Visitor Agreement.
I would like to take some things off of one and add them on the other.
1 - Is it possible to take the 10 CD changer with the control built into the center console out and install in the other?
2 - Also, neither drivers power seat controls work. Does anyone know the best way to get these working?
3 - How do I take the wood grain off of the instrument panel and put it on the other car?
4 - Finally, when I turn I get a pulling of the tires like the power steering has a catch in it. It does it whichever way I turn and although it does not cause me to lose control it is a gentle jerking feeling.
Thanks for any help
Thank You,
Q45rida
I think you have to send to clean you "air flow" meter that's what my garage "friend" told me he did
Great cars
Thank you in advance for your help.
Thanks in Advance
:shades:
I just found a 1997 Q45t, very impressive car. It has 130Kmi on it. It's offered for $6500 but needs some minor body work (trunk and left side have been keyed), and brakes and tires. Other than that, the car is in perfect condition. I was planning on buying the car in the next couple days. Does it seem like a good deal? Anything in particular I should look for before buying the car?
I really appreciate everyone's help...
Thank you,
Jamal
You may also want to post in this discussion: Got a Quick, Technical Question?
DB
please help me decided, I was looking at the M35. but they told me they sell them with MRSP. Thanks in advance.
I just had service done to my 93 Q45. The mechanic replaced the coil boots and air flow meter. the car runs 90% better now the transmission is not shifting. It will go into reverse, neutral and drive, but when I down shift nothing!. the car was shifting before I took him the car. Is there something that he left unplugged? I don't want to get ripped off when I take him back the car. Can anybody help me??
ALL THE FUSES ARE GOOD I TOOK IT TO THE SHOP THEY HAD IT FOR 1 1/2 DAYS BUT DID NOT FIND ANYTHING THEY TOLD ME TO TAKE TO THE DEALER BUT IM AM AFRAID THERE TOO EXPENSIVE PLEAS HELP HELP HELP
THANK YOU
You might want to also post that in our Electrical Problems discussion - someone there may have a thought for you.
But please unlock your caps key - it looks like you are yelling at us
Buzzby. :confuse:
While we're at it, my digital climate control display works but displays at will. I even replaced it with another one and still does the same...common problem? HELP anyone? THANKS!
Thanks for your time though!
http://autos.msn.com/research/vip/Spec_Glance.aspx?year=1999&make=Infiniti&model=Q45&trimi- - d=-1&src=VIP&tab=2&sub=0
hope this helps!
Today I will be picking up a 97 Q45T. Can someon tell me what kind fuel economy can I expect on this car, city and fwy? In addition, I know this car requires premium gasoline, does it matter if I switch it to regular unleaded? This car will replaced my 95 civic beater/commuter. A little bit more in fuel but in return is a more comfortable/safety vehicle. Thanks for all your help.
007
How much does it cost to replace the coil boots?
007
Jim
My car will not go when you step on the gas. I have to floor the gas pedal to get it to go sometimes and it revs out to approx. 4000 rpm's. It doesn't do this all the time. I'll be driving home and at a stop sign and it won't go. Well, it goes but not very fast. People behind me get all mad. Other times it flies! My idle seems to be a little low all the time and my air isn't that great when sitting at a stop light. I have to put the car in neutral and rev the engine up to 1000 rpm's to get the air working good. I do have a slight hole in the muffler too but I don't think that that would be the cause. I've put new spark plugs in it, new oil filter and a new air filter. Anyone have any idea what could be wrong with my car?
007
I live in New England, and I really need some advice on what to do. I currently have 16" wheels, and 60R16 tires. Any recommendations on what I can do to ensure that this car actually gets me through the snow this winter? I've been looking at Blizzac snow tires, but frankly the problem was so great last winter I'm not sure that's going to help me enough.
Advice anyone? Re: wheel size? Tire size? Make of tire?
Thanks in advance for help.
How can i tell if i have a leak in my air bags or if the compression/pump has gone bad? Could it be wiring also?
The warning lights say there's a transmission problem and then the speedometer won't move and low speed steering is difficult.
I was advised to check the connection for the power steering assist module behind the dash for corrosion. It would seem to me if the unit works when you smack the dash and it will continue to work most of that trip, it can't be dead if it comes to life...
So how do I remove the dash, locate the connection and try to clean up any possible corriosion. Won't it be a major expense if a dealer does it?
The only positive outcome of a dead speedometer is the odometer doesn't advance..I have probably 130 K miles on it, but it shows 110 K....
Help me save a major expense on this great car.
