Ford Taurus/Mercury Sable Sedans Pre-2008
The main advantage I have seen with the Vulcan is that they are readily available. Ford should probably just make the 200HP engine standard if there is no other advantage to the Vulcan.
I will be driving mostly around town and there is no lack of power in that situation. It has enough power to accelerate quickly onto a freeway onramp. The only time I would notice the lack of power compared to the Duractec, is if I was trying to quickly pass another car while already traveling at highway speeds.
I still prefer the torquey feel around town compared to a 4 cylinder Japanese car.
I paid less that I could have purchased even a 115HP used 2002 Civic LX with the same miles and price was a big factor in the selection of this car.
And 'upping the revs' on a pushrod motor ultimately doesn't do you any good because the pushrod valvetrain has more mass and becomes inefficient at high rpm. The limitation of the technology limits it to low rpm operation only. The engine gets coarse and unruly in mid-upper rpm ranges. OHC motors can be tuned for low end torque and high rpm power. The valvetrain is lighter so the valvetrain can remain operational at higher speeds.
But using technologies kind of Vulcan now means loosing market to competition and it becomes tougher every year. Everyone introducing excelent cars, even GM and Chrysler. GM pushrods are efficient fuel thirsty engines and transmissions are perfect. Ford has to turn its attention to engine and transmission design asap.
yes.
Class leading and worthy of gushing acclaim GM loyalists spew about it?
No. Its a decent reliable engine. Get over it GM fans. It is average by today's standards and although reliable for a GM product, its not any more reliable than typical Hondas, Toyotas, etc. In fact you will see the Duratec is just as reliable.
In no way do I say the GM 3800 is a bad engine. What i am saying is its performance and reliability are not above the standard of anything else these days. For someone accustomed to GM's less than stellar powerplants a 3800 may be a godsend. But in comparison to the industry as a whole, its 'just another engine'.
Ordinary, average, typical it is, the 3800. Like it for its power, reliability, etc....but its mid pack when all is considered. no reason to hand GM a gold medal for it. I certainly wouldn't seek out a car that has it, just for the engine. Especially when 300 other vehicles out there have just as good of powertrains or better.
now hondas v6 engines for the accords, odysseys and pilots are a different story. GM's 3.8l pushrod may have a little more low end grunt, but is otherwise put to shame (maybe this is too strong) by a good OHC engine. with the advent of 5 speed automatic transmissions and drive by wire throttle, that one advantage is dissipating.
even when GM supercharges the 3.8l, it's still no match for nissan's 3.5l in the maxima.
Go to some of the GM car boards, the folks there think the 3800 is still at the top of the heap! Some even think the 3800 is still on Wards' ten best engines list! They have the audacity to diss the best Honda and Nissan mills and say the 3800 is superior!
glad there are still others who have things in proper perspective and see its just run of the mill motor. Let's see how special that 3800 is when Nissan comes out with the TWIN TURBO v6 in the 350z. Those GM cars will be eating dust dust dust.
I think the whole 'to do' about the 3800 is that its ONE engine GM managed to figure how to make somewhat reliable and so the GM love crew thinks that's a special accomplishment. And even now, the 3800's are blowing plastic intake manifolds on aregular basis because they screwed up the design.
OHC is what enables a light car like the s2000 to produce phenomenal power. That engine COULD be retuned for torque if they wanted. With OHC you can have it either, or both ways. With pushrodsyou get only the torque....not the rpms, not the ultimate smoothness, not the full powerband hp experience.
Looks like they are actually increasing the production of the older engine despite no apparent benefit other than 1 MPG better fuel economy.
A pain in the [non-permissible content removed] that could have avoided by putting body access holes in the area!
Have the same problem with my 2000 Mustang!
Nice design Ford
Dealer wants $3500 to replace the engine. I called Ford and they would do nothing.
Too old.
Local mechanic can put in a used Duratec for $2000. Just doesn't seem worth it for a car with a trade-in value of about $3500 at most.
Local mechanic said he has seen a lot of oil leaks in the Duratec and that results in periods of use with insufficient oil. In addition, he said trannys were inadequate for that engine. He therefore feels it's too big a risk to put another engine in.
So there you have it. A Duratec that self-destructed at 60K and the car is a total loss.
Just thought you would all enjoy this tale of woe.
Leaks in duratec.....first I've heard of it. Sorry to hear about your costly issue.
For some reason I think that someone is going to get offended about my statement.
I don't have an extended warranty and my basic is about to run out. The thought scares me. I'm sorry about your predicament.
Well, it is a Ford......
and I own a Taurus!
MSRP was 22,870. I got $3500 rebate from Ford and $4000 discount from dealer. Obviously Ford is kicking them some money in some fashion.
The cruise control doesnt work, the indicator light comes on but the car coasts down. Yes I read the instructions. Not reassuring on your second day with the car. Of course I didnt test the cruise on the test drive...
80 miles on the car, but it was built in Sept 2001! I guess it sat around somewhere for a really long time.
Any opinions on whether all that time sitting will hurt the cars longevity?
Hell of a car for $15,370 -- hope it has the reliability. Hell, I paid 13,800 for a my stipped 94 Camry with 22K miles in 1995. That Camry was like a watch tho - just ticked away the miles.
There were a couple of pickups, one full size van,4 Escapes, 2 ZX2's (the coupe escort still around) and one Focus ZX5. No Tauri, however. I did see one on their list several weeks ago. So it is still possible to buy leftover new 2002 models, if you are not particularly picky. Good way to get a bargain and still get a new car.
BTW Audi announced that it has 2002 models still not sold and asked dealers to sell them as certified used cars. Audi gives $4,000 rebate to dealer and some other incentive. But Audi is inherently less reliable than Taurus and much more expensive to maintain.
First impressions
The brake pedal is quite a bit higher than the gas, seems like an ergonomic problem. Anyone else feel like you really have to lift your leg to brake?
The car has nice punch 0-30 and 70-90, but at 40 to 60 it is not that quick. It really picks up speed at 70 tho, I found myself driving faster than expected due to power and smoothness compared to my previous ride.
Taurus Has nice taut ride - not sloppy or wallowing at ALL. I had a rental Buick Century and it was piloting a Chris Craft. Amazing difference. I really felt a lack of control in the Century.
I really like all the grippy rubber on the console bin floors. My stuff doesnt rattle around.
Vulcan V6 does not have highway passing power, but seems quick enough at low speed in town and for intial acceleration onto freeway onramps.
Lighted controls on steering wheel are nice (especially since they are not as easy to control without looking as the Hondas).
Sloppier body panel fit and bigger gaps between panels.
Exterior street lighting on side mirrors when remote keyfob is used to unlock doors.
Keyfob is not as ergonomic as the Accords and it is very easy to accidently press the panic alarm. (On the Accord the panic button is smaller than other buttons and has to be held down before it goes off).
A little quieter.
Some wallowing and extra bouncing over speed bumps and exiting from driveway to street. Feels like struts could already be wearing out after only 24K miles.
Brakes softer and takes more predal pressure for the same stopping force.
Your other comments are similar to my experience as well except I don't notice a brake ergonomic problem, but I have driven Tauri now as my primary car since 1990, so am likely used to the brake placement. I don't notice it much different than my wife's '96 Caravan, however. My Taurus does not have the adjustable pedal option, however, so if you do, the pedal placement may be different than mine.
Taurus tight handling and ride without being punishing is definitely a winner. That and I have had absolutely no squeaks or rattles after 24k miles and 2-1/2 years.
I have no problem with pedals except I would like to move them farther away, so moving pedals is no help for me. Breaks on Taurus/Sable is worst compare to competition, but for everyday usage it is okay. They are a little spongy but I get used to it on my older Taurus (that has disk brakes on wheels).
Steering is not so fast as on more modern cars, but still okay for everyday use. It is a great commute car because it is more quiet and smooth than most of other cars, you don't get tired. Overal impression of interior is good, though craftmanship is not as good as on Japanese or german cars. But I like this overal good feeling, I find Camry and old Accord interior too boring even though better executed, so I like Sables interior more, really during driving I don't pay much attention to details, but Ford has to address this issue in next design.
"If somehow I could have been blindfolded when approaching the car, then blinkered while driving it, I would have sworn that I was in a peppy, responsive, nimble yet solid touring sedan from... Well, I wouldn't have been able to say where from exactly. The 2003 Sable delivers more pleasurable road feel and feedback than its typical Japanese rivals from Toyota and Nissan. On the other hand, the Sable is a bit cushier in the ride department--a little less severe, perhaps, in the way it absorbs bumps and road deflections--than the European models we get over here, most of them Teutonic. Could it be that Sable is a truly genuine interpretation of a distinctly North American automotive idiom? "
The link to the full review is
http://www.thecarconnection.com/index.asp?article=5627&n=157,- 180&sid=180
At $25,865 - $2000 to $3000 cash back makes this car an unbeatable value. ¿Are station wagons more expensive that sedans in the Taurus/Sable line?
Also, go to the beginning of this forum and it seemed like it was all "my car is junk". Now, there are lot of "I just got a Taurus and it's great." Good news for a change.
Whether a used car has wood trim is about the most minor issue you should concern yourself with when buying a used car, however. You should be much more concerned with the mileage, condition and service history.
History:
I bought the 2000 Taurus GL wagon Last January at 67K miles from a small dealer. It looked and worked well without any detectable problems. I even sent it to another large Ford dealer to check that it did not have any mechanic problem before I finally bought it. The mileage is high because it was leased by a company for some business purpose. I paid $7, 700 and I thought I had a good deal.
It worked all right till a day last May when it just passed 70k miles. The transmission occurred a sudden death in front of a traffic light. I went back to the Ford dealer who did the mechanic inspection before I bought the car, and they said that the transmission and other “internal” damages are not detectable by the inspection. They also said that the previous owner (the company guys) might have driven the car too hard, which causes the premature failure of the transmission. Finally, towed to AMMCO and the overhaul cost $2000, because it is actually cheaper than the Ford dealer. So overall, it was not a good deal any more.
It worked all right again till now. It is reasonably powerful and comfortable, but I really concern about the internal quality (Especially transmission) of Ford cars and I am afraid that it will go serious wrong some day again, suddenly.
I wish my bad luck had gone.
I've got plenty of time to wait, as I plan on keeping my 2000 Taurus for seven more years or so, so may see a couple of generation of Ford product in that amount of time
Almost all cars are becoming taller lately, to gain passenger and trunk space without adding length.
Looks like Ford's strategy is to come out with two sedans, one slightly smaller dimensionally than Taurus being the Futura, and one maybe a little larger, the 500. I think they should keep the Taurus name, however for one of these new models.
During 1986 redesign they took direction that no one else were going and lost big time.
Now they are moving in the same direction again. Similar to VW. Indeed in Europe many are simply copying VW, even interior and even gauge cluster. Ford does the same thing. In press release they note that interior has Audi like quality. It tells something. And BTW J May was working for VW before (e.g. New Beetle and Passat is his design).
Taurus will remain unchanged and be sold to fleets and may be other price concious customers. But basically it seems that nameplate is going to be phased out. Anyway name doesn't start with "F" so I don't see a place for Taurus name in Ford line-up. Sable also doesn't start from "M".
If you are careful, however, you can pull it off. VW Jettas and Passats are quite tall without being ungainly. Taurus when redone in '00 got a taller roof without looking slab sided. The sculptured doors that carried over may be the key to keeping it from looking slab sided. Focus isn't bad either for being tall. I have trouble liking the rear end treatment of the hatchback versions of Focus. The tailight treatment is just a little too funky for my taste.
