Visitor Agreement.
Dealer would have to program. S70 remotes aren't that much. Your better off getting a new one than getting one off ebay and finding out its defective, or broken or can't be reprogrammed.
Paint jobs cost as much as you want them to. A really good one can set you back $2-4,000.
Second, I was locking the door and my girl on the inside of the car opened the door as the lock was locking. Then, even with the door unlocked her FR door wouldn't open. I had to open it from the inside. Then I hit the key lock a few times and now it opens, but it doesn't lock. I lock could be up or down and the door will not lock.Any ideas... any trouble shooting thing I can do. Or did she inadvertently break the lock. Dear, this is agrevating. And I would like to know if any one has dealt with this and how much it costs... again. Thank you guys so much you have been a big help in the past
for the plastic, are you talking about the shield under the motor? that's all i can think of on mine that you may be referring to. It runs from just behind the front lip to just behind the oil pan. The whole thing is held up by four 10-mm bolts. If this is the one you are referring to (or, it really doesn't matter what it is for my suggestion), why not just get a nut and bolt with washers and secure it to whatever is left to grab on to? I mean, if you just ripped part of the plastic, there is probably enough left that a big washer couldn't cure, right? Either that or I am totally failing to understand what piece you are referring to.
I'm sure you could find some way to secure it. it is just plastic, after all. I can't imagine what a dealership would charge for it, but I can't imagine it would be worth it. Just a guess.
and you'd think i'd come up with that since anytime something breaks on mine, I use that oppurtunity to upgrade aftermarket.
1. Does anyone have a suggestion of how to tell which it is, strut vs. mount?
2. If I replace the strut should I also replace the mount?
3. If I replace one strut, should I replace both the left and right?
Any other advise is welcomed. Thanks.
The symptoms are:
1.When braking really quick the AC cooling decreases, one can smell the evaporation moisture, until it is not blowing cool..
2. When traveling at a consitant rate without any sudden decrease in RPMs the AC blow cold and doesn't loose the cool air.
3. When sitting still for a while, such as at a signal light, the AC is blowing cold when accelerating the AC then decreases the cool blowing air to an outside temp air.
4. I have found that if I keep the RPMs at 1000 or above while stopping and/or sitting still, then the AC will blow cool even when duplicating the above conditions.
It seems that as long as there is a load of 1000 RPM+, the conditions that cause it to stop blowing cool doesn't affect the AC.
Has anyone else experienced this issue or can deduce what might be a possible cause. I would like to get as much info as possible before taking it in for repair..
Thanks in advance
Can you change from regular oil to synthetic oil with no adverse effect to engine?
How to fix heated seats? Well.... what's wrong with them? Are they uncomfortable? Too hot? Wrong color? They have a cut or split in them? Are they not working when you flip the switch? Is the light on the switch coming on? I could go on and on. Need a bit more info to try to help.
Hope this helps
So, yes, you have to allow the turbo to cool a bit before shutting engine off. However, this does not necessarily mean you have to sit still with the engine idling. Its only really necessary if you, for instance, come off the highway and park within a minute. If you are driving slowly and at low RPMs on sidestreets for several minutes before arriving at your destination, this will suffice, especially with the GLT since this does not run at the boost that the T5 does. Basically, just don't drive hard and shut down the engine right away. If you do drive hard and come to a stop, let the car idle for about 45 secs or so before turning off.
It is a byproduct of turbo design and physics.
That being said, an S70 turbo doesn't need to be idled unless you have just completed some high speed long distance use. Then it is a good idea.
Simple commuting doesn't require idling.
First is my headlight warning light is on. All lights seem to be working however the light stays on. I have played with the trunk light switch and the light does go off however after a few bumps it comes back on. Any suggestions?
Next is my ETS light and the studdering. It's only happended once and I went to mid grade gas and hopefully it will not happen again. Any one seen this?
Lastly the ride seems bumpy compared to my old nissan pathfinder...and the whole car creaks when I get out of it? On speed bumps the car is painful. Should it be this way?
Thanks and hopefully this forum still has readers.
So you are referring to the lightbulb warning light, right? (since it tells you when any of the exterior lights are out, it wouldn't be just for headlights) ... I'm asking because I'm not familiar with 2000 and it might be different than my '98 (which just has the one warning light for all exterior lights). Anyway... I'm not sure why your trunk light should affect this at all. Are you sure one of the taillights isn't going on and off intermittently? I have this problem quite often and a tap on the trunk lid will make the light come back on and, therefore, turn off the dash warning light.
As far as the ride goes ... well... have you test driven any other S70s? How does it compare to those? It really shouldn't need it yet, but maybe new shocks and struts are in order. Who knows? Maybe someone REALLY heavy drove it all the time on very rough roads and wore it out prematurely.
The ETS light or the electronic throttle system light went on again today and this time with the check engine light...the car is only a month old! I'm raising heck with carmax and thank gosh I have a bumper to bumper for 100k miles. When the ets light goes on the car studders and if you read the manual it says to turn off the ignition and if the light still comes on driving performance will be affected. You're telling me...
The bumpy ride is more than the other S70s I drove. Maybe the previous owners were heavy...and maybe never got out of the house thus the 32k miles on a 2000.
Anyway, I will see where this goes...
Yes, I'm having this problem. It has been to the shop and they can't seem to locate
a specific problem. The guess has been fuse relays and computer.
Has a change in gas grade made any difference in the performance or studdering?
Thanks for your time and consideration.
Can't go wrong w/ Michelins but they are pricey.
Continentals are ok.
Falkens and Kumho's are probably the least expensive.
If you already have Dunlpos and aren't getting 4 new tires then stick w/ the Dunlops.
agree with volvomax. if only replacing 2, its a good idea to match the 2 you are keeping.
If you decide to replace 4, I found the Continental ContiExtremes to be a great tire for a great price.
Seems I mispoke. Price on the site says $130.
here is the gentleman who fixed mine:
http://home.earthlink.net/~vicrocha/
You may be interested in joining some of the discussions on our Maintenance & Repair board - your expertise would be most welcome there.
Welcome to our Forums - have fun!
Also i have found a lot of wind noise from passenger side window -- appears to bow -- ever heard of this?
qbrozen, "Volvo S70" #654, 7 Feb 2005 10:50 am
I'm not understanding your second problem. It bows? When closed? In an S70? If its moving at all while driving and while the window is closed, then it sounds like the window seal is missing or rotted in some way. You should get no movement at all when closed all the way.
However, the dash has become lose and makes noise on anything but the smooth asphalt (from a slight rattle to and annoying squeak). The lose dash is something I noticed a few months after I bought the car (though it was only minor at the time), but in the past year it has progressively gotten worse to the point where it is at now.
I found one poster that sounds like they might have had a similar problem ( #634 ). So I'm wondering if the only way to fix this problem is like the dealer told the other poster, "that the whole dash has to be replaced"? Any input is appreciated. Thank you.
I hope this is the right place to get some answers, because I've asked around at a couple of Volvo dealers and no one has given me a decent answer.
The clips are part of the dash itself.
I certainly wouldn't attempt it myself.
Thanks for your help. I enjoy coming to this discussion.
In unrelated news, I've got the dreaded ABS/TRACS OFF lights...but only intermittently. I may be placing a call to Victor soon...
LOL. Well, it was only a matter of time. I'm surprised it lasted this long.
by the way, mine has been working FLAWLESSLY since he fixed mine last year. (oopss... better find some wood to knock on)
Hah. I've got a GLT.
Thanks for the heads-up. I looked at Victor's website and it does look a good deal more involved than I thought. 'Tis ok, though: I like a challenge.
EDIT: oh, volvospeed has a pic of the hydraulic tensioner here and on page 3 of these instructions:
http://www.volvospeed.com/Repair/timingbelt2.php
