Sad to see how Acura is doing. Anyway, my favorite Legend is the first gen Coupe!
Two VERY different cars, and different driving sensations. Over the years, I've had a few normal "wear & tear" things replaced, (tranny motor mount, driver door latch, radiator reservoir, and a couple of thermostats. The car was sitting up for almost 6 months in a garage, then I realized I better drive this sucker before stuff starts going south. It has a true 99,300 miles on the odometer. The driver;s leather bolster is a bit worn, but otherwise the interior is still in excellent shape. Body is still tight, I just had a front bumper replaced, has the Alpine 6 CD changer in the trunk, Bose system all original. Only thing is the ABS unit went south a few months ago and at $1500.00 to replace it, it's not a priority (and I don't drive fast enough for the brakes to lock up). This Legend still turns heads, young guys always ask if it's for sale. I have chrome 17": Omni rims on Falken 245-45/17 times, a smoke tint, car is black, paint still looks great. The thing I must say I love is the styling-it still looks great, very timeless. I wish the gas mileage was a bit better-the Lexus has a 4.0 liter V8 and gets BETTER mileage. But it's my weekend cruiser. I have considered selling it, but I just can't yet part with this car. My step daughter rode in it a few days ago, and couldn't believe the car was a '93. The Lexus is a vault when the windows are up, the Nakamichi stereo is awesome, it is a fantastic luxo cruiser, no doubt, and a sleeper when accelerating. BUT...sorry, I love my Legend.
And it ain't going nowhere....but back in my garage!
92 Legend Coupe. 300k miles and runs like a dream. Looking to purchase a M or GS but will keep the legend as a daily driver. This has been the most trouble free car I have ever owned.
Anyway, I have 2 issues that I need to try and resolve. First is the Speedometer. The answer to this may be in the previous post, but it seems to be all over the place. Every once in a while it shows the correct speed but usually runs about 50mph above what I'm going and bounces around. Is this a "speed sensor" in the transmission? And if so what does it take to replace it?
The other problem is in the A/C fan motor. It's either on all the way or not at all. Someone mentioned to me about a resistor that controls the variable speed. Does this sound right? and, again, if so what does it take to replace it?
I'm looking forward to getting to know this car really well!
Thanks for any feed back.
Scott
If somebody could help me who has some knowledge of Acura or Honda, I’d appreciate it.
I have a 1993 4 door acura legend, it’s been a great car for me but it does have 200k miles on it. I’ve had an off and on problem over the last 9 months of overheating. 7 months ago, I replaced the thermostat, and put in new radiator. Shortly after 3 hoses had broken, over the course of about 6 weeks, 2 from the radiator. We replaced them, they were old and needed replacing. At the time we tested the engine with block test , it should turn the fluid from dark blue ultimately to yellow if there was a head gasket problem, it did change slightly to a green blue, but was not conclusive as to being a head gasket problem. And that made sense in that the car showed no symptoms of a head gasket problem, there was no water in the oil, there was no smoke in the exhaust upon starting up in the morning and the compression was fine.
For the first 3 months of this year, it ran fine until it started overheating again. It wouldn’t use much coolant. I would always pull aside at the first hint of overheating and checked my levels, usually to find that the radiator was down a quart but that the auxiliary reservoir was always full never augmenting the radiator coolant level. After letting it cool off, adding small amounts of coolant and turning on the heater, I could manage to continue where I was going or drive back home without a further incident.
A few months ago I took my car to another mechanic, he ended up replacing the thermostat again, the water pump, which was making some noise but I couldn’t determine was really leaking, an o ring in the manifold, and several sensors that I knew weren’t the problem. It cost me $1100 bucks.
Still a few days later, it overheated again,. The time between overheating incidents had became less and less , to the point they were happening every 75 miles if I didn’t replenish the coolant levels. At a friends urging I had the thermostat removed. I had heard that Honda had problems with their replacement thermostats.
When I removed the thermostat, I had over 120 miles without an incident, I was feeling confident that was the problem until I took about a 100 mile trip and found it overheating again.
At one point I wondered if I had the right radiator. After coming home from a 50 mile trip I opened the hood to find it spraying through a pinhole leak for about 30 seconds. I took it to the guy who sold me the radiator, he tested it under 18 lbs. psi and it didn’t leak. He said it was the right radiator and he couldn’t replace if he couldn’t find a leak it and that he suspected that it was a head gasket problem. We bleeded it , there were a few bubbles every once in a while but not enough to assume the worst.
More recently the symptoms are becoming more the same, the hoses feel very much under pressure after driving only say 15 miles. Without the common symptoms, could this still be a head gasket problem?
Thank You for any counsel
I'm in Southern Cal and it's really HOT! Is there a cheaper solution to this situation? I did a lot of my car work in college, but modern cars are a bit out of my league.
Thanks a lot.
Don.
Are these related??? Since timing belt installed engine seems to be louder too. A symptom?
a PS: Just drove it around the block: heater is blowing cold, and it revs strongly in idle. What are these signs of?? I am not savvy to know what I am looking at under the hood and so I would appreciate so input before I call the mechanic. Could the new water pump work be bad causing this new problem? Thanks.
Cristen
Does that ONLY come in the GS?
Im not looking at a coupe im looking at the sedan
What trims does the 230 horsepower come in for the Legend sedan?
Please make a recommendation as to what I must do.
You have to remember that the car was well made and that all the components kind of depend on each other to perform their very best. Try replacing the coolant temperature sensor and temperature switch as well as the usual like gaskets, pumps and thermostat. But it would also help if u have the engine, radiator, and transmission flush and fill.
I know it sounds like that would be a hefty repair bill but just think how much longer your "LEGEND" would last! You got to remember that the previous owner of your new baby may have not taken the best care possible. That's probably why they gave it up in the first place, thinking they'll just get a newer car and be alright. TRUST ME! They still reminise about that LEGEND!
As for as the car stalling, try replacing spark plugs, air filters and fuel filter. If that don't work, you might want to take a look at the catalytic converter.
These cars are AWESOME! This car helped me to convince my wife that buying a late model used car with over 125,000 miles is a great idea (as long as it is a "LEGEND"). We are the proud owners of two Acura Legends. A 1994 Legend GS(type II engine), and a 1993 Legend LS; both 4 door sedans. How ya luv dat!
Donald
Answer a few questions first. Have you experienced any overheating, or weird idling or even smelled something burning coming through the vents or when you get out of your car after maybe a 30 min drive? Those could be symptoms of leakage or problems brewing. As for the power steering, have you noticed that you have to put a little more muscle in to a turn from a dead stand, than compared to when the car was brand new? Have you had to refill the steering fluid, and if so how often? If it is a gasket problem and you want the car for longer period of time, my advise would to get it done as well as check every thing else related to those workings. Always get a second opinion or qoute for repair.
I hope this helps.
I love all my acuara's!! I have 4, the 2 legends, the sterling and an integra. However im gonna sale 3. The integra is sold basically, I want to get the sterling right before I sale it. I'm only gonna keep the 91 Coupe. Only gone to sale the 88 coupe after getting my wife a minivan or something. All have over 200kmi except the Sterling of 116kmi and run smooth.
Thanks Jimi H
Good luck - hope we can help. Legends are great cars!
Testing 123
No doubt if the car was well maintained before (engine oil, transmission fluid and antifreeze changed), with continued TLC, from my experience with my '88 Legend, I would believe your '92 will last quite a while.
The main issue with all Acuras as far as appearance goes, is the leather, which almost uniformly gives out around 100,000. I saw an '88 the other day with what looked like perfect leather, and I wish I could quiz the guy, because neither of our two specimens has done that.
Good luck! Your car should really last, and the price was right, seems to me.
But a rear bar should cure that. Once you have it in place, you will be looking at almost any car on the road receding in your rear-view mirror. The acceleration of this car, 6.4 sec. 0-60, with good cornering that doesn't panic you out, makes it into a very satisfactory way to get there.
But if you drive like I used to, you can count on only 21 mpg. It's a tradeoff.
new '88 Legend Sedan - totaled in accident in 1993 with 78,000 miles - no problems, all passengers suffered nothing. Hit black ice, right side guardrail, back onto interstate, broadsided by a van, hit center guardrail. Not even any airbags!
Used '88 LS Sedan with 96 K for our son - drove it to 168,000 and sold it
Used '90 Sedan for other son with 122K - one owner with all records. We kept it until 180K and gave it to charity. LOVED that car - great handling and power from 80-100 was amazing for only 161 HP!
Used '94 6 Speed LS Coupe with 57,000 miles on it. What a gas - would easily do 150+ (155 governed) 0-60 in 6.5. 230HP. Honda must have had BIG horses in there! :P
I have read quite a few of the other posts and it seems to depend on how well the car has been maintained and we must say this one had for the most part only one owner, but we would still like to know what are some of the things to look for to make us aware of oncoming extreme expenses.
My daughter is a student and does not have a high budget for alot of upkeep. This would be my 20 year old's first car. I hope you can clue us in and any advice is extremely welcome.
Thank you,
Meme
I have a 94 legend with 206,000 miles on it and have for that last 8 months experienced the same slight loss of coolant. Recently, it has begun to occur more frequently. My symptoms now are 100% identical to the situation that you had described. I get fluctuation of the temp guage, coolant loss, heat comes and goes, blows white smoke only in the morning, rough idle, pulsing idle. This sounds like the seeping head gasket that someone else here had described. Any thougths? What did you end up doing to your legend? Did you have the head gaskets replaced? Thanks.
