Visitor Agreement.
If it was just a used car with no warranty, I do believe that would be an entirely different situation as far as lemon law is concerned.
So is synthetic oil if the car has run on mineral oil for the first 75k.
As far as those brakes, how much are we talking about? I've spent less than $350 for cross-drilled brembo rotors and pads at all 4 corners. That was at 60k miles and I'm now at 112K and everything still looks really good.
It's good to havet my car back after 6 weeks - problem and all. I'm not ready tol give up on her... question is where to go from here...
Thx for your input
Thx for response and good luck as well.
1.800.986.9678
U.S. Department of Transportation
National Highway Traffic Safety Administration
Office of Defects Investigation
Room 5326-B
400 7th Street S.W.
Washington, DC
20590
I hear you on this- my previous Volvo was a 1984 240 DL. It's a tank- never a problem and is still in use by my family today. You can bet I won't be saying the same thing about my 99 S70 in 20 years!!
bought about 8 weeks ago
Occasionally stalls, and I'm aware of the whole ETM fiasco.
The ETM on this car was replaced last June, with the redesigned one, but there is still something funky going on.
This car idles fine in Park or Neutral, but as soon as the transmission is engaged, even with brake pedal on, it idles rough. And then at certain RPMs or throttle positions, it seems to run even rougher.
It stalls fairly frequently, and I am trying to isolate all sorts of relevant data about the different input parameters that might help someone diagnose.
When it goes into 'stall mode', the RPMs drop fairly abruptly. If I catch it, I can kind of 'rev' through it, and about half the time it does not completely stall.
Two observations that might help:
- I swear it seems connected to times when the car is either on a grade or if the car has just gone over a little rise or dip in the road. Not a severe bump, but one of those soft up-and-down floater type of bump. Certainly not every time I go over one of these, but almost every time it has stalled while driving, i seem to recall one of these types of mild bumps.
- The only time that it would not restart within a few seconds, I noticed that the instrument cluster was flashing IN UNISON with my emergency flashers, but only with the headlights in the middle position. I know that is weird, but it is true as I am sitting here. I have never been able to recreate that occurrence, but I've never been in permanent non-starting mode other than that one time.
I may have a combination of issues here, but I'd really appreciate anyone's insight.
THROTTLE BODY HAS BEEN REPLACED, DOUBT IT IS THAT.
WHY THE ROUGH RUNNING ONLY WHEN TRANSMISSION ENGAGED?
WHY WOULD SLIGHT CHANGES IN GRADE CAUSE RPM DROP OR STALLING?
I have had the same issues with my C70 and my dealer says they will NOT pay for it. Could you tell me the name and location of your dealer and any other information you would like to provide.
I will be filing a complaint
Marie Murray
I just happen to Google the problem and here I am learning a lot. I am supposed to pick it up in two days. What should I make the dealer do?
Thanks in advance. This is clearly a critical known problem which he said he would fix but if disconnecting the battery will reset it for a while (as I read in a prior posting) how can I be sure that whatever needs to be done gets done (i.e. ABS replacement module?)?
Did both the CEL and ABS light come on at the same time? What about the TRACS light? Are you sure it was the check engine light and not the TRACS light?
IF both ABS and TRACS, then, yes, a new ABS module is in order. Thisis an expensive fix. There is a cheap fix, which you can find by reading this board, but I certainly wouldn't want to buy a car that already had the problem. I would ask the dealer what they did to fix it and see if they say they replaced the module. If they didn't, then the problem will definitely come back.
As far as the CEL, that could be any number of things. They can find out what by pulling the code.
By the way, this guy will do the same rebuild for less money. Countless volvo owners have paid Victor to rebuild their units with great success (myself included).
qbrozen, "Volvo S70" #764, 20 Jun 2005 8:35 am
In your comments, there is a reference to a redesigned ETM that was installed in your vehicle. Could you identify what the redesigned unit might be? When the ETM was changed in my S70, the dealer never mentioned anything about a redesigned module and I was under the impression that it was replaced with one identical to the failed unit, except new.
I went with the Contis at that time, and never found fault with them. They were great in all aspects. I would have replaced them with the same, but at the time I was ordering, they were unavailable at the shop I wanted to buy new wheels from. Hence I wound up with Yokohamas.
New little thing started happening with my 99 S70 and I thought I'd ask the gurus before being completely stunned at the dealership as to what the problem may be. While at the ATM, I had my window down and noticed the car clicking. It sped up as I accelerated and then stopped clicking completely. I've only heard it twice, and it was in the same day. I have searched the threads but haven't found where this has been mentioned. Any ideas? Am I going to pay an arm and a leg to have the dealership replace whatever's going wrong? Car has 102,000 miles on it and is going in for an oil change Friday. It's not been 7500 miles since the last oil change but it's been a little over six months. Thanks for any help!
This has only happened once, but I worry because sometimes when I turn, the car makes a weird noise. It happens when I am going slow, like in a parking lot. It sounds like something that rubs, but it rubs by - not constant. I can feel it in the steering wheel. Closest sounding to geese maybe. This has happened maybe three times with the noise, but all in the past month. Just kinda makes me worry about the safety aspect with winter here! :confuse:
Any comments?
here ya go:
http://www.volvospeed.com/steerstops.php
The ABS light is an unknown at this point. If it stays away, great, then it may have been an anamolous reading. If it continues to pop up once in a while, then you most likely need to have the module rebuilt (search this topic for where you can get this done cheap). Question is, does your car have TRACS? If not, that would explain why just the one light came on. In cars with TRACS, both the ABS and TRACS light will come on when this common malfunction occurs.
Anyway, if the lights come on and stay on, then you have a problem. I fixed mine fairly quickly after the problem began because it scared the heck out of me to be driving a vehicle where the ABS might give out all of a sudden (imagine that happening DURING a panic stop!).
