-Kavan
It cost me $330 to get it fixed. $250 flat rate for fixing it and the punks at the Infiniti dealer charged me 1 hour labor to remove the head unit.
Try to remove it yourself and maybe you can find a local shop that'll fix it for less.
My 93' has a K&E air filter and I've used Mobile 1 sythetic oil starting when it turned about 40k miles. I plan to do the same thing on the 97'. It also has Enki wheels and BF Goodrich 235/45/17 Comp TA tires which look vey cool on the J. The 93'is still running as good as the day I bought it.
I looked at a lot of new cars, and narrowed my choice down to the Passat, the Audi A-4, and the new Infiniti G-35. When I found this mint condition J for about half to two thirds the price of the new cars, I was sold. Based on my experience with the first one, it's been a great car! By the way, the dealer told me that Nissan stopped production on the J because it was too expensive to manufacture at the target price.
The new G-35 is the closest thing to the J, and I plan on buying one of those in 42 months from the same guy that leased the 97' J. I told him to call me when his lease is up.
wants to sell for little under $10k.
The car looks good and drives OK with two minor? problems. The front vibrates at around 80 mph and
it also vibrates when braking hard.
While the first one seems to be balance on wheels
I am afraid the second could require the rotors to be turned. Am I right? I am no car expert.
One more question: how expensive is to change the timing belt since I might be required to do that
in about 20k miles if I decide to purchase the car.
Thank you in advance.
The timing belt will cost about $4-500 to change. You may get it done cheaper or for a bit more depending on where you go. The Infiniti dealerships I trust slightly more than an independent but if you have a good independent mechanic who normally does your work, go to that person. It's up to you.
Try to get your parts cheap.
If anyone could give me some idea what a certified 97 J30 (not a touring model) from an Infiniti dealer should cost me, I'd appreciate it.
Certification of any cars adds about $500 to $1000 dollars to its overall price, generally. I would look to pay at or below Blue Book prices. Check the net to see what similar cars are selling for.
I think I must be wrong. The sale person said it passes some 135 point check, as well as carfax history check. I am not sure if this type of check is the same as certification. I didn't ask and he didn't say it's certified.
Thanks for your response.
My '93 J30t looked new when I sold it last year.
The 93' has lighted exterior door locks. When you use the remote to open doors, the locks are lighted in a green light. Cool, but I'm not sure why they had this feature because once you've unlocked the doors remotely, you don't need to see the door locks.
The 93' also had a very complete service manual in the small compartment on the left side of the trunk. I'm not sure why this was not included with the newer models, because it is a very complete manual, similar to a Chiltons that you might purchase, but it was supplied by the factory. Both of these were probably cost reductions.
I think the service manual was no longer provided to save costs. I wonder if some of the european luxury brands offered the service manual?
The 93' has chrome exhaust tips and the 97' does not (more cost reductions?).
The 97, has a wood surround on the passenger window switch, the 93' does not.
Minor differences, but every day I'm seeing more of these.
The biggest difference is the 4-wheel steering on the 93'. I notice definite difference in the cornering, but then I also have 235/45/17 tires on the 93'.
Luxury cars today have clamored for this look now, most notably the Acura TL, which designers said they had to beg the Honda headquarters in Japan to let them keep that element from the concept. Even the Lincoln Continental has chrome exhaust tips. Go figure the turn around.
Am somewhat confused about gasoline. What is recommended...87, 89 or 93 octane. I read a posting here from a J30 owner who said he has been using 87 octane for years with no ill effects, comments?
Unless the gas station you go to has exceptionally pure gasoline in all their grades (and few do), I would stick to using PREMIUM only. People who spend that kind of money originally on such a car ($45 grand) could afford that kind of gasoline and any type of maintenance. If you can't or won't spend the extra few pennies to keep your J30 in the utmost working order by not skimping on the gasoline, I wouldn't suggest you buy one. Engine trouble is already terribley expensive. I wouldn't exacerbate anything or tempt the fates with cheap gas in any form.
We already know that auto manafacturers are trying to reduce costs by any means they can, starting first with their cars' quality instead of their excutive paychecks. Just think what the gas companies are probably doing!
To put it all in perspective, I know a few people who skydive, with no side effects like getting splattered in a cornfield. Now, if I went and did it, I could die as soon as I jumped out of the plane. In this case, what others did for years with no bad consequences happening I could do and easily end wishing I hadn't. Give your future J the best start in your life. LOL
Anything less will probably result in a fouled up fuel injector. Also, using Mobil 1 motor oil is highly recommended.
You really have to baby this car. Otherwise, you'll be spending a lot more money later. Trust me...I know.
Although I've been using Mobile 1 in my J that has 100k miles, I'd still like hear about any problems that you've had.
I remember an earlier post on this site that said to drain and flush the trannie, and replace the transmission fluid with Mobile 1. Have you done this?
But my business partner is now lamenting my loss, and she is looking for a J30 to replace her Ford T-bird----a real move up in the world. Since I enjoy shopping for J30's so much, I promised to help.
We are looking for a black J30 with tan interior, reasonable miles, for under $10K. We're in Birmingham, AL with easy access to Nashville, Atlanta, or other Southeastern cities. Our local dealer is currently sold out of used J30's, and keeps trying to sell an I30 instead. Nice try, but it's not the same car (I know, because my wife drives an I30).
So, how about it? Anybody out there have a black J30 with tan interior for sale, or know someone who does? Model year and mileage are flexible, as are the J30 vs. the J30t. I think the touring model is a bit better but not everyone prefers the sportier, stiffer suspension.
You and your business partner should have a look at Edmunds.com's Used Power Shopper either to look for a J30 and/or a J30t (or any other used vehicle).
The Membership Agreement strictly forbids using the Town Hall to buy or sell anything at all, so if any of our members have a vehicle that fits your description, the only way he or she could make it available is through that link.
Good luck - I hope you find something suitable.
Pat
Sedans Host
Dave, I'm glad you and your family are okay. I really fell bad for your J. But the Q45 will bring just as much pleasure! Now that I've got mine, I want another J! I guess that's the way the car is; it grows on you.
Well, as most know, I bought my J online and found the experience to be much better than walking onto a lot. I searched the web and found a few J30s that your coworker may want to check into. You are more willing to find a deal through the web and circumvent the salepeople and any pressure they may try to enlist in getting you into an I30. LOL Ebay has one that I at first thought was black but was instead Jade Green, which looks black anyway. It's a 1997 model with just a paltry 48k miles on it! Can't beat that. Have a look: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=1822425444
Does anyone have problems with their sunroof leaking? When I wash my car the roof leaks just enough to get the bottom side of the sunroof soaked. Anything I can do to prevent this?
141k miles and still going strong
I see J30s occasionally. The shape is unforgettable, and it's a lot better than the other closest try (the Taurus).
Forbes has the car in its list of "The Greatest Japanese Cars of All Time." The links: http://www.forbes.com/2001/04/23/0423feat_print.html
And I found at the Infiniti Owners Club that in Japan, some guy took a J. Ferie (the Japanese J30) and implanted the 300ZX's 300HP TWIN TURBO engine with, get this a 5-SPEED! They had pictures of it up a while back but I had a devil of a time remembering which owners club I saw them at. The pictures are gone now. But I saw them. I guess a heart transplant like that for the J30 isn't detrimental to its health and hard for it to reject. And it wasn't at all expensive liek you may be thinking.
I could forgo the 5-speed in favor of an automatic but I guess some people would want to dust an M3 or two on the road. If I see the pictures again, I'll let y'all know.
I wonder if their is a tuner in the states who would be capable of swapping the engines like that . . .
Jspears2, I will pass that info on to my business partner. Is there a way to contact you (e-mail address) outside of this board?
Anyone else with a good J30 to sell in the Southeast (prefer black exterior, tan interior) can contact me via e-mail with info at the following address: dnull2@csc.com
I'm not the buyer, but will forward the info on to my business partner, who has solicited my help in shopping.
In regard to another post, my old remote from my wrecked J30 did not work at all on my I30, but when I got my Q45 I was able to re-program it instantly. Instructions can be found at infinitihelp.com
Finally, if Infiniti is out of stock when you call for an owner's manual, ask them to give you the number for a company called Dyment. They are the publisher and can put one on back order for you.
Dr. Dave
http://infinitihelp.com/Infiniti/index.htm
See post #431 for information on the manual.
Is there really that much of a margin between the gauge and what really remains?
Any help is appreciates. I love the car, but don't like driving it right now.
Shannon
Thanks for the suggestions and help. It's good to know of alternatives to dealers. And really, still love this car, especially after reading the Forbes article.
Shannon
http://crutchfield.com
MGriffith
Thanks again.
MGriffith
