Pontiac Grand Am
14546474951
  • linreslinres Member Posts: 1
    I am experiencing similar maladies to the one described in messages 2443&4: 2-3 wks ago my 2002 GrandAm (54,106) started having problems with delayed A/C, digital readings (on dash board), and radio start-up about 1-2 minutes after ignition. Then, the Service Vehicle Soon light would come on for the remainder of the trip. The next time I started it, no problem. This went on for a while and then it wouldn't start at all. It would turn over, but not start. My dad disconnected the battery and had it checked (perfect condition), jumped it, had it towed, had the mechanic run a diagnostic....still nothing. Then, it started with no problem, no SVS light, nil. My dad drove it for a week with no problem. Just this week, the SVS light has started coming on again (sporadically as before). Also, just today, I started it and no delays...but the Security light came on. I was reading the above reply and wondering if this sounded like the same problem? Do you have any suggestions and how do you reset the security computer, if this does sound like it? Any suggestions appreciated~ :sick:
  • adoado Member Posts: 2
    I have starting problem with my 97 grand am. i just replaced fuel pump but still wont start. the car starts for like a second them dies down. there no electrical problems on spark plugs. can sombody help me with this one
  • kurtojkurtoj Member Posts: 1
    i am having the same exact problem with my 92 quad 4 2.3 i have done the same things as you with no results.
  • cblankcblank Member Posts: 1
    What up everyone. I have a 1999 grand am that overheated about 2 months ago. the block ended up cracking on me. I got a new engine put in and the same thing happened 2 weeks later! can someone please give me some ideas on why this is happening! I have changed the waterpump, flushed the radiator, put in a new throttle. fans work, radiator cap is fine. maybe electric? I dont know
  • cahlacahla Member Posts: 1
    I'm looking for the radiator cap on my 1999 Grand Am SE. Am I losing my mind, because I can't find it... Any direction would be appreciated!
    The cap is on the overflow resevoir, not on the radiator itself.
  • ginny13ginny13 Member Posts: 6
    How much does it cost to replace a system control module??? where is it located? my blinkers are intermittant and they local mechanic says he doens't do these ... i have to go to a dealership mechanic.. can anyone give me a ball park figure ? how about how long it should take?? thanks ya'll
    virginia :blush:
  • wveaglewveagle Member Posts: 2
    I have a 2002 Grand Am that does the same thing. Delayed lights, A/C, radio, and control panel. Had it back to the dealer and of course they couldn't tell me why it was doing it or even what the "service vehicle soon light was for". So I emailed the Pontiac main office and they couldn't tell me either. :confuse:
  • april51april51 Member Posts: 1
    I have a used 2000 one owner grand am. I have never had any engine problems with it, nor the transmission. Just recently this....After I have driven it and it sits I go out and coolant has leaked all the way off my carport. I looked under the car and it seemed not to be coming from the radiator. Could there be a hose or something loose? Is this expensive to fix? I almost have this car paid off and I can't go into debt for a new used car. The only other things that are wrong are these: the overhead light never would come on...the back drivers window won't come down..it would stick, then come down, now it stays up. The drivers window sometimes sticks, but after a few presses on the button it will go back up. My power seat used to go up until my long legged son shoved it back as far as it would go, now when I try to raise it all I hear is the sound of the power seat motor. Are these things going to be expensive to repair? I am a widow caring for an alzheimers mother, so I need my car in good running condition. How do I find the right repairman who will not take advantage of me? What kind of questions do I ask? Thank you
  • mercury1956mercury1956 Member Posts: 5
    how hard is it to replace the power steering pump on a 95 grand am v6. what all is involved in replacing the pump thanks for any or all help
  • wigs72wigs72 Member Posts: 1
    has anyone had compresion problems with the 3.4 liter engines my mechanic just called he said it was either a timing chain problem or the crakshft or cam shaft problem any feed back will be aprciated
  • pacecar68pacecar68 Member Posts: 3
    hi nickper -- i just did this operation on my son's 97 grand am and had the same feeling/fear. i followed the instructions in the owners manual and just pulled down firmly but gently, first on the driver's side and then on the passenger's side. it made a "thunk" noise but came off. i then replaced both light bulbs and put the cover back on by pushing it back up. it helps to take a flat tip screwdriver to get above the cover. good luck.
  • morrigan09morrigan09 Member Posts: 1
    Believe it or not, it's true. Says so right in my owners manual. I thought it was pretty crazy myself, and I don't usually wait for the light to come on before getting my oil changed. It is apparently supposed to 'sense' when you need to change the oil based on how hard (or not?) you drive the vehicle. I say, with a new car, why rely on a dummy light? After all, it is a 'dummy' light, right?
  • dp5010dp5010 Member Posts: 11
    My 2000 Grand Am V6 SE has Rear Turn Signal problems. When the blinker started blinking too fast, I removed the rear tail light covers thinking I would have to replace blown bulbs. Turns out the bulbs are okay but the housing/slots the bulbs fit in have melted and deformed and I either loose the connection or the heat also deformed the base of the bulb.
    Has anyone else experinced this problem. Dealer says he has never heard of this (yeah right!). Pontiac has refused to review the problem unless it comes from the dealer who wants $'s to look at it and diagnose.
    Do I have to replace the bulb holder? What does that cost?
  • sruiz2169sruiz2169 Member Posts: 7
    alright...so everytime i try to start my car it either takes four or five turns of the key, i have to pump the accelarator to keep it on, and will have a rough start for a little while...the fuel filter is new...could this be the fuel pump, the alternator, or something with the emission system? please help...
  • jeterletojeterleto Member Posts: 1
    Hey everyone just a quick question. I own a 2002 Grand Am and its a 5spd. 4dr. Its the 2.2 Ecotech engine and i wanted to know if there was any performance websites or parts that will actually work for the car. I havent found one just body kits and so on. Thanks
  • thoward23thoward23 Member Posts: 2
    I got in my car to start it, It wouldnt start. I already replaced the fuel pump once. Replacing it again, its eating my bank account up. Weird thing is when i try to start it if i do it to many times the trunk pops up on its own? anyone know what this is? I'm sure its my fuel pump because i placed my hand on the pump and its doing nothing. :mad:
  • jgandy99jgandy99 Member Posts: 4
    Hi! I have a 1997 Pontiac Grand AM SE. It has 210,000 miles on it and i need to squeze another year out of this thing.
    Here is my issue. Last Thursday I was driving home from work and the low collant light came on, however the car was not running hot just a tad above normal. On my way home I stopped and bought some collant. The next morning I went out to start up my car and it started fine. I went back outside about 10 min later to put the collant in and it was no longer running. Thinking nothing of it i popped the hood and proceeded to put in the collant. Well i must not of read the container because it was the sort of collant that you have to mix with water so it came out pretty thick...too late i had already put in half a bottle. So then I decided to fill up the collant reservour with water. OK now i go to start the car and almost started but then stopped i try again sort of the same thing. Now it is Wednesday and my car wont start...I seriously doubt that it is the battery and a friend thinks it is the fuel pump.....any thoughts? If it is the fuel pump does anyone know where it is located? :cry:
    Sounds like a large loss of coolant from your description. Any idea where it's going? When you were filling the coolant was any leaking out anywhere?
    The fuel pump is in the fuel tank.
    Did you ever get it to start after this incident?
    Also, if you knew you had a problem with coolant loss, why would you start the engine then walk away from it for 10 minutes? Even an idling engine with no or seriously low coolant can burn up in 10 minutes.
    It's not a big deal if you didn't mix the coolant before hand as long as you are able to get the proper amount of water in also. It will mix in the cooling system, the resevoir not withstanding.
    210K miles is a lot of miles for a Grand Am, especially if it's a quad 4 engine. Do you have any idea what repairs have been done on it?
    I honestly have no clue where the coolant is going...i never see any puddles in my driveway.
    It was not leaking when I was putting the coolant in.
    I figured that since the engine was not running hot the previous day...just a tad over normal then it would be OK to start it up in the morning eventhough the low coolant light came on...bad idea
    It almost started twice...it sounded like it was going to start then nothing.
    A few months back I had a seal replaced that was cracked...it was a seal that went to the water pump. i was loosing coolant then. After that was fixed all was well until now. The only other major thing that i had done to it was to the transmission.
    I always keep up to date on oil changes, have tune-ups and have it looked at if there is any indication that something is going wrong. I am sort of worried this time because i do not want to spend a lot of money :cry:
  • pbrandtpbrandt Member Posts: 1
    i just had the same problem with my girlfriends car. it would overheat 10 mins down the road. it is the heater core gone to crap. replace that and youll be good to go, or for a quick fix get a piece of copper tubing about an inch in diameter and join the two hoses going into your heater core so that it bypasses it all together. you just wont have heat until you replace the heater core.
    Funny you bring that up because I had the heater core replaced about 2 years ago. Maybe it has gone bad again. I am having the P.O.S towed today to agrage to get fixed depending on cost. I will post the outcome...i hope it is good :(
  • gearrgearr Member Posts: 21
    I had a 2004 grand am V6 and i got 30 MPH out of it.
    It had 75000 miles on it had NO problems out of it
    I liked that car.
    BUT going to work one morning at 3:30 AM I just got on the X-way
    got up to 70mph and a drunk driver hit me in the driver side rear tire
    and rould the car 3x and landed upside down.
    and walked away from it.
    Gearr
  • janeoliver08janeoliver08 Member Posts: 1
    Have a 2000 Pontiac Grand Am. Whenevr turning the car to the left, it makes a loud clunking noise like it is straining to turn. No difficulty steering or handling. Does not do when turning to the right. Quite a loud noise too. Almost like when pulling a cable to tight. Any thoughts on what the problem may be?
    sounds like something is hiting the break shield by the disc break
    Gearr
  • bglobalclbglobalcl Member Posts: 1
    May be a CV Joint (part of suspension).
  • marriedmanwmarriedmanw Member Posts: 11
    Hello, I have a problem I hope you can assist with diagnosing. I have a 1993 Pontiac Grand AM 2.3L Quad 4 that is making a ticking noise during idle. This is the only time the noise is heard. The unusual thing is the noise will go away if I slightly turn the wheel.
    It first sounded like a lifter stuck but I don't believe that is the case since I can drive the car 30 minutes to work and at idle it's still ticking. I recently have replaced the motor mount, timing chain and guides, and water pump. I don't believe that the noise is coming from the timing chain area.
    I think the noise is the power steering pump failing since the noise goes away when pressure is on system. I replaced the rack about 3 years ago.
    What's your thoughts?
    Michael
  • thursolassthursolass Member Posts: 1
    I just had the radiator replaced along with the heater hoses and the mechanic said that the water pump was going bad. I got a new pump so thay say it's a relatively easy job to do, I just paid over $500 for the radiator repair so we are going to takle this ourselves. Is it as easy as it seems?
    6 cyl. or 4?
  • sunnyladysunnylady Member Posts: 11
    The samething happend to me. I have a 99 P.O.S.It seemed to happen everytime I tried to start it when I had problems starting it. I found out it was the battery that was going dead.Weird and funny at the sametime.:)) :surprise:
  • stupidcarsstupidcars Member Posts: 1
    I have a 99 grand am and just last night the battery light came on, the abs light came on and the air bag light came on....I would get the car to about 25 mph and it would start to shake, Tonight it didnt shake but when in park I reved it up and when it hit 4000 rpms it started shaking and would not go past that mark....I dont understand why....Please help
    Eddie
    ether the belt came off or your alternater is going bad
    Gearr
  • trent3trent3 Member Posts: 4
    Happened on my 99 GA; turns out the battery was about dead. Thought it was my imagination, but since you have had the same happen, I now believe it. btw, car is going back in the shop for possible head gasket; after having replaced IMG, injectors, fuel pressure regulator, etc. not a real happy camper today
  • blackdeath2blackdeath2 Member Posts: 1
    Hello:
    Got a slight problem with my 98 GT. Lots of slack in the steering. This is the first front wheel-drive car with rack-con-pinion that I have owned. My guess was either the gear box or coupler. Where are they or do they even exist? I don't think the rack has an issue, the car steers fine (plains out nicely at about 90). If there is a coupler or gear box, how do I get to them? I popped off the left front wheel today to take a look under the brake boaster, oh god it looks tight. Does someone have an idea of were the slack could be? :)
  • scoot08scoot08 Member Posts: 8
    so i got my tranny replaced last week and that thursday i went to start my car and nothing.... they told me to check the neutral safety swich adn i did.... now it is cranking but it wont start i have put new plugs in it, a new camshaft positioning sensor in it, a new battery, and a new fuel filter and yet it still wont start will someone please help me!!!
  • madcoloradomommadcoloradomom Member Posts: 1
    Has anyone else had similar problems?
    2 years ago I bought my son a 1996 grand am. I worked with the owner and she drove that car back and forth to work for several years, so I thought I was getting a good deal. The car only had 89K miles on it when we bought it. Since we've had that stupid car, here's what we've had to fix/replace:
    Radiator
    Everything oil related
    Battery
    Front and Rear Brakes
    Fuel Pump
    Starter
    Air conditioner and heater
    Wiper motor
    Door locks
    Front wheel bearings
    Timing Belt
    Steering and Suspension
    And that's all I can remember. The car leaks, drips, rumbles, sputters, bucks, won't start half the time - we've put over $4000 worth of repair into it, and today it wouldn't start. So frustrating. Anyone thinking of buying a grand am - run like the wind. I can't speak for all of them, but the one we got is a money pit and a piece of junk. I'll never buy another Pontiac.
    The moral here is if you don't want to make repairs then don't buy a twelve+ year old car with 89K miles on it. Many of these items are wear items and are very common repairs for this age and mileage.
    We had a 95 and went 135K easily, but not without some repairs like you mention.
    have you checked the starter or the alternator?
    ok...for all of you with huge, expensive engine problems...here's my story: (maybe it'll help)
    i have a 99 Grand Am SE. i had my car parked for a couple of months over the summer and when i started driving it again i had major problems with over heating, delayed starts, etc. was told it was a head gasket problem. got them replaced ($500), overheating and other problems still kept happening, more money, time, and work wasted. Turns out the head job wasn't done right, had the guy redo it right. After that same [non-permissible content removed] different day. Finally, about a month ago i blow a rod.
    Totally pisses me off, i said screw it, opted to go with a remanufactured engine and get rid of my POS engine. the engine had a little over 171k. Now it sounds and runs beautifully. It cost me 2k but to me was well worth it. Everything with my car looks good it was just the engine that was a problem.
    now with the new engine my Service Engine Soon light came on, couldn't be the engine it's brand new. Went to the engine guy, checked the code, it's an O2 sensor going bad, the engine was also seemingly hesitating on cold starts and seemed to lose power on acceleration from a stop, he told me that it may be that my fuel injectors are dirty and need to be professionally cleaned (about $60), well i changed my O2 sensor ($70) and no engine light, no hesitation on acceleration, so i think the O2 was the cause of the new engine problems. But i'm keeping the fuel injector cleaning in mind.
    Hope this helped some of you. Fixing up a car is better than buying a new car. That's just me.
    Whomever recommended to you to replace the head gaskets on an engine with 171K+ miles (not mention one with an iron block and aluminum heads) gave you real bad advice. At that mileage it's mostly worn out, so your just throwing good money after bad.
    ya the alternator and the starter are good
    there was water in my oil and it looked like light chocolate milk...that's why they told me to fix my head gaskets.
    so i finally fixed it!!! it was the crankshaft sensor... for all of you who dont know where it is it's behind the starter... thanks for all your help :blush:
    Yes, that water had contaminated the oil which was no longer providing good bearing lubrication, so the damage to the bearings was probably done before the head gaskets were ever changed. Once the heads were put back on the worn engine block the compression increased which put more stress on the already old and probably damaged bearings which lead to the result you had.
    The lesson here is that major repairs to a high mileage engine usually aren't worth much - the final outcome which was to replace the engine with a rebuilt was the best choice from the start, depending of course on other factors, such as overall condition of the car, age of the rest of the drivertrain, etc.
  • rzimm23rzimm23 Member Posts: 1
    Has anyone ever replaced a starter on a 1995 Grand Am with the 2.3 Litre Quad Four Engine? I am assuming the starter is bad but was also thinking it could be the solenoid - wherever it might be located in the engine compartment????
    Ryan
  • candyjarcandyjar Member Posts: 2
    hell yes it works! cut that stupid yellow wire! its keeping you from enjoying your ride! I spent hundreds of dollars and tons of man hours till I finally took ten minutes to get to that damn wire and cut it. My car is working great now. and remember, if your scared to cut it, you can always put it back together again. No harm no foul. but I highly suggest it
  • vcscvcsc Member Posts: 4
    what yellow wire is everyone talking about please help me where is it located
    if you pull the radio out, on the left you will see the back of the ignition cylinder, it has a sleeve of three different wires in it, one is white, one black, and one is yellow. the yellow is the data wire that is associated with your passlock system. ( my car is a 2003 but the same passlock problem apparently has been going on for years). now apparently to do this technique you have to have the car running first. soooo...... try to start the car, when it doesnt start check to see if your security light is either staying on or flashing(see owners manual "anti theft system") leave the key in the on position for 10 minutes. after ten minutes you should be able to start it. put car in neutral. take out radio, dont unplug it, you just need that space to work in, so just let it hang till your done. behind the ignition switch is your black sleeve that has the three wires, cut the yellow wire. tape the wires, or cap them, or I recommend installing a toggle switch. but that can wait till another time when your ready. once the yellow wire is cut, the security light should come on and stay on "forever". Now if your battery dies or you put in a new battery, you will have to reconnect the yellow wire to get the car started the first time but then just disconnect it again ( thats the reason for the toggle switch) but even without the toggle switch, its well worth the inconvenience. I do hope this works for you. as I said, even if it doesnt work, its free, it takes ten minutes,its reversable, and its working for alot of people. I love my grand am, but was about to burn it in the street till this fixed all my problems
    thank you for that but i cant even get the car to start my theft system light stays on i tried to ddo the ten minute trick but still nothin so can u help me wiyh that
    hi im trying to find some help my radio got stolen yesterday woke up to go to try and start my car and nothin no crank nothin just a click noticed that when i put the keys in ingnition it doesnt ding like usally and the lamp on roof doesnt come on
  • larrykellerlarrykeller Member Posts: 5
    Anyone know how to self fix a crack in the front bumper??
    I own a 2001 GT, silver, and noticed a crack about 5 inches long on front bumper near the fog light on driver side. Is there some sort of quick fix I could do myself, just so it doesnt get bigger or crack all the way through?
