Visitor Agreement.
If it is having this issue, roll all of the windows down and open the roof for 10-15 mins and give it a shot. If you think it's hot enough outside for it to act up and aren't leaving for a little bit, just roll 'em all down a little bit before you leave.
If the "rolling-down-of-the-windows" trick does the job, you can bet it's probably the main fuel relay.
It took me a while of searching to figure this out, so I made an account on here to pass on the info. I probably won't be back on here, so good luck if you still have this vehicle!
Is that rocker switch part available, or, (and I shudder to think this) do I have to buy the whole window switch assy? Or is this a junk yard search? My car is a 1993 L Coupe.
_____________
Edit update: Found the following thread on Acura-Legend.com. Seems to work:
http://www.acura-legend.com/vbulletin/f13/windows-not-working-diy-master-window-- switch-fix-6544/
Any help would be appreciated
