Visitor Agreement.
This was after I bought the van.
Keep in mind for system limitations:
The destination icon shows the approximate location of the destination. This occurs because a city block can have as many as 100 possible addresses (for example, the 1400 block is followed by the 1500 block.) Since most cities use only a portion of the 100 possible addresses (for example, in the 1400 block, the addresses may only go up to 1425 before the 1500 block starts), the address 1425 will be shown a quarter of the way down the block by the system instead of at the end of the block where the destination is actually located.
No consumer GPS is 100% accurate. They will all be off by 100 feet or more but no better than that due to Government regulations. Military GPS is much more accurate (See link).
http://www.exn.ca/FlightDeck/News/story.cfm?ID=20000502-53
I hear a lot of comments about the Garmin or the Tom Tom being better than what is in the Honda but that really can not be proven. What we hear on this site is a small sample of the thousands of GPS units used. We also by default will alway get more complaints than praises as most people will vent when things do not go as expected but tend to be silent if things are going as expected or without issue. Also this is a honda forum not a Garmin forum so it is expected that you will get honda complaints.
Just visit a Garmin forum and browse over all the complaints Garmin users have on a Garmin site. Here are two link for you. You can just Google for more.
http://www.pocketgpsworld.com/modules.php?f=96&file=viewforum&name=Forums
http://www.pdastreet.com/forums/forumdisplay.php?s=&forumid=108
GPS systems of the same type will have differing results by design. I really can not begin to explain it but here are some links regarding the GPS technology and why some units are very accurate and other not. Again we could have the same exact GPS systems but have very different results.
http://www.romdas.com/technical/gps/gps-acc.htm
I hope I have helped you to understand a little of why you have the problems you have. The one thing I can tell you is that your GPS is accurately (within 100 feet) plotting your longitude and latitude. However it is most likely the map of your area that was used that is off, not the GPS position of where your car or GPS device is.
I did a test last week and ran the Garmin side-by-side in my Ody just for fun. On trips, I've been taking the Garmin along with me because I've found the POI's in the Ody system to be quite lacking. I've always thought some of the Ody's routing was goofy at times, but I was again surprised by just how bad it can be.
We were at a relatives Saturday and coming home I put in "go home" to both navs. There are two basic routes that we can take to get home from this relatives. One route involves a straight-shot out some two-lane state routes, and two turns onto county roads (we live in the boonies by most folks standards). The other route involves hitting the interstate for a large part, and then two turns onto county roads.
Historically, I've found both routes take about the same amount of time although I've never checked the mileage. So I thought I'd test the NAV systems and see which route they picked. Well I was actually blown-away by the crazy route the Ody system recommended. It had me making about seven additional turns and routing me out some deliverance type backroads. I even tried changing the routing method to easy, direct, etc. but it continued to offer a route that was bizarre to say the least. The Garmin mapped me home the exact way I normally go (the state routes, avoiding the interstate). What was really quite interesting was comparing the two. The Ody NAV route was stating it was 27 miles and the Garmin was stating 23 miles. But what was even more interesting was watching the Ody NAV recalculate as I would blow past a turn it was recommending; it would recalculate and then display a SHORTER time/mileage using the new route. It actually continued to recalculate using different backroads for nearly half the trip, and about 1/2 way home it finally calculated a route that matched the garmins.
I've ignored some of the Ody's goofy routing in the past. Usually I know the way to a town but program the NAV for finding an exact address in the town. There have been several occasions where the Ody NAV was routing me all over God's creation just to get to the town. In the past I just figured the goofy route was 1/10th of a mile shorter or something, but watching the NAV recalculate and showing a shorter distance just blew my mind.
Ha ha ha...that statement was too funny.
Yeah I am sure that your Ody for your town has a poor or bad map loaded. The POI may also be lacking for you area in the Ody as well.
But the GPS does have your position correct as the satellites are tracking you exactly where you are.
A bad or poor map being used is like copying a map at 1/4 or .250 scale but the copier really made a .249 shrinkage. This will have you off on your map if you put the two on top of each other by a half mile in any direction. There is just no way to sync up the two maps as they are not the same scale.
Hopefully you can get an update and Alpine/Honda uses a better map in the update.
Or if you can test the portable one at the same time that the test drive your car. If possible.
Also, you will save some money on the car if you choose not to get the NAV. But the built in NAV has a nicer look. That part is up to you.
I really like the NAV. I even told my wife she was fired. She use to be my navigator. My new NAV does not argue with me and I never get told to make a right when she meant left.
I feel compelled to respond to your posting. I've been having similar annoying situation since I started fooling around with the DVD player unit just to find out how it works. Last night I unplug the negative from the battery for 2-3 hours. Reconnected it. Started the car, Navigation asked for the code. After some 5-10 minutes systems seems to work well. Still working till today.
Let me know if anybody has better experience.
Hope it helps!
What kind of GPS is this that at 1/4 of mile does not shows anything on the icons?
What kind of GPS is this that it does not show the names of the streets on the map, just a few? If you are at 1/4 or more, good luck to you to know where the hell are you.
ALL other car GPS have better resolution and street addresses on EACH CORNER you cross as minimum.
If you are on a trip, you want to know where is the next gas station by just looking at the map, so you can calculate your self if you want to use that station or nor.
This is just garbage.
Bart
When I start the van, it asks for the security code which according to the manual happens when the NAV system loses power for a period like if you replace the battery. Our battery has not been replaced or run down that I know of.
I re-entered the code and will watch the system. Any ideas? Could the heat be effecting the system some how?
https://store.alpine-usa.com/Hondadvdsales/naviorder.php
I have also read the posts about a lower-48 NAV not working once it is shipped to Hawaii.
What I was wondering is what is affected/doesn't work when the NAV is inoperable due to it being in either GE or Hawaii---specifically, if the backing-up camera function still works...
Also--any info on if there are Honda extended warranties available for purchase in GE or if the US HondaCare warranty is honored in GE would be much appreciated.
From reading the Odyssey glossy brochure it also mentions that the NAV system has voice-activated cmds for such things as audio and climate control--do those still work with the NAV inoperable??
Does anyone know if there are some new 2007 Odys being sold with 4.62 NAV, or is the 4.62 NAV only a version that will be sold with the 2008 models ?
I hope this helps.
1.For updating set the car in ACC or turn it on.
2.Then go underneath the seat while doing step one.
3. Open the door that covers it and eject the disc. Then take it out and carefully replace it with the new disc.
4. Insert the updated disc and close the cover then do whatever you want with the older disc. It will go blank but then when you put the new disc it will automatically update it.
5. Then when its done just turn off the car and enjoy!
A quick tip.
You can't go back to your older disc. I don't want to discourage anybody but why would you want to. You buy the discs to have the latest maps. I hope this helps.
Frankly, the Honda NAV system is completely useless to me. I do like the rear-view camera, however, but don't drive backward very far!! I'm highly disappointed with the NAV system and with Honda for putting such inferior products in their cars.
I bought the Ody in Tennessee but live in Kentucky. I cannot find my home in the system. Neither can I find the Honda dealer in Tennessee, my parents in West Virginia, my old university in West Virginia, my church in Kentucky. To tell me it's acceptable to get within a half-mile of a destination is ludricruous when the little Cobra unit puts me on the doorstep and would give change if I needed it!
Honda got duped and apparently does not care. If I could figure out some way to remove the Honda NAV, I would yank it and install some aftermarket techno-whiz that would work correctly.
http://mapreporter.navteq.com/dur-web-external/secured/submitDur.do?userType=CON- - SUMER&language=en
for number 4 please click factory installed system. Then honda and then choose your model. It should say DVD navigation system and thats it. I hope this helps.
This should help you report map data. Blame it on navteq and alpine. Alpine presses these discs months in advance. I hope this helps.
Take it to another dealer because the one you're using doesn't know what the hell they're talking about.
The only reinorientation needed here is their attitude toward customer service.
-My Garmin runs circles around any of the OEM systems.
-The Honda is the best OEM system I've used.
Now after that little blurb, the Honda system really makes things difficult. So at least until really playing with the system and learning EXACTLY how to find something, give it a chance. And I wouldn't expect a dealer to really know how to operate it either. But even knowing how to run it, there's still no reason for some of the poor routing, missing roads, and lack of POI's.
Now onto the help: If you want help with this, go out and try to find something (like a college, restaurant, or address). Then come back here and give me the step-by-step on how you did it and I'll see if I can help. I initially found the Honda system deplorable but after playing with it for some time, I now at least give it a passing grade. But on long trips into unknown territory, my Garmin is along for the ride as well.
According to the site, it says: "The fall 4.62 DVD release is currently available to dealers for 2008 vehicles only. A release for customer vehicles will be available early next year."
Dealers don't carry the GPS disc. You must order it from the site above. Alpine is the only company that sells it. Currently it's on back order until 2008.
> finally determined our GPS was malfunctioning as we had
> indicated and it needs to be replaced at a cost
> of $4700. Yikes, has anyone had this experience and found a
> cheaper option for replacement?
There is something wrong with this picture.
Four thousand seven hundred dollars for a GPS?
Even if it were so, any system this expensive is usually built
in a modular way, so that it is possible to replace individual components
when they fail. This isn't a throw-away $50 DVD player.
If this happened to me, I would ask for an explanation of why
this can't be done by replacing a single, cheaper part.
Then I would escalate the issue, first with the dealer, then
with Honda itself. This is way unreasonable.
