Visitor Agreement.
for instance lets say im driving straight. i have to move the wheel left and right just to keep it straight. almost as if was loose. then when i go to make a turn i have to turn the wheel more than im supposed to.
alighnment??
other probs?
yesterday i finally figured out how to change my brake pads on a 97 concorde lx..and since then the parking brake like near my speedometer turns off and then on for a while and then just randomly turns off....could i have done something to the brakes? they work fine to me...bled them and everything....
one thing it could possibly be is that the resevoir for the brake fluid isnt all the way filled up...but when i take the cap off it still has some in it. would i need to fill it up to the max line possibly?
also does the same thing with my brights near the speedometer...ever since i changed the bulb the light stays on all the time (which i did that maybe 3-4 months ago)
one other thing....
for a while now my steering wheel has felt loose, for instance, while driving straight my steering wheel is turned to the left or to the right (depending on how im trying to stay straight).
alighnment??
other probs?
one other thing....
alighnment??
other probs?
Concerning the loose steering, you really need to get this checked out ASAP!!!! Look on any of the lemon sites, and type in Chrysler Concorde steering problems. Some of the LH platform cars(such as our concordes, intrepids, and 300's) had defective parts in the steering that break suddenly, and without warning. This obviously could be very dangerous!!!! As long as it is checked out and fixed, it's fine. Just one of those random design flaws that every car maker has. Hope this helped!
God Bless,
Jeremiah
Would a good preventative maintenance plan to avoiding sludge buildup include using, say, (1) Changing with Castrol GTX synthetic every 2,500 mi. (short trip driving is guaranteed at times and cold winters are almost guaranteed in most parts of the US, hence why the 500 mi. reduction from the recommended), (2) Replacing the PCV valve every 6 months to avoid accumulating too much crud at that point? (2) was recommended by one other tech I spoke with, as opposed to replacing the valve by the recommended schedule every 30k mi.
I'm also interested in hearing about any explanations or advice about coolant leaks and the timing chain (o-rings, the chain itself, whatever). Obviously, if the coolant reservoir or water pump have a leak, then the most likely ensuing mix with the crankcase oil is setting the stage to kiss the 2.7 engine goodbye. So, outside of ensuring leaks aren't happening by following the recommended maintenance schedule to practically the letter, what else can be done about coolant- and timing chain-related problems?
Thanks for your input.
steelerfan
What is causing this? I change the oil regularly about every 6 weeks (I drive a lot).
While driving with cruise on it will cut out. 1 time the car died and them restarted itself and remained in cruise. Now I am having stalling problems. It will just die when I'm stopped and when I'm driving down the road. It won't restart right away. I have to wait a few minutes then it will restart. I get the error code P 1684. Which is the battery has been disconnected within the last 50 starts. Which the battery has not. Does anyone have any suggestions??? This is driving me crazy. I have had it in and out of the shop many times. :mad:
Any input will be greatly appreciated.
Any how, the issue is that when it rains the odometer, the gear indicator in the dashboard, the clock on the radio and the overhead computer flash together from less bright to very bright and back randomly for several minutes and then it stops for a while. I washed the car this evening and soaked the engine compartment intentionally so I could duplicate the problem which I was able to do. I killed the dash board lights altogether and then brought the brightness up slowly. The problem did not reoccur.
Any thoughts welcome.
I have a gold 99 Concorde. Does anyone have a Concorde they are parting out? And are you willing to sell the interior door handle?
Or does anyone know where I might get one?
Just yesterday (July 3) I tried a different dealer. Within a half an hour he returned my call and had located a passenger side handle from another dealer. It's not the original color; it is a tan color however.
The moral of the story: There are still some handles out there. You just have to start calling dealers. Be prepared to give the parts person the last 9 digits of your VIN.
anyone have an answer or any other suggestions.
Darren
I'm sure i will have more question that i haven't found but for the moment i really just would like to know if there is another way to install the pulley.
:confuse: thanks
In January I had to have the starter replaced and I thought that perhaps that is what was causing the issue but unfortunately it did not correct the problem.
Through all this I've had a light on the dashboard noting a problem with the car. When I had the car analyzed on a computer the only issue it showed was an "evaporative emissions leak." The mechanic said the two problems (lights going on and off at random and the leak) were not related.
Three questions:
1. What could be causing the interior lights to go on and off? What can be done to fix it?
2. What can I do to fix the evaporative emissions leak? Will it be an expensive fix?
3. Do either of these issues represent a potential hazard in driving?
I'm a graduate student in school out of state and the last thing I want is to get stuck somewhere!
Thank you in advancec for your time and assistance.
