Mike
1999 concorde le.....airbag light came on wednesday night, no power windows, no turn signals, no heat/blower---(had to drive it 2 days in a row to work sub zero temps--driver window stuck partially down)
any suggestions are appreciated. does anyone know if that light can be disabled?
Cat
My wifes 2001 concord just clicks when you turn the key.
Turn it off and try again, sometimes 10 - 15 times before it starts. Then it starts like it has no problem and runs fine.
Anytime I do something to it, it doesn't come back for awhile.
But comes back and does the same thing.
I think I have traced it down to a bad connection of GND or +.
I am going to clean the grounds to see if it takes care of it.
If not I will run my own ground from the battery to see if it is the ground. That don't work I will swap out the positive cable from battery to the post (which is what I really think it is) but I want to find the exact problem and cure. Anybody have a similar problem let me know.
I just financed a 1999 Inrepid with the infamous 2.7.....needless to say 6 weeks later we now need a new engine! The dealer is not willing to help us get it fixed. He is willing to put us in another car if we come up with another $800! THe car he wants to put us in is a 1999 Concorde with the 3.2 engine. Any thoughts positive or negative. The car has 180,000kms on it
Anyone with the 2.7 please be aware!!!
Has anyone been able to verify the cause and cure?
roger_vaughn at hotmail dot com
They are older people and don't know where to start with this so I'm trying to help them out. Thanks to any and all of you who can give me any tips.
Have a great day!!!
I am having Concorde LX '02. I am getting a whistle sound, when it reaches 50 mph and above. If anyone come across this problem please let me know.
regards
Ignition Switch
Starter Relay
Transmission Range Sensor or Park/Neutral Switch
Wiring Harness
Battery
Starter Motor / Solenoid
Powertrain Control Module (PCM)
If you would like something specific let me know @jka1100@aol
I need to replace a battery on my 99 LXi. Can anyone post instructions on doing so (I know it's under the air filter). Also, has anyone used a store that offer free installation (I believe Advance Auto Parts does that) for replacing an LXi battery? If it's not something the store would do, I'm reluctant to spend the extra cash taking the car to a dealer.
Thanks for the help.
Remove the plastic inner skirt.
Dis-connect the battery and replace it.
Good Luck
demitch256
Let me say all I have ever owned are used cars, I have owned a car from all the GM companies, both Chrysler and Dodge, Honda, Toyota, Mazda and Volvo. I could flip a coin between the reliabilty of these automobiles I have owned as to which was best or worst. All cars break down, period. I put 20,000 miles per year usually for 2 or 3 years and then either sell or donate the vehicle to charity. I always plan on putting a few dollars in repairs to keep the car functioning.
I am really impressed with the Concorde LXI, nice quite engine, good ride, manuevers well, slightly noisy cabin but comfortable, wonderful back seats, plenty of cargo room. So far good on gas. Rides on Goodyear, could be softer ride. The stereo does crank up well! And what is most importanct engine is sound, airconditioning works well and the brakes are firm.
For those of you considering a used car the Concorde LXI is a great buy.
#1 While slowing to a red light, the car would shift down and it would not shift up until I turned the car off and restarted it.
SOLUTION: had to replace the control pack that in the tranny. Cost for part is 187. Total: 400.00
#2 Check engine light comes on with Purge flow low error. Error Code P0441
SOLUTION: Replace purge valve. Cost: $60. The part is under the hood next to master cylynder
#3 Check oil light comes on when at idle. Even though real oil level is fine.
Solution: replace the only oil sensor on the engine. (mine was leaking oil THROUGH the snesor.) If you get under car and look up passed the oil filter, you will see the sensor. Cost of part: 23.00
#4 The last and most troublesome... Intermittent starting when turning the key. Sometimes it would start immediately. Others it would take ten turns of the key. However, there was never a set number of turns. one way to eliminate the starter is to pull the starter relay and use needle nose pliers to start car. If it works every time then all is well from the starter to the fuse box.
Solution: replace electrical part of ignition switch. Also check the connectors to ensure they will connect tightly. Cost: 58.00
1. Anyone have any clue what could prevent the car from starting ? The local car mechanic eliminated the battery and starter.
2. The dealership said that they need to order a new BCM (Body Control Module) in order to get any reading. However, getting in a new BCM does not guarantee anything, which could mean $1000 down the drain.
3. The dealership has had the car for 10 days now. Is that normal ?
4. Help, I need to get grandma back on the road. Is there a related Service Bulletin i can share with the dealership.
I have the column around the key switch off and drive it this away.
When it doesnt start, I start unplugging the connectors and and try starting it.
It sooner or later fires right up like there is no problem and keeps starting for an undetermined amount of time.
The last time I had the connector going to the key switch & 2 connectors on the top of the column unplugged and it started.
Thats the best I can tell you for now.
GOOD LUCK & LET ME KNOW IF YOU FIND ANY INFO.
Joe
P.S. I happen to be a dealership mechanic, so I do have experience with these kinds of things!!!
I'd like to give some of our personal experience and what to watch for.....the engine of course as your last reply touched base on and I agree the 3.5 is better. But beware of the sensors---speed control sensor--when it goes, you would think its the transmission going out--about 200 to replace....the output control sensor is another one---this one, you won't be able to move the car--tow it in--transmission will not shift--250 to fix plus labor. Air bag light--if it comes on/stays on-you won't have power windows, blower for heat/ac or turn signals---check the clockspring in the steering column---another 250-300 to have fixed. Chrysler had alot of problems with these cars BE SURE to check to see what's been replaced and the engine sludge build up--have it looked over before you buy it! if I had my 'rathers',,,i wouldn't have bought it. I'm not a guy or a mechanic---I'm a mom of two and have learned about the chrysler concorde!
but each to their own and good luck!
