2-piece trim on. Remove these bolts and the trim pieces, and everything is accessible. I let the dealer do it, but I think the multi-function switch comes off with 2 small bolts and one electrical connector. The steering wheel trim pieces are also a pain to get back on..takes a lot of jockeying around to get them to fit together correctly at the back (dash) end. I'm betting your problem is the multi-function switch and that the flasher relay is okay.
I have a 1993 pontiac grand am se v-6 3300 and i am looking for performance parts that help it in power and speed.anyone know where i can find anything.all replies appreciated!
i recently owned a 92 grand am quad 4 and was consistenly getting 25 mpg with the 5 speed. I quickly got rid of it because of all the trouble it was causing me, and then purchased a 1993 grand am automatic with a 3.3 liter v-6. I am so disappointed in the gas milage that i have no clue what to do about it. I am getting maybe 15-16 mpg. Its rediculous. I dont drive it hard or anything, but am barely seeing 250 per tank. I changed the plugs and wires to bosch platinums and some lifetime autolite wires. I saw a very small improvement but nothing i wouldnt have expected. Any suggestions or are the 3.3 just gas hogs. I have thought about going to a k and n filter but im not gonna waste my money if theres nothing wrong with the gas milage. HELP
The 3.3 is listed at fueleconomy.gov as tested to provide 20 city and 29 highway. You might consider replacing the o2 sensor(s), fuel filter, air filter and ECV valve, if applicable. It might also be a good idea to inspect all of the emission systems specific to the vehicle.
I'm not a big fan of higher octane fuel, but you might try 2-3 tanks to see if it has any effect.
I have a 93 pontiac grand am v-6 3.3 and mine gets about 18-20 m.p.g around town,when i first got it i put some lucus fuel injector cleaner in it and got better gas mileage,but it also depends on how much stop and go driving you do and how fast you accelerate,but whatever you do dont get rid of it that year and motor is a really good car,mine has 138,000 miles and it still goes strong.
Been awhile since I posted, so here's an update. 2000 3.4 V6 SE1 w/ 57000 miles. Recently, my gas milage has gone to hell. for mostly highway driving I would normally get 27-28 MPG, now....I get 18 MPG! also, my fan switch no longer operates on settings 1 and 2, and yesterday i started smelling burning wires from outside my car. I am bringing my car to the dealer next week. Has anyone esle had either of these problems?
The fan not working is probably the blower fan. Happen to me in an older Pontiac, very easy fix. It was less than $200, but that was about 5 years ago (it was a Pontiac 6000 - anyone remember those?). Good luck.
older Pontiacs? Do you remember the Pontiac Tempest??
Nah, I didn't think so. :-)
That was the car I learned to drive. I saw a picture of it just this past weekend (family stuff and all), and I was amazed at what it really looked like as opposed to what I remember.
That was longer ago than many of you have even been alive, much less driving, I am quite sure.
As a matter of fact, I do thanks! Ever see the movie, "My Cousin Vinnie"?? They had one in there, so I have seen one. Driving one is a different story though. What can I say? I am only 24..
My 2000 Grand Am now has about 69k miles on it and I have a service appointment scheduled for tomorrow morning. I'm having the coolant flushed and filled as well as an oil change, I just recently changed the air filter.
My question is: Should I request anything else be done? (fuel pump, oxygen sensor, etc.) In the manual I don't think it states any major service done until I get to 100k. Also, last time I took it in the technician said to start thinking about having the struts replaced, how long do those last?
03 GA GT COUPE..currently 2500 miles...been back to the dealer twice. The engine does not idle smoothly. It could go un-noticed by someone not familiar with engines. I can detect a slight drop and rise in idle speed and notice it more when in gear. Dealer says nothing shows on the diagnostics. Could this be normal break-in ? Should I persue this ? Anyone else notice this in the 03's ?
If the check engine light isn't triggered, there might not be a way to cure this. It might well happen sometimes on the 03 engines. I don't know, as I have never driven one. The idle speed has always remained pretty constant through break-in and any other time (except when starting cold, when it will be a little higher, but settle down to normal levels) on all the cars I have owned.
the check/service engine light is NOT triggered. The engine appears to run smooth on the road. Cold start does have a high idle speed. I only really notice this when the engne reaches normal operating temperature.
- At 69K some authorities would recommend a brake fluid change. If struts are not making noise or causing uneven tire wear, they may be fine for now. I've had struts last over 100K. - Re engine idle, it's frustrating, but you can bet that your service dept. would be happy to find a problem and fix it under warranty. If general driveability is good, maybe you'd like to wait it out a while longer and see what happens. My '99 v-6 still idles fine and returns good mileage at 44K. Mobil 1 oil may be helping a bit.
Thanks for the advice. And it is VERY frustrating when the dealer technician tells you there is no problem. Any one out there that has experienced this with 03's or earlier. Thanks.
Is anyone else having a problem with this reservoir cap? I can't get it off without the inside (the part with the two o-rings) snapping off the cap. Then I have to pry it off with a screwdriver. It just snaps back together, but it's annoying. I tried a new cap, but it does the same thing. I'm thinking I need a new reservoir, but I hate to have the same problem after that expense. It's a 99 V6.
My 1999 GT1 has had the fan problem twice. It stops working at speeds 1 and 2. The cure is to replace a mini relay (similiar to a fuse). Look in owners manual to locate the correct mini relay and replace. Mine were done under warranty twice. I haven't had that problem for over two years now. In fact, that has been the only problem in an otherwise flawless car. I now have 35,000 miles and have needed no maintenance. Tires, brakes, battery are all original.
I have a 1999 Grand Am that is making a tapping sound around the front right tire sounding like something is loose. I had a mechanic check it out and he is saying that it has something to do with the CV joint somewhere in the transmission. To repair it, the transmission would have to be removed which could be costly. My question is this? Is this a recall situation? A factory default? Is anyone else having this same type problem?
I had to replace the grease in my sunroof tracks awhile back and the dealership recommended any standard white lithium grease.
Anybody know why the oil filters for the 4 cyl grand ams cost so much more considering they appear to be so much cheaper to make?
Or am I just living in a high rent area and folks are paying less elsewhere for these?
Thanks for your help.
Eric
Thanks in advance for any and all help.
-2000 Grand Am SE1
Happy New Year!
JD
:-D
Would some of you with experience with this car give me some ideas about what type of realibility to expect from this engine and transmission?
Is the engine prone to problems? water pump, head gasket. Does it use timing belt or chain?
What type of wear to look for in these years?
Is the auto trans. a 3 or 4 speed?
Joe
Any help on this would be appreciated.
I hear the water pump's a pain in the Quad 4, don't know if that carries over to the 2.4 or not.
