How to you adjust the clock manually? I only looked around little bit last night and did not find any options to change the time.
The clock picks up the time from the satelites?
Do we have to bring the car in to update the software with new daylight time saving? Free service?
Or have to buy new DVD with include updated software?
Go to setup, then at the top right of the screen press "more" and on that screen you can adjust the time.
I'm guessing the DVD is where it's getting the time info.
I thought it got the time from the sattelite because when you change time zones the clock adjusts. But I guess that could be built into the DVD as well.
Now the next question is the system will auto change the time next month...then we have to manually change the time back?
Or I guess we can turn the Daylight Saving Time option off?
The manual was obviously written by some geek who made too many assumptions about user know-how. OR maybe they never thought of having to delete an address or two.
ANy way HELP!http://a332.g.akamai.net/f/332/936/12h/www.edmunds.com/media/townhall/webxi- cons/emotorcons/emo_confused.gif
confuse
Press the Setup Button (on the right side of the screen)
Press "More"
Press "Personal Information"
Press "Address Book"
If you have a PIN I think you add it here to continue. If not then:
Press "User 1" or "User 2"
Press "Address"...select the one you want to delete
Press "Delete"
Seems like a lot of work to edit or delete things in the address book. A simple delete or edit button in the address screen would have been helpful!
Good Luck.
We manually set the screen to night when driving in the dark.
I think the Honda NAV is rather primitive and overrated.
Did you ever get a copy of the Navi manual? I am also looking for one myself. We just purchased a 2004 and it's has everything but the Navi manual. I've been checking online everywhere and can't find anything.
Please let me know!
velippert
Our sales guy told me that he had heard it was possible, despite what the manual says.
PHK
So is it OK to just switch the engine OFF, when the Navi screen is ON. Or Do I need to use one of the methods you mentioned above to switch the Navi OFF and then turn the Engine OFF?
Am I sounding too paranoid?
PHK
Do you know if there's a way to speed up response time for the back-up camera (and/or eliminate/delay the OK screen)?
Most days when I get in the van, start it up, and begin backing up, the OK screen is on for the duration of my back-up. Thus making it much less useful. I like the back-up camera but wish I could see it for those quick starts and back-ups. I'm really not in that big of a hurry - it's just seems really slow/delayed.
And I completely agree with the other comment above. Honda: Why didn't you just make NAV have an on/off switch like every other (non-critical) device in the vehicle? Most days I don't need NAV. Why does it default to turning on and I have to ignore to get it to go off? The radio, heat & AC, lights, turn signals, cruise control, etc. don't work this way! Why not an on/off switch for NAV with back-up camera more quick/responsive all the time in reverse? And why do we need legal disclaimers in a vehicle we purchased once and drive everyday? OK, I'll stop griping. I like our Ody.
This usually happens when I'm alone in the van. The kids slow me down and I usually get the screen in time. My irony is that my parking lot at work is where I need the backup camera. We have plenty of space at home... I guess the solution is for me to just chill out and slow down!
BTW: The camera's wide angle lens is especially useful when you have to back out into traffic and the view is nearly blind. It's like being able to crawl to the tailgunner's position and lookout for the enemy. It's great! I won't buy another long vehicle without one of these.
Anybody have ideas on how to speed up respose time for the backup camera?
I'm getting backup sensors installed in my trucks. The camera is nice, but the sensors will catch kids etc. just as well. The camera would be a bigger plus on the trucks for hooking up the trailers though! Get both!
Backing in a minivan has a big disadvantage: tough to load stuff into the back.
There is no known way to speed up the boot up time. I can't help but wonder if this isn't intentional to prevent folks from wholly relying on the camera.
Touch Screen Keypad:
Some of the letters on the touch screen keypad are non-responsive. The only way the system will respond is to use the joystick to highlight the letter/number and then push the joystick to select it. This occurs with some letters/numbers on touch screen keypad, in particular L,P,O,S,0.
Place Search Feature:
The place search feature does not function properly. When typing in a place such as Costco, Wal Mart, K Mart, Target, or any other place (find place by "category" or "name"), the system cannot find the place nearest our location. Instead, the system returns locations hundreds or thousands of miles away from our current location. You can be sitting in the parking lot of the place and the system still can't find it. If you happen to know the address, the system will work. Honda says they are aware of the problem but do not yet have a fix. We were informed that Honda is supposed to have a "Fix" in sixty days. However, Honda was not able to explain what the "Fix" is or what it will accomplish.
Has anyone else experienced either issue with their Odyssey Nav system?
Once the navigation system is running it seemed to be impossible to shut it down other than to turn the car off. However it can be shutdown by going into "Setup" and set the "Display" to "Off". For a 2007 Odyssey the screen just goes blank and for a 2001 Odyssey you get the normal startup screen that allows you to select "Shutdown". In both cases, the screen will start up again in a display mode of "Auto" if you push any of the control buttons.
One other trick on the 2001 Odyssey is that you can get the LED clock to enlarge into the center of the screen if, instead of selecting "Shutdown" you touch the small LED clock display.
My father just bought a 2007 Odyssey and I bought his old 2001 Odyssey so I've been fooling around with both displays.
American Honda or you local dealer? We have the same issue but didn't complain about it. The whole NAV system is primitive & thought this was just another setback. Did you ask about the limited POI database that is outdated by 5-10 years?
BTW, have you experienced any of the issues with the touch screen keypad (some keys non-responsive)?
Yes. I thought it was just a finger temperature issue just like our touchpad on our kitchen range. Like I said before, we hardly ever use the NAV system so I really wouldn't know if keys are not functional.
$2200 bucks for the NAV is definitely a rip off. I wanted NAV in the van & didn't want a pod with wires hanging from the windshield in a $30k+ car. Oh well, chalk it up as a lesson learned.
Wow, you hit the nail on the head. We have an 07 CRV with exactly the same issue. Searched for a McDonalds and it returned something a thousand miles away. Plus, the POI database is crap. Very limited and out of date. We have a Garmin Streetpilot 2620 and it really makes the the Honda Nav system seem more like a children's toy rather than a state of the art navigation system.
I sure hope that Honda recognizes this as a PROBLEM and works to fix it. Because what we have now is nothing more that a satellite tracking system, but useless for navigation.
The POI's are lacking greatly compared to my Garmin unit as well. I love the integration of the Honda system, but it's not the best navigation aid. What's really sad is that as far as OEM navigation units, the Honda system is actually very good. I've used several others and they were 100 years behind my Garmin. The honda system is about 20 years behind...... :P You wanna see a piece of crap, try using my wifes Lexus GX470 nav....you can't even change anything while you're moving.
Strangely enough, that's what we did, although I think when we had our biggest problem, it was while we were already on a route and we selected to add a waypoint and then selected along route and then searched for McDonalds, and it came back with somplace in California (we were in Virginia!!).
Another issue with that is that in the setup, you can specify to only display POIs that are within a certain distance of where you are. For example, we only selected items that within 1 mile of a highway, so while we were on Interstate 64, we should only have seen the closest McDonalds to where we were that are within 1 mile of the highway. How it determined a McDonalds in California was the closest is where I think the bug is and is similar to the issue that the other person had.
Otherwise, there is just the general disappointment that the Honda Navs have a limited and out of date POI database which will make it virtually useless for finding places when traveling. When it can't find a Sears department store that's been there for 20+ years, or it retrieves a Dairy Queen that's been closed for nearly 7 years, it lends itself to question why bother even including a POI database if you're going to have one that is so poorly maintained.
You would think that someone like Honda would team up with Garmin/Navteq/etc. to use common maps and POIs. Maybe that's coming down the pike, but never the less, Honda should be able to get access to the same POI databases that someone like Garmin has. I'm OK with the fact that the system itself may not have as many features as a Garmin unit, but I would at least expect that for my $2,000 investment that it be as accurate as a Garmin.
The NAV is not the greatest but it's nice to have it in the van. I had the same problem before, and my wife always told me that we wasted our money ($2K) on this stupid NAV when I tried to look up something.
The biggest advantage of the build in NAV for our Odyssey is it has big screen compare to other portable one.
This is really more of a gripe than an actual question. I still wish NAV would just stay off until I wanted it on. I just don't use it everyday. It seems to hang up/slow down the response for the back-up camera which I DO use everyday.
Thanks for your reply!
I think the system should be more user friendly so that I don't have to be very careful how to search for things. Have you noticed all of the categories? It is like you have to know how they programmed the database and how they categorized everything to be able to effectively use it. Why should the user have to know which category (e.g. Department Store, Grocery Store, Clothing Store, etc.) to search to find the nearest Wal Mart or Costco?
Ridiculous!!!!
The only reason why I have the GPS is because I had no choice. With the Odyssey I knew that having a backup camera was a must. With the Odysseys you have to get the GPS also if you really want the camera...or vice versa.
Here's a story to let you all know how reliable Honda's GPS is. The system listed a Honda Dealership a full one-half mile south of the dealership's actual location! The POS can't even list HONDA locations correctly!! :surprise:
Find Nearest:
Carwash
Gas station
Fastfood
Movie
It will list you the nearest requested POI sorted by closest to your current position.
Hope this helps.
