Visitor Agreement.
It takes about 20 minutes each side to follow the instructions and the lenses are looking like brand new. I couldn't believe how well this worked. The lenses are like brand new and clear as new glass! No hard work required just persistent gentle rubbing as in the instructions. The capper is that it seals the finished product with a hardener which should make a repeat in 10 years unnecessary. This is a rare product which does what it says for $20. I wanted to pass this on simply because it is so good and inexpensive.
The plastic clips can be lifted from the fuel hose with the tip of the screw driver (think of lifting a staple from wood with a screwdriver). Gentle pressure and they come off in one piece (the filter comes with a pair as well if you break them). Then pry the end of the hose off the fuel cannister with the flat blade of the screwdriver. They came off easily even after 140K miles. The cannister is secured with a radiator hose clamp. Unscrew it, jiggle the cannister out of the protective metal shield (there to prevent road debris from rusting the cannister) and reverse these steps to connect the new cannister.
Once done turn the key from off to on (but not start) 5-10 times. You will hear the fuel pump come on strongly at first and then more quietly. Turn the key to start and off you go. It didn't even have to crank more than usual.
The drainage from the pump side of the cannister was foul looking: black-brown but liquid, no sludge or large particulate pieces. I haven't cut the cannister open yet to see the inside situation.
Further reading of how often to change the fuel filter has convinced me that they don't need to be changed very often. New Toyotas, I read, say it never needs to be changed. I have read other stories about fuel filters not being changed for 250K. The symptom of a clogged filter would be hesitation and reduced acceleration and reduced top speed (none of which I noted at 140K miles). One poster made a good point,however. He opined that the fuel pump has to work harder to push the fuel through a partially spent filter and that would shorten the life of the pump. Certainly the back pressure on the pump for a given flow would be higher. Since replacing the fuel pump requires dropping the gas tank it is expensive.
In any case I think everyone can be confident that changing the filter every 40-50K is more than sufficient.
Again kudos to the design engineers. Many cars require a special tool to disconnect the hoses from the cannister. Also every thing is right there in front of you and easily accessible.
Takes about 45 minutes the first time. I will never change it again but if I had to I could do it in 20 minutes now that I know the routine.
It will start, but the engine vibrates and sputters like misfire. Engine light is one. Hit on the gas and the engine is not running faster or responding. The car would not go either. There is also dark smoke coming out of the tail pipe.
This car has a history of hard cold start. I had to try 2-4 times to start the engine in the morning. Meanwhile, I had to hit on the gas pedal hard while cranking the engine. I have got 9 codes:
1. P0190: Fuel Rail Pressure Sensor Circuit Malfunction, or Fuel Rail Pressure Sensor "A" Circuit
2. P0191: Fuel Rail Pressure Circuit Range/Performance, or Fuel Rail Pressure Sensor "A" Circuit Range/Performance
3. P2196: O2 Sensor Signal Biased/Stuck Rich Bank 1 Sensor 1
4. P2198: O2 Sensor Signal Biased/Stuck Rich Bank 2 Sensor 1
5. P0190(pd): Fuel Rail Pressure Sensor Circuit Malfunction
6. P0191(pd): Fuel Rail Pressure Circuit Range/Performance
7. P0300(pd): Random/Multiple Cylinder Misfire Detected
8. P2196(pd): Undefined code
9. P2198(pd): Undefined code
Any idea what could cause the problem? How to find out which part to replace? Thanks a lot
Let's hope someone can pick it up from there. It is possible to measure the fuel rail pressure. There is a valve just like the ones on a bicycle tire which is very visible about the middle of the engine compartment on the top. It allows measurement of the fuel rail pressure but I am not sure what type of pressure reader it requires (could you use the one you measure tire pressures with?). Another idea is to crank it with the fuel line to the fuel rail disconnected and see if gas squirts out at a good rate. Point it away from the engine compartment with an extension hose if you need to. Be sure the engine is completely cold and nothing is sparking or that may turn out to be a very bad idea.
I hope someone who knows something chimes in and educates us both.
I removed the Idle Air Valve and flushed with electric motor cleaner. Starts are ok now.
The valve had minor exhaust residue and the cleaner flushed out the area not visible.
Some earlier Sable models had a similar problem.
