Visitor Agreement.
Chrysler is recalling 23000, 2001 and 2002 Dodge Caravan and Chrysler Town and Country ... The rear brake lines can rub together and become corroded. ...
http://www.canada.com/calgary/globaltv/consumerbeat/vehicle_recalls.html
Chrysler should also look at the 1999 Models. I just had my 1999 Dodge Caravan up on a lift and it has the same design problem with the brake lines rubbing together. When the brake lines rub together, the zinc coating is removed and the brake lines will rust out.
I have a 95 Caravan SE with 183,000 miles on the clock. The following are the items on which I've had work done:
Fuel pump replaced under warranty.
Serpentine belt replaced by the dealer and guaranteed for the life of the vehicle.
3 brake jobs.
1 A/C compressor.
2 rebuilds of the transmission - It should have only been once, but I foolishly took it to AAMCO the first time and it lasted just past their warranty (12 months). Second time to the dealer at 112,000 miles. It's still working fine.
It's been a very reliable, comfortable vehicle and I would buy another without hesitation, but this one's just getting broken in so I expect to have it for a few more years.
Try to get a jump start from someone. If it starts, then drive immediately to a autoparts place that can check out your old battery and charging system-these places usually do it for free, in anticipation of you buying a battery from them if needed.
Please help!
I have mentioned it to Chrysler dealership mechanic before and he said, "it'd be very hard to troubleshoot", which to me means "get a second job to pay for this fix".
Any similar incidents or anyone know how to fix?
Since my ex-wifes '99 Avalon has had the transmission apart twice, the sway bar links replaced three times, the problem with engine oil sludge, a power window that refuses to go up (or down) occasionally, a "Check Engine" light that goes on and off when it wants to, the three fuel injectors that failed costing nearly a $1000, she should be transmitting the same kind of message. But she isn't.
When these same things happen to a Honda, Toyota, or a Nissan those owners don't seem to think that level of reliability is outside the normal. When it happens to an American nameplate, its a near conspiracy! Since my daily travels take me past three automatic transmission shops I've noticed that at least once a week there's a Honda mini-van sitting at one of those shops. Sometimes two a week. That's just about the same amount I see a Chrysler/Plymouth/Dodge mini-van.
I was in the fleet management business for a number of years with a large machine manufacturer in Rochester, New York. We began leasing Plymouth and Dodge minivans the first year they came out ('84) and still run them. The first years they were excellent vehicles for reliability. There was a turndown in reliability after '90 and up to the '96s they were below average. Almost all of these were component quality issues, such as power window regulators, AC compressors, evaporators, power steering pumps, idler pulleys, etc.
With transmissions we didn't start to see any problems until the 4-speed electronic versions. The 3-speed automatics were bulletproof. The Ultradrive A604 transmission, which later was revised and renamed the 41TE had a couple of seal problems early on and somewhat later they went through some bad shift solenoids (shift packs) in the valve body. They also had a problem with the the shift schedules and Chrysler issued some TCM reflashes; anti-drain back valves getting clogged and bad electrical terminals. These problems have been long resolved and there are far more people that have gone 150,000-200,000 miles without a transmission problem than there are those that do.
In my company's experience we found that even when the A604s had a higher than normal problem rate our Ford Windstars were worse and for a couple of years the failure rate of the Chevy AstroVan was even higher than the AeroStar/Windstar. Since then our Chrysler versions continue to have less transmission troubles than either the Windstar or the Venture.
There are a few of things that must be realized. One, according to the Automatic Transmission Rebuilders Association (ATRA), minivans from all manufacturers in general have a higher transmission problem index and failure rate than cars. Minivans were designed like cars with car-like attributes, but are often used and driven like trucks or taxis. On average they accumulate more miles in a three year period than passenger cars, are more often driven over the rated load, more often use to tow trailers than passenger cars. According to one study they see more stop-and-go driving than any other non-commercial vehicle. All this leads to stressing various mechanical aspect of a motor vehicle.
Chrysler was the first with a fully electronic and a fully adaptive automatic transmission. These transmissions require complete understanding of how they operate and special tools for diagnosing problems. Both of these requirements were not well met by the transmission rebuilding industry and many, MANY Chrysler automatics received expensive rebuilds when in fact the solution was something much simpler, like a TCM reflash or changing the fluid out. And the same thing is still happening.
In the case of Chrysler automatics, they received a very significant upgrade in '98 that provided increased fluid flow to the overdrive units, as well as a host of other redesigned components or components from different manufacturers to increase reliability and durability. The 41TE that's being used now is a much more refined transmission than just a few years ago.
Unfortunately a very larger percentage of past Chrysler automatic transmission problems had another negative influence, that being the wide spread use of Dexron-Mercon ATF in a Chrysler transmission. General auto repair and transmission shops used Dexron-Mercon in Chrysler mini-vans when the filter or fluid was changed. Dexron-Mercon will initiate a death spiral in these transmissions and many quick oil change places in this area were successfully sued because of it. Still today I see or hear of Dexron-Mercon being used in a Chrysler product. It is shortly after that shift problems begin and eventually so much friction material will be lost off of the clutches that the fluid gets contaminated and then a shift solenoid or valve body gets clogged, or a governor valve starts to stick, or the seals start to erode.
If a Chrysler FWD transmission is maintained accordingly, they will outlast most other competitive versions. Don't change the fluid (always use ATF+4 in a Chrysler...), or the filter and I can guarantee you'll have a transmission problem.
Dusty
Dusty
some questions if you don't mind: are we asking a lot (maybe too much) of a transmission in a FWD mini-van? someone once suggested to me that because these vehicles are heavy (like trucks), and because of the tight packaging and placement w.r.t. the engine and the drive to the front wheels, many mini-van manufacturers have a problem with transmission longevity.
would you suggest servicing by the dealership, or would servicing at a chain be acceptable?
what do you think is an appropriate / reasonable expectation for the lifespan of a transmission in a chevy, honda, toyota, mazda, ford etc. mini-van with appropriate scheduled maintenance performed? 100K, 125K, 150K, 200K?
why are transmission rebuilds so expensive, and what sort of lifespan should we expect out of a rebuild?
last - when a transmission is replaced, does one need to worry about other parts being replaced as well (say a torque convertor)?
i wish someone made a manual transmission mini-van!
thanks for any followup to any of my questions. regards.
Good Luck, Gene
Americans are an impatient lot. As the mini-van platform became more popular, larger and heavier (Grand Caravan), there was a demand for increased performance. The introduction of more powerful engines actually exacerbated the problem of a vehicle that was designed to be a car but ended up being used like trucks and taxis, a use scenario that manufacturers never anticipated to the full degree. This put actual use into and beyond the margin area of reliable design.
Design engineers are faced with criteria that are in direct conflict with each other, such as comfort, performance, fuel efficiency, emission standards, safety, cost, and usability. Change to the limits on one type of design consideration sometimes translate to a change in the limits of another. Compromises are not the exception, but the rule. The inherent compactness of the mini-van concept translates to a very close balance of subsystems and various design considerations. In order to improve the long term reliability of the transmission, for example, would probably require the addition of weight or a change to the packaging parameters in such a way that would impact cost, or some other subsystem design or desirable feature and would change the vehicles competitiveness in one or more areas.
I think there are competent transmission servicers or rebuilders among dealers, chains, and independents. Dealers have one advantage that independents and chains do not: they have the correct diagnostic tools, hopefully properly trained technicians, and factory parts. Independents and more so chains, may sometimes be more motivated to use an off-the-shelf, "factory rebuilt" by a third party supplier in order to expedite a repair. This usually translates to a higher cost for the owner. The big problem in my opinion nowadays is the proliferation of off shore transmission replacement parts.
What is a reasonable expectation for transmission life? I've seen them go out at 4 or 5K, others of the same design and manufacture go 250,000 miles. I don't know, but in the auto industry the accepted design target is (or was) 100,000 miles. Most go that and more without trouble as long as they are well maintained and not stressed too often.
Mini-van rebuilds, like any other FWD car, are more expensive because they are not just a transmission but also the drive axle. They are not as nice to work on, either, because of FWD. A quality rebuild should provide at least the same amount of trouble free miles as the factory original. In a rebuild a lot depends on the quality of the diagnosis, the selection of replacement parts, a super clean rebuilding process, and a technician that's not in a hurry. Usually a torque converter is considered part of the transmission, but like any other component would not be considered a candidate for replacement unless it showed signs of a defect.
And believe it or not, manual transmission was available in the early Dodge and Plymouth mini-vans.
Best regards,
Dusty
I've also had intermittent problems with my Chrsyler minivan not starting and last August it finally failed so the mechanic could trace it to a intermittent short in the $365 starter.
Lman
Topic of noise experience by at least one other owner besides myself of exhaust and other noises in 2005 S&G minivans came up in the #240 range of posts in another forum dealing with 2005+ T&C minivans.
I bought my T&C Touring with leather, luxury and trailer tow groups in mid July. From day one, it exhibited the following faults:
1. A noisy exhaust system. At any rpm over about 1300, a motor boating or glasspack muffler sound is very evident coming from the engine compartment through to the front driver/passenger area. By 2000 rpm, the noise is intolerable! I know it's coming from the front because it doesn't get any louder with the windows open.
2. A loud, irritating whine/moan from the a/c compressor at all speeds. It is especially noticeable at engine speeds below 1300 rpm when the exhaust noise isn't helping to mask it. Easy to diagnose because it vanishes the minute I switch the a/c compressor off.
3. Noise coming into the front compartment from the front wheel wells. Even at very slow speeds and over very small pavement imperfections, I not only feel the slight bump, I also hear it. The tires themselves are as good as I can expect from OE tires and really make little noise over a wide variety of pavement surfaces.
None of these noises were evident on any of the vehicles I test drove or on a couple of similar vehicles belong to neighbors. Even the beater 2005 entry-level lwb minivan my nearest Chrysler dealer uses to drive service customers home has none of them.
I went all the way up to the service manager at the dealership from which I bought the car, only to be told that all the sounds were normal - even when he and I took a vehicle off the lot and I could hear none of the noises in it, he swore that my car was the quieter of the two!
Yesterday the district service manager came to the dealer nearest me (the selling dealer is about a 70 mile round trip away and I can't afford to waste gas on unfruitful trips). I quote verbatim from the service report given me afterward in part 2 of this tale.:
1. "Customer states there is a groaning/drone sound in exhaust system from engine area at 1300 RPMS and above.
Being determined by Chrysler Product Engineering
Test driven by district rep . . Confirmed noise present.
District rep notified customer that engineering is working on resolve.
Customer will be notified at that time."
2. "Customer states that there is a whine sound from engine area when a/c is running.
Normal operating condition per Chrysler district rep.
Test driven by district rep . . all sounds are normal and can be heard in like vehicles."
3. Customer states tire/suspension road noise from front end over any imperfection in roadway at any speed.
Test driven by district rep . . tire noises on test drive are normal and can be duplicated in like vehicles."
I really like that "... can be duplicated in like vehicles." Sheeesh - even the droning exhaust sound can be "duplicated in like vehicles," it seems - DC engineers wouldn't be working on a fix if it couldn't!
So . . . I'm batting .333 at the moment. At least I got someone to admit that DC knows it has a problem with NVH in one area. I might have gotten a higher average if I had had the time to hang around waiting for the rep to show up, but I had other things that had to be done that day. He only shows in my area once a month, anyway. Now I just have to keep badgering DC about my other two beefs because I KNOW that other DC minivans don't sound like that!
If the noises were coming from the redesigned floor pan area that was changed for stow and go, I might be more tolerant, But I really can't see that DC has made any major changes in the driver's area forward.
Watch this space for further developments.
if you place some sound deadening material in the Stow-N-Go area, does it mitigate the noise at all?
does your vehicle use the exact same tires (manufacturer and model) as the other vehicles you test drove that were quieter? the tires (composition and tread design) can have quite a dramatic impact on road noise. plus - check tire inflation pressure. are you at the extreme of the tire manufacturer rating? you might want to consider adjusting inflation and see if that mitigates at all.
did you have someone look underneath the vehicle? i'm thinking one mis-aligned or missing exhaust system hanger, or some heat shield, and it's possible a resonance in one are of the piping could induce a resonance in another area. think of a string plucked under different tensions. depending upon tension, you get a different number of standing waves (thus different frequencies - more tension, higher frequency, and potentially different amplitude (wave height)). maybe your vehicle has a hanger or shield that is not connected properly, or making contact with the underbody of the vehicle.
good luck.
I'm almost certain the dealer will claim no knowledge of this kind of problem, as he did for a head gasket problem a few years ago. (I paid for that replacement - 78,000 miles).
How do we get their attention to the problems/dangers?
Ive done this on other cars before but every new car is a challenge.
The only problem Im having is getting the power steering pump to budge after loosening the 2 bolts that APPARENTLY are suppose to be for slacking it up for removal...... NO dice! & I cant see the entire pump since it sits low behind the head.
Ive cut the belt off so it doesnt slow my progress down but eventually Ill have to get a new belt on it....
Any ideas, tips, etc on how the pump swings free?...is it frozen?....and there really isnt any place to get a pry bar behind it to try & worry it lose.
Thanx in advance!..
Dave.
As far as your problem..... it sounds like a grounding problem from the socket.... just for kicks run a ground wire to the bulb .......
Bill
Bill
These can be found thru www.rockauto.com.
They arent really easy to replace because they are down low on the front of the trans but its do-able with patience.
It may or may not fix the problem but, its a low cost approach to eliminate one item that can be the cause. It worked for me & I had the same problem you have.
Dave.
There is a Recall on the Chrysler Minivans in Canada for rusted brake lines which should start in September.
You should also check your brake lines all the way back to the rear wheels. The design of the holding clamps allow the brake lines to rub together and the protective zinc coating will be removed. When the coating is removed corrosion will occur very quickly.
The only way that you can get their attention is to notify Chrysler and NHTSA about your problem.
We had a brake line burst on our 1999 Dodge Caravan. The brake lines were original equipment on the vehicle. We had a brake job done with 31K miles and we now have 47K miles on the car.
If you check your brake lines you will see that the solid line is made of steel and it is welded to a stainless steel flex segment. The welding of dissimilar metals can cause crevice corrosion which can cause a brake line burst without warning.
I just sent the following letter to NHTSA in August.
Dr. Jeffrey W. Runge
National Highway Traffic Safety Administration Administrator
400 7th Street, SW
Washington, DC 20590
August 22, 2005
Dr. Runge,
A review of the NHTSA complaint site indicates that Daimler Chrysler Corporation has a very serious safety defect or nonconformance that could result in a serious injury and or death. Daimler Chrysler has been notified of this defect/nonconformance on several occasions and continues to deny the problem.
The metal brake lines on the 1999 Dodge Caravan, Plymouth Voyager, and Chrysler Mini-Vans are welded with dissimilar metals. They have braided stainless steel flex segments that are welded to steel brake lines. This welding of dissimilar metals could cause corrosion of the steel brake lines and results in a brake line burst which occurs without any warnings.
We found five (5) complaints to NHTSA, on the Office of Defects Investigation (ODI) Complaint Site pertaining to the corrosion of Chrysler supplied brake lines which resulted in brake line bursts. There may be more that we didn't locate.
Ref: ODI Complaint Numbers - 10112174, 10121461, 10023409, 10087291, and 10125674.
Complaint Numbers 10103217, 10044433, and 10017536 may also be related to this same problem.
This complaint is very personal to us because my wife experienced a brake line burst in our 1999 Dodge Caravan. If the brake line burst occurred in heavy traffic and/or at highway speed, it could have resulted in her death or serious injury. Ref: ODI Complaint # 10121461.
We notified Daimler Chrysler Corporation on several occasions by telephone and emails concerning this serious safety defect/nonconformance. They were apologetic about the mishap, however, they stated (1) that they had never had a complaint concerning brake line burst on any of their vehicles, (2) they had never issued a Service Bulletin or Recall, and (3) they could do nothing for me because the vehicle was out of warranty.
We are appalled by Daimler Chrysler's lack of concern on this serious safety issue and we believe that their lack of corrective action is criminal.
We are also upset because NHTSA, has had several complaints on this safety related defect/nonconformance and no action has been taken.
Do we have to have a DEATH before Daimler Chrysler Corporation or NHTSA investigates this serious safety defect or nonconformance?
What is the LIFE EXPECTANCY of these brake lines?
How do you stop a vehicle in heavy traffic or at highway speeds?
Is the consumer or manufacturer, responsible to prove that these brake lines are defective or nonconforming?
The Safety Recall Compendium issued by NHTSA (3rd Release, June 2001) clearly requires that,
When to Report (49 U.S.C. & 30118 and 49 CFR Part 573.5 b)
A manufacturer who has determined that a safety defect or noncompliance exists, must report such a determination to NHTSA within 5 working days. A manufacturer need not have identified the cause, scope, or remedy in order to make a determination that a safety defect or noncompliance exists, at least in some vehicles or items of motor vehicle equipment. If part of the information which is required to fully describe the recall is unknown, notification to the agency must still be made with the existing information within 5 working days. The remaining information is to be provided as it becomes available.
Who Should Report (49 U.S.C. & 30102 AND 30118: 49 CFR Parts 573.3 and 579)
Each manufacturer of a motor vehicle has recall responsibility for any safety-related defect or any noncompliance determined to exist in a vehicle or in any item of original equipment. The manufacturer of an item of motor vehicle equipment in which a safety defect or noncompliance is determined to exist (1) is responsible for notifying the vehicle manufacturer and (2) with respect to an item of replacement equipment (including tires), has recall responsibility for the equipment containing the safety defect or noncompliance. (49 CFR Part 579 "Defect and Noncompliance Responsibility".)
We understand that Daimler Chrysler Corporation has the same type brake line configuration in the 1997, 1998, 1999, and 2000 models of their Dodge Caravan, Plymouth Voyager, and Chrysler Town & Country, Mini-Vans.
We also understand that a change was made on the 2001 models that removed the welded Stainless Steel Flex segment from the brake lines.
We have copies of emails sent to Daimler Chrysler Corporation concerning this complaint and also emails with their replies to us.
We also have a section of the original brake line that was removed from my 1999 Dodge Caravan. It can be made available to your testing facilities to analyze the cause of the defect/nonconformance. Ref: attached picture.
Please keep us informed as to your progress on this serious safety defect/nonconformance.
This is my third DC minivan ('92 owned for 9 years and '99 owned for 3 years), so I have some realistic expectations as to what a DC minivan sounds like.
My Bridgestone Turanza tires have been standard equipment on DC minivans for some time now and the Tire Rack site shows that DC Minivans owners mostly say they are OK, unlike owners of Toyota Sienas and other Japanese cars that use this tire as OE. I can separate out the noise component created by them by noting the changes in sound when I go from new coarse asphalt to new smooth asphalt to old coarse and smooth asphalt to concrete, both smooth (relatively) and grooved. I find their noise to be as good as any others I had on previous cars (Goodyear and Michelin). My '92 van got almost as noisy as my new one when the OE tires wore out at close to 50K miles.
I have test driven three other new T&C minivans and found two neighbors who own stow and go versions of DC products. None of the others exhibit the levels of noise that mine does - I can hear a faint a/c compressor whine, but it is very low level and quickly subsumed in other noises. My noise is very loud at slow speeds (quite a bit of my local driving is at 30 mph or less - 15 in the manufactured home community in which I live) before the exhaust noise builds at around 1300-1400 rpm, then adds to the growling roar at speeds of 40-45 and above.
Two different dealers have looked it over and say they can't find anything.
One other thing I notice, this car, like the other two DC minivans I owned, exhibits a bit of vague steering and wandering over road dips when the tires are inflated to normal pressures. On the other two, I merely bumped up the tire pressure about 4 lbs over standard and that sharpened up the steering considerably with only a minor increase in ride harshness. This car is so harsh at normal pressures that I haven't tried upping the tire pressure yet.
This is the most unsatisfactory new car I have bought since the 1977 Dodge Aspen sedan that put me off Chrysler products for 15 years. I don't count the 1988 Dodge Colt Vista wagon because that was made by Mitsubishi and was a good car indeed - it might even still be soldiering on as a taxi in Morocco to this day.
FWIW, my van's original OE tires were Bridgestone Potenzas (ODY LX) and they were noisy at recommended pressure and moreso with more pressure. They showed a great deal of sensitivity to surface, being louder on concrete and cut surfaces used to channel water. They wore out at about 25K. I replaced them with the ODY EX OE tire Michelin Symmetry, and I'm quite certain, on my van, they are much quieter w.r.t. noise levels...
I understand your frustration, and the fact that a few dealerships supposidly looked at the vehicle. Unfortunately, it looks like you need to do more sleuthing on your own.
I was supplying a number of questions to help you think outside the box about potential root causes. I like the suggestion that perhaps they didn't install firewall insulation...Did you check that? I think that more unlikely than other possibilities, but I think you need to start by casting a wide net, and starting as if noone has looked at your car.
Have you had someone else drive while you ride in the passenger seat? It may help with sound localization.
Do you have OE or Aftermarket Floor Mats? This is an example of something which might seem like a dumb question, but shouldn't be ruled out.
Maybe someone in the plant installed the carpeting without insulation also???
