Honda Odyssey GPS Navigation System
I saw alot of questions in the regular Odyssey
forum about navigational systems, and thought it
would be a good idea for those with NAV systems to
post setup, and other technical information.
Enjoy the ride !!
Enjoy the ride !!
It DOES estimate time until arrive when you have entered a destination, and it updates the information as you drive. This is done by calculated distance, and updated locations and speed estimate from gyroscopic sensor. However, the estimated arrival seems to assume you don't exceed 60 MPH (even if you have been going faster).
It does have a database that includes gas station locations (and Honda service, and much more) although it is certainly not complete.
If you're talking about the whole vehicle, well, check out its description under "new trucks" at the bottom of the page.
guitarzan
Community Leader/Vans Conference
Jefe5, sometimes it is easier to start with questions. Have you thought up any specific q's that could help spurn some response?
guitarzan
The section on the NAV answers a number of general questions about the Navigation system, and you might want to read it.
There is also the potential for add-on updates -- I would be willing to pay for updates containing detailed information for places not included in the standard DVD. However, this is just a wish -- I haven't heard anything suggesting this from Honda or NaviTech.
i love it
Press on the time while at the shutdown screen.
A great tip! The clock is actually visible now.
Apologies in advance if my memory is bad ... I haven't tried deleting previous entries.
from 1st setup screen
press previous
then follow the instructions to delete any of the addresses on the list or all of them!
David.
Also in the other topic, someone had trouble setting up the pin for the use personal addresses list... the 1st time you try it, you have to enter done with no numbers i.e. there is no pin yet so don't try and enter one... (pp 52 in the nav book)
I too have tried to delete previous destinations. I think you just enter new ones and the old ones eventually go away because the system will hold just so many.
nav screen, maybe 3.5 x 5? but it is not lcd... at least it does not look it, or have the problems with looking at it from an angle... it is very bright and viewable from any angle, side to side or high or low.
Any guesses on when a NAV system will feature in the first criminal trial? "Where were you on the night of October 3rd?" "I was at home all night." dramatic pause "Not according to the NAV system in your CSS '02 Ody EX-NAV you weren't!" "Rats, I forgot about that."
Can you add a Cassette tape player in addition to the standard CD player(which comes with EX model), since Nav screen takes some space on the dash board?
David
2) As much as I also wish it, the system can't play DVD movies. Even if the operating system let it try, it doesn't have MPEG-2 decoding needed to play them. (No reason for a mapping system to have it, and it would add to cost.)
[It is also illegal to have video displayed in front seat of car in many states.]
3) Satellite updates -- nice idea, but would require an additional receiver, of a different type. The NAV is a GPS system which means it can receive position information only from GPS satellites. It is not a satellite receiver like a TV dish receiver, and GPS satellites do not transmit extra (map) data.
4) Use in criminal investigation, etc. While the system does track previous destinations, I doubt sincerely that it tracks location otherwise. And there is no indication that it records time or date.
5) Many posts ago some in the general Honda Odyssey list speculated on tracking location of a van because of GPS -- not possible as far as I know -- the GPS system receives only -- unlike a cell phone it does not send anything that can be tracked.
One thing to think of: a nav system is unique to the vehicle, not like a radio that broadcasts the same signal to thousands of receivers.
And yes Goverment planes have transmitters that can identify the location of the plane... but they had it long before gps... any pilot out there can explain it. As to our previous lcd thread... yes I agree it has to be lcd... and the thick glass theory explains alot... however it is still the best one I have seen!
For E911 purposes, Congress has mandated that the first phase (transmitting the one specific "cell" tower handling the call to E911 Emergency Response Providers along with the call itself) be in place by 2000 (I think). The second phase requires the triangulated location to be sent with the call by 2006 (I think). So, this problem is being addressed for cell phones, but it is an unwanted expense to the providers in capturing, processing and transmitting the information with the E911 calls.
However, I think dcrisler is also correct in that there is no "sent" signal from the Nav system as it is only a receiver (everything necessary is sent from the satellite(s)). In addition, even if the Nav system did send a signal, it would be a costly proposition to track and process each one; I really doubt that our government (who has built and maintains the satellites) has taken that on (Big Brother fears notwithstanding).
I work with databases all the time. While there is certainly a lot more information available and collectible on each of us than we may like, it tends to be information with Social Security Number as the key. Without that clear and unique key, it is nearly impossible to match up and collect the information together in any meaningful way. The volumes of data become so immense so quickly that the expense and the error rates are enormous; so I think it happens far less than our paranoia might indicate.
Having read the last couple of messages twice, I still am not sure I'm understanding what each poster is saying. However, I *THINK* that I agree with dcrisler and disagree with csade.
What I was trying to say in my last post (although obviously not clearly) was that cell phones can be located (in theory -- not every system has yet implemented E911) because they do transmit;
GPS receivers cannot be located because they do NOT transmit (unless some other transmitter is added to the device). The GPS system consists of satellites that transmit, and a receivers (like the one in the Odyssey) that receive signals from multiple satellite transmitters and compute location from that.
I also speculated (I really don't know) that no database of where you have been is kept in the system. It would take storage, which is limited in the Navigation system.
That last is from the assumption that anything beyond the entered destination points would result in a huge amount of data in short order -- even if the "granularity" of the way-points stored was big. Sorry, getting off again and I don't even plan on getting a Nav. Never mind.... ;-)
Yes, GPS systems don't transmit, and therefore can't be tracked. Yes, the Odyssey system doesn't keep track of its whereabouts. My hypothetical question was very generalized, and I was just musing on when (3 years from now or 30 years?) a NAV system in a car would figure in the first criminal case.
Also consider that if you get a constantly streamed updating map database (wouldn't it be cool if your NAV system knew where road work was going on and could route you around it?) you don't need to keep data on the whole country, only data that is within range of your car during the repeat cycle of the satellite. GPS receivers don't use a dish or other large reception device because the bandwidth the signal required is very small. Low bandwidth plus digital signal gets you a small receiver. *Someday* static databases will be yesterday's technology, how we get to dynamically updating databases is just fun to speculate on.
The text follows: (somewhat long)
Alpine Launches First Aftermarket DVD-Based Navigation System In North America
The DVD PowerNav System Offers Unprecedented Computing Speed and Continuous Coverage on One Disc; Raises Benchmark for In-Vehicle Navigation Systems
TORRANCE, Calif., Oct. 6 /PRNewswire/ -- Alpine Electronics, the industry-leading manufacturer of high-performance mobile electronics, today announced the launch of the first aftermarket DVD-based Navigation and Information System. Alpine is the global leader in mobile navigation systems, with more than seven generations of product development and nine years marketing experience in the Japanese and European markets.
Alpine is the first manufacturer to expand the North American navigation business into a two-media product strategy. With both CD-ROM and DVD-ROM-based navigation technologies in the marketplace, Alpine is the first company to offer consumers a choice of systems that now defines a category of product in North America.
Similar to Alpine's award-winning CD-ROM based navigation system, the new NVE-N851A DVD PowerNav System is the most advanced in-vehicle, Global Positioning Satellite (GPS) linked computer available in North America. The DVD PowerNav system offers the same door-to-door route guidance system that allows drivers to be safer and more efficient on the road. Because of the data capacity on a DVD-ROM, Alpine is able to offer this coverage for the entire continental U.S., as well as the greater Vancouver and Toronto areas, on a single disc.
The biggest advancement of the DVD-ROM platform is the software's operational speed. DVD-based navigation dramatically increases the speed-of- route calculation and off-route recalculations, making the system far more responsive in a vehicle. The DVD system operational speed is ten times faster than other navigation systems on the market. It also incorporates an embedded CD Audio technology that delivers enhanced voice guidance, including specific freeway entrance/exit names; 16:9 wide screen aspect ratio graphics; and full integration with Alpine's Mobile Mayday(TM) telematics system.
"Alpine's goal is to offer the best and most powerful mobile multimedia products to consumers," said Stephen Witt, Alpine's vice president of Brand Marketing. "As the leader in navigation product development and marketing, we are committed to delivering products that are the most technically advanced yet easy to use and safe to operate in a moving vehicle. We're shifting our navigation platform to DVD to ensure we deliver the highest performance and value available to consumers. Alpine is aggressively pursuing ways to advance navigation technology and get more drivers to realize the time savings and safety benefits a navigation system can yield."
The new navigation system builds on the positioning accuracy of the CD-ROM based NVA-N751AS model by gathering information from three sources to accurately display the vehicle on the map. The DVD-ROM system's GPS receiver, speed sensor and electronic gyro work in unison to provide precise vehicle positioning for accurate announcements of voice instructions.
The new system utilizes a new Alpine DVD mechanism that reads a single-sided dual-layer DVD-ROM. The dual-layer DVD-ROM stores a maximum of 8.5 Gigabytes in map data and Points of Interest (POI) information. This enables the system to cover the entire continental U.S., plus Vancouver and Toronto on one disc, eliminating the need for multiple CD-ROM changes when travelling cross-country.
The new features that are exclusive to the DVD PowerNav system are:
-- Mobile Multitasking: Allows you to search for alternate destinations or view certain Points of Interest locations -- all without interrupting your current route's voice guidance.
-- Local Point Search: Looks for points of interest surrounding the local destination.
-- Enhanced Voice Guidance: Voice prompts are announced from CD-Audio files for superior clarity and specific guidance instructions. A library of entrance/exit names and numbers are stored and announced when using freeways.
-- Way Points: Allows you to electronically mark certain places on the route to your destination, or can be used to customize the route you travel.
-- Avoid Points: Allows you to avoid certain street or areas which is useful when navigating around specific areas or highways with known heavy traffic.
-- Beep Points: Alerts you with a series of audible beeps to a specific point(s) on your drive that have been selected or want to remember.
-- GPS Satellite Status Screen: All-new screen design displays not only how many satellites are being received, but also the signal strength from each satellite -- a visual representation of their relative position with respect to your vehicle and your vehicle's current directional heading.
-- Trip Information Screen: All-new screen keeps track of important trip information such as distance driven, time elapsed for the current trip, system odometer (total number of miles driven since navigation system was first installed) and the total time the system has been used.
Version 1.0 of the DVD Smart Map Pro software includes --
-- GUI for Drivers: Alpine's exclusive "Graphic User Interface" for drivers, designed for a safe and simple user interface in a moving vehicle.
-- Destination Input by Phone Number: Entering the phone number gives you the option to call the destination, route the destination or do both simultaneously.
-- Smart Key Filtering: The easiest way to input requests through your system's 10-key remote controller. Once you start inputting a destination, it quickly offers destination options that match the words you've typed.
-- GPS Clock: Accurate GPS timing allows for calculation of precise arrival times, even across time zones.
-- Today's Plan: This feature allows you to input and list the day's destinations (up to eight), then the system calculates the most efficient travel order for all of them. No backtracking, wasted steps, or stress.
-- Map and Call: MAP allows you to confirm the destination's location on the map and view the area around it. CALL allows you to place a call to the destination with a single keystroke to the places found in the Points of Interest database or Address Book (requires optional accessories and a wireless phone).
Mapping and information for the DVD PowerNav is available on a single Alpine Smart Map Pro DVD for easy loading and future upgrades. The Smart Map Pro DVD-ROM stores thousands of pre-programmed points of interest (POI) around the U.S. and parts of Canada, and will be updated to keep up with the ever-changing road systems and locations. Alpine's DVD software incorporates the Navigation Technologies (NavTech(R)) map database and the Info USA(R) points of interest/business information database for state-of-the art precision and detail.
Alpine's DVD PowerNav System is available with a choice of three monitor options: the TME-C005AS Control Monitor, a new 4.6" LCD monitor with built-in control buttons; the TME-M750, a new 6.5" LCD monitor with large 16:9 wide screen display and video inputs for entertainment sources; or the CVA-1005, the flagship 6.5" wide screen motorized in-dash Mobile Multimedia Station for integrated audio, video, navigation and telematics, featuring 16:9 wide screen GUI for Drivers graphics for all sources.
The DVD PowerNav, model NVE-N851A, is scheduled to ship November 1, 1999 to authorized Alpine retailers and has a Suggested Retail Index (SRI) of $2000. The SRI's for the three monitors are: TME-C005AS Control Monitor at $600; TME-M750A 6.5" Wide-Screen Monitor at $800; and the CVA-1005 Mobile Multimedia Station at $1300.
About Alpine Electronics
Alpine Electronics is one of the world's leading mobile electronics companies. Alpine is the only manufacturer specializing in mobile multimedia, an integrated system approach incorporating audio, video, security, telematics and navigation products for the mobile environment. With research and development facilities in Asia, Europe and the U.S., Alpine is the global leader for in-vehicle navigation systems in Japan, North America and Europe for the after-market and for OEM factory installations. Visit Alpine's Web site at www.alpine1.com to discover the future of Mobile Multimedia or call (800) ALPINE-1 for the closest dealer.
I found a chinese restaurant that I never knew it existed so near my home thru nav system.
One minor problem/nuisance.................To my disappointment .. the touch screen is not finger mark/impression free as I had heard it earlier from a dealer. Is there a solution to that?
I am not missing the audio tape at all.
As far as the screen goes -- I've never found a touch screen that didn't pick up finger marks (after all there is oil naturally on fingers). I find that disposable pre-moistened eyeglass cleaning cloths -- such as "Sight Savers" from Baush & Lomb work fine -- and I can also clean my sunglasses or glasses from the same wipe. We get them at Price/Costco for about $7 for 100 of them.
Computer screen cleaners would probably work as well, but are generally more expensive.
Why pay $2,000 if you can get a portable GPS for less than $500???
You also need mag. glasses to look at that small screen. Would recommand the nav for old people with memory loss.
As far as your comment regarding memory loss... well that maybe true but at least there is a solution... but there usually is no solution for being short sighted...
Oh and as for touch screen smudging... we don't seem to have a problem... but dust does collect and we use the little cloth that was provided to clean the screen, with the vehicle.
