Visitor Agreement.
ric
ric
I found the easy fix in one of these forums. Today I went out and cut snipped the yellow wire (WHILE THE ENGINE WAS RUNNING)
cut the engine off, then held my breath while I turned it back on. SHE FIRED UP RIGHT OFF! and has been firing up nicely all day.
He's the post I got the idea from:
Ric
he 3 wires from the ignition are right there on the left. Start the car and cut the yellow wire. That's it. You won't have to replace the ignition lock cylinder until it falls apart. I don't have to worry about my wife and kids being stuck somewhere. I certainly didn't mean for it to come across as being complicated at all. Enevitably, someone will ask why this works.
Report Post | IP: Logged
http://www.automotiveforums.com/vbulletin/t491067.html
Anyone know of a Web site where I can find an armrest replacement for my gold, er, taupe 97 GA SE? Im struggling to find one. The one in the car now is cracked and about to give way.
http://www.trademotion.com/partlocator/index.cfm?action=getLocator&siteid=213815- &chapter=DR1FQ92&appSectionid=2648&groupid=3396&subgroupid=4626&componentid=0&ma- ke=28&model=Grand%20am&year=1997&graphicID=FQ92250&callout=17&catalogid=2
Anybody have any ideas on what might be going on?
regards
rod
http://www.gmupfitter.com/publicat/bull/bull26.pdf
PASSLOCK I or II DISABLEMENT
The following is a procedure to disable Passlock I or II Systems for vehicles in which remote start/stop system installations are required. This procedure is required because a remote start system will not function with the current Theft Deterrent System (Passlock) which is included on many 1996 and up GM vehicles.
Please note that this modification is intended to be used only in conjunction with the installation of a remote start/stop system and does not provide a procedure to install a remote start/stop system.
CAUSE
If an attempt is made to start a vehicle by a means other than a key rotation in the ignition switch, the Body Control Module (BCM) will interpret this start as a vehicle theft and disable the fuel injectors.
CORRECTION
A minor wiring modification may be made to allow the vehicle to be started remotely. This modification includes adding a switch to allow the customer to select “ON” to allow remote starting or “OFF” for normal Passlock operation.
CAUTION: When this modification is performed and the switch is set to the ON position, the theft deterrent feature will be disabled. When the theft
deterrent is disabled the SECURITY/THEFT SYSTEM telltale will light up indicating that the theft deterrent system is NOT functioning.
PASSLOCK MODIFICATION
Refer to appropriate GM service manuals and/or SVMQP Electrical Guideline Manual for instruction on splicing and electrical connections.
1. Select a suitable on-off switch (see note below) which will be used to disable/
enable the Passlock System. Mount the switch in a location such that it is
accessible to the driver and will not interfere with normal vehicle operation.
NOTE: This is an extremely low current circuit (approx. 7mA), it is therefore very important that a high quality, low energy, fast acting switch be utilized
for this application.
2. Turn the ignition switch to the OFF position.
3. Locate the Main Ignition Switch Harness in the Column. GM's Passlock System wires exit the Ignition Switch Tumbler together and then join with the Main Ignition Switch Harness. (See http://www.bulldogsecurity.com/ or http://64.85.6.118/diagrams/diagrams.asp and select your Make, Model and Year for wire colors and clues on the quickest way to access these wires.)
4. Locate the Yellow Passlock Data Wire which is included in a bundle of three tiny (20 GA) wires wrapped in friction tape.
Cut this wire and splice a 0.5mm2 (20 GA) yellow wire to each end of the cut wire.
Keep wire length to a minimum. Route modification wires clear of moving parts.
Connect the yellow wires to the switch such that the contacts are OPEN when the switch is in the ON position.
5. Turn modification switch to the OFF postion (contacts closed).
6. Start vehicle to verify normal operation. If engine “cranks but will not start"
recheck the switch position (contacts should be closed), wire connectors and
modification wiring.
SWITCH OPERATION
To enable remote start:
Start the engine with the ignition key (modification switch must be in the OFF
position). Turn modification switch to the ON position (contacts open). The
SECURITY/THEFT SYSTEM Telltale will light up indicating that the Passlock System is inoperative.
Once the SECURITY/THEFT SYSTEM telltale has been on for at least 5 seconds the vehicle can be turned off and then remotely started.
To disable remote start:
The Passlock System can be reactivated by turning the modification switch OFF
(contacts closed). Vehicle can either be running or off when this is done.
Please note that the VCM/PCM will record Diagnostic Trouble Codes (DTCs) related to the security system when the modification switch is in the ON position (circuit open). This is due to the way that the VCM/PCM interprets this condition.
NOTICE
Any condition which removes battery power from the Vehicle Control Module/Powertrain Control Module (VCM/PCM) (e.g. dead battery, disconnected harness connectors, etc.) will prevent the vehicle from being restarted. If the engine exhibits a “cranks but will not start” symptom, place the modification switch in the OFF (contacts closed) position. This will reactivate the Passlock System and allow the vehicle to be started with the ignition key.
Ray
Proud Member of The Anti-Passlock Club :P
thanks,
Question: Is there enough demand for these cars that I may be able to sell it if I post an ad in the paper/online? Or is it better to just trade it in for the pittance a dealer will give me? Any advice would be appreciated.
However for your car, I suggest the fuel filter to be changed out. It's recommanded for the grand am's fuel filter to be changed ever 30,000 miles. Tune up ever 100,000 miles.
Can anyone advise what is wrong please?
If I remember right, the last time I did it I dropped the pan, cleaned it and put in a new filter, then re-installed it (you don't need a new gasket if the steel lined one is still good), then put I believe three quarts of Dexron III in. Run it until it's all at normal temp (15-20min or so), then continue to fill (don't shut the engine off!) until fluid just starts to drip out of sight hole. Don't forget to put the plug back in, and don't shut the engine off until you have done so. I took the right front wheel off when I did it for better access, but you need the have the car relatively level to get the refill right.
Don't know what the plastic thing you found was from.
hope this helps
