Audi A4 2004 and earlier
1112113114116118
  • adrianraceradrianracer Member Posts: 4
    Just buy the S4 which comes with twin turbos from the factory? Adding is not easy and is expensive.
  • cultured_hickcultured_hick Member Posts: 10
    I also got the APR stage 1 upgrade for my 2003 A4 1.8T quattro tip, but noticed a dramatic improvement. This improvement was especially notable in the turbo lag that had almost caused me to get rid of this car due to it being a safety concern at times. Make sure you are running premium fuel. I switched from 93 octane to 87 to experiment (due to rising gas prices) and the difference was quite significant to the point that I wondered if the chip was still working. Nonetheless, when I switched back to 93, the chip was clearly working properly. I will probably get the 1+ (injectors) and exhaust once the warranty runs out, which will only be a total of $1000 in upgrades--signicantly less than an S4 (though I would love to have one).
  • simple2simple2 Member Posts: 16
    Thanks for reply.
    I run on 98 octane. I think my problem is the low rev torque.
    Car fells reasonable once the revs go over 2500-2700. And I simply like cruising around the town in 5-th gear.
    My dream is to get new S4 V-8 and drop twin turbo in it. I think I will leave my 1.8T alone for the next year and than swap it for S4. I wonder if upgrade turbo kits are out for those by now.
  • fireflyfirefly Member Posts: 2
    Hi All
    I have a 1997 A4 1.9TDi with 275000 on th the clock.The car is going the best but there is a problem with acceleration. When there is any kind of loading on the engine ie going up hill on motor way or driving on wet roads the acceleration cuts out at 70mile/hour. (60miles in fourth gear) the throttle is still there and the rev counter still goes up but there is no power it feels like the turbo just cuts out.Once the power goes the only way to get it back is to switch the engine of and restart. Full power is restored then immediately. Like i say its seems to happen when the engine is under extra loads and only occurs in 4th and fifth gear . Does anyone know what is causing this?What can i do to rule out the electronic throttle as i have been told is a possible cause.?
  • mpt2222mpt2222 Member Posts: 2
    Speaking of hissing, has anyone ever heard of the 1.8t making an abnormally loud hissing during acceleration only? My 1998 A4 1.8T started hissing loudly from the front-passenger side a few months ago and my local mechanic can't figure it out. We ruled out any exhaust leaks. I'm starting to wonder if this is a sign that the turbo is starting to go bad. The car does have 105,000 miles on it. Other theories are that the catalytic converter may be plugged, causing some back pressure. Anyone ever experienced such hissing?
  • kworstkworst Member Posts: 8
    I have been looking at this car and just had some questions. I saw in comsumer reports that only the 2002 really had any problems. See below:
    Is the 2002 Audi A4 1.8 T quattro the lemon of the group or should I still seriously consider buying this car. Any help would be extremely helpful
    Coolant leak: The oil cooler is prone to turning during oil filter removal, which causes damage to the coolant lines resulting in a coolant leak. (2002)
    Electrical problem: Water leaks into wiring harness near the A-pillar causing assorted problems such as the remote will not lock/unlock the door, the windows won't work, the interior lights may stay on occasionally, and the door ajar warning may glow even though the doors are shut. (2002)
    None: The throttle body control valve tends to sludge up on the 1.8L turbo engine causing a very low or uneven idle. (2002)
  • juejuebiejuejuebie Member Posts: 2
    I need some help. I am looking to replace my original car speakers with some aftermarket ones. Does anyone know the speaker size information for the 02 A4 sedan? I've looked everywhere on the internet and even called the dealers but apparently no one knows the speakers' size not even Crutchfield. :mad: ... if anyone knows this information, it would really help!
    Juejuebie
  • bdr127bdr127 Member Posts: 950
    Does anyone know what the actual "official" name for the thing that controls the self-leveling xenon headlights? It is a "box" that's about 4"-5" cubed that's right behind the headlights under the hood.... There is a group of wires terminated with a clip that goes to it. Anyone know what this thing is called? I'm looking for a replacement, but I don't know the name of the thing to search for..... Thanks!
    (2002.5 Audi A4 1.8T Quattro)
    I should clarify that to say "under the hood, behind the headlight assembly" (not just the actual bulb itself).... Thanks in advance!
  • jrollinsjrollins Member Posts: 4
    i've dealt with a lot of these controllers, (my dad owns a autobody shop) and i believe it might just be called a igniter, or starting box, if you call a audi/ vw dealership they will prolly be able to tell u
    im running a 97 1.8t and was wondering if anyone knew what the factory boost is, and what i should, or can run, without worrying about detonation??
  • badrdogbadrdog Member Posts: 1
    Hello everyone, I just bought a sweet '99 2.8(not quatro) tip, as a second car, but was wondering what chip most people recommend,can I install it myself or whats involved and can I somehow put litronics or Xenons on this car? Also, where can I get a used or reasonabally priced car cover for a '99 A4? Thanks in advance, and I'm happy to be part of the group!
  • makethetreesmakethetrees Member Posts: 1
    I have to exact same problem with my A3 TDI. Did you get an answer to this problem? Any advise would be much appreciated.
  • audiman5audiman5 Member Posts: 8
    Hi All,
    Just got a 99 A4. Cool car and all that, but I recently had a dead battery issue. I tried to jump it using another car which turned on but I had to replace it because it was completely drained. I installed the new battery, but now the engine rpm is not holding steady at idle. When the car is warmed up and in "park", the rpm oscillates up and down and sometimes it turns off. Otherwise it drives fine. Did I damage anything electronic? Need your help and thanks in advance.
  • l3ftyl3fty Member Posts: 2
    Anyone know if you can run a serial number anywhere online to find out what the car has for options? Looking at an 03 a4, but wondering if it has the sport suspension and 17" wheels. I have the serail number to run. I guess if there isn;t a website to run it, I'll call the dealer...
    No, you can't just get that info anywhere.... Call a dealer and see if they'll cooperate with you.
  • mechengr1mechengr1 Member Posts: 19
    We have a 2002 A4, 1.8T quattro that beeps 4 times on start, Dealer has not been able to explain it.
    There are two car seats in back, one belt always connected.
    Anyone know what that is for?
  • mjb1979mjb1979 Member Posts: 1
    bought it certified from audi dealer... 25K miles 3 months ago.
    when temperature drops well below freezing, my calipers seem to be freezing... my entire commute (10 miles) there is constant vibration (pretty violent), major lag when i let up off the gas (even in 6th gear), brakes are extremely sensative when i touch them (assuming this is so because the rear brakes are already gripping) and when i park and get out of the car, there is a strong burning smell (smells like very overworked brake pads). the problem always goes away by the time i get in the car for my commute home (assuming everything warms up and stops sticking).
    brought it to the dealer twice when it was happening but of course when they finally got around to test driving it, the car was fine, so they don't know what it is. they replaced the emergency brake coard but that wasn't the problem... i experienced it again this morning.
    anyone esle have this problem? ...please help. love the car, but this is killing me!
    thanks,
    mike
  • andys120andys120 Member Posts: 23,674
    If I had to guess I'd say it's your E-brake cable that is freezing which happened to me when I had my '98 A4 (B5). Take your car to a good indie, it doesn't sound to me like your dealer knows what they're doing.
    Meanwhile, refrain from using the parking brake when it's really cold but don't forget to put the car in gear when parked.
    P.S. If replacing the cable didn't cure the problem it's prolly cause there's water getting onto the cable and then freezes and causes the sticking.
  • pmj1pmj1 Member Posts: 1
    Did you get a line on the beeping? I also have an '02 A4 that began (and stopped) beeping around 40k miles. I asked the dealer to check it, but they were unable to reproduce the sound. The problem was intermittent, seemed more likely to occur in cold weather. I suppose the noise will return at some point. Otherwise, totally happy with the quality. Zero problems at 40k mi. thanks
  • dag212dag212 Member Posts: 1
    I am considering purchasing an A4 (2003 1.8T Quattro)with 54K miles. Though I've read about the long-term tests of the A4 (15K - 25K miles) I'm not certain of the reliability of the car with higher mileage. Can anyone provide information on the A4's performance and reliability, generally speaking, at 50K - 100K miles? Thanks.
    I acquired a used '98 A4 Avant 2.8 in 2000 that was a CPO with around 43K on it. It was probably the most reliable car I've ever owned including a couple of Hondas. Other than routine maintainence the only repairs were for a failed fan motor, ball joints, rotors and a repair to replace wiring that field mice had gnawed thru (hardly a reflection on the car.)
    When I traded it in at 123k needed a new airbag module but was otherwise in good shape. Be aware that routine maintainence and parts are expensive and that Quattro equipped cars are hard put to get more than 25K from a set of tires.
    Best of luck with your purchase.
  • discoboy87discoboy87 Member Posts: 1
    I'm eventually going to be looking at used cars as I will be going off to college soon. Needless to say, the A4 (96-01) is on my shopping list. I know that it is hard to generalize about the reliability of used cars, but I'm wondering about the difference in reliability of the 6 cylinder versus the 4 cylinder. I have heard that the 4 isn't as good.
    How big is the reliability difference between the two engines?
    I'm not into modifying vehicles... so I don't need an engine with great tuning ability.
  • formercressidaformercressida Member Posts: 3
    I've just had a break-in and the thief stole my summer rims and tires Michelin MVX4s. Audi quotes new rims at about $700 each. I had winter tires on the car itself. What are people buying for after market tires?
    Ted
  • 204meca204meca Member Posts: 369
    Just had the 25K free service on our 2004 1.8t/CVT. We continue to be immensely satisfied with it. Comfort, performance, and fuel economy all meet or exceed our expectations. The new 2.0T sounds mighty good & I like the A3, but we're gonna stick with this one for a while,
  • triplesn8striplesn8s Member Posts: 1
    The Audi 'problems' forum is scaring me badly. I have heard all of the German cars with the latest multitasking electrical systems have beaucoup electrical problems. But I am tired of driving crap feeling vehicles & I drive 35K miles per year for work with my own car at my own expense (self employed). I own triumphs and a vintage 911 so I like a car that feels good. I am not 'well off' with money to burn.
    A friend is offeringme a '99 1.8T with 80K miles for about $5000. He claims no electrical problems. Sometimes older designs are more reliable, is that the case with the '99 1.8T? This owner is the meticulous type. He says the only problem is the front lower control arms which were squeaking. Audi shafted him on the recall so he won't buy another Audi. He says the squeaking just went away and the car drives fine, it is a 5-speed. His car has minimal options. He did mention he had one rear caliper acting up. I do trust him.
    I need to get 3 years of relatively low cost motoring out of it. I try to get 200K miles out of my cars. (My Pontiac threw a rod yesterday at 179K.) I have access to a low cost mechanic and can scrounge parts myself, NAPA has rebuilt control arms for $123 each.
    Am I nuts for considering this car? Does it have the same reliability issues as the later ones with regard to electrical gremlins & oil sludge etc?
    Will this car bury me? What should I watch out for? How long do the turbos, motors and transmissions last? I drive a lot so a car constantly under repair costs me twice- once for the repair & again for the lost time. Should I just run like hell & just buy another crap Pontiac? [non-permissible content removed] cars are kind of out as I call on US automakers. For some reason they are more forgiving if you drive a German car.
    Bill
  • seattledanseattledan Member Posts: 1
    Try the Cardomain Store..they have a fit guide that should tell you which speakers will drop in easily.
  • kellilou3kellilou3 Member Posts: 1
    I was just looking at some 2002 A4's on the internet, and the majority of them had peeling coating on the driver's side door handle, and the black on the window buttons had worn off. Is this something that many of you have seen over time? Thanks!
    The peeling on the driver's side doorhandle did occur on my '98 A4 2.8, the paint also started coming off the sunroof control as well. Otherwise the interior held together well and I was still getting compliments on the condition of the car after five years and over 100,000 miles.
  • lsmmsu88lsmmsu88 Member Posts: 1
    I'm deciding between a 1.8T (all have CVT?) or a 1.8T Quattro, any feedback on pros and cons of CVT vs. Quattro?
    Also, what are advantages or disadvantages of tiptronic
    transmission? Read somewhere that it results in higher fuel consumption and slower acceleration? Any benefits?!
    I live in Michigan, so driving in snow is consideration.
    Well, do you want FWD or AWD? Lots of factors involved in this decision... Certainly AWD is a benefit to getting going in snow. If you've had FWD cars and haven't had a problem in the past, then consider the FWD, and maybe even consider getting a set of winter tires (they make a BIG difference!) The dry pavement handling will fill slightly difference, especially if you like to hit the gas a little into turns...
    The AWD will get 1-2 mpg lower than the FWD. Not a huge difference.... When I drove the 1.8T with the automatic transmission, I thought it was dreadfully sluggish. The manual, IMO, was much snappier. Turbo lag was much more noticeable in the auto.
  • richb1richb1 Member Posts: 9
    Anyone know the difficulty of replaceing the left headlight on a 2003 A4 1.8T? Dealer wants over $45 plus parts to do this and I must leave the car all day. I have a hard time paying that much for something I've done several times on my wife's Honda for the cost of the bulb. Thanks in advance.
  • audisucks1audisucks1 Member Posts: 2
    Do not EVER buy an Audi. I have an A4 from 98 and it has eaten $3000 to $4000 annually since 35,000 miles. Every single part has a flaw in it -- front suspension cracked on both sides, ABS module fails and needs $1500 replacement, clutch failed on the highway, gas pump failed on the highway, brakes wear out after 12,000 miles. I will NEVER buy an Audi again!
  • mbnut1mbnut1 Member Posts: 403
    Well there are two sides to every story. My '98 A4 1.8T 5 spd quattro had some problems (turbos, front suspension)which were fixed under warranty. I now have 110,000 miles on it and have't had to do much to it. If it weren't such a good car I would have gotten another Mercedes by now. I should add that it has also seen two weekend long track sessions at Mid Ohio in it's life.
  • sd38sd38 Member Posts: 1
    You are lucky that your bulb replacement only cost $45, as one of my 2002 A4 low-beam headlights cost $96. To date I have not figured out how to replace the front bulbs, but the rear ones can be replaced without going to the dealer.
    The side edge of my 2002 A4 rear-light-panel can be lifted up(it is held in place with two pressure-fitted rubbber-fastners)with a putty knife or small screw driver. Then on the inside of the trunk opening on the side-trim-panel is a small round cover that can be opened from the rear side. Inside is a Phillips-head/8mm socket screw that needs to be unscrewed before the entire light panel will open.
    The bulb specs are found on the light holder, but beware that the Sylvania Bulb book found in most auto supply stores did not have accurate cross reference information for my vehicle.
    Maybe someone will come up with the solution for the front bulbs.
    Hope this helps.
  • kelbelle37kelbelle37 Member Posts: 8
    Hi Bill,
    I would seriously consider buying anything but an Audi. My car is now about 2.5 years old (bought it new - on the showroom floor - with 4 miles on it) and I've replaced every headlight, tail light, turn signal, and now the "regulator" - all electrical problems. The regulator (because my driver's side window will not work properly will cost ~ $350. The car is a lemon and everyone I work with that has one (6 people - years 1998 - 2005) have various problems and it's costing them an arm and a leg to keep up with. They're great looking cars and I love the way mine handles (2004 A4 1.8T Quattro), but it's too costly and too much of a pain to keep up with.
    Good luck,
    Kelly
    I have a 2004 Audi A4T Quattro and since I purchased it (new), it's had electrical problems. So far I've replaced every headlight, taillight (one twice), one turn signal, the windshield washer motor, brackets (twice) on the windshield wipers because of corroding, the fuse for the wiper fluid injectors, and the regulator for the power window. I've complained to Audi and me dealer since the beginning (prior to my warranty expiring) and the dealer just blew it off as "it happens" and Audi said last time I spoke to them to let them know if it keeps happening and if so, they would look into it. Well, I called today (Audi America) and was TOTALLY blown off with some scripted BS about now it's not under warranty so they've fulfilled their obligation. They told me to talk to the dealer which will do nothing. What are my other alternatives? I'm not even sure what I'm supposed to ask the dealer or Audi to do. Buy me a new car??? I've sunk so much money into a two year old car. My plan was to run this one until it died, but it looks like it's headed to the grave before it's time. What should I do?
  • 944boy944boy Member Posts: 14
    you looked at crutchfield web site? looks like there are several option with or with out bose also with or without Nav system and from the looks of it theres an adaptor ring around the speakers that can be removed or inserted depending on what level audio group was supplied with your car for diff speak sizes..I know this wasn't any help but the best bet Jubie is to measure the ones in you car?
    Later
    944boy
  • rallyalldayrallyallday Member Posts: 1
    I was wondering if i should buy an audi A4. I ask this only cause i have heard of massive electrical problems since it was bought by VW. Also if thats a lie I am looking at 96 to 98 5speed awd. Should i get the 1.8T or the 2.8. Any advice will be much appreciated. Thanks for you time.
    From Drew
  • a4driver1a4driver1 Member Posts: 2
    Hey Drew,
    I have had 2 A4 1.8Ts, originally a 2000 model year (which I bought new and my brother still drives everyday reliably with over 300,000 on the odometer, plus my current car which is a 2004 model year with 85,000 on it.
    Both have been extremely reliable as I have not experienced the problems that everyone has heard.
    I have driven the 1.8T as well as the 2.8 many many times, I would get the 2.8 if you are going to go with an automatic, otherwise I would pick the 1.8T with the 5 or 6 speed any day of the week. On top of a more sports car feel, you can chip the 1.8T from 150 or 170 to about 208bhp. Which is what I have done, and that changes the whole dynamic of "turbo".
    Ed.
    I have had two A4s (a 2000 and a 2004) both of which I bought new of which my brother still drives the 2000 which has over 300K on it and I drive the 2004 which has 85K on it.
    Neither car had any major repairs other than oil, gas, brakes, tires etc... except the 2000 needed a new radio after 200K and 3 years (replaced very economically I may add through a dealer swap program) and the 2004 did have a transmission replaced under warranty early in the warranty period with no hassles (in fact it was the dealer that found the problem, I was just in for an oil change).
    I highly recommend it, enjoy!!!
  • jga4jga4 Member Posts: 1
    If you have an A4 with a 1.8 liter engine, watch out! You may have the same problem I had last week. My oil warning light came on as I was driving on a busy highway. I pulled over and checked the oil, and it showed that my oil was full. I continued on my way and the oil warning sounded again. I checked again and the oil was still full. I started to drive again and the warning went off another time and then I heard a loud POP. Smoke poured out of the back of my car, it lost all power, and I had to drift across 4 lanes of busy traffic to get to safety.
    The Audi dealer says I have a hole blown out of the engine. He refuses to say how it happened, but did say that no oil was circulating in the engine. Now, he wants me to pay $12,000.00 for a new engine, even though I had kept my car in great condition, changed the oil, used top of the line synthetic oil (as instructed), and just had my last scheduled service 2 months ago.
    I called Audi of America for assistance, but they absolutely refuse to help me. Their customer service is a sham. They have a bunch of unknowledgeable operators who just take information. They will call the dealer and if the dealer refuses to help you, then Audi won't help you either.
    The problem was not of my making, it was a problem endemic to the 1.8 liter engine. Audi has apparently had a long history of problems with the 1.8 liter engine and oil starvation (among other problems - belts, etc.), but won't replace your engine if it blows up after it reaches the 50,000 mile warranty limit. I am left without a car and must either buy another vehicle or pay a huge sum to get the Audi fixed. I wouldn't drive another Audi if it were given to me.
    OMG!!! I'm so sorry to hear that happened to you! I PRAY it doesn't happen to my lemon. I know exactly what you mean about Audi customer service - it's a bunch of 22 year old girls (nothing again women - I am one - but... they're clueless and scripted) who just consistently repeat "I'm sorry, but we've satisfied our obligations to you for the past 50K miles...blah blah blah." Right now they are "in discussions" with my dealer as to whether or not they (the dealer probably) should help me out with all of my electrical problems. Good luck! and by Japanese next time, I know I am!
  • 4ringer4ringer Member Posts: 2
    Does anyone know where i can find the IAT sensor for a 2002 audi a4 3.0 quattro?? I have bought a performance chip that installs to the harness wires. Do anyone have any comments on that either? Any help would be greatly appreciated.
  • wagonshowagonsho Member Posts: 4
    i've had it for a week now...a 2002 a4 avant with 3.0 v6 and tiptronic, sport pkg, luxury pkg, everything but the Bose stereo and navigation (which i've used and isn't very good for this model year - i don't pay them much attention anyway...i'm too involved in driving). so far no problems at all. i'll keep you posted as i put more miles on the odo.
    got a great deal from the dealer including a bumper to bumper warranty for 4 yrs and 48k miles...yep, an out of warranty car is now completely covered, and the warranty cost me next to nothing (this is goes way beyond the CPO warranty they offer). i did my research and got a screaming deal on this after negotiating with the dealer - i went as far talking to several of the sales people and with the managers so that when it comes in for service, i'm not just dealing with them as car sellers but more of a bunch of friends. the dealership was fantastic, and possibly the least pushy staff i have ever encountered at a car dealership. it was refreshing since i had been test driving cars for a month and began to loathe going to any dealer. another plus...Audi is replacing the rims (previous owner scratched them while parking) and back bumper (because of a tiny scratch i couldn't even see...but they say it happened when they were moving the car on the lot so it must be replaced - now that's honesty and service). not sure if i can mention the dealership name here...
    i've wanted this car for a while and waited until the year, color, engine, trans, accessories, etc were exactly what i wanted and could afford...i think the 2002-2005 platform look is the best Audi has made. the new large-mouth bass grill for 2006 is okay but the previous version is a 10 for looks inside and out - i think the wagon is far more attractive than the sedan, which is no slouch itself. driving dynamics are great and the sport suspension makes any stretch of open road or sweeping turn a pleasure to blast through. while only a bit less refined than a bmw engine, the 3.0 v6 with tiptronic is great and has plenty of power. not to mention 22-28 miles per gallon at 75-80 on the highway. because of Audi's drive-by-wire electronic throttle, using the cruise control improves gaas mileage on the freewat by 4-6 mpg over using your foot the whole time.
    i'm not completely star-struck here...i know German cars a bit (have had 3 of them now...MB, BMW, and the Audi) and expect some little gremlins to develop given the high level of technology in the car. but with my warranty, i won't have to pay to play. to give you an idea, i spent nearly as much in repairs last year for my outgoing 1990 Mercedes wagon (out of warranty) as i will in car payments on this newer Audi. i loved the Benz wagon for its size and feel on the road, but it was simply getting ridiculous to spend $1000 for repairs a few times a year on a car worth less than $10k. but for a car with over 150k on the odometer, the car still drives/maintains very well. not even Mercedes makes cars like that anymore, with a llifetime measured in decades not years. the Benz can easily go another 150k on the motor, so i didn't have to get rid of it if i didn't want to.
    tip...when test driving a car, drive the exact same car (if possible) on several different days at different times of the day including at night to get the feel for it. this will also let you determine how comfortable you are with the view, the cockpit and controls (is everything within reach? and lit at night for use?), the dynamics of the suspension (drive over some potholes, speed bumps, etc...expansion joints on sothern California freeways is a good test of any car's composure at high speed) and how well the engine responds in different scenarios - merging onto the freeway or merging into city traffic on a busy street. watch the gas gauge as you drive too...is the engine gulping gas when you drive hard around town? a half hour to hour long test drive will let you know...if the dealer is reluctant to do this, spring for the cost of the gas yourself, and then be weary of a dealer that won't spend a few bucks on gas to sell a $20k plus car.
    overall, i am very happy with the entire experience and the car too. my apologies to Audi owners who got a "bad one." it happens with every manufacturer, especially the higher end cars loaded with gizmos. that is the price you pay for having a car that is more than just transportation. if i didn't enjoy driving so much, i would have gotten a different car and saved some money.
    put it/keep it under warranty, test drive the heck out of it (i test drove the car i bought three separate times over the course of a week totaling about 2-3 hours behind the wheel), and enjoy.
    where did you get your chip? i want to chip mine too, but there don't seem to be too many chips for the 3.0.
    I bought a chipe from contestmotorsports.com. it was about $30 bucks with shipping. I got it in, but I cant seem to locate the IAT sensor to install. I don't really feel like ordering a chilton for this. There is also a chip called black ice.
    I purchased my 98 A4 1.8t in 2002 for $10k with 80k miles. I now have nearly 110k miles four years later. While I definitely got my money's worth, they are notorious for having problems. It drives like nothing else for the relatively low money (compared to shelling more for a bimmer or benz). My mechanic warned me that both 4 and 6 cyl Audi's are notoriously the most difficult vehicles to work on and are expensive to maintain. In fact, he said the 6 cyl are worse because they pack so much into a small engine compartment. With that said, I recently found out I need to replace the turbo ($1500 repair). This isn't a big deal to me since I hadn't spent anything on repairs in the four years I've had it (Except did replace the timing belt at 85k miles for about $400 as preventative maintenance). If you are looking for simply low cost, most reliable: stick with japanese. If you want fun to drive and with a decent purchase price and are willing to take a risk with expensive repairs, look at the audis. With gas prices as they are, consider the 4 cyl. turbo (but save $$ now for emergency repairs).
  • genjunkgenjunk Member Posts: 2
    Dear jga4:
    I encountered the similar experence you had with the A4 last night. It happened at I-5 Washington States while I was driving back to Canada. The situation similar to your description. Since it just happened last night, I have not contacted the Audi service yet. Don't know what they would tell me. What happened to your car now? Did you pay the engine repair cost? My vehicle just did the 300+ point inspection and certification process a month ago, I am hoping that the dealer can takes the responsibilities for that. Also when I do the search about this engine oil signal, I found this article. http://www.canadiandriver.com/roadtest/96-01a4.htm The key point is Audi issued technical service bulletins on this problem and has extended the warranty to eight years with unlimited mileage on the 1.8T engine for all Audi A4s built between 1997 and 2004. The extended warranty is transferable. Owners who have experienced engine damage and paid for repairs can request reimbursement for those repairs provided they can prove the appropriate oil was used and changed at the intervals recommended in the owner's manual.
    If you were not aware this before, hope this help.
    Josephine
    I have a 2004 Audi A4 1.8T Quattro with 65K miles. My book says I need the timing belt replaced at 75K miles. Any one have any opinions on this? Can I go longer than 75K? About how much should I expect it to cost to have it replaced?
    Also wanted to tell the folks with engine troubles - I complained to Audi about my electrical problems (took about 4 weeks for an answer) and they agreed to reimburse me for the replacement of the "regulator" for my window. This was my most recent expense. Others were under warranty. They agreed to pay for the part, but not the labor. Better than nothing. I did have to complain to everyone though before they "looked" into the issue.
    Kelly
