Visitor Agreement.
refused to replace in pairs, so a few months later, I returned with similar complaints about the LF strut and they replaced it. For the past
3 months now, the right rear is making noise and when it hits a bump, especially on a curve, it loses a grip on the road.
Dealer head mechanic had two opportunities to diagnose this, didn't hear it the first time, refused to replace.
Finally admitted hearing it the second time, but brought in a regional advisor who claimed not to hear it, so they
dropped the matter altogether. Meanwhile the problem is getting worse. Anyone had this problem? The mechanic also mentioned that there is an unfixable noise in this model year and in 99's from the right front, but this is clearly right
rear origin in my opinion. Anyone got any ideas?
Mine is one of the earliest productions when the car was first introduced, ordered directly from the manuafactuer.
The only three times I have to take it to the dealer besides its regular services were two trips for headlight bulb replacement (covered under warranty) and the engine fan recall.
Happy cruising, you all S80-ers!
I am ordering a anchor hook through my dealer and is wondering which position to install it? The center headrest cannot be removed to accommodate the car seat, so I am thinking maybe one of the window rear seats.
Please do let me know if you had worked with car seats on S80 before. Thanks!
New problem-buzzing coming from engine area under acceleration.
--Spolla
Talk to Herb Wiley or Pete.
Bill
So, does anyone know any specifics on this?
I disagree. Every engine is designed to work under optimun conditions. It can compensate for less than optimum conditions, but that would result in compromises. Not only compromise in performance, but probably compromise in reliability and longevity. I have a T6. I do not believe that running this engine with a retarded ignition timing over the long haul when it was specifically designed to work at a specific ignition timing with 92 octane will not do it damage.
Volvo turbo engines for North America are not "required" in any way to use an octane higher than 87. I should think your owner's manual can be the last word on that. If you own a turbo, or normally aspirated for that matter, and consistently run it with 87 octane and don't experience knock, ping or starting problems there is no definitive reason to spend more money on a higher octane unless you feel it might provide better performance. An octane number indicates the fuel's resistance to premature detonation. A higher value, a higher resistance. In a cylinder the fuel and air are injected as the piston moves down. Then as the piston returns to the top of the chamber the valves close and the fuel/air is compressed. When the piston reaches the top a spark is generated and the mixture violently ignites and forces the piston down, creating power. If the engine is a high compression engine and is run on low octane fuel the fuel ignites due to the high compression and heat before the piston gets to the top and the plug fires, that is knocking, pinging, and that sort of stuff. Volvos turbo engines are not high compression. The non-turbos are a higher compression but are engineered, by way of knock sensors, to be perfectly fine when used with 87 octane. Testing has shown that a car recommended to use 87 that is run on 92 will have barely any HP or driveability change for the better and can actually decrease in performance. Whereas an engine "required" by the owner's manual to use 92 will decrease in performance, albeit a small amount, when run on 87.
Spend your money on other things.
The Volvo S80 T6 REQUIRES an octane rating 0f 91 RON. To anybody who says otherwise, my advice, RTFM!! And as far as I know, in the US or anywhere else in the world, 91 octane is NOT regular fuel. Go ahead. Use regular octane despite what is recommended. I for one would like to know the litany of problems you can develop. At least, it will happen to you, not me.
At the very best, you'll get reduced performance. At the worst, serious engine damage.
And, if they can prove that it was caused by using improper fuel, damage that the warranty might not cover. You got some dangerous advice I am afraid.
But then, it isnt MY car. My T6 gets premium.
In some countries (Generally in Europe) octane ratings are far higher. But, heck, look what they pay for fuel! (over $1.00 a LITRE!)
Bill
1 week later at my garage at work , it would not shift out of the forward gears or reverse. Volvo service acame and we managed to push it so we could drive it out of the garage. Then after a 20 minute cruise home (forward was no problem) , it shifted to P easily.
I think I hate this car.
This problem was mentioned in some previous posts -- go to Posts #954 & #956. I think these may help you possibly shed some light on your frustrating experience. I think once you understand the workings of the Volvo, you will not hate the car, but come to really appreciate the beauty of it. Don't give up. The people on this board are very knowledgeable about this vehicle and can assist you greatly with questions and problems that might come up.
Hang in there!
Better to be safe than sorry.
Bill
Been months since I've been here. I see octane discussions, I use the highest I can get. I change the old every 5K miles, and use Mobile 1, synthetic. My car is turning 45K miles now, and no real issues. 2 recalls, done under warranty. I've had to pull the radio out twice for a stuck CD, and other than this, it's running very well. I have replaced the plugs at 30K miles, used Autolite.. no issues. Had the transmission fluid changed at the factory, and replaced the front break pads at about 30K miles (but dealer said I did not have to do once they looked at - but it was there, up on the rack, so why not). I have no real complaints, but I'm not sure I'd buy another one - just personal opinion, no hard reason. I really like the handling of our BMW 535, and it's got 125K on it, and running great. I do like the S80 on long trips.. it's really great, but corning leaves a bit to be desired for me.
I won't sell the car, as it seems to be a good one, but may - at some point - give to my wife, and I'll get something else.
Good luck to all.
Scott
pop off the fuse cover on the driver side of
the dash. Pull fuse #21, replace fuse 21,
start car, and drive away.
The adaptive mechanism is slow to respond. It does take several shifts and several stop and go before it adapts to aggressive driving. Funny, it seems to adapt quicker to mellow driving. I have found that for the occasional sprints of hard driving that I subject the car to when I drive it, it is simpler to use the manual shifting capabilities of the auto trans. Shifts are quick and solid near the red line. The Volvo is a wolf in sheeps clothing. Despite front wheel drive and auto, the acceleration is awesome. My T6 has beaten a BMW 530i in a straight drag race!!!
Anyway, back to the topic. I have found that after several runs up and down aggressively in manual mode, the car is now adapted to aggressive when I resume full auto. I believe the T6 and 2.9 share the same auto tranny, so they should behave simillarly. So, next time that Civic EX comes up, go manual and leave him staring at your VOLVO logo, heh-heh-heh.
By the way, does anyone else have problems with their car surging at idle?
I'm looking at purchasing a 2000 Volvo S80, 2.9 (fully loaded with leather interior) that is off-lease with 85,000 miles. I know, rather high. Selling price is $17K. He came off his selling price (obviously not by much). This is a used car lot in town (good reputation) who only specializes in off-lease cars with higher mileage.
Other car I'm looking at is an Audi A6 with 53,000 for $18,500.
Any comments regarding the Volvo S80's performance as it approaches 100,000 miles would be greatly appreciated.
thanks,
Steve O.
At idle, the engine speed sometimes swings wildly -- down to 600 rpm then up to over 1000 rpm and then down again. It's very noticable to everyone in the car. I have earlier noticed some light cycling (maybe a 100 rpm move) that I think is associated with the air conditioner, but this is much more severe. Has anyone else experienced this? of course, it is intermittent, and won't perform for the dealer.
I'd appreciate any input from those who have driven their Volvo under such conditions.
I found it not quite as good in snow as other front wheel drive vehicles with narrower tires.
The S80 does have a switch, but it is a "W" switch. It is for bad road conditions such as ice, where the tranny starts in 2nd gear and modulates the power more to prevent wheel spin. As to aggressive vs Mz. Daisy mode, the tranny supposedly adapts automatically.
I hear click and clunk noise on my suspension when I go over the bump.
The probloem is that I don't hear anything after about 30 minutes of driveing or I have somebody on the passenger seat. It might be ball joint or just loosen nuts and bolts. What do you guys think? I don't want to take my car to the money hungry dealer and pay for the new ball joint but it is actually tightening the bolts and nuts...
At the first scheduled service (7500 miles), I checked all of the fluid levels, lubricated various contacting surfaces, and added distilled water to the battery. I had my dealer change the oil only, to ensure I had evdence of compliance with minimum warranty requirements. Total cost: $40.
At 15,000 miles, I also changed the pollen (cabin) filter, intake air filter, and front brake pads. Another $40 charge at the dealer.
When I reach 30,000 miles, it will be more expensive, because the brake fluid must be changed to keep the warranty in force. With my last Volvo, I paid $50 for that procedure in addition to the oil change.
I am enjoying the car immensely!
I've never seen mention of a "Service Urgent" message here before, so I thought you all might be interested. The service manager never had seen it either.
Still love the vehicle. rld.
Gerry
I decided to lease a new one instead.
Also, does anyone have a non-Volvo navigation system they use?
Thanks for the help!
