The passenger airbag went off beacuse the seat belt wasn't buckled.
All the say about the bags is that they were re-designed in response to new Federal regulations governing airbag deployment at low speeds.
The original legislation was written to protect an unbelted 5'8" 175 lb man in a frontal collision. The current legislation is for a belted man. 2 stage bags were mandated.
As far as the bumper test is concerned, Volvo also has to meet the European NCAP regs which state that the front ends of cars must be soft in order to offer some protection to pedestrians if they are struck by the car. The 5 mph test isn't about safety, its about saving the ins co's $$.
As for the rest, I have probably seen alot more wrecked Volvo's than you have and I'm quite aware of their construction. Your statement about the door possibly been blown inwards is silly. The door is held in 4 places on a side impact, 2 WELDED, not bolted on hinges. Plus a robust door lock and a flap of reinforced steel that protrudes up from the floor to catch the bottom of the door under the latch.
Volvo has stated numerous times to us, and to others that their airbags are secondary protection and only deploy when absolutely necessary, especially the side bags.
I never said you don't know Volvo's system. I said you can't state Volvo uses higher thresholds unless you know OTHER car's systems. As for the door caving in comment, since I have seen the door caved in on some cars with almost no damage to the floor, I don't think its silly and I was using the example to counter your ridiculous assumption that an airbag will only go off if the frame is damaged. As you originally stated, "frame damage is the SOLE decider on a Volvo", but I proved to you its a matter of deceleration based on readings from an accelerometer. If the force is enough to shove the door inward toward the occupant and risk injury but there is little to no frame damage, then the side bag should inflate.
The new airbag designs are all about preventing injuries period. Notice if you will how some newer car's side airbags also inflate in the offset impact. They are designed to do so to keep the dummies head away from the door panel and other potential hard points that can cause head injuries. Granted, the S70 in question was designed before these new ideas came around.
After reading the guy's comments again, my thought is the side airbag didn't go off in this case because the car was hit in the front fender area. Had he hit square on the driver's door at the same speed, the airbag should and probably would have inflated.
If you can't politely agree to disagree, then please don't post to each other anymore.
Pat, I agree, this forum should not be turned into a Jerry Springer show, but once in a while we all need a good laugh.
Let's just get back to the S70 - minus the fisticuffs. Okay?
I hate more then anything for the unknowing to be given false, misleading, or vague info. I got a little carried away (I was mostly being heavily sarcastic because I thought it was funny he didn't see the details right in front of him) because I knew I was right about the S80 info and even after seeing my links, the guy still said I was wrong. Anywho, I'm glad some people saw humor in the bantoring. I mean this forum is to be taken lightly, not personally.
Right now the light is going out after each restart but coming back after 5 or ten minutes.
Performance was great before and still after the ETS started on the 5 year mark a few days ago.
Car is out of warranty and don't have a grand for a new ETM Electronic Throttle Module right now.
I need to buy some time. Can anyone who has been down this road tell me how much time they had before they absolutley had to bring it to the dealer? I hear there is no warning to the ETM fully malfunctioning.
I love this car but the myriad of problems is putting a bad taste !!!
Thx
rd
99' C70 HTP M 43k Miles
I just did a search for ETS on this board and found no other solid information on it.
99's and newer have no distributor cap and rotor just a computer box called to TCM Throttle Control Module. I think what has been happening to the ABS Tracs module is now happening to the TCM module. Little cracks and the such in the circuit board as the box is connected directly to the manifold. Think how hot that thing must get.
The constant tempereature fluctuation must be tremendous. From winter cold to 0 or colder to hundreds of degrees day in and day out.
I can and would expect to pay a decent amount of money to replace these parts but $900 - $1,100 is a bit outrageous.
rd
sorry to hear about it.
all i can say is i'm glad that's one less thing i have to deal with on mine.
Now, the question is, where did you buy it from that they don't know? Was this not a Volvo dealer that you purchased it from? If the dealer you got it from did not get it right from the factory, then, unfortunately, I believe that is a problem because then the title did change hands before you bought it.
They should easily be able to see if you are the original owner or not.
And what happened when you originally bought it? Did you buy a new car or a used car?
The S70 had already ceased production
jocelyn bought a used car.
Heck, I know someone who bought a "new" 1999 Chevy pickup when the 2001s came out.
But it is starting to sound like, in this case, it was used.
-edit - oh, you beat me to the punch with that last one.
But, again, even if it was part of the dealer's fleet, its not usually titled as such and the warranty in-service date does not start until the titled owner buys it. That's how I've always seen it done, anyway.
But I'm also thinking she didn't buy it from the original dealer since, according to her, "they don't know if it was a dealer car or what but the warranty started in Sep of 99." So it sounds like this was bought at auction and sold as a used car.
everything imaginable beginning with additives to clean throttle
and injectors. I have a friend that works for Mighty Auto Parts
that instructed me a few years ago on how important it is to be sure
and tighten the gas cap at least three clicks or it would cause a
malfunction light to come on. The S70 cap has always been very easy
to turn with very little resistance when new and finally just sounded
very smooth and silent. I purchased a new one from Volvo($32). I
compared them and it is apparent of a change in design. The man at
the parts counter said he had it in stock and said, 'does that tell
you something'. Bottom line- fixed- not a single incident of the
light coming on for the last three months. It was coming on three or
four times per trip of 50 miles. Hope this helps.
I noticed rear door panel leather "bubbling" The car is not covered by warranty anymore, does anyone know how much it costs to fix this or can I fix it myself?
Also, have the beige interior with beige leather steering wheel. I noticed that the color is coming off the leather, does anyone else have this issue, and if so, what can I do about it?
I also have several worn spots on my steering wheel. The only solution I know of is a complete replacement and, given the presence of an airbag, its something I wouldn't even touch myself and haven't bothered to price out because I know it will be expensive.
I did happen to notice, however, when someone posted some interior picks of their V70R (not the new R, but the older one that isn't really all that fast), that it had door panels that were different. On this car, there was stitching running across the panels right at the top and bottom of the indent. I would think this would hold up much better and those owners probably aren't experiencing this problem. I'm not sure if i can find that photo again (i believe it was on swedespeed). I would, however, love to know if those panels would work in our cars.
Volvo does have a replacement kit available which is much cheaper than ordering all new door panels.
As for the V70R, 2000 edition its panels will fit any 98-00 S70 or V70, assuming the color matches.
The difference was the R panels were leather, the standard panels are vinyl.
Thanks for the info on the R. Hmmmm... real leather. I wonder if I could track a set down. Maybe start calling the junkyards.
So am I remembering correctly, though, is there lines of stitching on those R panels as well? Basically running right through the areas that typically let loose on our S70s?
The back side of those panels is smooth in order to allow the glue to bond.
Was wondering if this is something I can take care of, i.e pull out the radio and fiddle with the wires? Does ayone else have electrical issues, can I take care of this myself or should I take it to the dealers? I know the radio has an alarm code and I don't want to disable it because I lost the code. Maybe the lights will just come back on, I know volvo has electrical quirks?
yeah, well, if I was Volvo corporate and I had the choice of just replacing the stereo or paying a dealer $95 a hour to change out lightbulbs, I'd opt for the replacement, too.
ok, ok, i know corporate probably doesn't pay the dealer $95 an hour, but its still all about the numbers when it comes to warranty. Its also the reason why they will, many times, send out a replacement engine rather than authorize the dealer to rebuild the original.
The real reason is that no one at the dealer has the foggiest idea how to work on the stereo unit.
My S70 also has the clicking problem while the wheel is turned sharply to the left. What have ya'll found is the cause/solution to this problem? Is it something which can be done cheaply (i.e. lubrication)? Is it a problem which needs immediate attention?
I would appreciate any help on these matters.
http://www.volvospeed.com/steerstops.htm
Chris
I WILL SAY, HOWEVER, AT FULL LOCK TO EITHER SIDE, THERE'S STILL A TINY BIT OF "RUB" FELT, BUT NOWHERE NEAR WHAT IT USED TO BE...
OF COURSE, WITH THE STOCK TIRES, THE DEALER SAID ALL THE PREVIOUS "RUB" WAS NORMAL...BUT IT'S SO DIFFERENT RIGHT NOW!
SIDE NOTE: SWITCHED OUT FROM THE STOCK MICHELINS TO FALKEN ZIEX ZE-512, IN THE 205/50R16 (CONSUMER REPORTS RATED #1 OVERALL) AND THEY SEEM TO BE DOING PRETTY WELL...WERE ABLE TO GET THEM AT $78/EACH
"Real-World Trade-In Values"
he can help you pin down a fair price.
At first look, not knowing the year, just knowing its an S70 with 55K miles makes me think that is too much money. Is the certification from Volvo still only to 74K miles? But, again, Terry is the expert to ask.
