Visitor Agreement.
Thanks in anticipation
The dealer doesn't know anything about the matainnace record either so we don't know the belt has been changed or not. I won't be able to change the belt by myself. I wish $300 will be enough to cover it.
We also don't know the tranny has been rebuilt or not. The fluid is OK, but not very clean. I saw some bubbles in the fluid, is that a bad sign? If I take it to a tranny shop. Should they be able to tell me whether it has been rebuilt before or not? The mechanic said the tranny is shifting well and engine sound good. I made appointment with him at tomorrow noon to further check the car. I also made appointment with a tranny shop tomorrow to check the tranny. It's a small tranny shop. Do you guys think I should take it to a Chrysler dealer to have the tranny checked because the samll shop may not be able to do the job because of insufficient equipment?
This car has 3 previous owners according to carfax report(since there are 3 dirrefrent title number from the report). 1st owner 93-94. 2nd 94-03. 3rd May-03-to-04. The car has 4 almost new tires(maybe 1/2 or 1 year old) on it. I assume the car has been taken good care of. One question is that there is no milage reading of the car when in May 2003 a new title with different title # was issue, if that still means the car was sold in May 2003. Why this 3rd owner want to sell the car just a year later after he bought it.
I did take the car to the mechanic today. He did not have much time today so he did a short testdrive for me. He noticed the car has accident before(which didn't appear on the carfax report). The front bumper and hood have been repainted. Also the front rail after the bumper before the radiator had been worked on because of the accident. He said there probably is no serious structure damage so it's no dig deal since many cars on the street has been involved in accident before.
What do you guys think?
Please give some opinion if you know about this car. Thanks a lot!
Any Suggestions, hidden warranties, lemons, etc??
Many thanks!
My questions to you: Have any particular problems been common in these later iterations of the LH? Were any significant improvements made since they were bolting these together in 1999?
Dealer wants $18990, but I see Edmunds only estimates about $17000 so I would have some negotiating to do.
I am disappointed in the small trunk that Chrysler has decided to go with on the 300--it's size would be a drawback to my purchasing one. I often carry 4 to 5 people on 700-1000 mile trips along with all their gear, so trunk space is important.
Thanks, I will check back.
Sincerely,
Disgruntled1
BEST REGARDS
My multifunction switch which operates the blinkers/wipers & washer broke from the steering column.
Has anyone replaced one of these? Please advise the steps.
Thanks for the help.
Realtor2
"Larry"
1. Disconnect negative battery cable
2. Remove the tilt lever
3. Remove the upper and lower steering column shrouds.
4. Remove the switch mounting screws and connectors.
So far only a few things to question... one of the door locks does not work when I lock or unlock all the doors, it has to be manually locked/unlocked. Do you think this just a bad switch? The same thing happens with the trunk. It will not open with the inside button or the remote. Another switch?
I am also getting a moaning, grinding sort of sound from the steering only when the car is first started and cold. It goes away after a minute or so. I hope this isn't the steering rack going out?
Other than that, I really like the car.
I recently inherited a 99 Concorde, and overall I'm happy with it. However, I have a problem with my windows working intermittently -- which judging from the messages here has been a common problem.
I was able to get the three passenger windows functioning by using a knife to loosen the window seals, and then cleaning the seals out and the gunk of the windows. However, the driver's window won't budge. It seems like the switch is working, as I notice a dip in power on other electrics.
Has anyone had luck with other techniques? I'd rather not pay a dealer to replace the motor if I can get it working enough to clean the track out (which worked on the other windows).
According the an independent mechanic I took it to this time, the noise was a bottom bearing in the engine. He says the 2.7 liter engines are defective and Chyrsler should have recalled them.
If you plan on trading in your Concorde b4 the mileage gets high, no problem; but if you commute to work like me - don't buy one. I now drive a 2004 Honda Accord and will never go back to Chrysler.
I just want to say thanks for all who have submitted questions and/or answers in this forum. I have learned a lot from reading these posts and it's greatly appreciated.
Yesterday I purchased a '99 Concorde LXi w/ 90k miles. I was going to buy a new car but my credit isn't the greatest right now so the interest rate on the load that I was approved for was too high for me to be comfortable so I moved to plan B.
Plan B is: A) buy a used car with cash.
Good plan? I hope so! So before I bought the Concorde yesterday I was already aware of some of the problems that this model has. But since I only plan on having it for a year or two I hope to escape with little trouble.
The car has had one owner. Everything OK on Carfax. The previous owner lived in a small, somewhat isolated town..not sure what that means if anything. The car seems to have never been smoked in which is a big plus for me. I have noticed the rubber trim around the headlights separating, not too big of a concern for me as long as it doesn't get worse. Road noise is acceptable, ride is great, comfort is fantastic. Super, super clean car. Previous owner really took care of it.
I bought it from a small dealer. He had it listed for $6,299 a several days ago when he first got it then dropped it to $5,999 this last Friday. I showed up Saturday morning and took the car home for $5,000. I checked other Concordes in this area and I believe I bought it at a reasonable price.
I expect things to come up that need attention, I just hope it won't be too hard on my pocket book. I am hoping that many of the common things that happen on these cars has already happened while the previous owner had possession and have been dealt with. I am prepared for things to happen since it's reaching 100k miles but after all...this is Plan B!
Anything I should have done to the car at this point in it's life?
Thanks again!
Thanks again!
There are 16 codes for ATC faults.
If the temperature reasdout was working, you could put the ATC in dianostic mode w/o a scan tool and read the faults on the temp display.
There are four conditions when the draw fan for the in-car sensor will run: one is when the vehicle door is opened and closed w/o turning on the ignition switch - the fan will run for about 2 minutes after the car door is shut.
That is the best I can tell you!!!!!!!!!!!
I did some research and found that the 2001 were the best over-all of the 2000's, so I bought a fully loaded customized 2001 LXi two weeks ago for $13,500. I feel spoiled driving this car, it's so beautiful from its looks to the performance. I still need the Owner's Manual and the only thing I noticed a difference is the size of the gas tank, which I have to fill more often than I did with the '94.
TLCM
Good Hunting
while the fan continues to run. Reaching half way, I was able to get the button sequence on the ATS to get error code read outs. Whether it was working or had quit working, I NEVER got any error codes. My son - a mechanic - says that he can't fix it if he doesn't get a code or I can't get it in when it isn't working. We are now approaching another cross-country vacation and would sure like to have it working again. Is there any history you have on this failure? Will we have to replace the control head? Next week I'll be driving it long enough for it to fail - Maybe - can anyone tell me which buttons to push to read out the error code - I lost the information. We have about two weeks to get this fixed. What do you recommend?
2: Do you guy think that a suspension from an Intrepid would fit my Lxi ???.....just thought I'd ask.
Could be a Fuel level sender or the whole non-servicable Instrument Cluster may have to be replaced.
1) Sometimes the headlights will flicker on and off. This is most noticeable when coming to a stop and sitting for a few moments, like at a stop light. I can't tell if the flickering is happening while the vehicle is in motion, or just while idling at a stop.
2) I will occasionally notice the sound of a fan running when the ignition is off. It sounds like a heating/defroster fan, coming from the vicinity of the dashboard.
Any ides? Thanks in advance!
-JD
Libby in GA
Otherwise take it to someone who has the manual or experience.
car will not start(turns over) and when it sits for a couple hours will start. No codes
come up to indicate problems. Has also died while driving and may or may not start.Anyone have any thoughts on this. Work done at local ser station that has diag. equip. but feel like they are guessing. Help!!!
