Chevrolet Impala Audio
1202123252631
    Did you search this topic for any past posts that may apply to your question? Enter "amp" into "Search this Discussion".
  • base02impalabase02impala Member Posts: 3
    Thanks Karen S
    For all you Impala owners with the RDS Radios, I have one too! I had poor reception and sound until this weekend. I had PIONEER 4way 6.5 installed the front doors and 5 way 6x9 in the rear. The sound was better but it was still not getting any power from the factory amp and still my highs were horrible with not much bass. Then this weekend I went in my front doors and cut the wires leading to my factory tweeters located in the doors. I heard an immediate improvement in the sound. I even have better sounding bass @ 1-3 notches to the right of center. So after I noticed an improvement in the sound I had my amp installed to factory unit by tapping into the factory amp like clayton did. Everything sounded good until my amp blew both my subs( I have a very strong amp and the subs were'nt strong enough). But all in all I am pleased to have better sound. Next I'm going to move my radio to the trunk and install a new aftermrket unit and replace my blown subs.
    If you have any question feel free to ask
  • lowride24lowride24 Member Posts: 1
    Hi!
    I have a 2000 Impala with a factory AM\FM\Tape deck. I bought a factory CD/MP3 player that I was told would work in my car. I works fine, until you try to start the car. At that point, the car wont start and "LOC" comes up on the radio display. I was told the radio remember the VIN of its last host. So say the deal can reprogram this, some say they can't. HELP!!!!!!!
  • tagalong100tagalong100 Member Posts: 3
    Even with the key out of the switch we have a blinking on the dash of the radio/time light (with a clicking sound) and a blinking of the headlights. The only way we could get it stopped was to disconnect the battery cable. Any ideas?
  • geas101geas101 Member Posts: 1
    I just had my factory radio replaced and they moved it to the trunk, It is just sitting and the trunk and while I drive the radio slides around, anyone have any tips or ideas on how to mount it so its stationary? Brackets perhaps?? Anyone have pictures of how they did it?
  • cpkuszniajcpkuszniaj Member Posts: 2
    You can put in the new factory unit you just purchased and bypass the LOC (result of CLASS 2 COMMUNICATION WIRE). I tinkered with the problem for the last 4 years. Your suppose to take it to the dealer to have them reprogram it with the correct vin for the vehicle. However you can bypass it all together. Only problem is you will lose your ability to customize your car settings through the radio. The solution is to cut the CLASS 2 wire in the harness to the radio and connect it to a ground connection (BLK). This keeps the Radio for verifying the VIN on the Car's BCM, but without the radio detecting it cannot connect to the computer. This allows you to use your radio but you still loose chimes and programming.
  • mpbrown18mpbrown18 Member Posts: 1
    Did you ever get this to work, I would love to get one for my 2000 Impala.
  • axel7axel7 Member Posts: 2
    Go to www.crutchfield.com. They have a "What fits my car?" feature that will tell you what decks and speakers are installed fron the factory, and what will fit.
  • gmoney3gmoney3 Member Posts: 1
    DO ANY BODY KNOW HOW TO TAKE THE BACK REAR SPEAKERS OUT
  • mstngwnr97mstngwnr97 Member Posts: 1
    did you fix your radio? i'm having the same problem???
  • sundquistsundquist Member Posts: 2
    I have the exact same problem also. Does anybody know what the fix is? If I find out I'll post.
  • mssegbefiamssegbefia Member Posts: 1
    I also own a '01 Impala with exactly the same problem. Took it to the dealer, they informed me that I would have to have the unit replaced. Called me back and told me that the radio has been discontinued and I'd have to have it rebuilt at a cost of $335.00. Not sure what the next step is going to be, but I sure do miss music in the car. :(
  • dgonzalez13dgonzalez13 Member Posts: 110
    My old 2000 Impala had the radio cut out after about 10-15 minutes of use, then come back on within a few minutes of "cool down time". I pulled ou the radio and discovered my car-stereo installer had left a wire on the radio harness behind the radio cut and exposed, which caused a short. The short would allow the radio to operate for 10 minutes until it overheated the radio, causing it to slowly fadeout, or quickly drop output (all the while still showing it had power- time was still displayed on face of radio).
    If you have the time to check it out yourself, you just need a screw driver to remove the instrument cluster front panel, then remove the radio to check that there are no exposed wires. If there is an exposed wire, wrap it in electric tape, and then use a cheap $1.99 plastice wire loom to cover it so it does not become scraped again. hope this helps..
  • hifonics_4everhifonics_4ever Member Posts: 2
    I recently purchased a 2001 Impala with the RDS radio and amp mounted in the trunk. Reading this post got me thinking. My radio dosen't lack bass at all, in fact it had way too much. the only way I could stand it is if I turned the bass almost all the way down to 0 in the manual mode listening in the auto tones was way over bassed in all modes.
    Doing some internet searching lead me to a company that sells car repair manuals online I signed up for the 1 year 1 car deal. They keep an updated list of all the Tech Service Bulletins for my model. One that caught my eye was "Radio has too much Bass. Simply put GM has a radio recalibraton procedure that resets the tone levels to a more neutral level.Only a garage that has a Tech II programer can do this.I printed this TSB off and went to my local GM dealer. They loaded in the new calibration in about 5 min. for free, no questions asked. Even though the car is WAY out of warranty.
    Now that the stereo tone is fixed. The stereo sounds much better now.
    Hope this helps someone.
    Now that the dealer has fixed the tone issue. The stereo sound is good but still need some power to get it in the ballpark for my tastes. So I removed the factory amp and dropped in one of my own. A modest 50 watt x 4 channel amp for now. All this was done in the trunk using all of the existing factory wiring.
    I'm writing this as kind of a how to for everyone has been asking about this.
    I found online a BHA2003 connector "google it", you need 2 of these, this plugs directly into the factory harnnes, the reason you need 2 is because you have to rob pins from one to have enough wires to complete the job. this make for a nice clean look too.
    Here is what I did.
    Remove the retainer clips from the back of the plugs. take a small paper clip or screwdriver and push it into the connector from the front of the plug, this releases a metal tang that holds each pin in. This is not easy to do and takes time to figure out the technique. Do not pull too hard on the wire or you will damage the connector pin.
    Strip both connectors bare of pins take all of the wires and plug them back in one of the connectors in the following order .
    Pins coming from the head unit, used as line level signals wired to 4 RCA plugs
    for the amplifier input signals.
    Channel 1 "right front" RCA plug.
    A10 right front + grey wire
    A9 right front - grey black wire
    Channel 2 "left front" RCA plug.
    B10 left front + white
    B9 left front - white/black
    Channel 3 "right rear" RCA plug
    A12 right rear + purple
    A11 right rear - purple/black
    Channel 4 "left rear"
    B12 left rear + green
    B11 left rear green/black
    Connections coming from the amp that feed to the car speakers.
    Channel 1 "right front speaker"
    A2 right front + grey
    A1 right front - grey/black
    Channel 2 "left front speaker"
    B2 left front + white
    B1 left front - white/black
    Channel 3 "right rear speaker"
    A4 right rear + purple
    A3 right rear - purple black
    Channel 4 "left rear speaker"
    B4 left rear + green
    B3 left rear - green/black
    The second plug contains an orange and a black wire.
    The orange wire is 12 volt always live. Fused at 15 amps you can use it to power the new amp. I would suggest running a larger pair from the battery because most amps draw a lot more more than 15 amps.
    the black wire is ground. I couldn't find a mating connector for this one so I just tapped in the sides and soldered wires on.
    A5 blue wire use as remote turn on lead connect to amplifier.
    A6 "amplifier present" line orange white.
    connect this to the battery + through a 10k ohm resistor.
    A word about the amp present line.
    This will force the radio to output a "line level signal" and disable the "loudness" function that boosts the bass at low levels and chokes it back as you turn up the volume. If you do not force the radio (meaning leave disconnected) into this mode and feed the speaker level signals into the RCA lines you WILL damage your amp. Reserve that mode for the guys bypassing their amps altogether or use line level converters to get your signal down to your RCA levels.
    If you want to bypass the factory amp just and run off the head unit, just connect the like colors together.
    Also of interest. the factory radio I have outputs a slightly lower signal to the left channels. I' have to move the balance to the left 2 clicks to get it even. I have verified this with an ocilliscope and a test tone cd. I'm guessing that this was programed into the radio by the factory for this specfic car. The dealer told me that the same radio is used in many different models of cars and each one is custom tailored for the vehicle. When they reset the tone on my radio I saw on the Tech II the screen where they can load setups for different makes and models.
    I saw in earlier posts that people are saying the factory amp isn't much better that the head unit by itself and believe it.
    Try this out and you will be amazed at the results. Even with the factory speakers.
  • zim1zim1 Member Posts: 2
    Can You Tell me which pin on the radio is the class 2 .
    I would like to do this also.
    Thanks Jim
  • impala19impala19 Member Posts: 1
    My 2001 Impala's radio is stuck in the menu function and constantly shows settings instead of the radio station. Every once in a while the radio station shows for about 2 seconds and then it reverts back to settings. I have tried to exit out of the menu and it goes right back to settings again. Another problem is the dash lights blink every once in a while like when the car is first turned on. I took the car into a dealer for both problems and they said they didn't know what it was and would suggest putting in another radio. They said the radio and the dash lights are wired through the same area and could be causing the problem.
    Has anyone else had this problem/problems with the radio?? Please help.
    I had the identical symptoms with my 2001 Impala radio. I tried the amplifier bypass that is talked about in other postings and determined that the problem was with the trunk mounted amplifier. By bypassing the amplifier the radio and all warning chimes worked. I purchased a new amplifier, a "103" to replace the "104". As soon as I plugged in the new amplifier everything worked. Retried the old amplifer just to see what would happen and all of the same problems as before came back, i.e. nothing worked. Have had the new amplifier in for about 3 weeks and so far so good. No relapses. Good luck and hope this helps someone out there.
  • deminindeminin Member Posts: 214
    Thanks to all you folks who have registered complaints on earlier Impala radios. Your voices appear to have been heard. We just bought a 2006 LTZ a few days ago, and the radio is super. They are now using a Bose unit, and the sound and reception are very good. It does not have the "booming" base that the hip-hop generation seems to prefer....just clean, crisp tones throughout its range. The stereo effect can be perceived in every seat...they have really improved the speaker placement, etc.
  • stagpolestagpole Member Posts: 6
    My wife and I purchased a 2006 Impala LTZ in late August. The car is nice, but we have been very displeased with the performance of the Bose stereo. There is a constant background noise (static) through all components (AM/FM/XM/CD player) of the system. The noise persists even when the system is muted. It is very annoying and the dealership seems to be unable to fix the problem. They said that Chevy is aware of (apparently present in other LTZ's as well) and is working on the problem. Also the turn signal somehow is connected through the speakers and it is now extremely loud when in use (very annoying) since the dealership worked on the car. So far, buying our first new vehicle has been an unpleasant experience. We have been without our new vehicle for a few weeks while the problem is being investigated. Does anyone have any additional info on this problem?
  • stelrolerstelroler Member Posts: 1
    I have a 2001 Impalla with the amp in the trunk.Recently it started acting up. It sounds like the radio isn't on a station. At first it would work once in awhile now it is garbled all the time. Do you think it could be an antenna problem or what???
  • jntjnt Member Posts: 316
    Stagpole,
    Since this radio has Bose amplifier, the Head Unit just send out low level audio signals to the Bose unit. This unit, in turns, amplifies the sound. Since you could hear noise in all modes with radio muted, the cause of this problem could be:
    1. The low level audio from the head unit is contaminated with vehicle noise due to cable bundling (audio + data bus,...). Shielding of audio cable from other noisy cable should help here.
    2. Head Unit itself generates noise that coupled onto the audio line (internal)
    3. The Bose module makes this unwanted noise or fails to cancel out vehicle noise coupling to the audio cable. To cancel out the noise, each input must be truely differential input (two wire, for example Left Front + and Left Front -) inside the Preamp block.
    I suspect you have to wait until GM radio engineer find the root cause of this problem before dealer can fix it
    On the Turn Signal connected to the speaker: it is likely the radio that produces the turn signal sound and sends it to the speaker. Whenever you activate the turn signal, a message is sent on the vehicle bus to the radio and tell it to make the sound. The volume should be calibratable if they chose to do so: but who know?
    JT
    If the radio works in CD, CA modes all the time without problem then you are probably right.
    One way to check if you have antenna problem: tune to a AM station at least 100 miles away and listen to it during daytime. If you can hear it, then your antenna connection is OK. AM is very picky about good antenna connection. With FM, you could receive local stations (within 5- 10 miles ) even if the antenna connection is bad. You can try to listen to FM stations about 40 miles away. If not possible, then the antenna connection is bad.
    Your vehicle AM/FM antenna is on the rear glass (wire imbedded in glass): near the rear defroster. There is connection between this wire pattern and an antenna module near it (in the trunk likely). Another connection is between the antenna module and the antenna coax cable that goes to the radio. That connection could be loose. The final connection is between the coax cable and the radio itself. Any of these connection could be bad (intermitten in and out).
    Good luck
    jt
  • ibaswimmeribaswimmer Member Posts: 24
    Did you ever receive any more information about that noise? My husband and I were thinking of buying an 06 Impala and that is literally the only thing that is keeping us from purchasing it.
  • markj5362markj5362 Member Posts: 3
    Just bought a new LTZ last weekend...My last three cars Buick Regals and were trouble-free. This is my first Chevy since '98. I have noticed slight backgound static on the Bose system. I was going to wait a bit to see if anyone else has this problem. I drive alot of miles per year and notice any little "bug" with my rolling office. The car is GREAT other than this little problem. I'm hoping a G.M. or Bose engineer reads this message!
    I agree that I hope GM or a Bose engineer reads your message. My husband called the customer service hotline for GM and was told "It is none of your business if this problem has been reported or if we are trying to fix it!" We couldn't believe it! We really want to buy this car because of it's clean look, but don't know that we can based on the response we got when asking if anyone else has reported this problem or if it is fixable. Please let us know if you happen to hear anything about this background static. It seems awfully loud to us and I am sure it will bug the tar out of me since I do a good amount of driving myself.
  • osarbosarb Member Posts: 1
    does anyone know about the tpms (tire pressure monitoring system)? i am having a hard time finding out what is required to do to swap tires and wheels. i want to take my factory wheels and tires off for the winter and replace them with snows. i am being led to believe that there is more to it than bolt on. can i just relearn these tires and wheels onboard or are the sensors they keep talking about really wheel mounted? i don't see them, so are they mounted inside tire/wheel assembly? can i buy 4 new ones? are they expensive?
    there must be away to use different wheels.
    any help would be greatly appreciated.
    thanks in advance,
    bud
    ps i love my 2006 impala ss. highly recommend it.
    I'm glad to hear that you love your SS. Quick question, do you hear what is kinda like a background static coming ot of your speakers when the volume on the radio is almost all the way down or when the radio is off and you turn on your blinker? It's faint, but just curious if you have heard it. I am trying to find out if it is in just a few cars, most cars, all cars, etc.
  • dstowersdstowers Member Posts: 5
    We just got a new 2006 Impala LT with the BOSE system yesterday and noticed the same issue. I haven't been back to the dealer yet to verify it, but it appears to be a statis/hiss noise that shows up with the slightest amount of volume from the radio. Does anyone know if the BOSE amp has a gain adjustment of some sort?
    Please let me know what the dealer has to say about that. I am extremely curious. Nobody seems to have a real explanation yet.
    Dealership claims that Chevy has sent them an updated program for the stereo to help eliminate this noise. Car is currently in the shop and I should know if it is fixed within a few days.
    That's great news. I would greatly appreciate it if you could let me know if it is truly fixed or not when you get it back from the dealership. If so, I'm going to be a new Impala owner. :-)
  • badams2badams2 Member Posts: 4
    After 2K miles I am only getting 18/19 mpg with this new V-8. Most of my driving is on level roads at 60/70 MPH. My old 3.8 got 30+ on the highway. Dealer is of now help, the car is to new and they do not understand the dod system. I was hoping to get closer to the 28 advertised but so far the feed back I have seen is no one is getting any mileage under normal conditions with this engine. Anyone have any ideas what I could do next?
    What are you getting for real gas mileage, not from the computer but from actual fill ups.
    I am interested in your tire problem as well but think I will just buy chains.
  • jberdjberd Member Posts: 1
    Hello.
    I own a 2000 Impala and jut recently stumbled onto your post for the amplifier by-pass procedure which I am going to try soon. Before I do, I just wanted to ask you a couple of questions. Does disconnecting the power to the amp effect any other operation of the car since the entire system seems to be tied to the radio. And, after the by-pass is complete and the radio is on, can the treble, bass, fade and other sound adjustments still be made from the radio knob?
    jberd
    Tampa
  • capratcaprat Member Posts: 6
    Hi jberd,
    I have not yet done the bypass either, but am thinking fo replacing the entire amp. Don't know how possible that is.
    However, to your questions, if you disconnect your amp you will lose anything that would be coming through your speakers. So, the chimes that you hear when you get a low tire, or when it's time for an oil change, etc, will not be played. However, you will still see those messages in the yellow display in your dash.
    As to your second question, from hat I've read, there will be no issues with using your treble, bass, fader, etc after the bypass.
    Cheers,
    Matt
    So I have read lots of discussions that have gone back for years regarding bypassing the factory amp in the earlier Imapla's (mine is a 2000).
    But what I haven't really read here is why can't the amp just be taken out completely and replaced by a new aftermarket amp? And if done, what is the impact on the system?
    Matt
    I think with the old generation Impala radio, the radio itself is actually capable of driving the speakers directly. So, if the Amp is too boomy for your taste, you could just connect the radio outputs to the 4 speakers directly. All the EQ, Bass, Treb controls are likely done in the radio head anyway. I think the Amp on your Impala is a low cost amp: it just boost up the audio level from the radio.
    jt
    I would have guessed that you were right. However, if that is the case, why does everyone feel the need to perform an amp bypass, rather than just remove the amp and connect the speakers directly to the head unit?
    This head unit is kind of unique: it has its own internal amplifier and is capable of outputing decent audio power to the speakers. The whole reason for it was GM wanted to use the same head unit for vehicle with or without external amp.
    There has been a lot of complaints from old Impalla owners about their radios sounded too boomy. It turned out that the cheap external Panasonic Amp has been causing this problem. And adding insult to injury, this external amp does not provide any perceivable advantage in power output in comparison with the built-in one. Normally we all assume that when you have an external amp, and if you do not like it, you have to buy an aftermarket replacement. Otherwise, the head unit could not drive the speakers directly (typically in most cases). That was the reason for bypassing the amp and use the radio to drive speakers directly.
    jt
    Any luck with that noise being fixed by Chevy?
  • bossgamebossgame Member Posts: 1
    Does anybody know the theft unlock code for the 2000 rds cd am/fm player? I just brought my 2000 impala from a used car dealer Nov.23,05. The cd player work fine until today when I started my car it read locked. Please send help asap!!!!!!!!! :confuse: :confuse:
    there is no code for the Impala radio. The lock/unlock is controlled by the class2 serial interface in the car's wiring system. It transmits basic car data including VIN Number. When the radio was initially installed at the factory, they used a GM Tech2 programmer to "build" the vehicles computer and radio, telling the radio it's expected VIN to match the car it's installed in.
    3 Fixes for this. The all involve the Dealer or someone with a GM Tech2 programmer.
    1. Serial interface is not transmitting VIN correctly. Dealer Replace.
    2. Current Radio is damaged, will not read or receive VIN to unlock radio. Replace Radio at dealer.
    3. Have Dealer connect programmer and "build" cars computer again, after reading and saving current settings. Then have them "reset" the radio to the new build.
    Someone had mentioned a way of disabling the class2 serial reading to allow universal unlocking of the radio. Search this and the other Impala newsgroups to find which pins need to be shorted to ground to accomplish this.
  • tina5tina5 Member Posts: 11
    I'd also like to know if you got the radio problem fixed. I took delivery of my 06 Impala LTZ two days ago. I really really love the car, but the static on the radio is a bit annoying. As soon as a fix comes out for this problem I want to take it to the dealer to have it fixed. But other than the radio problem: Awesome car. I'm so happy with it.
  • scauerscauer Member Posts: 13
    Add me to the list of people annoyed by this car's stereo. I was having another problem with it as well. In two weeks, the FM stopped working about half a dozen times, next trip it would work again.
    I took it to the dealer this past week for both problems, they said they fixed both, or rather, they didn't say they didn't fix either. But when I picked it up the hiss was still there, so far the FM issue seems fixed but it was intermittent so its hard to tell. I didn't realize the hiss wasn't fixed till I left and have yet to confront them about it.
    Scauer,
    I think in the case of your radio, they probably either replaced radio or just unplugged the fuse feeding the radio. In the case of latter, they basically did the radio "reset".
    The hissing noise is a design problem. Unless they replaced offending component (radio or Bose Amp or speakers) with the newly designed part, the problem will always be there. Unless it is simple software update or hardware rework, I doubt that they have a solution soon.
    jt
    Good Luck
    Your radio could not read VIN code from the vehicle. It is more likely a case. If you are lucky, it is just a connection problem in the back of radio. This Class 2 bus wire may be pinched by metal bracket and short it out may be?
    Some older Chevy radio design, you have to enter 3 digit Theft code to secure radio. If battery is ever disconnected from radio (like someone steal radio from you and put in his car), then he needs a right theft code to unlock it.
    jt
    Has anyone else noticed the amount of hearing loss among car dealers? My 2006 LT2 has the same issue, and everytime I try to illustrate it for dealer types they can't hear it, even with the motor off and the doors closed. I can understand that I am probably more sensitive to white noise, but I think some of these shops need to invest in some hearing protection for their employees :)
    YES!!! Finally other people that have heard this noise. I get the same thing when I tell a dealer about the hiss and try to demonstrate it to them. They look at me like I have a third head or something. We were told by one salesman that the noise would be fixed by a patch that was supposed to come out mid-November, but no other salesman has a clue what this guy is talking about and when we called the salesman back a couple of days ago to ask if the patch had come out he said no!(so basically he lied from what I can tell just to try to sell the car to me). Nobody seems to be getting a straight answer on what this noise is and I can't seem to figure out why. If anyone has any ideas on this it would be greatly appreciated.
    :mad: The FM stopped working again today. I'm really regretting getting this car.
