Michelins cost more, but it's worth every penny
i installed a bug screen right in front of the radiator and invisible from the outside. works great, protects your radiator and cheap! you can only see the screen if you look under the bumper or peek through the grill.
took me less than 30mins. to install it.
just buy fiberglass bug screen and cut to the correct size. it's better if you can get another set of hands to help you.
- remove 2 bolts/brackets that holds the radiator.
- lift the radiator a bit so you can slide the screen underneath it.
- lower radiator so it will sit on the screen and hold it in place. pull up the rest of the screen and use the bracket on each corner to hold screen in place.
- screw back in the bolts and you are done!
you may have a bit of pulling to do on the screen so it's tight. other than this, the install is real easy. i did this for my sienna van as well. works real great. lots of room between the grill and radiator for the 03' corolla so it's real easy to install the screen.
btw, cost of the screen was about C$5.00
good way to keep your radiator from getting damaged by rocks or bugs
but now, it's ok for me. i guess my back got used to the position. i just adjust the seat enough so i can reach the pedals and i try to lean back a bit. seems to work well for me. i also have seat covers so it sort of acts as extra cushion.
i find the front seats too narrow on the 03' corolla. my right hip is always hitting the seat belt mechanism.
These are the seat cushions that are designed to fit over the seat with both backrest and seat bottom covered with the new cushion. I fold it down and turn it around, so the LONG part, which was intended to be for the seatback, is on top of the short part and both are now deployed on the seat bottom [a folded package]. You can then secure it with a bungee or something similar threaded through the package and around the back of the seat, so it doesn't want to move around.
This does two things: it increases thigh support, and also boosts the seating position about a half inch higher, which helps for those of us long of leg.
I realize this description sounds convoluted, and a purely verbal medium doesn't easily convey what needs to be done, but essentially, you're using a conventional two-part aux cushion differently than designed, sitting on BOTH portions with the long part facing up. Hope you can visualize what I'm talking about. We have used this approach with Corollas, Accords, and Camrys to increase both height and thigh support.
i dont think u can use aluminum screen coz they break easily. fiberglass screen is flexible so it works great. mine is the black color.
The Corolla Wagon would be perfect....family sized cargo room, amazing gas mileage and all the other virtues of the Corolla sedan, including an affordable price. Make mine an LE with leather.
My ultimate Corolla wagon would have the Matrix's
V-Flex awd system and the Camry's 4 Cyl. engine, but I think I could live with FWD/Corolla 4.
To all Toyota sedan owners.....how's entry/exit with the 2003 Corolla? I like the taller styling and the hip point seems higher than a regular car (very important for me & my wife).
Ford Focus Wagon....perfect size, high hip point, sharp styling but, as FORD stands for Faults, Omissions, Recalls, Defects......well, you get my point.
VW Jetta wagon....base engine is weak, up-level engines need premium fuel, expensive and back seat is cramped.
Subaru Impreza wagon...more of a five door hatch and back seat is very cramped...not practical for families.
So come on, Toyota.....there's a whole market segment waiting for you!
They'd have to take it away from Subaru and Mazda (with the Protege 5, perhaps the finest small wagon made...)
Where they COULD clean up but are missing the boat is in the mid-size wagon segment, where only FORD has a mass production product that sells in any numbers...for now. I hear Mazda may be bringing in a Mazda6 wagon a year from now, and Ford itself is bringing the Freestyle (formerly known as the Crosstrainer).
Wagons and hatchbacks are both neglected in the US market. My guess is makers have had the luxury of pushing would be buyers into SUV's. Pity.
I have an Corolla SE 2001. Since I bought it (new) I use 91 gas. Some people tell me that using 91 doesn't do my car a favor and just waste money. Should I continue to use 91 gas or should I switch to 87 ?
I would also love a Corolla Wagon - used to have one. I had a large recycling bin that would not fit in my Taurus wagon, but would fit in the Corolla - roomy, effecient and fun to drive.
We are also looking at the Mazda Protege, Saturn Ion and possibly the Nissan Sentra (still to be tested) to replace our old Civic. We aren't all that impressed with the new Civic and we don't like our local Honda dealer much.
If you are going to get a sunroof make sure you drive a car WITH a sunroof as it lessens headroom....I didn't and wish I had. I don't regret the purchase one bit but wish I had paid closer attention to the above mentioned items.
The Protege is a BALL to drive but lacks the high MPG, quietness,fit and finish, high resale, and bulletproof reliability of the Toyota products. No, I'm not dumping on the Protege, just looking at it with the cold hard eyes of reality. I still miss my 626 V-6 5 speed but not the many repairs.
I will save the usual complaining about the POOR tires for later in this.... BUT I was REALLY looking forward to purchasing this car for a long time, but as much as I hate to admit it( a Toyota LOVER here) , this car isn't the resurrection some people claim it is.. The car does wander ALL over the road,( especially when windy)check corolland.com on (REPLACE the stock tires IMMEDIATELY)... I hope all people have not had this problem.. Also, I am 6 foot 2 with decent size legs, and the pedal to rest your foot leaves your leg cramped. To people looking to buy this car, look SERIOUSLY at Honda, Mazda, and hard to spit it out, Hyundai.... I hope my conflict with the dealer can be worked out, as I would love to have a GOOD handling car with a comfortable ride..Toyota does build quality, I just hope this car is a aberration. Insist on buying the car with a set of GOOD tires , not the stock Goodyear Integrity crap tires -- the flintstone cars had better ones, or the Firestone falling apart tires.. Good luck in your purchase!!
boilerman: Are you arbitrating your Corolla over the tires?
Gas mileage was as high as 43 (averaging 65). It was as low as 38 (averaging 80).
The car has serious shaking issues behind tractor trailers.
The seats are always very comfortable, but the driving position always takes a 5 minute plan to make driving comfortable. Its really hard to get the rest of the body correct and not have your arms fully extended to drive.
Trunk and back seat very roomy for luggage.
The second DC outlet in the armrest a little annoying. Had extention cord and Y-plug to get around it. First DC outlet was tolerable.
The dash lights were incredible.
Car has plently of power, even for the auto I drove.
I noticed that automatic downshifted on its own for braking on steep grades.
Overall, I liked the car, but I would get the manual if I ever owned a 03. My 89 and 95 are still more comfortable (driving position) though (front seat). The 03 is by far better in the back seat.
if the car is lowered, then it may help.
just my $0.02
i was all over the road a few weeks ago when i was caught in a sudden change of weather where it was real windy. with 3 people in my car, i still had a hard time keeping the car straight. it wasnt so bad when i slowed down. after i slowed down, i was able to control the car much better.
this happens everytime when your compressor kicks in to maintain the cool temp. you will notice this happen more when the weather is really hot and your a/c is on. when the compressor kicks in, your RPM rises... its like you stepped on your gas a bit so your car inches forward if its in gear. this happens only on cars with auto tranny.
you will notice this more if your car is a 4 cylinder. if you have a v6 or v8, you wont notice it very much unless you look at your RPM gauge.
now you know what is going on... all you do is when your a/c is on and each time you come to a complete stop, make sure you step on your brakes firmly. this will solve your problem of the car inching forward.
MANY are upset that the driving position is VERY different in a 2003. Magazines, posters here and dealership customers have all made this observation. And they have all tried to fit in a 2003. The problem, when it exists, is indeed legroom. It wouldn't matter if the car was a convertible with the top down, if there isn't room for your legs to stretch out comfortably it doesn't matter how much headroom there is.
There is NO substitute for trying the car itself. Figures indicate their is no problem. But actual seat time may reveal a different conclusion!
