High End Luxury Cars
1382383385387388463
  • sysweisyswei Member Posts: 1,804
    If those are the only 2 equipment differences (I didn't check that carefully since I'm not shopping a GS) then I agree it is a stiff premium, much stiffer than for the RX, which I understand is in the $4k range.
    If they upgrade the engine to 3.5L from 3.0 at some point, it will address some of your hp concerns, though.
  • lexusguylexusguy Member Posts: 6,419
    As far as I was able to tell on their site, those were the only two major features on the 450h not available as options on the 350. As for the engine, the 450h already uses the 3.5L, in the 450h it makes 292hp. In the 350, its 303hp. Unless Lexus makes major changes to the hybrid system, 339hp is all the 450h is going to get.
    Didn't realize that on the engine, you are right of course.
  • patpat Member Posts: 10,421
    CLS-Class added. :-)
    We have one more spot - want to give it to the Q45 and see where things go? We can always remove it (or remove any of the others) if another one comes to mind.
  • tagmantagman Member Posts: 8,441
    BTW, the LS430 will likely need to be updated to the LS-Series? (LS460, LS460L, and eventually LS600hL).
    As far as the Q goes, brightness mentioned that it was already included here . . . if that is true then it's a done deal. If not true, then I'll toss it around a bit.
    TagMan
    Thanks for the nudge on the LS, I didn't think of it.
    Including a vehicle in the categories above means that when someone searches on that vehicle, this is one of the discussions that will be returned. The categories are limited to 9, but the number of vehicles under discussion certainly don't have to comply with that limit.
  • laurasdadalaurasdada Member Posts: 5,214
    For clarification, the MB CLS is not based on the S class. The CLS is a variation on the E class theme. The new CL is S class based while the CLK is C Class based.
    So, if the consensus is that the CLS (essentially a rebodied E500/E550) is includable here, is the E class really that much of an outsider?
    I think, for example, that in this country MB is considered a luxury marque not because they sell a few very high priced models (e.g. as oft mentioned the S class), but because their cars have ALWAYS been expensive in the US compared to their competition (read Japaneese/US mfg. And maybe some smaller Euro marques). Model for model, a MB traditionally has been more expensive than the logical competition. Of course, thanks to Lexus (read: COMPETITION!), the price deltas are not as great as they used to be, but MB/BMW models are still relatively expensive.
    Now I'm not assigning a "value" equation to the pricing structure. Simply, similarly equipped, a MB has historically been much more expensive than a Lexus, Caddy, Infiniti, (Saab, Volvo?) et. al. Enough buyers discount the price premium because there is value to them in owning the MB.
    Gotcha (understood).
    TM
    While I did post that the CLK was indeed C-Class based, I somehow thought that the CLS was based upon the S-Class . . . but you are sure that it is E-Class based?
    If so, that's terrific. Nice work. :)
    TagMan
    Cs, Ls, Ks, Ss - my head is spinning. These have to be the screwiest naming conventions anyone ever made up. Don't expect me to know all of this tomorrow!! :D
    The category is now the CL-Class, forget what I said earlier. :blush:
    Good enough for me, too! I don't want to get any dizzier either. There actually is logic to it, but it would require a Germany vacation package, and a factory tour. ;)
    TM
    Yeah? Well cough it up, big man! I can be packed in an hour. ;)
    You didn't think I wasn't going to catch THAT, did you?
    Of course not. Actually I put it in there for you!
    2013 LX 570 2016 LS 460
    Yep, its an E in a fancy tux. Platform, drivetrain, etc are all identical. Its the same with BMW's 5 and 6 series. The CLS was a genious move on M-B's part, it basically created a new segment that all of the other top brands are now rushing to fill.
  • anthonypanthonyp Member Posts: 1,860
    As I remember the battle was that the LS was not in the same category (not class) as the Mercedes...The arument went round and round, and as Mercedes began to have the problems it did, you slowly recognized Lexas as at least a competator--althougha poor one at that...This perspective has closed over the years, and now unfortunately the value aspect has departed, leaving a choice that in my opinion really isn`t a choice as the numbers are high...In other words `why not eat the steak` vs the pork....It`s nice to occasionally read the `old` Merc vs the newer Merc....I hope you are enjoying the car? Anything to report? Tony
    Yes, the CLS is a high-zoot E class. As the CLK and CL are coupe versions of their respective sedans, the CLS is the "four door" coupe version of the E. And from most exterior angles, imho, a stunning piece of architecture. I also find the E a particularly handsome design, both sporty and elegant. It does not, however, stand out in a crowd as does the CLS.
  • mariner7mariner7 Member Posts: 509
    host, it's not that hard to remember, if you know K stands for Klein or small. As in the German-origin last name. Also, Mozart's Ein Klein Nachtmusik (A Little Nightmusic).
    Traditionally MB uses one letter for sedans (C,E,S). If it's not a sedan, the second letter has always been L. SL for the large 2 seater, SLK for the small one. CL for the large coupe, CLK for the small one. If MB builds a small SUV, it's logical to call it MLK.
    BMW and Audi are coming out with CLS competitors. Audi calls it A7, based on A6 of course. Does anyone know what BMW's will be called? In case no one has noticed, German carmakers always copy each other. I bet the Japanese won't have CLS competitors.
  • hpowdershpowders Member Posts: 4,331
    It's Eine kleine Nachtmusik.
  • drfilldrfill Member Posts: 2,484
    I kinda thought HELM meant "High End Luxury Marque"
    As much as I admire the G35, FX, and M35/45 dynamics, I don't consider Infiniti, or Acura/Lincoln/Cadillac, a HELM. Maybe I'm wrong, but I believe you have to successfully market high end cars before you make it to that class.
    Maybe the Escalade is a HELM vehicle? I don't know. But this does tie in with my idea of 1st-tier luxury marques and 2nd-tier.
    That turned into a Pandora's box, no? :blush:
    Maybe the Next Q will be a hit? Don't know.
    Same for the Photon. I think you need to sell more than 20 a month to make the cut of HELM. This is not hopscotch. This business is based on sales and image.
    DrFill
    I will be driving the New LS460/L at A Taste Of Lexus this Sunday!
    My battle plan is to drive the S-Class first, than 750, than LS460L, to see how it stacks up.
    Eye sore a 750 recently on the street and they really cleaned up the rear! Very nicely updated.
    Wish they could do the same with the S
    I'd like a 335i to match against the IS350.
    I'll let you know how it went after the Giants game!
    DrFill
  • brightness04brightness04 Member Posts: 3,148
    Well done, the CL gets its well deserved spot, we should all give ourselves a pat (bad pun unintended) on the back for successfully navigating the hazards of MB coupe naming convention :-)
    Assuming SL is already on the list (it used to share platform with S, not sure about now), if another model from MB is to be added, it should have been the R class, with a 126" wheelbase, it's even longer than that of the S class. When it was introduced, it almost had the price tag to boot too with R500. However, it seems to have lost the spot due to some very funky market repositioning going on. Did anyone else notice that the 2007 R350 is $5000 less in MSRP than the 2006 model? No equipment change as far as I know. What's really funny is the lease deals currently being offered on MB USA website:
    2007 R350 w/PP1, MSRP$47k, suggested nominal "sales price" (what is it anyway if what the mfr is suggeting is not MSRP) $44.4k, residual $32.4k, monthly payment $549
    2006 R350 w/PP1, MSRP$54k, suggested nominal "sale price" $45.5k, residual $37.4k . . . monthly payment $499.
    Now, what kind of genius will pay $5000 more for a 2006 R350 in January 2009 than for a 2007 R350, both equipped with Premium Package 1?? It goes to show that the residual is not the least bit grounded in reality, nor are MSRP and suggested "sale price" (which is not defined as MSRP despite the suggestion being from the same manufacturer). What is real is the monthly payment . . . the $50/mo difference to account for 2006 vs. 2007. All the other numbers are just cooked up in order to have the monthly payment numbers in the right order and amount.
    BTW, I agree with adding Q45 if it is not already in the HELM. It qualifies in every which way, seeing that it's lower brother, the M35/45, is a legit competitor to 5, E and GS. The 340hp V8 and 200" body certainly count; they have been available since 2002.
    Its already in the pipeline. Mercedes is not about to let the X3 be the only German compact lux-ute. You're correct on the name. Audi is also jumping in with the Q3. This segment is going to get very hot in the next few years.
    I wouldn't be so sure of that. There probably won't be one from Acura as they have yet to prove they can sell a car above $48K. Infiniti could go that route with the next Q though, no one knows what its going to look like. It would also be easy for Lexus to do a CLS style GS spin-off, (or just replace the GS entirely).
    Actually, I think I agree with drfill on this one. The Q is sort of the opposite situation as the E class. Mercedes is without question a HELM, but the E is in the wrong segment for this board. The Q is in the full-lux segment yes, but is Infiniti a HELM? Not really.
    K stands for Kuntz, i.e. "short" in reference to wheelbase or body length.
    Japanese already have a CLS competitor. It's called the GS . . . the swoopier and less mainstream mid-size offering. Unlike the CL above and the CLK below, both of which are sedan-derived coupes, the CLS is a sedan not a coupe. MB is seeing the wisdom in further differentiating the midsize range, into the sporty variety vs. the luxury variety . . . both being sedans. IMHO, it won't be long before we see E280 and perhaps even E220 diesel here in the US, to do battle with ES in a more direct fashion. ES on the other hand may take a page from Acura playbook and get AWD, assuming it does not get renamed to something else.
    It's sort of like the failed VW entry :-) or the not so successful either Ford-Jaguar XJ. At least Infiniti is still selling it, in however miniscule amount.
    Not quite. The '98 GS also had that tiny rear deck, it takes a bit more than that to be a "4-door coupe".
    That seems very unlikely. The TL desperately needs AWD so that it can eliminate the torque steer issues with the 6-speed TL-S, and compete on a more level playing field with the G35 and 3 series. The ES competes with Buicks, not BMWs. I dont see any reason why AWD would be necessary.
    It's sort of like the failed VW entry or the not so successful either Ford-Jaguar XJ. At least Infiniti is still selling it, in however miniscule amount.
    Not exactly. VW is a mass market auto company, Infiniti is not. Unlike the Q, the XJ has in the past been a successful and definitely HELM class luxury sedan, its just in a slump right now. The XJ12 was a very high end car and a serious competitor to BMW and Mercedes V12 7 and S cars.
    I see. Nothing really to report just enjoying the car. These summer tires hate cold temps though, so some winter tires are next.
    M
    Yes Tag the CLS is a fancy, very fancy E-Class right down to the lugnuts. Such a stunning job they did in converting it huh? The interior uses the same hardpoints as the E, but the materials and trim are different. The big ole plank of wood really sets it off.
    The small MB SUV will be the GLK, not the MLK. MLK couldn't be used for obvious reasons.
    Lexusguy, you continue to impress despite your handle...lol!
    The Mercedes lineup for all of those who are bewildered by the sheer number of models and their meanings, stay with me here:
    C = To the best of my knowledge stands for compact, "Kompakt".
    E = This used to mean the German word for fuel-injection (Einspritzung) when it was used in everything from 560SEL to 300CE, but now it mean "E-Class" which from what I've seen on dedicated MB boards means "Excutive".
    S = Special or Super, continued debate on this elsewhere. Derived from "Sonderklasse" which means super in German or something like that.
    CLK = Coupe, Light, Short.
    CL = Coupe, Light.
    SL = Sport, Light.
    SLR = Sport, Light, Racing. (my favorite)
    G = Geländewagen.
    CLS = Coupe, Light, Sport maybe? I have no idea.
    SLK = Sport, Light, Short.
    GLK = Geländewagen, Light, Short.
    GL = Geländewagen, Light.
    The ML and R I don't have a clue as to what they mean. M could stand for multi-purpose something. The R was originally the "Grand Sport Tourer", but they didn't call it the GST-Class so who knows. Knowing Mercedes though it means something.
    Obviously the word "light" (Leicht) as in being lightweight doesn't accurately describe any modern day Benz! Neither does short really except for maybe the SLK.
    Prior to the 1994 model year Mercedes used to put the letter before the number, that number being the engine size. The 560SEL which meant a 5.6L Super/Special, Fuel-injected, Long. The 300E for example meant 3L, Fuel-Injected. Then you had models like the 300TD which mean meant 3L, Touring (i.e. wagon), Diesel. 300CE meant 3L, Coupe, Fuel-Injected. Then you had 190E, which wasn't the engine size or anything, but still Fuel-Injected. Makes sense doesn't it?
    Anyway, the greatest MB sedan of this era was the "500E" IMO.
    M
    What category would you put the Q in? I think it is close to the Jag in perception.
    I saw a new Q in a parking lot the other day and I have to say that it looked great to me. The fit and finish was excellent. I will admit that I know nothing about the driving dynamics, etc.
    "4-door coupe" is just a self-contradictory term invented to say "we are new, we aredifferent" Overtime, IMHO, that styling difference will give way to the practicality of normally proportioned sedans. The difference between CLS and regular E will be in the performance department.
    ES competes with Buick? only in the minds of some ES detractors. Even Buick only claims their sedan compete against Toyota's. Getting AWD will give ES a major differentiator from Camry, and position the model more inline with Audi A6. Sure, its mission is not to compete agaisnt BMW (that's the department of GS and CLS), but having AWD is a major credibility point on paper now that RWD and AWD are in fashion. Audi did not even bring the FWD base A6 to the US until recently, despite the A6 platform is basicly a FWD platform just like that of the ES.
    So, in other words, since Infiniti is a luxury brand, you are inclined to include the Q as HELM? XJ's "success" has to be taken in context . . . its sales volume was not much higher than that of the Q even in its heydays. Speaking of glorious past, Buick actually had a history of building extremely high end luxury sedans/saloons, decades ago :-)
    Thanks for the valiant effort to clear up some of the confusions. MB certainly lacks the BMW marketting department's clarity of vision.
    E class was derived from the old 300 series, and you are certainly correct about where the letter E came from. MB used to be engine-centric, building cars around engines. It may not have been unique in that regard, just witness all the car companies with "motor" in their names. 1600, 2000/2002, 200, 240, 300 were all popular names for cars. BMW was the first one to systematicly classify cars according to body size instead of engines, and achieved great success doing it, in the 80's. By that time, electronic fuel injection had popularized to such a degree that, the coach building part had become a more expensive part of carmaking than engine manufacturing.
    C stands for "cheap" or "commonplace," just kidding. It's probably a mistake when MB succeeded 190 series with the "C" designation when the company also use the same letter to stand for much more expensive coupes.
    R may stand for "recreational" but more importantly, giving it a wheelbase comparable to the S class, MB was intending on taking the top end in a new direction and increase sales aggregate volume at the top end without diluting S class price premium . . . hence the "R," right next to the letter "S" in the alphabeic order. A,B,C were probably chosen for the alphabetic order to indicate their low status compared to the E and S. MB may have abandoned or made an exception to the alphabetic order when they named GL class, trying to capitalize on the Gelandewagon name that was already used in the army vehicle.
    I've noticed that myself . . . It's worth repeating.
    TagMan
  • dhamiltondhamilton Member Posts: 878
    currently a discussion going on as to whether or not the new MDX cancels out the RL's flagship designation. I've driven it, and it is just that good IMO. So My question is, will Acura ever build a HELM? It's not a question of can they, but will they IMO. I think that they almost have to or go down in history as another Saab type vehicle. Not quite quirky enough, but better reliability, and a more solid product in the mind of consumers.
    Trucks can indeed be more expensive than sedans because trucks are much more vehicle (the commercial trucks and 18 wheelers are even more expensive, whether Benz, Volvo or Mitsubishi brand, just an illustration of the logic.) For years, the lexus LX was more expensive than LS.
    Acura will probably succeed putting forth a HELM car in the next generation RL or the one after that, when the V10 becomes available. Developing a HELM car is actually easier than developing a successful mass market car: the R&D cost of the Maybach is only a couple hundred million, compared to 4-8 billion dollars that it takes to develop a platform like Civic nowadays. The tricky part of HELM is finding enough buyers of the car to make the whole project profitable . . . as illustrated vividly by the Phaetom experiment. The car is fine, finding buyers of the brand is the tough part.
    Acura is not Saab. Honda/Acura has the money and the economy of scale that Saab never had.
    There's a difference between the A6 and ES though, the A6 has usually only offered Quattro AWD here, where as the ES has always been FWD. There's no stigma about it being FWD, like say the Jaguar X-type.
    A definite possibility would be an AWD ES450h. They could power the rear wheels using the electric motors, as on the RX400h.
    I think there's a definitely possibility of the next one being invited to join the HELM club. I don't see any real desire on the board to include the current Q, as it only seems to show up in conversation to be the butt of a joke.
    I'll admit I don't know much about the XJ's sales numbers in the early '90s, I just remember seeing a lot more of them then than I do now. I also know some XJ owning friends that have since moved on to Mercedes or BMW. I even considered an XJ6 myself, but I went with a LS400 instead.
    There will have to be a major shift in the HMC culture before that can happen. Toyota and Nissan are no strangers to 200"+ cars, but Honda has never done anything like that. As was already said the question isn't can they do it, Honda has some of the most brilliant engineers in the world. Will they do it? I would say no, at least not for quite awhile. I think after the market recpetion to the RL, Honda\Acura is going to design the next one as a low-mid $40s car.
    Honda skipped that segment and went straight to corporate jet. ;)
    I'm assuming you noticed Honda's new jet in the news this past month. Amazing.
    Regarding the Acura HELM, I believe that the next Acura NSX will have to come first, and from there we could possibly see a branching off into a HELM sedan . . . but only maybe.
    TagMan
    The super V8 editions of the XJ are probably a better drivers car then the S55/S63 and the 760il.
    There's another CLS competitor no one has mentioned: Panamerica. Interesting name, does anyone know the history behind it? What are its powerplants, V8, V10, any possibility of V12?
    I don't know why Audi bothers with A7. Luxury market will treat it as an afterthought after CLS, PA and the BMW.
    Toyota supposedly has V12 hidden somewhere in Japan. They should bring it over here, I'm not sure V8+hybrid can hold its own against the German artillery.
    To make Q worth doing, IMO Infiniti needs a V12, and I'm not sure Infiniti wants to go that far. Years ago when LS and Q debuted, V8 was the top end. MB and BMW didn't have V12, the only one on the market was in XJS. Midsize E and 5 didn't have V8, all they had was six cylinders. Now the HELM market has been taken up a notch and 2 cylinders.
    Panamera will probably use the VW V8, just like the Cayenne. It's all an experiment on how to capitalize on Porsche's good name while selling VW economy of scale. Porsche owns 20% VW. The R&D cost for a well engineered car is so high now, a niche player like Porsche would end up like Saab if it can not raid a mass producer's parts bin on its own terms.
    V12's were historically stop-gap measures for companies that did not have V8 engines. V12's were relatively easy to make by putting two I-6's together. Porsche's own flat-6 may not lend itself to such packaging engineering.
    I doubt that. While I haven't actually driven a Super V8 Portfolio, I have driven the XJR. The steering is too light and the suspension is way too soft for track duty, as seen on Fifth Gear when a CLS55 absolutely murdered a XJR on their test track. There aren't any major suspension changes to the Super V8s that I know of. They're like the XKR Silverstones of a few years ago, big wheels, some flashy bits and more luxury, but the actual running gear is the same. Also, the blown 4.2 isn't even in the same ballpark as AMG's 6.3L monster. Its only slightly more powerful than the standard S550.
    According to R&T, the Panamera (as well as the rumored 2-door 928 version) will use NA and turbocharged V8s, with the V10 from the Carrera GT being a possible range topper. Power is supposed to range from 300-650hp.
    The Toyota Century from '97 onward has offered a 5.0L V12 called the 1GZ-FE. Officially it makes 276hp, actual power is unknown. It doesn't have any of the ultra high-tech features of the new 4.6L V8 though, like direct injection and dual electric\hydraulic variable valve timing. Toyota would have to develop a new V12 from scratch in order to compete with the MB and BMW V12s and Audi W12.
    Nissan doesn't have a V12, even in the JDM. I dont think the Q needs one. No S600, 760 buyers will be interested in an Infiniti, period. If Infiniti can do a 4.7 or 4.8L V8 with 360hp+, and at least a 6-speed auto, they'll be fine. At least as far as the drivetrain is concerned anyway.
    Exactly. Making a 12cyl is easy, either putting two I-6 side by side or two V6's front to back like VW's W12 . . . the tough part is finding enough buyers willing to pay much more than what the V8 offerings charge.
    The funny thing is that Honda is supposed to be doing a V10 for the next NSX. They'll make it happen for sports cars, but I guess they remain unconvinced that a V8 is needed for a luxury car. I and the Acura dealers of America have this stunningly brilliant idea about a V8 for the NSX that could be shared with the next RL...lol!
    M
    Just for you, the new CL, a CL600 in AMG sportswear to be exact:
    M
    I think there has already been something in the press suggesting that the V10 would make it into the next RL.
    Quite a transformation. The car looks much better with the AMG visual treatment. The piano black trim is also great. I really don't get why Infiniti won't offer that on the M when the Japanese version does.
