Visitor Agreement.
The list is growing...
No more aluminum trim in 1.8T
No tiptronic controls on steering wheel
No rear heated seats
No...
I can do fine w/o it.
My wife's old mini-van (traded in on the A4) only randomed across one CD at a time. I agree its because the change time is too long between CD's.
Actually my motion sensor in my 01 A4 was not sensitive but became way too sensitive after a battery draining episode. The dealership has a choice of using the diagonostic tool to change the sensitivity to 50%, 75% or 100%. Now it's back at 50%, it goes off at the right moment. Andys120, you might want to check that with your dealership.
Billy
1. The dealer recommended changing the oil at intervals at 15000 miles. That seems extremely high, for on my previous car I never went over 4k. I know that oil changes are covered through the dealer, but should I change it more often than 15000 miles? And should I use synthetic?
2. The dealer also recommended using 91 octane, but said 89 would work just fine. I know all the facts an lies about octane, and if he says 89 will work than i assume I should be able to run 89 no prob. Correct?
Thank you all for your input.
-Matt
The following applies to both the 1.8T and the 2.8 powerplants.
Thus far the maximum Audi oil change interval is: oil + filter @ 10,000 miles -- syn not required.
If this is a keeper car -- I would suggest that you look in the manual and do what it says. Moreover, I would use syn oil (the dealer will upcharge you ONLY the diff in price, which should be about $4 -$6 per liter) and always change the filter even if your manual says every other time.
15K miles? Sounds like the new Porsche's -- my 2003 Audi 2.7T turbo motor has 10K intervals.
I changed at 3K miles (oil and filter) and then at 10K miles using syn oil and filter. Planning my next change to be @ 20K miles with syn oil and filter. I am leasing and may or may not consider this -- an all optioned 6spd manual allroad -- to be a "keeper" car.
If you don't plan to keep the car, follow the manual to the letter (with my personal suggestion to always always always change the filter whenever you change the oil regardless of factory specifications).
Gasoline
This car requires 91 - 94 octane. It is a false economy to use 89, although the engine managment will most likely prevent any serious damage to it should you use low octane. Your milage will suffer and your power will be reduced. Conversely, the engine will advance the spark -- so to speak -- with 93 octane and improve the power output (although the difference between 91 and 93 would have to be something that you "studied" so that you could really notice it). A couple of 91 octane tankfulls, follwed by a couple of 93 octane tankfulls then returning to 91 octane will produce a sense of "what happened to the power?" which is reminds me of some of the older cars that you could feel the difference when the air conditioner compressor kicked in.
Also use gasoline -- not a blend of gas and "corn squeezin's" -- it says right on the side of the pump if the gas you are pumping contains something other than "pure" gasoline. Again, the issue is power loss and for these Audi engines, it too is a false economy.
Buy good gas and you will be a happy Audi driver.
Good luck, good car -- congrats.
Up in Denver, the performance difference between the 1.8T and the 3.0 is going to be a lot smaller than at sea level, where the 3.0 should be noticeably more powerful than the 1.8T.
Billy
The naturally aspirated engine's ability to be so "dynamically tuned" is less.
I think this means I am in violent agreement with Brian (tiredofmanual).
As far as gas goes I always put in premium but one note to Mark is that here in WI-IL there are no gas stations that do not use straight gas anymore. My friend drives for a petro transport and all they do is blend gas with ethanol. Also, Premium and Regular are combined to make Mid-Grade. Some stations do it themselves, some have a seperate in ground tank and then he'll bring a blend to the station himself. I forget what the mixture is but can ask if anyone is curious...
Safe driving. Brian
Brian
Mobil 1 with SuperSyn™ 10W-30 –
Higher-Mileage Vehicle Formula
Mobil 1 with SuperSyn™ 5W-30 –
Newer Vehicle Formula
Mobil 1 with SuperSyn™ 15W-50 –
Performance Driving Formula
Mobil 1 with SuperSyn™ 0W-30 –
Enhanced Fuel Economy Formula
Mobil 1 with SuperSyn™ 0W-40 –
European Car Formula
Mobil 1 with SuperSyn™ is truly a global formulation, exceeding the latest standards from the government, the oil industry and vehicle manufacturers. For instance, the appropriate grades of Mobil 1 with SuperSyn™ exceed ILSAC GF-3, API Service SL/CF, European ACEA standards and Japanese valvetrain requirements. In addition, some viscosity grades exceed specific OEM standards. One example is Mobil 1 with SuperSyn™ 0W-40, which exceeds Mercedes Benz's 229.3 specification. As a CF rated oil, Mobil 1 with SuperSyn™ can also be used in diesel engines calling for a CD oil.
And yup, all the grades of gasoline in the Chicago and Milwaukee areas have 10% max ethanol in it. Reformulated gasoline that burns cleaner for environmental reasons. I think it's the same thing for California. And of course that's why we and Cali always fight for the honor for the "most expensive gas award". Lucky us.
Billy
I still advocate to get it if you can and always use Premium
Oh, and by the way, when talking about 15,000 mile oil changes and sounding like Porsche, of course the reason is that Porsche uses a modified dry sump and the engine holds around twice as much oil as our engines. In days gone by, a Porsche engine might hold 15 quarts of oil, while modern ones hold around 10. When you've got that much oil circulating through the engine, you can go a long time between oil changes.
I am in the market for a "new" car and am considering either a low mileage (28k miles) 2002 BMW 530i w/ Sport, Premium, and Steptronic, OR a 2004 Audi A4 3.0 Quattro Tip w/ Sport & Premium Pkg. Given this choice, what would you buy?
I live in FL so Quattro is not a must-have. I think the Audi has a nicer interior and more features, but the BMW has better fuel economy and acceleration. The BMW is priced at $35,900...a steal at that price!
Which ever car I get will be a keeper for a while, so reliability is an issue too!
I am surprised to hear the dimensions are close. The 530 looks larger to me.
Good luck
The Audi seems to be all about style, while the BMW is certainly graceful in its own rights. I really like both cars and it's such a hard choice!
As far as Quattro is concerned...I know it's not *needed* in FL, but it certainly sounds helpful as far as safety is conerned. Is does rain here a lot! And who knows, I may need when I travel out of town some day. Also, I've driven the CVT and didn't like the driving dynamics as much as the Quattro.
Thanks for the input!
And, as I am brainwashed, my opinion should be taken with a grain of salt.
Both BMW and Audi make great cars. Drive them both, drive them long, drive them over the same test drive circuit. Push them both -- perhaps on a rainy day take another test drive.
The merits of Quattro may not be visible or able to be felt on a test drive loop. Over time, the Quattro drive train's benefits make themselves known.
Based on my friend's experiences, the BMW will probably feel the stronger accelerator.
Both of these cars long to be configured as manual transmission cars -- if possible try driving the 6spd manual versions.
And, no matter what, either one of these cars is a good choice.
Audi of America 2004 Model Year Change Points
2004 Audi A4 1.8 T / 3.0 Sedan
* Satellite radio preparation standard on all A4 models
* 6-speed manual transmission on A4 1.8 T quattro® Sedan / Avant
* 16" 5-spoke cast alloy wheels now standard on all 1.8 T models
* 17” wheels now standard on 3.0 models in Canada only (Sedan, Avant and Cabrio)
* Driver information display now optional on A4 1.8 T and 3.0 FrontTrak®
* Concert radio replaces Symphony radio on all FrontTrak models
* Power passenger seat removed from A4 3.0 FrontTrak
* Power Lumbar support now optional on A4 3.0 FrontTrak
* Tire pressure monitoring system standard
* Full body paint standard
* 2 stage advanced front airbags, including occupant detection
* new generation modular steering wheel family
* New valet key
So, Audi is getting rid of more stuff in the upcoming model year. Good bye power passenger seats for the FrontTrak model!
Question #2... What will void a warranty. I know chips will, but will a k&n filter void it? Or exhaust or cold air intake? Anyone able to fill me in that would be greatly appreciated.
Matt
The dealer has informed me that the oil coating on the K/N air filters could clog the Audi Mass Air Sensor and at the least cause a rough idle situation.
Synthetic oil is highly recommended and I have used it with no ill effects in my '00 A6 2.7T for about a year now.
Anyone else heard of this, or anyone running a K&N filter with problems?
Matt
100K).
Quick answer: It depends on your tolerance for risk. They're very well-made and reliable but repairs are expensive. It's a crap shoot.
Anytime anything is purchased (car, TV Stereo, computer, washer/dryer, power tool, etc.) instead of buying the extended warranty, put that same amount in a savings account. If/when things need repairs, draw from the account. Over the years, the odds are that the account will grow substantially.
1999 AUDI A4 Quattro, 82k mi, black, 5 spd, V6, pw, pdl, sunroof, 6 disc CD changer, ABS, immac in/out, $15,000
I Carfaxed it and it checks out. Has the leatherette interior. Anything to look out for? I'm going to look at it tomorrow. I also think probably more like $14000-14200. Thanks for any info.
4 yrs and 82k seem a lot of miles. I personally don't think it worths $15k. Is it Audi certified? Most likely not due to the mileage.
Billy
When I looked at the car, it is in great shape in and out, other than quite a few touch up chips on the front. No door dings, paint everywhere else is great. Tires only have about 3k on them. Has the Bose option. No sport package. Drove quite well.
KBB has it for around $13.6k and Edmunds $14.7 for private party.
On another note, there are several like it listed in Ebaymotors, better options, lower mileage with service around $12.5. All seem to be either previously commercial registered or lease. Anyone have any experience buying one from Ebay?
Please post any news!
Here is the info I have:
The base price for an A4 1.8T Quattro Automatic (what I want, so thats all I have) is:
Base Price: $28,300
Destination: 690
options-
Cold Weather Pkg: 625, same
Premium Pkg : 2,000, same
Lighting Pkg: 750
will include Xenon lights, auto dimming mirrior, automatic headlights, and compass.
Infotainment Pkg: 1,000
The Infotainment System is the Bose Premium Sound System with either the Sirius or XM Satellite
Radio.
17" All-Season Tires 750
MetallicPearl Effect Paint 450
Other options are: Sport Package, Ultra Sport
Package, Audi Telematics and sometimes Rear Side Air Bags.
Cloth Upholstery is a n/c option. Leather Seating Surfaces are part of the Premium Package.
The following exterior colors will be available for the 2004 models:
Brilliant Black
Light Silver Metallic
Arctic White
Canvas Beige
Cambridge Green Pearl Effect
Dolphin Gray Pearl Effect
Ocean Blue Pearl Effect
Moro Blue Pearl Effect
Brilliant Red
Crystal Blue Metallic
Crimson Red Pearl Effect
I've been told by some that the 6 disc changer will no longer be standard, you'd have to order the premium sound package for that, but I've heard conflicting reports...
Any additional info anyone has, or a website, anything, please post as well.
Teddy, where have you seen specs? What does your dealer tell you re: availability? I'm hearing mid aug from multiple dealers in multiple states.
http://vwvortex.rely.net/artman/publish/article_1.shtml
Also, I am wary about dealers being honest in regards to new models. They need to move what they've got!
A few questions, it says Driver information display now optional on A4 1.8 T and 3.0 FrontTrak®. Is this the digital screen that shows Temp, and other types of information? If so, what pkg will that be available in, is it standard now?
What is the difference in body paint?
I also heard the 6 disch in dash CD changer is no longer standard on the A4 1.8T Qa, is this true?
Jason
There is no change in cd changer, and the changes in driver info display, although she did not know what pkg it would come in, is only on the frontrak not Quattro.
Also the tire pressure monitor system and full body paint will not be available till at least Feb.
anyone know about this?
We just bought a 2003 A4, and the dealer was asking for $2900 for the 6yr/100,000 mil warranty,$0 deductible, we decided to take the $100 deductible, knocking off a few hundred dollars more. You maybe able to get better deal with AAA, if you have AAA...
As far as for KN filter, I have used it in my Honda, no problem at all. Make sure you don't over oil it when you clean it...
We are very happy with our new A4, so far...
In November of 2001 I purchased a certified pre-owned 98 Audi A4 2.8 Avant Quattro with 56,500 miles, my second A4. This past July 11th I turned over the 9s and took the car over the century mark.
My CPO came with an extension of the original factory warranty thru 75k miles. I thought it might be useful to post the total of repairs to my car for which I would not have been out of pocket had a bought warranty coverage thru 100k.
That total is just under $2000.... $1912.00 as nearly as I can figure (my shop bills me for total labor and does not break out specific items
so I had to estimate how much was for normal maintainence vs. repairs that would have been covered by warranty.
-Major possible warranty items that would have been covered were a failed electric fan motor, replacement of warped rotors and wheel bearings all around (I have one wb that hasn't been replaced.
-Repair expenses were low until going over the 75k mark with one exception, the 70k service which included replacing the cam drive belt, v.-belt, thermostat front engine seals and pulleys,
none of would be covered under warranties.
-Repairing the fan motor was the only occasion for taking the car in other than services performed at the regular 5000 miles I use for l/o/f.
-the car has held up well cosmetically, inside and out. Paint has good gloss, few scratches, chips, some light swirl marks.
-Factory warranty repair was done on replacing front suspension bushing prior to my ownership.
-Factory recall repair was done @ n/c to replace vacuum hose related to emission control system.
-Vorsprung durch teknik! I really believe the A4 is a fantastic car, as well made and reliable as any. Take care of it and it will take care of you.
Long may you run!
I have several questions as to proceeding.
1) I live in New Orleans. What is the best dealer to work with as far as deals and selection? I would be willing to drive a little bit to Jackson, Mobile or Houston.
2) What do you think I should be willing to pay for the negotiated price? How close will I get to invoice? Anyone with recent experience out there as to their negotiated price?
3) With the new 2004 due in late August, will I be able to negotiate a better deal on a 2003? How much better? Will I have to sacrafice options with scarce supply of 2003s?
4) Should I forget the 2003 and just hold on for the 2004? Will I even be able to get my hands on one before my old lease runs out? I'm not sure if I'd be willing to pay more for the new ones, but it may be cheaper to get a 6-speed which would rock!
Thanks a ton for your help.
