Visitor Agreement.
Had a trans shop drive it; they couldn't duplicate the problem. (I also get the infamous 3-4th gear shudder every now and then.)
I plan to have the fluid changed before investing in a rebild, but will the new fluid possibly help correct the "dropping out of gear" problem? Any thoughts?
What year car and how many miles? When does it happen---cold or after driving 20 minutes? How fast and accelerating or steady speed?
For it to "drop" out of gear, it is probably something besides the oil itself. More likely inadequate pressure to the clutch pack (bad pump or seals), a worn out clutch pack, or something broken that keeps clutch pack from locking up tightly. I suppose a really plugged filter might do this but I would doubt that.
Low oil level could do this too, but I assume you've checked that with the engine running as specified.
I hate to have the trans rebuilt unless I absolutely have to. I'm gearing myself for a new Marauder next spring, assuming that dealers don't mark up the car as much as they have with the new TBird.
I've heard that HotRod magazine projects a $29,500 MSRP, but which options are included (or not included), I don't know. Guessing a 32-33K with options/delivery etc, and a possible markup on top of that figure puts the car into a bracket that could hurt it.
Regarding my trans issues, problem never happens during cornering, only at highway speeds in 4th gear. (The car is a 94 Bird, not a CV, but, as you noted, drivetrains are similar.)
Ther is a condition refered to as "transmission shudder" that seems to effect nearly every panther platform car. I think that this is what a lot of you guys are dealing with.
There are a few fixes and precautions found on those sites for that problem.
low "whizzing" sound as the car shifts, and it only lasts for a split second. The dealer said its
just the Anti lock brakes. I really dont think so.
Are there any problems for that model year that you should look out for? Also, with this car having the rear air suspension, what's the track record on its reliability?
If anyone has some advice to pass along, I'm all ears...thanks
Pat
Sedans Message Board
still have tranny shudder. The ONLY fix for this is to have ALL the transmission fluid replaced with fresh, clean, Mercon V synthetic fluid. Not Mercon III or IV, not Dextron III or IV, not Type F, not Type A. It's expensive to buy from the dealer, but it is the ONLY fix.
Shakyb has a letter on this car from Ford regarding the manifold, should it ever fail, to have it replaced, so my cab is at the dealer now. I want to have that transmission fluid replaced while it's there. Hope I catch them while it's there.
I just bought a 2001 CV LX, Comfort+, and Handling & Performance Package from my local Ford dealer. I've put on 300 thrilling miles on this beast and love the car.
Now, a couple of thing recently cropped up that I would like to ask the learned members of this forum.
The door that covers the refueling cap pops open after I hit a minor bump or when I shut my door. I looked at the latch at it seems fine. Any takers?
Second, my turn signal stalk occasionally blinks faster than normal when I click it down or up. I have the digital dash version. Should I be worried about that?
Andy
Ron35
Man the low end pickup on this car amazing. Has anyone done a 0-60 timing of this car?
Andy
MArio.
http://www.toughguard.com
Andy
I live in the mid-Atlantic region (Wash, DC Area) where our average snowfall is only 18 inches per year. I bought a 92 Crown Vic 4 months ago and this will be my first winter in it. The last RWD vehicle I had in the snow was a small pick-up truck with no weight in the back. That thing was fine in the snow until you came upon the smallest incline...then it was finished. It couldn't climb a 1% grade to save its life but on FLAT snow covered ground it was fine.
I would like to put 4 good snow tires on my CV, but that would run me over $400 installed. The police in my area run all-season radials year round and just keep snow chains in their trunks or at the motor pool for the winter months. A good pair of snow chains only costs about $60 so that's probably what I'll keep in my trunk, too.
Does anybody have any other advice to offer? The only thing that worries me are hills. I learned how to drive in Ohio, so I'm no stranger to snow, but up to this point, all of my snow driving has been in FWD cars where I did fine. I'm thinking the 50/50 front to back weight distribution will help in a Crown Vic. I've heard about putting some 50 pound sand bags in the trunk, too.
Anyway, thanks for any suggestions.
2. Buy two Firestone Winterfire (~$60/each) tires for the rear wheels. This is not the ideal case (4 snows) but will get you out of parking spots and keep you moving while you're going up hills.
3. Having traction control does not eliminate the need for #1 and #2.
4. Chains are a mess and are really only needed for extremely steep inclines or when you didn't do #1 and #2.
The ideal case is buying a set of 4 good snow tires along with a set of rims. This eliminates frequent tire swapping which adds up pricewise, can cause rim damage, and gives you even tire rotation for winter and summer. However, it costs upwards of $600 depending on rims and tires.
The best snows I have found for my CV are the Nokian Hakka 1's. They're traditional snows like the WinterFire and run about $110 shipped (for 225/60R16). Imported from Finland, these tires specialize where deep snow and ice are an everyday reality. I rate them top notch in every category, and find it hard to imagine the Blizzaks giving better traction/control. However, I do know these Nokain's wear like iron (3 seasons with 35k miles and they're like new) which definately isn't true for the Blizzaks.
Final note: stopping is even more important than getting going. Going *down* hills or around curves are where the front snows will help you the most. Keep this in mind if going for the cheaper 2-tire route (which I think is appropriate in the DC-metro area).
Ron35
Luckily, our average snowfall in this area is only about 18" every year. However, some years we'll get 2-3 feet, and then some years it won't snow AT ALL. It's hard to predict.
I'll take your advice and add at least 200 lbs to the trunk, but I don't have air suspension in my CV so I'm not sure if the extra weight will make the car sag. Keeping the gas tank full also adds about 125 pounds in the rear too (19 gals times 6.5 lbs per gallon). Keeping the transmission in "1" or "2" is also a good idea (provides engine braking). Thanks again.
Thanks again. It's great to be able to come to a forum like this and get such excellent advice.
Have a safe winter.
