THAT could be the problem OR the electrical harness connection to the computer which is supposed to be my problem
The National Highway Traffic Safety Administration (NHTSA) is studying reports of airbag problems in the Chrysler Group minivans. The 2005 model-year vans, the NHTSA reports, could have front airbag sensors that fail, possibly due to corrosion. The agency has logged five complaints from owners who say their airbag sensors failed. The sensors for the front airbags are located behind the front bumper, and owners have reported the warning light for the front airbags had illuminated in their vehicles. More than 400,000 minivans are being studied; if enough evidence is presented, the safety agency could order a full recall of the vehicles in question.
T&C will not open in cold temperatures. When activated by console switch it will unlatch but not open. Works fine in warm weather. Any experiences like this?
We have a 01 DGC EX and have the same problem. The gas lifters on the lift gate are weak from age and use. (Ours started doing this in fall 2004). I don't think this is a quality issue since it opens manually and stays up with out sagging. I've priced the gas lifters each for around $30-40 at Murray's. I will be replacing them my self soon. :shades:
Thanks in advance.
At 1st the blower would not work on the forth setting now it only works on High. Any suggestions, I checked the relay under the hood at its OK
chinadoll.
she is going through a costly divorce and if possible wants to avoid repairing the door. she definitely is not in a position to junk the vehicle either.
she is willing to have her children climb through the passenger door, and climb back into the seats, and exit by doing the reverse. Note: she has 5 children, aging from 2 to 13.
question: from a safety perspective, is this a concern? Is the sliding door considered a safety exit? or can she have it bolted or welded shut (to avoid someone accidentally pulling it off, causing injury.
concerned big brother asks for your input.
Now, it's a little worse on start-up and while still cold, but it goes away when the engine is good and warm. We're taking it in to the dealer soon, just wondering if ya'll had experienced anything similar so we'll know what to expect. Thanks!
We just had a cold snap go through my area and was warming the van up with the garage door open. After 10 minutes, I went out, opened the rear hatch, then shut it. Ever since then, it will not open at all (seems like the mechanism stopped working whether locked/unlocked).
Any time I pull on the handle to lift it, I hear a "click" like it's trying to release the latch and nothing else. Seems like something broke with the latch mechanism (and I don't dare try using the power liftgate). Wondering if anyone has any ideas?
Stinks having kids and the liftgate not able to open. It has warmed up since then so if it froze up things should have thawed out by now. My next step is to try and pull the inside trim from the door and see if I can get to the mechanism. Thanks
The key works to manually unlatch the door to open it. It is the electronic part which doesn't work. From what I've found out, it's either the lock actuator or the lock control (which the actuator connects to) module causing the problem. Dealers are quoting $300 just to replace the actuator and control module.
Since it's easy to remove/replace, I'm going to pull the rear panel, test for voltage on the components (making sure some wiring didn't go bad) then replace the actuator/control module for $120 ordered off the net.
Unless someone has other ideas on this one.
It's a '00 Caravan (Sport model) with 53,000 miles. My wife absolutely loves the car, and I don't feel like going through the process of getting another car. It would really be a shame if something was seriously wrong.
Alternately you might have water sitting in the cowling below you windshield wiper arms due to leaves etc blocking the drainage holes.
Try the cold start first.
These vehicles are prone to smelly air exchange. I never turn off the blower fully. If you let it stagnate it will get musty and smell. Worse in the summer.
For the gas smell. Either get under the vehicle and sniff around the gas tank or take it in to your favourite shop and have them look for a leak. fuel smells are pretty distinct and can only come from a leak. they need to be fixed asap.
